Lotan ohjauspaneeli
From Helsinki Hacklabin wiki
Jump to: navigation, search
Näyttö ja ohjelmointi / Display and programming
Vasen:
Keski:
Oikea:
[RESET] Hälytysten kuittaus
CURSOR [↑], [↓] riviselailu
PAGE [↑], [↓] sivuselailu
Left:
(Gauge :) Spindle speed (RPM)
(Gauge :) Spindle load (LOAD)
(Lights :) Magazine ready (ATC READY); axes in home position (X) (Y) (Z) (B)
(Lights :) Alarms (ALARM): Cutting fluid (COOLANT), Spindle (SPINDLE TROUBLE), Guide oil (LUBE FAULT), Emergency stop (EMG), Compressed air (AIR PRESSURE)
(Buttons :) Manual operation of the magazine (MAGAZINE): [CW] = clockwise. [CCW] = counter.
'Central:'
Display and soft keys below it
Right:
[RESET] Acknowledge alarms
CURSOR [↑], [↓] line break
PAGE [↑], [↓] page navigation
(Buttons, white :) Enter and edit G codes
(Buttons, blue. Right) Edit G code; [ALTER] change word, [INSRT] insert word, [DELET] delete word, [CAN] cancel keying
(Button, white right) Edit G code; [/.# EOB] End a sentence in edit mode
(Buttons, blue :) Screen content selection; [POS] station, [PRGRM] program, [MENU OFSET] Job coordinates and tool offsets, [DGNOS PARAM] diagnostics and machine parameters, [OPR ALARM] operator messages and alarms, [AUX GRAPH] toolpaths and cycles graphically
Käyttöpainikkeet / Operation buttons
Vasemmalta:
From left:
(Button, yellow :) SPINDLE RESET; Spindle reset in case of error (rare)
(Button, green :) T.UNC; tool removal. BEFORE USE, READ THE INSTRUCTIONS IN “Operating with Tools”!
(Switch) PROGRAM RESTART ON. Mainly used in production when duplicating songs. Don’t touch - ask if you feel the need. Must be in the “OFF” position.
(Key switch) PROGRAM PROTECT. Prevents editing of the G code program when it is upright.
(PROGRAM SOURCE buttons): automatic mode selection; g-code editing; manual data input1
(OPERATION SELECT buttons): Fine-tunes the auto driving mode
(Buttons EXECUTION): Auto run control (also start MDI functions)
(OPERATION buttons): Selects the manual mode
(SPEED / MULTIPLY buttons): Manual speed selection / coefficient selection
(AXIS / DIRECTION buttons): Select the axis and direction of manual travel
(SPINDLE buttons): Start and stop the spindle manually
(COOLANT buttons): Cutting fluid control on / off / auto
(Rotary selector OVERRIDE): Speed ​​control in automatic driving and some manual driving modes
Lotta Ohjeet:
Edellinen
Ylös
Seuraava
