Lotan käytön perusohjeet
(Ohjattu sivulta Käytön perusohjeet)
Left column Finnish!
Right column English
Boot from "cold & dark mode"
REMEMBER! Whenever it happens that has never been possible, or the machine does anything other than what you wanted it to do, DO NOT HESITATE for a moment but warm the EMERGENCY STAND NOW! This machine eats iron, but also meat. Yours?
Shutting down and shutting down the machine
After finishing the day's catch, clean the machine and turn it off:
  • Done, you can leave.
Peruskäytön ohjeet
MDI-moodi Esimerkki Esimerkki
Basic operating instructions
MDI mode Example Example
Edellinen
Takaisin Lotta
Seuraava
