Työkalun asetus (Lotta)
From Helsinki Hacklabin wiki
Jump to: navigation, search
Tool setting (Lotta)
Työkalujen kanssa operointi
Operation with tools
Tool change from magazine to spindle
The tool is changed from the magazine by issuing the necessary change commands in MDI mode when the spindle is first driven to the home position. To switch, follow these steps:
a) Check that the spindle is not already on the home boundary (the limit switch is displayed on the right side of the spindle). If the counterpart of the limit switch is close to the switch box, then manually move the spindle lower away from the limit by hand.
b) Select [HOME], [+ Z] or [-Z] in the axis selection mode and press [HOME START]. The spindle is now driven to the home position and when the corresponding light comes on you can continue.
3. Use the programming keys to enter the following switching sequence:
a) [T] [x] [x] [INPUT], where xx is the number of the desired tool in the magazine (01… 16)
b) [M] [0] [6] [INPUT], (actual exchange execution command)
c) [OUTPT START], (start function)
Työkalun vaihto käsin karalle
Manual tool change for spindle
A tool that is not in the magazine but is otherwise ready for use can be changed directly on the spindle without first loading it into the magazine.
1. Manually drive the Z axis to a suitable height so that you can reach the tool properly by hand. The shaft does not have to be in the home position.
2. Select a manual mode, eg [JOG]
3. See how large the gap is between the tool holder and the face of the spindle (approx. 2 mm) so that you can visually assess whether the new tool is properly seated when you have replaced it. Take a firm grip on the tool arm and then press the [T UNC] button on the left side of the panel. The tool now disengages into your hands (may sometimes require a detach) and you can release the button. When the spindle is empty, you can look for a spindle cavity cleaning tool (red plastic handle with a conical head) on the shelf and screw it through the hole in the spindle so that extra grooves are cleaned from the mating surface
4. Pick up a new tool, wipe the surface of the cone clean of any excess, and take a proper grip on its shaft. Please note two things:
b) The slots on the sides of the tool holder must hit the drawbar shoulder blades, otherwise the holder will not reach the destination. So make sure the holder is in the correct position in your hand.
5. Place the new tool in the center of the spindle cavity, straight and as deep as it will go,
6. Press and hold the [T UNC] button to unlock,
7. Press the tool all the way in firmly and hold it down with force,
8. While pressing the tool, release the [T UNC] button.
If all went well, the tool now sits on the spindle with a gap of a couple of millimeters between the end face of the spindle and the top surface of the slot groove. If the gap is clearly larger, you did not press hard enough and the tool is not at the bottom. In that case, grab the grip of the tool and the other point 6 forward again, but press harder. Also, make sure that the tool was in the correct position so that the shoulders hit the correct position.
If you use a tool that has been changed in this program, its length must be calibrated as stated at the beginning.
Työkalun pituuden mittaus
Measuring tool length
Lota uses the so-called “reference tool” method, in which the Z-offset of the table of the reference tool is stored as the Z-offset of the work coordinate system 0 (always valid so-called EXT coordinate system). The length offset of all tools used is reported as the difference to this reference offset. The length offset is measured for the tool as follows:
Mikäli laitoit työkalun karalle tilapäisesti ja aiot ottaa sen pois työn lopuksi, käytä offset-taulun paikkoja 18 tai 19. Muista käyttää G-koodissa vastaavaa taulupaikan numeroa xx pituuskompensoinnissa G43 Hxx. HUOM! offset 17 on 3D Tasterin pituuskompensaatio.
If you temporarily placed the tool on the spindle and plan to remove it at the end of the job, use positions 18 or 19 on the offset table. Be sure to use the corresponding table location number xx in the G code for length compensation G43 Hxx. NOTE! position 17 is reserved for 3D Taster.
Figure 8
Measuring tool length with piper
  1. Aseta työkalu karalle
Ylös
