Lokerikot-lista
Diodit
TVS/MOV/Varistors
05D431K @05.1.1 10 diodi TVS 430V 10% Datasheet
05D471K @05.1.1 10 diodi TVS 470V 10% Datasheet
07D180K @05.1.1 10 diodi TVS 18V 10% Datasheet
07D270K @05.1.1 10 diodi TVS 27V 10% Datasheet
07D181K @05.1.1 10 diodi TVS 180V 10% Datasheet
07D241K @05.1.1 10 diodi TVS 240V 10% Datasheet
07D271K @05.1.1 10 diodi TVS 270V 10% Datasheet
07D361K @05.1.1 10 diodi TVS 360V 10% Datasheet
07D391K @05.1.1 10 diodi TVS 390V 10% Datasheet
07D431K @05.1.1 10 diodi TVS 430V 10% Datasheet
07D471K @05.1.1 10 diodi TVS 470V 10% Datasheet
07D561K @05.1.1 10 diodi TVS 560V 10% Datasheet
10D330K @05.1.1 10 diodi TVS 33V 10% Datasheet
10D241K @05.1.1 10 diodi TVS 240V 10% Datasheet
1V5KE8VA @05.1.2 10 diodi TVS 6.8V 5% Datasheet
1.5KE12A @05.1.2 40 diodi TVS 12V 5% Datasheet
1.5KE24A @05.1.2 40 diodi TVS 24V 5% Datasheet
1.5KE27CA @05.1.2 60 diodi TVS 27V 5% Bi-directional Datasheet
1.5KE27CA @05.1.3 300 diodi TVS 27V 5% Bi-directional Datasheet
1.5KE100A @05.1.4 5 diodi TVS 100V 5% Datasheet
1.5KE400A @05.1.4 5 diodi TVS 400V 5% Datasheet
1N5908 @05.1.4 3 diodi DO-13 TVS 6.0V 1500W Low Voltage Transient Suppressor Datasheet
1N6267A @05.1.4 22 diodi DO-201 TVS 5.5V Datasheet
08Z1 @05.2.1 13 diodi GER2 08Z1 7mm 5.5V TVS/Varistor LittelFuse Data Table
12Z1 @05.2.1 20 diodi GE MOV GES9 12Z1 7mm 8V TVS/Varistor LittelFuse Data Table
22Z1 @05.2.1 3 diodi GER0 22Z1 7mm 18V TVS/Varistor LittelFuse Data Table
250L40 @05.2.1 2 diodi 250V 20mm TVS/Varistor LittelFuse Data table
P25S250 @05.2.1 10 diodi Littelfuse TVS/Varistor 250VRMS 22KA Radial Datasheet
P6KE 6.8A @05.2.2 9 diodi DO-15 6.8V Transient voltage suppressor TVS Datasheet
P6KE 12A @05.2.2 80 diodi DO-15 12V Transient voltage suppressor TVS Datasheet
P6KE 18A @05.2.2 5 diodi DO-15 18V Transient Voltage Suppressor TVS Datasheet
P6KE 20A @05.2.2 10 diodi DO-15 20V Transient Voltage Suppressor TVS Datasheet
P6KE 39CA @05.2.2 1 diodi DO-15 39V Transient Voltage Suppressor TVS Datasheet
MDC Z151 @05.2.2 2 diodi TVS 150V Datasheet
S07 K20 @05.2.3 9 diodi Siemens 07 K20 TVS Data table
S10 K550 @05.2.3 1 diodi Custom 550V TVS/MOV Data table
S10 K625 @05.2.3 1 diodi Custom 625V TVS/MOV Data table
S14 K460 @05.2.3 4 diodi Custom 460V TVS/MOV Data table
S14 K550 @05.2.3 1 diodi Custom 625V TVS/MOV Data table
S14 K625 @05.2.3 2 diodi Custom 625V TVS/MOV Data table
SA12A @05.2.3 5 diodi 12V SA12A SA.pdf
SA5*0A @05.2.4 16 diodi SA5 * 0A P4045 SA.pdf
TNR220KM @05.2.4 5 diodi 22VDC TNR220KM 9W 1 TVS {https://nx2063.your-storageshare.de/s/Se8CFnGffcnEH8c TNR.pdf]
TNR221KM @95.10.2 100 diodi 220VDC TNR221KM TVS {https://nx2063.your-storageshare.de/s/Se8CFnGffcnEH8c TNR.pdf]
V7511U @05.2.4 100 diodi 510V MOV Panasonic TVS/Varistor Data table
V130LA2P @95.10.2 500 diodi 220VDC TVS LittelFuse-LA-Varistors.pdf
WE-5 Varistor @05.2.4 14 diodi 820552711.pdf
Zenamic MOV @05.2.4 8 diodi Datasheet
Ylijännitesuoja AC240L @05.2.4 3 muut Datasheet
Ylijännitesuoja DC230 @05.2.4 2 muut No Datasheet found
P150L10 @05.6.4 70 muut LittelFuse-LA-Varistors.pdf
P420L20 @05.6.4 70 muut LittelFuse-LA-Varistors.pdf
Bridge Rectifiers
10DB10A @05.3.1 1 diodi Custom 1.9A/1000V Bridge Rectifier Datasheet
15B4B41 1-F @05.3.1 1 diodi Toshiba 12-26A1A 15A/100V Bridge Rectifier Datasheet
18DB8A @05.3.1 1 diodi Custom 1.8A/800V Bridge Rectifier Datasheet
1N4436/S @05.3.1 2 diodi Custom 10A/200V Bridge Rectifier Datasheet
26MB40A @05.3.1 2 diodi 25A/400V Bridge Rectifier 26MB40Apdf
2KBP005 @05.3.1 4 diodi KBPM 2A/50V Bridge Rectifier Datasheet
36MB100A @05.3.1 1 diodi 35A/1000V Bridge Rectifier Datasheet
3N246 @05.3.1 1 diodi KBPM 1.5A/30V Bridge Rectifier Datasheet
AM1510 @05.5.4 5 diodi Custom 1.5A/1000V Bridge Rectifier Datasheet
B125 C5000 @05.3.2 3 diodi RS-5 5A/280V Bridge Rectifier Datasheet
B40 C3200/2200 @05.3.2 4 diodi G5 4A/40V Semikron Bridge Rectifier Datasheet
B40 C3200/2200Si @05.3.2 7 diodi G5 4A/40V Semikron Bridge Rectifier Datasheet
B80 C5000/3300 @05.3.3 5 diodi G5 5A/80V Semikron Bridge Rectifier Datasheet
BA10B @05.3.3 10 diodi N/A 1A/100V Rectifier Bridge Datasheet not found
BR104 @05.3.3 2 diodi BR-10 10A/400V Bridge Rectifier Datasheet
BR156W @05.3.3 2 diodi BR-25W 15A/600V Bridge Rectifier Datasheet
BR258 @05.3.4 7 diodi BR-6 25A/560V Silicon Bridge Rectifier Datasheet
BR66 @05.3.4 3 diodi BR-6 6A/600V Bridge Rectifier Datasheet
BY122 @05.4.1 4 diodi Custom 3A/42V Bridge Rectifier Datasheet
BY123 @05.4.1 1 diodi Custom 3A/280V Bridge Rectifier Datasheet
BY164 @05.4.1 2 diodi SOD-28 1.2A/60V Bridge Rectifier Datasheet
BY224 600 @05.4.1 2 diodi SOT-112 4.8A/600V Bridge Recfitier Datasheet
BYW22 @05.4.1 1 diodi N/A 15A/200V Bridge Rectifier Datasheet
DF06 340M @05.4.2 40 diodi 4-Pin DIP 1A/600V Bridge Rectifier Datasheet
GSIB1520 @05.6.1 1 diodi 15A/200V Diode rectifier bridge Datasheet
KBL02 @05.4.2 15 diodi KBL 4A/200V Diode rectifier bridge Datasheet
KBL406G @05.6.3 18 diodi KBL 4A/800V Diode rectifier bridge KBL401G.pdf
KBPC1010 @05.4.2 1 diodi BR-8 10A/1000V Bridge Rectifier Datasheet
KBPC2506 @05.4.2 1 diodi BR-8 25A/600V Bridge Rectifier Datasheet
KBPC3506 @05.4.2 1 diodi BR-8 35A/600V Bridge Rectifier Datasheet
KBPC3508 @05.4.2 1 diodi BR-8 35A/800V Bridge Rectifier Datasheet
KBPC5010 @05.4.3 6 diodi BR50-M 50A/1000V Bridge Rectifier Datasheet
