G-koodi
G-Code
A CNC program that follows G-code syntax consists of low-level functions called blocks. Sentences, in turn, are built from words (code). The words are either "preparatory" G-codes or "Miscellaneous" M-codes.
The G-code syntax is almost unstructured because no program control controls are included in the language. A subroutine call using M codewords exists but little else.
G-code is interpreted code in the sense that the code interpreter always parses one whole sentence at a time and optimizes the execution of the content before it is launched. Lotta's Fanuc controller works in such a way that the last of the conflicting command words in a sentence remains valid and executed.
In particular, it should be noted that almost all G codewords are "modal", meaning that they remain in effect until another code belonging to the same modal group replaces them. Similarly, an argument that is missing from a sentence gets the value it last had in an earlier sentence. Therefore, the unchanged argument does not need to be repeated sentence by sentence.
Esimerkki yksinkertaisesta NC-lauseesta:
N001 G01 X500.000 Y60.000 Z0.000 M03
G01 X500. Y60. Z0. M03
X510.
X520.
Example of a simple NC block:
Line number 001; coordinated movement at machining speed to XYZ coordinates while starting the spindle to rotate clockwise
Example of a modal NC block:
X510.
X520.
Coordinated movement at machining speed to coordinates 500/60/0, then 510/60/0 and 520/60/0 because G01 is modal.
G-koodisanojen argumentit
T --- Työkalun valinta
R modaali 09 koodit
G02, G03
P G04 Taukoaika ms
G-code words recognized by Lotta
Most G-code statements consist of a preparatory G-code, and one or more arguments associated with it. The sentences also use "Miscellaneous" M-code words to control the machine functions on and off.
G codeword arguments
T --- Tool selection
R modal 09 codes
G02, G03
The return level of the movement in break drilling and the like
P G04 Pause time ms
Varsinaiset G-koodisanat
G-koodi Modaaliryhmä Toiminto
G04 00 Tauko
G09 00 Täsmällinen paikoitus
G20 06 Mittayksiköt tuumina
G21 06 Mittayksiköt milleinä
G22 00 Esimerkki
G23 00 Esimerkki
G28 00 Ajo kotiasemaan
G29 00 Paluu kotiasemasta
G30 00 Paluu 2. kotiasemaan
G31 00 Toiminnon ohitus
G33 01 Kierteitys
G50 11 Skaalauksen peruutus
G51 11 Skaalauksen asetus
G61 15 Tarkka pysäytystila
G63 15 Kierteitystila
G64 15 Leikkuutyöstötila
G65 12 Makrokäsky, makrokutsu
G68 16 Koordinaatiston kierto
G76 09 Tarkkuusavarrus
G80 09 Työkierron peruutus
G81 09 Pisteporaus-työkierto
G82 09 Vastaporaus-työkierto
G84 09 Kierteitys-työkierto
G85 09 Avarrustyökierto
G86 09 Avarrustyökierto
G87 09 Vasta-avarrustyökierto
G88 09 Avarrustyökierto
G89 09 Avarrustyökierto
G94 05 Syöttö yks/minuutti
Actual G codewords
G code Modal group Function
G04 00 Break
G09 00 Accurate positioning
G22 00 Example
G23 00 Example
G27 00 Home drive check
G31 00 Bypass function
G33 01 Threading
G45 00 Tool offset breeding
G46 00 Tool offset reduction
G50 11 Cancel scaling
G51 11 Scaling setting
G60 00 One-way parking
G61 15 Exact stop mode
G63 15 Threading mode
G64 15 Cutting machine mode
G76 09 Precision armature
G80 09 Cycle cancellation
G81 09 Spot drilling cycle
G82 09 Counter-drilling cycle
G84 09 Threading cycle
G85 09 Boring cycle
G86 09 Boring cycle
G87 09 Counter-reaming cycle
G88 09 Boring cycle
G89 09 Boring cycle
G94 05 Input one / minute
M-koodi Toiminto
M05 Kara seis.
M09 Leikkuuneste pois
M40 4. akselin lukitus
M41 4. akselin vapautus
M95 X-akselin peilaus
M96 Y-akselin peilaus
M98 Aliohjelman kutsu
M99 Aliohjelmasta paluu
M-code words recognized by Lotta
M code Function
M05 Kara stand.
M09 Cutting fluid off
M29 Rigid threading mode on
M40 4th axle lock
M41 4th shaft release
M95 X-axis mirroring
M96 Y-axis mirroring
M98 Subroutine call
Ylös
