G01 Engl
G01: The function performs a coordinated movement at the machining speed to the given coordinates.
Syntax:
G01 {X | Y | Z} {F}
The movement takes place from the current starting point to the coordinates given in the block. If an axis is not mentioned, its previous value remains valid (no movement takes place with respect to the axis in question. At least one axis must be specified. otherwise be valid, otherwise no movement will take place.