KBPC602 @05.4.3 4 diodi BR-6 6A/200V Bridge Rectifier Datasheet
KBPC608 @05.4.3 4 diodi BR-6 6A/800V Bridge Rectifier Datasheet
LB-156 @05.4.4 2 diodi Custom 1.5A/600V Bridge Rectifier Reference Table
MB256 @05.4.4 1 diodi MB-25 25A/600V Bridge Rectifier Datasheet
MDA202G @05.4.4 8 diodi RS-1 2A/140V Bridge Rectifier Datasheet
MDA970G5 @05.4.4 1 diodi RS-4L 4A/400V Bridge Rectifier Datasheet
NT/H B50/42-0.5 Si A @05.4.4 10 diodi No Datasheet found
R622/T @05.5.1 2 diodi N/A 36A/140V Bridge Rectifier three phase full wave Datasheet
RB-152 @05.5.1 1 diodi RB-15 1.5A/100V Bridge Rectifier Datasheet
RS404L @05.5.1 13 diodi RS-4L 4A/400V Single-phase silicon bridge rectifier Datasheet
RS605 @05.5.1 7 diodi RS-6 6A/600V Bridge Rectifier Datasheet
RB157 @05.5.1 50 diodi RB-15 1.5A/1000V Single-phase glass passivated silicon bridge rectifier Datasheet
RB157 @05.5.2 150 diodi RB-15 1.5A/1000V Single-phase glass passivated silicon bridge rectifier Datasheet
SA6090 @05.5.3 1 diodi SEMTECH SA 6090 No Datasheet found
SB604 @05.5.3 14 diodi SB-6 6A/400V Bridge Rectifier Datasheet
SB606 @05.5.3 14 diodi SB-6 6A/800V Bridge Rectifier Datasheet
SB804 @05.5.3 1 diodi SB-10 8A/400V Bridge Rectifier Datasheet
SC3BA2 @05.5.3 1 diodi G37 18A/200V 3-Phase Bridge Rectifier Datasheet
SDK25/02 @05.4.2 2 diodi 12A/200V 3-Phase Bridge Rectifier SKD25.pdf
VE27 @05.5.4 1 diodi Custom 1A/140V Bridge Rectifier Datasheet
VH247 @05.5.4 10 diodi Custom 6A/200V Bridge Rectifier VH247-VH1048.pdf
VH447 @05.6.3 1 diodi Custom 6A/400V Bridge Rectifier VH247-VH1048.pdf
VH647 @05.6.3 3 diodi Custom 6A/600V Bridge Rectifier VH247-VH1048.pdf
VS247 @05.6.1 5 diodi Custom 2A/200V Bridge Rectifier VS247-VS1048.pdf
VS447 @05.6.1 3 diodi Custom 2A/400V Bridge Rectifier VS247-VS1048.pdf
VT200/S @05.6.1 5 diodi Single Stud Mount 25A/140V Bridge Rectifier Datasheet
BY122 @05.6.2 100 diodi Custom 3A/42V Bridge Rectifier Datasheet
W06M @05.6.1 9 diodi Custom 1.5A/600V Bridge Rectifier W06M.pdf
12CTQ045 @15.1.3 2 diodi TO-220 6A/45V Double Schottky Diode Datasheet
1N180 @15.1.3 2 diodi Color Coded Datasheet not found
1N198 @15.1.1 500 diodi Custom Germanium Diode 500mA/80V Color Coded Datasheet
1N23 @15.1.2 14 diodi CS100 S-X Band Point Contact Mixer Diode 9.375 GHz Datasheet
1N23C @15.1.2 4 diodi CS100 S-X Band Point Contact Mixer Diode 9.375 GHz Datasheet
1N3880 @15.1.3 30 diodi DO-4 (DO-203AA) Fast Recovery Diode 6A/100V Datasheet
1N3891 @15.1.3 5 diodi DO-4 (DO-203AA) Fast Recover Diode 12A/200V Datasheet
1N4001 @15.8.4 400 diodi DO-41 Silicon Rectifier 1A/50V Datasheet
1N4002 @15.8.4 400 diodi DO-41 Silicon Rectifier 1A/100V Datasheet
1N4004 @15.1.4 49 diodi DO-41 Silicon Rectifier 1A/400V Datasheet
1N4005 @15.1.4 300 diodi DO-41 Silicon Rectifier 1A/800V Datasheet
1N4007 @15.2.1 500 diodi DO-41 Silicon Rectifier 1A/1000V Datasheet
1N4148 @15.2.2 500 diodi DO-35 Signal Diode 150mA/75V Datasheet
1N4148 x 4 @15.12.3 280 diodi Custom Signal Diode 4 x 50mA/80V DAP401.pdf
1N4153 @15.2.3 500 diodi DO-35 Signal Diode 150mA/75V Color Coded Datasheet
1N4153F @15.2.4 90 diodi DO-35 Signal Diode 150mA/75V Datasheet
1N415D @15.1.2 2 diodi CS101 S-X Band Point Contact Mixer Diode 9.375 GHz Datasheet
1N4385 @15.2.4 21 diodi DO-41 Rectifier 1A/600V Datasheet
1N4448 @15.2.4 500 diodi DO-35 300mA/100V Small Signal Fast Switching Diodes Datasheet
1N4448 @15.2.4 200 diodi DO-35 300mA/100V Small Signal Fast Switching Diodes Datasheet
1N5399 @15.3.1 10 diodi DO-41 1.5A/1000V General Purpose Plastic Rectifier Datasheet
1N5402 @15.3.1 22 diodi DO-201AD Silicon Rectifier 3A/200V Datasheet
1N5404 @15.3.1 80 diodi DO-201AD Silicon Rectifier 3A/400V Datasheet
1N5408 @15.3.1 20 diodi DO-201AD Silicon Rectifier 3A/1000V Datasheet
1N5817 @15.3.2 2 diodi DO-41 Schottky Barrier Rectifier 1.0A/20V Datasheet
1N5818 @15.3.2 15 diodi DO-41 Schottky Barrier Rectifier 1.0A/30V Datasheet
1N5819 @15.3.2 44 diodi DO-41 1A/40V Schottky Barrier Plastic Rectifier Datasheet
1N5822 @15.3.2 10 diodi DO-201AD 3.0A/40V Schottky Barrier Plastic Rectifier Datasheet
1N647 @15.3.2 20 diodi DO-35 Rectifier 400mA/400V Datasheet
20ETS08 @15.3.3 5 diodi TO-220AC 20A/800V Input Rectifier Diode Datasheet
6A10 @15.7.2 85 diodi R-6 Rectifier Diode 6A/100V 6A05-6A100.pdf
6F20 @15.3.3 6 diodi DO-4 (DO-203AA) Standard Recovery Diode 70A/200V Datasheet
6F40 @15.3.3 3 diodi DO-4 (DO-203AA) Standard Recovery Diode 70A/200V Datasheet
70HF100 @15.3.3 2 diodi DO-5 (DO-203AB) Standard Recovery Diode 70A/1000V Datasheet
BA159 @15.12.4 800 diodi DO-41 (DO-204AL) Fast Switching Plastic Rectifier 1A/1000V Datasheet
BA483 @15.3.4 33 diodi DO-43 100mA/35V Band-switching diode Datasheet
BAT46 @15.3.4 6 diodi DO-35 150mA/100V Small Signal Schottky Diode Datasheet
BAT85 @15.3.4 12 diodi DO-34 200mA/30V Schottky barrier diode Datasheet
BAX16 @15.3.4 10 diodi DO-35 500mA/150V General Purpose Diode Datasheet
BAX18 @15.3.4 4 diodi DO-35 500mA/75V General purpose diode Datasheet
BB405 @15.3.4 44 diodi DO-34 20mA/30V Variable capacitance diode, White band BB405B.pdf
BB809 @15.4.1 100 diodi DO-34 VHF variable capacitance diode, Yellow band Datasheet
BBC 207 344 @15.4.1 2 diodi Datasheet not found
BBC 4216 023 @15.4.1 1 diodi Datasheet not found
BY100 BY143 @15.4.1 2 diodi DO-27 550mA/800V 1.1A/600V Silicon Diode Datasheet
BY210-400 @15.4.1 25 diodi DO-15 Fast soft-recovery diode 1A/400V Datasheet
BY227 @15.4.1 9 diodi SOD-18 1.5A/800V Silicon Rectifier Diode Datasheet
BY228 @15.4.1 6 diodi SOD-64 3A/1500V Standard Avalanche Sinterglass Diode Datasheet
BY229-600 @15.4.2 5 diodi TO220AC (SOD59) Fast soft-recovery rectifier diode 8A/600V Datasheet
BY255 @15.4.2 80 diodi DO-201AD 3A/1300V Silicon Rectifier Diode Datasheet
BY299 @15.4.2 33 diodi DO-201AD 2A/800V Fast Recovery Rectifier Diode Datasheet
BY550-200 @15.4.3 30 diodi DO-201AD Silicon Rectifier Diode 5A/200V Datasheet
BYD43-20 @15.4.3 11 diodi SOD81 Fast soft-recovery rectifier 680mA/2000V Datasheet
BYT30P600 @15.4.3 3 diodi SOD93 Fast recovery rectifier diode 30A/600V Datasheet
BYV27-50 @15.4.4 12 diodi SOD-57 Ultra-fast avalance sinterglass diode 2A/150V Datasheet
BYV28-150 @15.4.4 28 diodi SOD64 Ultra-fast silicon mesa rectifier 3.5A/150V Datasheet
BYV28-200 @15.4.4 110 diodi SOD64 Ultra-fast silicon mesa rectifier 3.5A/150V Datasheet
BYV29-500 @15.4.4 34 diodi SOD59 (TO-220AC) Ultra-fast rectifier diode 9A/500V Datasheet
BYV96E @15.4.4 36 diodi D2 Avalance fast recovery rectifier diode 1.5A/1000V Datasheet
BYW29-150 BYW29F-200 @15.5.1 13 diodi SOD59 (TO-220AC) Ultra-fast rectifier diode 9A/150V 9A/200V Datasheet
BYW56 @15.5.1 14 diodi SOD-57 Standard avalance sinterglass diode 2A/1000V Datasheet
BYW72 @15.5.1 64 diodi SOD64 3A/200V Fast Avalanche Sinterglass Diode Datasheet
BYW77-100 @15.5.1 1 diodi 50A/150V Rectifier Diode Datasheet
BYW96E @15.5.1 40 diodi SOD64 Fast soft-recovery controlled avalance rectifier 3A/1000V Datasheet
BYX25-1000R @15.5.2 1 diodi DO-4 20A/1000V Avalance Rectifier Diode Datasheet
BYX38-300R @15.5.2 2 diodi DO-4 Rectifier diode 6A/1200V Datasheet
BYX38-600R @15.5.2 2 diodi DO-4 Rectifier diode 6A/600V Datasheet
BYX38-1200 @15.5.2 3 diodi DO-4 Rectifier diode 6A/1200V Datasheet
BYX96 1200 @15.5.3 2 diodi DO-4 Rectifier diode 30A/1200V Datasheet
BYX96/1200R @15.5.3 5 diodi DO-4 Rectifier diode 30A/1200V reverse polarity Datasheet
BYX97 1200R @15.5.3 3 diodi DO-5 47A/1200V Rectifier Diode Datasheet
DSEI3010A @15.5.4 1 diodi N/A 30A/1000V Fast Recovery Epitaxial Diode Datasheet
FCQ10U06 @15.5.4 1 diodi N/A Double rectifier diode 10A/60V Datasheet
FR107 @15.5.4 10 diodi DO-41 1A/1000V Fast Recovery Rectifier Datasheet
FR207 @15.5.4 10 diodi D2 2A/1000V Fast Recovery Rectifier Datasheet
FRP810 @15.5.4 3 diodi TO-220AC 8A/100V Ultra-fast Rectifier Datasheet
FRP815 @15.5.4 2 diodi TO-220AC 8A/150V Ultra-fast Rectifier Datasheet
HFA15TB60 @15.6.1 20 diodi TO-220AC 15A/600V Ultrafast Soft Recovery Diode Datasheet
KYS 30-40 @15.6.1 1 diodi D55/1 30A/40V Schottky Rectifier Diode Reference Table
LC180 @15.6.1 6 diodi N/A 60mA/18000V Rectifier Diode Reference Table
MBR20100CT @15.6.2 22 diodi TO-220 (221A6) Double schottky barrier rectifier 20A/100V Datasheet
MBR745 @15.6.2 47 diodi TO-220AC (221B1) Schottky barrier rectifier diode 7.5A/45V ON Semiconductor Datasheet
MBR745 @15.6.2 13 diodi TO-220AC (221B1) Schottky barrier rectifier diode 7.5A/45V International Rectifier Datasheet
MR501 @15.6.2 7 diodi 267-01 3A/100V Rectifier Diode Datashe et
MUR115 @15.6.2 2 diodi CASE 59−10 STYLE 1 1A/150V Ultrafast Rectifier Datasheet
MUR420 @15.6.3 150 diodi CASE 267−05 ISSUE G 4A/200V Ultrafast Rectifier Datasheet
MUR420 @15.6.4 150 diodi CASE 267−05 ISSUE G 4A/200V Ultrafast Rectifier Datasheet
RAS310AF @15.6.4 8 diodi DO-1 1A/1000V Rectifier Diode Reference Table
RP810 @15.6.4 1 diodi N/A N/A Datasheet not found
RHR30120 @15.7.1 2 diodi TO-220AC 30A/1200V Hyperfast Diode RHRO30120.pdf
RHRP8120 @15.7.1 1 diodi TO-220AC 8A/1200V Hyperfast Diode RHRP8120.pdf
SB140 @15.7.1 16 diodi DO-41 1A/40V Schottky Diode Datasheet
SB350 @15.7.1 2 diodi DO-201 3A/50V Schottky Barrier Rectifier Datasheet
SB540GI @15.7.1 2 diodi DO-201AD 5A/40V Schottky Barrier Rectifier Datasheet
SB550 @15.7.1 5 diodi DO-201AD 5A/50V Schottky Barrier Rectifier Datasheet
SCDA 1 @15.7.2 4 diodi G24 Standard recovery, medium current center tap rectifier 7.5A/100V Datasheet
SCDA 6 @15.7.2 1 diodi G24 Standard recovery, medium current center tap rectifier 7.5A/600V Datasheet
SD103A @15.7.3 500 diodi DO-35 Small signal schottky diode 200mA/40V Datasheet
SD241P @15.7.4 24 diodi TO-247AD 30A/45V Dual Common Cathode Schottky Rectifier Datasheet
SJ403-F @15.7.4 1 diodi DO-1 0.9A/500V Rectifier Diode Datasheet
SK1/16 @15.7.4 35 diodi E33 Rectifier diode 1A/1600V Datasheet
SK 25/10 @15.8.1 1 diodi Stud N/A Datasheet not found
SKE1/16 @15.8.1 1 diodi E3 Rectifier diode 1.3A/1600V Datasheet
SKR71/12 @15.8.1 1 diodi E11 Rectifier diode, SKR for reverse polarity 94A/1200V Datasheet
SKR60F15 @15.8.1 2 diodi DO-5 120A/1500V Rectifier Diode Datasheet
SN113 @15.8.2 25 diodi DO-15 Rectifier diode 1A/1600V Datasheet
SSI E 1105 @15.8.2 3 diodi Custom Rectifier diode 25A/75V Datasheet
SSI E 1205 @15.8.2 12 diodi Custom Rectifier diode 25A/75V Datasheet
STPS745 @15.8.2 7 diodi TO-220FPAC 7.5A/45V Power Schottky rectifier Datasheet
TR43R 38-6 @15.8.3 3 diodi Motorola TR4338 tms Datasheet not found
TR43R 39-6 @15.8.3 1 diodi Motorola Datasheet not found
TR43 44-6 @15.8.3 3 diodi Motorola Datasheet not found
TR43 45-9 @15.8.3 1 diodi Motorola Datasheet not found
UF5402 @15.8.3 5 diodi DO-201AD 3A 200V Fast-recovery Datasheet
Z122109 @15.8.3 9 diodi DO-4 E8905 Philips Datasheet not found
SCR/DIAC/TRIAC etc.
15/80H @15.9.1 1 diodi TO-220AA Thyristor Datasheet not found
17088 @15.9.1 4 diodi TO-220 Thyristor 5A/700V Datasheet not found
17089 @15.9.1 9 diodi TO-220 89C25 17089R Thyristor 5A/700V Datasheet
1N5758 @15.9.1 20 diodi 182-02 Bilateral Trigger 16-24V Datasheet
1N5761 @15.9.1 20 diodi 182-02 Bilateral Triggers 28-36V Datasheet
BR100/03 @15.9.2 25 diodi SOD27 Silicon bidirectional trigger device DIAC 28V Datasheet
BR101 @15.9.2 1 diodi 18A4 Silicon Controlled Rectifier (SCR) 175mA/50V Datasheet
BT138 500 @15.9.2 3 diodi TO220AB 12A/500V Triac Datasheet
BT139 500 @15.9.2 6 diodi TO220AB 16A/500V Triac Datasheet
BT152 600R @15.9.3 4 diodi TO220AB 13A/650V Thyristor Datasheet
BTA26-600BW @15.9.3 19 diodi TOP3 Insulated 25A/600V Triac Datasheet
BTA41-600B @15.9.3 5 diodi TOP3 Insulated 40A/600V TRIAC Datasheet
BTA41-800B @15.9.3 2 diodi TOP3 Insulated 40A/800V TRIAC Datasheet
C106B @15.9.4 189 diodi TO-202 4A/200V Silicon Controller Rectifier SCR Datasheet
C106B @15.9.4 44 diodi TO-202 4A/200V Silicon Controller Rectifier SCR Datasheet
C106B1 @15.9.4 3 diodi TO-202 4A/200V Silicon Controller Rectifier SCR Datasheet
C106D @15.9.4 3 diodi TO-202 4A/400V Silicon Controller Rectifier SCR Datasheet
C106D1 GE @15.9.4 24 diodi TO-202 4A/400V Silicon Controller Rectifier SCR Datasheet
C106D1 Motorola @15.10.1 100 diodi TO-225AA 4A/400V Silicon Controller Rectifier SCR Datasheet
D3202U @15.10.1 3 diodi DO-15 R4 45412 Diac 25-40V 2A Datasheet
GFT20B12 @15.10.1 14 diodi TO-66 Gate turn off thyristor 7A/1200V Datasheet
GFT50B12 @15.10.2 15 diodi TO-3 Gate turn off thyristor 18A/1200V Datasheet
HAFO 3A143 @15.10.3 100 diodi CB429 Bidirectional crowbar 180V (=TPB200) Datasheet
Laser diodi @15.10.4 20 diodi N/A N/A Datasheet not found
MAC11-6 @15.11.1 1 diodi TO-220AB Bidirectional thyristor 10A/400V Datasheet
MAC224A6 @15.11.1 1 diodi TO-220AB Bidirectional triode thyristors 40A/200-800V Datasheet
MAC4DLM @15.11.1 34 diodi DPAK-3 4A/600V Sensitive Gate Triacs Datasheet
MAC77-6 @15.11.1 4 diodi TO-127 TRIAC 4A/400V Datasheet
MCR1063 @15.11.1 26 diodi TO-225AA 4A/100V SCR Datasheet
MCR218-8 @15.11.1 1 diodi TO-220AB 8A/800V SCR MCR218.pdf
MPT20 @15.11.2 1 diodi CASE 182 20V Bidirectional Trigger Datasheet
S1612NH @15.11.2 2 diodi TO220 Silicon controlled rectifier SCR 16A/800V Datasheet
S2800D @15.11.2 3 diodi TO220AB Silicon controlled rectifier SCR 10A/400V Datasheet
SKT40/12E @15.11.3 19 diodi B3 Line Thyristor 28A/1200V Datasheet
TIC106A @15.11.4 1 diodi TO-220 Silicon controlled rectifier SCR 5A/500V Datasheet
TIC106B @15.11.4 3 diodi TO-220 Silicon controlled rectifier SCR 5A/500V Datasheet
TIC106E @15.11.4 1 diodi TO-220 Silicon controlled rectifier SCR 5A/500V Datasheet
TIC106M @15.11.4 2 diodi TO-220 Silicon controlled rectifier SCR 5A/500V Datasheet
TIC106D @15.11.4 18 diodi TO-220 Silicon controlled rectifier SCR 5A/400V Datasheet
TIC116 @15.12.1 2 diodi TO-220 TIC116C TIC116D Silicon controlled rectifier SCR 8A/400V Datasheet
TIC116E @15.12.1 1 diodi TO-220 Silicon controlled rectifier SCR 8A/500V Datasheet
TIC116M @15.12.1 3 diodi TO-220 Silicon controlled rectifier SCR 8A/600V Datasheet
TIC206D @15.12.1 4 diodi TO-220 4A/400V Silicon Bidirectional Triode Thyristor Datasheet
TIC226M @15.12.1 1 diodi TO-220 8A/600V Silicon Bidirectional Triode Thyristor Datasheet
TIC236D @15.12.1 1 diodi TO-220 12A/400V TRIAC Datasheet
TIC44 @15.12.2 4 diodi TO-18 600mA/30V Silicon Thyristor Datasheet
TIC46 @15.12.2 1 diodi TO-18 600mA/100V Silicon Thyristor Datasheet
TIC47 @15.12.2 5 diodi TO-18 600mA/200V Silicon Thyristor Datasheet
TXC18E40 @15.12.2 6 diodi N/A 4A/400V Triac Reference Table
Zener-diodit
10Z18 18V @14.1.1 4 diodi zener DO-4 18V 10W Zener Diode Reference Table
1N1767 6.8V @14.1.1 4 diodi zener DO-12 6.8V 1.0W Zener regulator diode Reference Table
1N1957 6.8V @14.1.1 7 diodi zener 6.8V 400mW Zener diode - Color coded Reference Table
1N2990B 33V @14.1.1 1 diodi zener DO-4 33V 10W Zener Diode Datasheet
1N3826A 5.1V @14.1.2 20 diodi zener DO-13 5.1V 1.0W Zener regulator diode Datasheet
1N3829A 6.8V @14.1.2 16 diodi zener DO-13 6.8V 1.0W Metal silicon zener diode Datasheet
1N3032B 33V @14.1.2 17 diodi zener DO-13 33V 1W Metal case zener diode Datasheet
1N3040B 68V @14.1.3 6 diodi zener DO-13 75V 1W Metal case zener diode Datasheet
1N3041B 75V @14.1.3 15 diodi zener DO-13 75V 1.0W Zener regulator diode Datasheet
1N4728A 3.3V @14.1.4 18 diodi zener DO-41 3.3V 1W Silicon zener diode Datasheet
1N4729A 3.6V @14.1.4 14 diodi zener DO-41 3.9V 1W Silicon zener diode Datasheet
1N4730A 3.9V @14.1.4 8 diodi zener DO-41 3.9V 1W Silicon zener diode Datasheet
1N4732A 4.7V @14.1.4 5 diodi zener DO-41 4.7V 1W Silicon zener diode Datasheet
1N4734A 5.6V @14.2.1 12 diodi zener DO-41 5.6V 1W Silicon zener diode Datasheet
1N4736A 6.8V @14.2.1 22 diodi zener DO-41 6.8V 1.0W Zener Diode Datasheet
1N4737A 7.5V @14.2.1 2 diodi zener DO-41 7.5V 1.0W Zener Diode Datasheet
1N4740A 10V @14.2.1 22 diodi zener DO-41 10V 1W Zener Diode Datasheet
1N4742A 12V @14.2.1 7 diodi zener DO-41 12V 1W Silicon zener diode Datasheet
1N4744A 15V @14.2.1 24 diodi zener DO-41 15V 1W Silicon zener diode Datasheet
1N4745A 16V @14.2.2 120 diodi zener DO-41 16V 1W Silicon zener diode Datasheet
1N4746A 18V @14.2.2 14 diodi zener DO-41 18V 1W Silicon zener diode Datasheet
1N4747A 20V @14.2.2 200 diodi zener DO-41 20V 1W Silicon zener diode Datasheet
1N4749A 24V @14.2.2 18 diodi zener DO-41 24V 1W Silicon zener diode Datasheet
1N4755A 43V @14.2.3 5 diodi zener DO-41 43V 1W Zener Diode Datasheet
1N4757A 51V @14.2.3 3 diodi zener DO-41 51V 1W Zener Diode Datasheet
1N4759 62V @14.2.3 2 diodi zener DO-41 62V 1W Silicon zener diode Datasheet
1N4763 91V @14.2.3 5 diodi zener DO-41 91V 1W Silicon zener diode Datasheet
1N4764 100V @14.2.3 7 diodi zener DO-41 100V 1W Silicon zener diode Datasheet
1N5240B 10V @14.2.3 4 diodi zener DO-35 10V 500mW Zener Diode Datasheet
1N5333B 3.3V @14.2.4 37 diodi zener DO-201AE 5W Zener Diode 3.3V Datasheet
1N5337 4.7V @14.2.4 58 diodi zener DO-201AE 5W Zener Diode 4.7V Datasheet
1N5339B 5.6V @14.2.4 13 diodi zener DO-201AE 5W Zener Diode 5.6V Datasheet
1N5347B 10V @14.2.4 10 diodi zener DO-201AE 5W Zener Diode 5.6V Datasheet
1N5355 18V @14.2.4 9 diodi zener DO-201AE 5W Zener Diode 18V Datasheet
1N5358B 22V @14.3.1 22 diodi zener DO-201AE 5W Zener Diode 22V Datasheet
1N5360 25V @14.3.1 14 diodi zener DO-201AE 5W Zener Diode 25V Datasheet
1N5361B 27V @14.3.1 21 diodi zener DO-201AE 5W Zener Diode 27V Datasheet
1N5372B 62V @14.3.1 70 diodi zener DO-201AE 5W Zener Diode 62V Datasheet
1N5374B 75V @14.3.2 3 diodi zener DO-201AE 5W Zener Diode 75V Datasheet
1N5375B 82V @14.3.2 70 diodi zener DO-201AE 5W Zener Diode 82V Datasheet
1N5378 100V @14.3.2 13 diodi zener DO-201AE 5W Zener Diode 100V/12mA Datasheet
1N5384 160V @14.3.2 14 diodi zener DO-201AE 5W Zener Diode 160V/8mA Datasheet
1N746A 3.3V @14.3.3 80 diodi zener DO-35 3.3V 500mW Silicon planar zener diode Datasheet
1N746A 3.3V @14.3.3 11 diodi zener DO-35 3.3V 500mW Color Coded Silicon planar zener diode Datasheet
1N747 3.6V @14.3.3 20 diodi zener DO-35 3.6V 500mW Datasheet
1N748A 3.9V @14.3.3 12 diodi zener DO-35 3.9V 500mW Color Coded Silicon planar zener diode Datasheet
1N748A 3.9V @14.3.3 27 diodi zener DO-35 3.9V 500mW Silicon planar zener diode Datasheet
1N749A 4.3V @14.3.3 6 diodi zener DO-35 4.3V 500mW Color Coded Silicon planar zener diode Datasheet
1N751A 5.1V @14.3.4 100 diodi zener DO-35 5.1V 500mW Silicon planar zener diode Datasheet
1N752A 5.6V @14.3.4 100 diodi zener DO-35 5.6V 500mW Silicon planar zener diode Datasheet
1N753A 6.2V @14.3.4 18 diodi zener DO-35 6.2V 500mW Zener Diode Datasheet
1N754A 6.8V @14.3.4 16 diodi zener DO-35 6.8V 500mW Zener Diode Datasheet
1N755A 7.5V @14.3.4 2 diodi zener DO-35 7.5V 500mW Color Coded Zener Diode Datasheet
1N756A 8.2V @14.4.1 50 diodi zener DO-35 8.2V 500mW Silicon planar zener diode Datasheet
1N756A 8.2V @14.4.1 40 diodi zener DO-35 8.2V 500mW Zener Diode Color Coded Datasheet
1N757A 9.1V @14.4.2 16 diodi zener DO-35 9.1V 500mW Silicon planar zener diode Datasheet
1N758A 10V @14.4.2 30 diodi zener DO-35 10V 500mW Zener Diode Datasheet
1N759A 12V @14.4.2 100 diodi zener DO-35 12V 500mW Zener Diode Datasheet
1N759A 12V @14.4.2 3 diodi zener DO-35 12V 500mW Color Coded Zener Diode Datasheet
1N958B 7.5V @14.4.3 12 diodi zener DO-35 7.5V 5% 500mW Zener Diode Datasheet
1N960B 9.1V @14.4.3 23 diodi zener DO-35 9.1V 5% 500mW Zener Diode Datasheet
1N961B 10V @14.4.3 7 diodi zener DO-35 10V 5% 500mW Zener Diode Datasheet
1N962B 11V @14.4.3 1 diodi zener DO-35 10V 5% 500mW Zener Diode Color Coded Datasheet
1N963B 12V @14.4.3 20 diodi zener DO-35 12V 5% 500mW Zener Diode Datasheet
1N965B 15V @14.4.4 20 diodi zener DO-35 15V 5% 500mW Zener Diode Datasheet
1N967B 18V @14.4.4 80 diodi zener DO-35 18V 5% 500mW Zener Diode Datasheet
1N969B 22V @14.4.4 11 diodi zener DO-35 22V 5% 500mW Zener Diode Color Coded Datasheet
1N970B 24V @14.4.4 22 diodi zener DO-35 24V 0.5W Silicon planar zener diode Datasheet
1N971B 27V @14.4.4 100 diodi zener DO-35 27V 0.5W Silicon planar zener diode Datasheet
1N973B 33V @14.4.4 2 diodi zener DO-35 33V 0.5W Silicon planar zener diode Datasheet
1N980B 62V @14.5.1 4 diodi zener DO-35 62V 500mW Silicon Zener Diode Datasheet
1N983B 82V @14.5.1 11 diodi zener DO-35 82V 500mW Silicon Zener Diode Datasheet
1Z18T10 18V @14.5.1 4 diodi zener DO-15 18V 1W Silicon diffused junction zener diode Datasheet
1Z27 27V @14.5.1 3 diodi zener DO-15 27V 1W Silicon diffused junction zener diode Datasheet
1Z6.2 6.2V @14.5.1 14 diodi zener DO-15 6.2V 1W Silicon diffused junction zener diode Datasheet
4IZ 6A 7.7V @14.5.2 20 diodi zener Color coded Yellow-Violet Datasheet not found
5234BR 6.2V @14.5.2 70 diodi zener DO-35 6.2V 500mW Motorola Zener Diode (=1N5234) Datasheet
5236B 7.5V @14.5.2 20 diodi zener DO-35 7.5V 500mW Motorola Zener Diode (=1N5236) Datasheet
5240B 10V @14.5.2 20 diodi zener DO-35 10V 500mW Motorola Zener Diode (=1N5240) Datasheet
BZ100 10V @14.5.3 3 diodi zener DO-7 10V 1W Zener Diode Reference Table
BZD10C82 82V @14.5.3 17 diodi zener 82V 1.3W Zener Diode Reference Table
BZD23C200 200V @14.5.3 18 diodi zener SOD81 200V 1.0W Voltage regulator diode Datasheet
BZT03C130 130V @14.5.3 24 diodi zener SOD-57 130V 1.3W Zener diode Datasheet
BZV40C4V7 4.7V @14.5.4 4 diodi zener T-18 4.7V 5W Zener diode Datasheet
BZV85C4V7 4.7V @14.5.4 15 diodi zener DO-41 4.7V 1W Silicon zener diode Datasheet
BZV85C5V6 5.6V @14.5.4 1 diodi zener DO-41 5.6V 1W Silicon zener diode Datasheet
BZV85C6V2 6.2V @14.5.4 10 diodi zener DO-41 6.2V 1W Silicon zener diode Datasheet
BZV85C6V8 6.8V @14.5.4 20 diodi zener DO-41 6.8V 1W Silicon zener diode Datasheet
BZV85C10 10V @14.6.1 90 diodi zener DO-41 10V 1W Silicon zener diode Datasheet
BZV85C12 12V @14.6.1 5 diodi zener DO-41 12V 1W Silicon zener diode Datasheet
BZV85C22 22V @14.6.1 17 diodi zener DO-41 17V 1W Silicon zener diode Datasheet
BZV85C27 27V @14.6.1 22 diodi zener DO-41 27V 1W Silicon zener diode Datasheet
BZW03C10 10V @14.6.2 40 diodi zener SOD-64 10V 1.85W Zener Diode Datasheet
BZW03C24 24V @14.6.2 10 diodi zener SOD-64 24V 1.85W Zener Diode Datasheet
BZW03C39 39V @14.6.2 9 diodi zener SOD-64 39V 1.85W Zener Diode Datasheet
BZX55B8V2 8.2V @14.6.2 10 diodi zener DO-35 8.2V 500mW zener diode Datasheet
BZX55C3V3 3.3V @14.6.3 20 diodi zener DO-35 3.3V 500mW zener diode Datasheet
BZX55C3V6 3.6V @14.6.3 16 diodi zener DO-35 3.6V 500mW zener diode Datasheet
BZX55C3V9 3.9V @14.6.3 7 diodi zener DO-35 3.9V 500mW zener diode Datasheet
BZX55C4V3 4.3V @14.6.3 100 diodi zener DO-35 4.3V 500mW zener diode Datasheet
BZX55C4V7 4.7V @14.6.3 100 diodi zener DO-35 4.7V 500mW zener diode Datasheet
BZX55C05V1 5.1V @14.6.3 15 diodi zener DO-35 5.1V 500mW zener diode Datasheet
BZX55C05V6 5.6V @14.6.4 9 diodi zener DO-35 5.6V 500mW zener diode Datasheet
BZX55C06V2 6.2V @14.6.4 140 diodi zener DO-35 6.3V 500mW zener diode Datasheet
BZX55C09V1 9.1V @14.6.4 7 diodi zener DO-35 9.1V 500mW zener diode Datasheet
BZX55C12 12V @14.6.4 6 diodi zener DO-35 12V 500mW zener diode Datasheet
BZX55C15 15V @14.6.4 10 diodi zener DO-35 15V 500mW zener diode Datasheet
BZX55C27 27V @14.6.4 15 diodi zener DO-35 27V 500mW zener diode (Motorola C27) Datasheet
BZX75C1V4 1.4V @14.7.1 3 diodi zener DO-7 1.4V 400mW zener diode Datasheet
BZX75C2V1 2.1V @14.7.1 22 diodi zener DO-7 2.1V 400mW zener diode Datasheet
BZX79B13 13V @14.7.1 8 diodi zener DO-35 13V 500mW Voltage regulator diode Datasheet
BZX79C3V3 3.3V @14.7.2 19 diodi zener DO-35 3.3V 500mW Voltage regulator diode Datasheet
BZX79C3V9 3.9V @14.7.2 50 diodi zener DO-35 3.9V 500mW Voltage regulator diode Datasheet
BZX79C4V3 4.3V @14.7.2 90 diodi zener DO-35 4.3V 500mW Voltage regulator diode Datasheet
BZX79C5V6 5.6V @14.7.2 1 diodi zener DO-35 5.6V 500mW Voltage regulator diode Datasheet
BZX79C7V5 7.5V @14.7.2 160 diodi zener DO-35 7.5V 500mW Voltage regulator diode Datasheet
BZX79C10 10V @14.7.2 31 diodi zener DO-35 10V 500mW Voltage regulator diode Datasheet
BZX79C12 12V @14.7.3 12 diodi zener DO-35 12V 500mW Voltage regulator diode Datasheet
BZX79C13 13V @14.7.3 10 diodi zener DO-35 13V 500mW Voltage regulator diode Datasheet
BZX79C18 18V @14.7.3 35 diodi zener DO-35 18V 500mW Voltage regulator diode Datasheet
BZX79C22 22V @14.7.3 20 diodi zener DO-35 22V 500mW Voltage regulator diode Datasheet
BZX79C24 24V @14.7.3 22 diodi zener DO-35 24V 500mW Voltage regulator diode Datasheet
BZX79C27 27V @14.7.4 400 diodi zener DO-35 27V 500mW Voltage regulator diode Datasheet
BZX83C6V2 6.2V @14.7.4 6 diodi zener DO-35 6.2V 500mW Zener Diode Datasheet
BZX85C3V3 3.3V @14.8.1 80 diodi zener DO-41 3.3V 1.3W Zener diode Datasheet
BZX85C4V7 4.7V @14.8.1 20 diodi zener DO-41 4.7V 1.3W Zener diode Datasheet
BZX85C5V1 5.1V @14.8.1 11 diodi zener DO-41 5.1V 1.3W Zener diode Datasheet
BZX85C5V1 5.1V @14.8.1 35 diodi zener DO-41 5.1V 1.3W Zener diode Datasheet
BZX85C5V6 5.6V @14.8.2 4 diodi zener DO-41 5.6V 1.3W Zener diode Datasheet
BZX85C6V2 6.2V @14.8.2 7 diodi zener DO-41 6.2V 1.3W Zener diode Datasheet
BZX85C7V5 7.5V @14.8.2 50 diodi zener DO-41 7.5V 1.3W Zener diode Datasheet
BZX85C8V2 8.2V @14.8.2 17 diodi zener DO-41 8.2V 1.3W Zener diode Datasheet
BZX85C09V1 9.1V @14.8.3 16 diodi zener DO-41 9.1V 1.3W Zener diode Datasheet
BZX85C10 10V @14.8.3 9 diodi zener DO-41 10V 1.3W Zener diode Datasheet
BZX85C12 12V @14.8.3 45 diodi zener DO-41 12V 1.3W Zener diode Datasheet
BZX85C13 13V @14.8.3 10 diodi zener DO-41 13V 1.3W Zener diode Datasheet
BZX85C15 15V @14.8.3 80 diodi zener DO-41 15V 1.3W Zener diode Datasheet
BZX85C16 16V @14.8.3 8 diodi zener DO-41 16V 1.3W Zener diode Datasheet
BZX85C18 18V @14.8.4 3 diodi zener DO-41 18V 1.3W Zener diode Datasheet
BZX85C20 20V @14.8.4 7 diodi zener DO-41 20V 1.3W Zener diode Datasheet
BZX85C33 33V @14.8.4 50 diodi zener DO-41 33V 1.3W Zener diode Datasheet
BZX85C62 62V @14.8.4 10 diodi zener DO-41 62V 1.3W Zener diode Datasheet
BZX5V6 5.6V @14.8.4 42 diodi zener DO-35 5.6V 500mW zener diode BZX2V0-39V.pdf
BZX13 13V @14.8.4 100 diodi zener DO-35 13V 500mW zener diode color coded BZX2V0-39V.pdf
BZY88C9V1 9.1V @14.9.1 13 diodi zener DO-35 9.1V 500mW Zener diode Datasheet
BZY88C27 27V @14.9.1 5 diodi zener DO-35 27V 500mW Zener diode Datasheet
BZY93C15 15V @14.9.1 2 diodi zener DO-4 15V 1A/20W Voltage regulator diode Datasheet
C7V5 7.5V @14.9.1 4 diodi zener N/A Motorola 7.5V No Datasheet Found
C30 30V @14.9.1 13 diodi zener N/A Motorola 30V No Datasheet Found
KELZ4V7 4.7V @14.9.2 100 diodi zener DO-35 4.7V 500mW Zener Diode No Datasheet Found
MZ2360 0.7V @14.9.2 4 diodi zener DO-41 0.7V Forward Voltage Reference Diode Datasheet
Orange-Yellow @14.9.2 26 diodi zener No identification information
PH C2V7 2.7V @14.12.1 10 diodi zener PH=Philips? No identification information
PH C3V3 3.3V @14.12.1 10 diodi zener PH=Philips? No identification information
PH C5V1 5.1V @14.12.1 19 diodi zener PH=Philips? No identification information
PH C5V6 5.6V @14.12.1 26 diodi zener PH=Philips? No identification information
PH C6V8 6.8V @14.12.1 10 diodi zener PH=Philips? No identification information
PH C11 11V @14.12.1 10 diodi zener PH=Philips? No identification information
PH C22 22V @14.12.1 10 diodi zener PH=Philips? No identification information
Z7 7V @14.9.3 5 diodi zener Custom 7V 250mW Zener Diode Datasheet
Z8 8V @14.9.3 18 diodi zener Custom 8V 250mW Zener Diode Datasheet
ZD6.2 6.2V @14.9.3 1 diodi zener DO-13 6.2V 1.3W Zener Diode Datasheet
ZF3V3 3.3V @14.9.4 90 diodi zener 3.3V 400mW zener diode C3V3 ST Datasheet
ZF12 12V @14.9.4 100 diodi zener 12V 400mW zener diode C12 ST Datasheet
ZF15P 15V @14.9.4 15 diodi zener 15V 400mW zener diode Datasheet
ZF43 4.3V @14.9.4 10 diodi zener 4.3V 400mW Zener Diode Datasheet
ZPD4.3 4.3V @14.10.1 90 diodi zener DO-35 4.3V 500mW Zener Diode Datasheet
ZPD4.7 4.7V @14.10.1 90 diodi zener DO-35 4.7V 500mW Zener Diode Datasheet
ZPD5.6 5.6V @14.10.1 2 diodi zener DO-35 5.6V 500mW Zener Diode Datasheet
ZPD6.8 6.8V @14.10.1 1 diodi zener DO-35 6.8V 500mW Zener Diode Datasheet
ZPD8.2 8.2V @14.10.1 2 diodi zener DO-35 8.2V 500mW Zener Diode Datasheet
ZPD9V1 9.1V @14.10.1 9 diodi zener DO-35 9.1V 500mW Zener Diode Datasheet
ZPD15 15V @14.10.2 7 diodi zener DO-35 15V 500mW Zener Diode Datasheet
ZPD18 18V @14.10.2 50 diodi zener DO-35 18V 500mW Zener Diode Datasheet
ZPD24 24V @14.10.2 8 diodi zener DO-35 24V 500mW Zener Diode Datasheet
ZPD27 27V @14.10.2 90 diodi zener DO-35 27V 500mW Zener Diode Datasheet
ZPD33 33V @14.10.2 43 diodi zener DO-35 33V 500mW Zener Diode Datasheet
ZPY3.9 3.9V @14.10.3 4 diodi zener DO-41 3.9V 1.3W Zener Diode Datasheet
ZPY4.3 4.3V @14.10.3 2 diodi zener DO-41 4.3V 1.3W Zener Diode Datasheet
ZPY5.1 5.1V @14.10.3 7 diodi zener DO-41 5.1V 1.3W Zener Diode Datasheet
ZPY10 10V @14.10.3 5 diodi zener DO-41 10V 1.3W Zener Diode Datasheet
ZPY33 33V @14.10.3 2 diodi zener DO-41 33V 1.3W Zener Diode Datasheet
ZPY36 36V @14.10.3 9 diodi zener DO-41 36V 1.3W Zener Diode Datasheet
ZPY56 56V @14.10.4 400 diodi zener DO-41 56V 1.3W Zener Diode Datasheet
ZPY68 68V @14.10.4 400 diodi zener DO-41 68V 1.3W Zener Diode Datasheet
ZPY82 82V @14.11.1 60 diodi zener DO-41 82V 1.3W Zener Diode Datasheet
ZPY110 110V @14.11.1 5 diodi zener DO-41 110V 1.3W Zener Diode Datasheet
ZX5.1 5.1V @14.11.4 9 diodi zener DO-4 5.1V 12.5W Silicon zener diode ZX24.pdf
ZX24 24V @14.11.2 1 diodi zener DO-4 24V 12.5W Silicon zener diode ZX24.pdf
ZY8.2 8.2V @14.11.2 25 diodi zener DO-41 8.2V 2W Silicon zener diode Datasheet
ZY36 36V @14.11.2 80 diodi zener DO-41 36V 2W Silicon zener diode Datasheet
2.0V - 7.5V @14.11.3 diodi zener 2V0,2V2,2V4,2V7,3V0,3V3,3V6,3V9,4V3,4V7,5V1,5V6,6V2,6V8,7V5
8.2V - 39V @14.11.3 diodi zener 8V2,9V1,10,11,12,13,15,16,18,20,22,24,27,30,39 V
BZX61C75 75V @14.11.4 80 diodi zener DO-41 75V 1W Silicon zener diode Datasheet
IT 2039A 3.9V @14.11.4 70 diodi zener 3.9V Silicon zener diode Arvo mitattu
Kannat
Kanta 6 - pin @46.1.1 X kannat Putkikanta
Kanta 8 - pin @46.1.1 X kannat Putkikanta
Kanta 10 - pin @46.7.2 11 kannat Pyöreä OP-Amp kanta
Kanta 14 - pin @46.1.2 X kannat Putkikanta
Kanta 14 – pin @46.1.2 X kannat
Kanta 16 – pin @46.1.3 X kannat Putkikanta
Kanta 16 – pin @46.2.1 X kannat
Kanta 18 – pin @46.1.3 X kannat Putkikanta
Kanta 1x9 – pin @46.1.3 45 kannat Putkikanta
Kanta 18 – pin @46.2.2 X kannat
Kanta 20 – pin @46.2.3 X kannat Putkikanta
Kanta 24 – pin @46.3.1 X kannat 24-Pin 300mil
Kanta 24 – pin @46.3.1 X kannat 24-Pin 600mil
Kanta 24 – pin @46.3.1 X kannat 24-Pin 300mil Putkikanta
Kanta 24 – pin @46.3.1 X kannat 24-Pin 600mil Putkikanta
Kanta 28 – pin @46.3.2 X kannat Putkikanta
Kanta 28 – pin @46.3.2 4 kannat 28-Pin 300mil
Kanta 28 – pin @46.3.2 X kannat 28-Pin 600mil
Kanta 28 – pin @46.3.3 X kannat 28-Pin 600mil
Kanta 28 – pin @46.8.2 X kannat 28-Pin 600mil
Kanta 32 – pin @46.3.3 X kannat 32-Pin 600mil
Kanta 40 – pin @46.7.2 3 kannat 600 mils 1.78mm/0.07in ? pitch
Kanta 40 – pin @46.4.1 X kannat
Kanta 22 – pin @46.4.2 20 kannat Putkikanta
Kanta 48 – pin @46.4.2 X kannat Putkikanta
Kanta 64 – pin @46.4.2 X kannat Putkikanta
Kanta 14 – pin @46.5.1 X kannat Wirewrap
Kanta 16 – pin @46.5.2 X kannat Wirewrap
Kanta 18 – pin @46.5.3 X kannat Wirewrap
Kanta 20 – pin @46.6.1 X kannat Wirewrap
Kanta 22 – pin @46.6.1 6 kannat Wirewrap
Kanta 24 – pin @46.6.2 X kannat Wirewrap
Kanta 28 – pin @46.6.3 X kannat Wirewrap
Wirewrap pins @46.6.3 X kannat Wirewrap pins
Kanta 40 – pin @46.7.1 X kannat Wirewrap
PLCC Kanta 28-pin @46.4.3 2 kannat
PLCC Kanta 32-pin @46.4.3 2 kannat
PLCC Kanta 44-pin @46.4.3 40 kannat
PLCC Kanta 52-pin @46.4.3 10 kannat
PLCC Kanta 68-pin @46.4.3 1 kannat
Prosessorin koteloita @46.7.1 X kannat
Juotoskomponentin kantoja @46.7.1 6 kannat 7x2 300-mils
Juotoskomponentin kantoja @46.7.1 18 kannat 7x2 ja 8x2 800-mils
DIP 16 Adapter @46.7.2 2 kannat 16-Pin 300mil socket component adapter
DIP 22 Adapter @46.7.2 66 kannat 22-Pin 300mil to 400mil adapter socket
ZIF-kannat @46.7.3 X kannat
Prosessorikantoja @46.7.3 X kannat
Liittimet
15mm DIN @35.5.2 X liittimet
15mm DIN @35.5.3 X liittimet
2-napaliittimiä @41.5.2 X liittimet
2-napaliittimiä runko @41.5.2 X liittimet
pitkäpinniset 2-päiset rimat @29.2.3 X liittimet
2-riviset rimat @29.2.3 X liittimet
2.54 mm 2-rivinen naarasrima @29.4.2 X liittimet
2.54 mm lyhyt 1-rivinen naarasrima @29.4.2 X liittimet
4-nap plugi ja runko @60.3.3 X liittimet
4-nap PCB JST liitin ja runko johdolla @45.5.1 50+ liittimet JST ZH 1.5mm Straight pin
5-nap Uros/Naaras – johtoliitin @41.6.1 100 liittimet
audio 3.5 mm mono jakki kytkimellä @59.1.1 400 liittimet johdotettava
audio 3.5 mm stereo jakki @59.1.2 240 liittimet PCB
audio 3.5 mm stereo jakki kytkimellä @59.1.3 160 liittimet PCB
audio 3.5 mm stereo jakki kytkimellä @59.2.1 230 liittimet PCB
audio 3.5 mm mono plugi @59.2.2 250 liittimet
audio 3.5 mm stereo plugi @59.2.3 5 liittimet
audio 3.5 mm stereo plugi @59.2.3 60 liittimet
audio 3.5 mm mono jakki kytkimellä @59.3.1 65 liittimet
audio 2.5 mm mono jakki @59.3.1 70 liittimet
audio 3.5 mm stereo jakki @59.3.1 45 liittimet
audio 3.5 mm mono plugi @59.3.2 7 liittimet metallirunko
audio 2.5 mm stereo plugi @59.3.2 38 liittimet
audio 3.5 mm jatkojakki @59.3.3 50 liittimet
audio 2.5 mm jatkojakki @59.3.3 50 liittimet
audio 6.35 mm plugi @59.4.1 35 liittimet
audio 6.35 mm plugi @59.4.2 35 liittimet
audio 6.35 mm jatkojakki @59.4.3 16 liittimet
audio 6.35 mm jakki @59.4.3 10 liittimet
audio 6.35 mm mono plugi ja jakki @59.5.1 21 liittimet 2-nap/mono
audio 6.35 mm stereo plugi ja jakki @59.5.2 17 liittimet 3-nap/stereo
audio 6.35 mm jakki @59.5.3 27 liittimet 2-nap/mono kytkimellä
audio sekalaiset 6.35 mm plugit @59.6.1 X liittimet
audio sekalaiset mutterit @59.6.1 X liittimet
audio sekalaiset adapterit @59.6.1 X liittimet
audio 4-pin jakki 3.5mm @59.6.1 4 liittimet 4-connector 3.5mm jack panel mount SJ1_43502PM.pdf
audio sekalaiset liittimet @59.6.1 X liittimet
audio neutrik 6.35 mm jakit @59.6.2 8 liittimet np2rcs right angle mono phone plug
audio sekalaiset 6.35 mm jakit @59.6.2 X liittimet
audio sekalaiset @59.6.3 X liittimet Kaiuttimen johtoliittimet
audio RCA johtoliitin @59.7.1 X liittimet
audio RCA jatkoliitin @59.7.2 X liittimet
audio RCA jatkoliitin @59.7.3 X liittimet
audio RCA jatkoliitin @59.8.1 X liittimet
audio RCA laiteliitin 2-nap @59.8.2 X liittimet
audio RCA laiteliitin 1-nap @59.8.3 X liittimet
audio RCA adapterit @59.8.3 X liittimet
audio kaiutinliitin koiras @60.1.1 55 liittimet Johtoliitin
audio kaiutinliitin naaras @60.1.2 100 liittimet Paeneliliitin
audio kaiutinliitin naaras @60.1.3 2 liittimet Johtoliitin
audio kaiutinliitin naaras @60.1.3 10 liittimet Johtoliitin
audio kaiutinliitin koiras @60.1.3 21 liittimet Johtoliitin
audio DIN 5-nap naaras @60.2.1 47 liittimet Paneeliliitin
audio DIN 5-nap naaras @60.2.1 5 liittimet Johtoliitin
audio DIN 5-nap naaras @60.2.2 40 liittimet Johtoliitin, suoja puuttuu
audio DIN 5-nap koiras @60.2.3 28 liittimet Johtoliitin
audio DIN pistoke sekalaiset @60.3.2 X liittimet Johtoliitin
audio DIN sekalaiset @60.3.1 X liittimet Johtoliitin
audio DIN sekalaiset @60.3.3 X liittimet Johtoliitin
DIN sekalaiset @60.4.1 X liittimet Johtoliitin
Banaaniliitin suojakuori @17.7.1 X liittimet
Banaaniliitin koiras @17.7.3 X liittimet
Banaaniliitin koiras @17.8.1 X liittimet
Banaaniliitin RA72 @17.8.3 X liittimet 2.5 x 1.6 mm, DIN 45315/45316
Banaaniliitin kauluksia @17.8.3 X liittimet
Banaaniliitin 2mm @25.9.1 X liittimet
Banaaniliitin 2mm @25.9.2 X liittimet
Banaaniliitin 2mm @25.9.3 X liittimet
Banaaniliitin 2.5mm naaras @25.9.4 X liittimet
Banaaniliitin naaras @17.7.2 X liittimet Metallirunko
Banaaniliitin naaras @17.7.3 X liittimet Metallirunko
Banaaniliitin naaras @17.8.2 X liittimet Sormiruuvi johtokiinnitykselle
Banaaniliitin turvabanaani naaras @17.6.1 42 liittimet
Banaaniliitin jatko @17.6.1 X liittimet
Banaaniliitin naaras @17.6.1 X liittimet
BNC-liitin 50 Ohm naaras @36.4.1 10 liittimet paneeliliitin
BNC-liitin 50 Ohm naaras @36.4.1 4 liittimet johtoliitin
BNC-liitin 50 Ohm koiras @36.4.2 20 liittimet
BNC-liitin 75 Ohm koiras naaras @36.4.2 3 liittimet
BNC-liitin T-liitin @36.4.3 14 liittimet
BNC liitin adaptereita @36.4.3 7 liittimet f-f, m-m, m-?, f-rca-m
BNC päätevastus 50 Ohm @36.4.3 4 liittimet Päätevastus
Centronics HD 36pin @45.4.2 2 liittimet
Centronics lattakaapeliliittimiä @45.3.1 X liittimet
DB-25 lattakaapeliliittimiä @45.3.1 X liittimet
DE-9 lattakaapeliliittimiä @45.3.1 X liittimet
Centronics 50pin @45.3.2 X liittimet
Centronics 50pin iso liitin @45.4.2 X liittimet
Centronics muuntimia @45.3.2 X liittimet 36-Pin F-F, 36-Pin M-M, 36-Pin-DB-25
DC 5.5mm liittimet koiras+naaras @17.1.2 5x2 liittimet DC-liitinparit johdolla
DC 5.5mm liittimet koiras @17.6.2 X liittimet
DC 5.5mm liittimet naaras @17.6.2 X liittimet 2.5mm ja 2.1mm
DC 5.5mm liittimet naaras @17.6.2 7 liittimet 761KS17 Naaras 5.5/2.5mm johtoon Datasheet
DC liittimet koiras @17.6.3 X liittimet Liittimet alle 5.5 mm
D-liitin Muuntimia @36.6.1 X liittimet D-Sub Adapters
D-liitin DE-9 Naaras @36.6.2 X liittimet 5-4
D-liitin DE-9 Koiras @36.6.2 X liittimet 5-4
D-liitin DA-15 Koiras @36.5.3 10 liittimet 15-pin 8-7 PCB 90-Decr.
D-liitin DA-15 Koiras @36.5.3 34 liittimet 15-pin 8-7 PCB 90-Decr.
D-liitin DA-15 Naaras @11.8.3 10 liittimet 15-pin 8-7 PCB 90-Decr. KF22-AI5S-NJ
D-liitin DA-15 Koiras @11.8.3 12 liittimet 15-pin 8-7 Johtoliitin
D-liitin DA-15 Naaras @11.8.3 11 liittimet 15-pin 8-7 Johtoliitin
D-liitin DA-15 Naaras @11.8.3 8 liittimet 15-pin 8-7 PCB 90-Decr.
D-liitin DA-26 Koiras @36.5.2 4 liittimet 26-pin 9-9-8 Johtoliitin
D-liitin DA-26 Naaras @36.5.2 5 liittimet 26-pin 9-9-8 Johtoliitin
D-liitin DA-26 Koiras @36.5.2 6 liittimet 26-pin 9-9-8 PCB
D-liitin DA-26 Naaras @36.5.2 12 liittimet 26-pin 9-9-8 PCB
D-liitin DA-26 Naaras @36.5.2 7 liittimet 26-pin 9-9-8 PCB 90-Decr.
D-liitin DB-25 Wirewrap koiras,naaras @11.8.2 3 liittimet 25-Pin 12-13 wirewrap liitin
D-liitin DE-15 Koiras @11.8.2 5 liittimet 15-Pin 5-5-5 johtoliitin
D-liitin DE-15 Naaras @11.8.2 9 liittimet 15-Pin 5-5-5 johtoliitin
D-liitin asennustarvikkeita @36.5.1 X liittimet
AMP 749193-2 @36.5.1 3 liittimet SCSI-2 Liitin Datasheet
D-Virtaliitin? @36.5.1 7 liittimet 3-napainen virtaliitin
DIN-41612 liittimiä @41.3.1 X liittimet DIN-41612 Wikipedia
Erikoisliittimiä @61.6.3 X liittimet 5, 10, 12 pinnisiä
Ethernet liittimiä @39.2.1 X liittimet Sekalaisia johtoon ja paneliin
Ethernet RJ45 socket @35.1.1 100 liittimet PCB Ethernet Steward Connectors SS-60000-009 Rev.D
Ethernet RJ45 socket @35.1.2 21 liittimet PCB Ethernet Steward Connectors SS-60000-009 Rev.D
Ethernet RJ45 socket @35.1.2 60 liittimet PCB Ethernet
Ethernet RJ45 socket @35.1.3 48 liittimet PCB Ethernet with leds
Ethernet RJ45 socket lattakaapelilla @35.1.3 6 liittimet
Ethernet RJ45 socket @35.1.3 X liittimet PCB Sekalaiset
Ethernet RJ45 socket @35.2.1 24 liittimet TE 5557786-1 PCB Ethernet 5557786.pdf
Ethernet RJ45 socket @35.2.1 24 liittimet Amphenol RJHSE-5340 PCB Ethernet RJHSE-5380.pdf
Ethernet? 8-nap johtoliitin @35.3.3 8 liittimet Phoenix SACC-MSX-8QO SH ETH SCO
Ethernet RJ-45 8-pin johtoon @35.3.1 5 liittimet RJ-45 8-pin johtoon
Ethernet RJ45 moduleita johtoon @35.2.2 28 liittimet
Ethernet RJ45 moduleita johtoon @35.2.3 11 liittimet
Ethernet Feedthrough @35.3.2 6 liittimet Paneliin Neutrik NE8FDP Datasheet Catalog
Ethernet jatkoliitin @35.3.2 3 liittimet
ATX-liitin @25.12.4 X liittimet
RJ-45 4-pin @35.3.1 4 liittimet RJ-45 4-pin puristusliitin johtoon
RJ-45 6-pin @35.3.1 9 liittimet RJ-45 6-pin puristusliitin johtoon
RJ-45 8-pin @35.3.1 22 liittimet RJ-45 8-pin puristusliitin johtoon
RF-liittimiä @29.2.2 X liittimet
Ruuviliittimiä PCB @61.2.1 X liittimet .3in jako, 2-napainen, jatkettava Ruuviliitin-0.3in.jpg
ST1210/S2 @35.7.1 1 liittimet 2-pin johtoon
ST1211/S2 @35.7.1 1 liittimet 2-pin johtoon
ST1210/S3 @35.7.1 1 liittimet 3-pin johtoon
ST1211/S3 @35.7.1 1 liittimet 3-pin johtoon
ST1210/S6 @35.7.1 1 liittimet 6-pin johtoon
ST1211/S6 @35.7.1 1 liittimet 6-pin johtoon
ST1212/P2 @35.7.1 1 liittimet 2-pin paneliin
ST1212/P3 @35.7.1 1 liittimet 3-pin paneliin
ST1212/P6 @35.7.1 1 liittimet 6-pin paneliin
Hirschmann ELWIKA 4012 @65.1.3 4 liittimet
Hyppylanka @29.5.1 X liittimet
Hyppylanka @29.7.1 X liittimet
IDC 6pin @29.1.2 X liittimet
IDC @29.1.3 X liittimet
IDC @29.1.4 X liittimet
IDC @29.1.5 X liittimet
IDC 2x11pin korttiliitin naaras @29.2.1 59 liittimet
IDC 2x13pin korttiliitin naaras @29.2.1 20 liittimet
IDC 2x13pin korttiliitin koiras @29.2.1 10 liittimet
IDC 2x13pin 90-astetta korttiliitin koiras @46.8.3 50 liittimet
IDC 6pin PCB @39.4.1 230 liittimet Amphenol 69168-106HLF Datasheet
IDC 14pin PCB @39.4.1 21 liittimet Amphenol 75869-102LF Datasheet
IDC 2x3pin 2.0mm pitch @39.4.1 X liittimet
IDC 14pin @39.4.2 X liittimet
IDC 26pin @39.4.2 X liittimet
IDC 34pin @39.4.3 X liittimet
IDC 40pin @39.5.3 X liittimet PCB koiras
IDC 50pin @39.4.2 X liittimet
PCB liitin @29.5.5 X liittimet .15in = 3.81mm 6-nap
IEC-virtaliitin naaras @37.5.1 X liittimet
IEC-virtaliitin uros @39.7.1 X liittimet
IEC-virtaliitinrunkoja @39.7.1 X liittimet
IEC-virtaliitinrunkoja @39.1.1 X liittimet Kytkimillä yms.
Jumpperit oikosulkupalat @29.3.5 X liittimet
Juotostorni @61.7.3 X liittimet
Kaapelikengät @61.7.1 X liittimet
Kaapelikengät @61.7.2 X liittimet
Kortinreunaliittimet @39.5.2 X liittimet
Kortinreunaliittimet @39.5.3 X liittimet
Lamppujen liittimiä @13.5.2 2 liittimet
Lattakaapeliliittimet @45.1.1 X liittimet 14-Pin Female + Male
Lattakaapeliliittimet @45.4.1 X liittimet 26-Pin PCB
Lattakaapeliliittimet @45.4.1 X liittimet 10-Pin PCB
Lattakaapeliliittimet @45.5.2 X liittimet
Lattakaapeliliittimet @45.6.1 X liittimet
Lattakaapeliliittimet @61.6.1 X liittimet
Lattakaapeliliittimet @61.6.2 X liittimet
Lattakaapeliliittimet @61.6.3 X liittimet
Lattakaapeli ohut @46.8.1 X liittimet Ohuita lattakaapeleita
Liitinrimoja @41.1.1 X liittimet Piikkirimoja 1x40 uros
Liittimet USB Firewire Opt. @29.6.3 X liittimet
Liittimet USB @29.5.2 X liittimet
Liittimet USB Adapter @29.5.2 1 liittimet USB-mini --> USB-micro
Liittimiä SD-kortti @29.5.2 3 liittimet 24mmx32mm
Liittimiä 8-pin @29.7.3 X liittimet
Liittimiä 2x5pin piikkirima naaras @29.7.3 50 liittimet
Liittimiä @29.6.1 X liittimet
Liittimiä @35.4.1 X liittimet
RJ11 4p4c @35.4.1 X liittimet Steward Modular Plug 4p4c 940-SP-3044 940-SP-3044.pdf
Liittimiä @35.4.2 X liittimet
Liittimiä @60.4.2 X liittimet Sekalaisia liittimiä
Liittimiä @60.4.2 1 liittimet R04-R5M PLUG,PANEL 5-WAY 2A 300V, R04-P5F SOCKET 5-WAY
Liittimiä @60.4.2 1 liittimet HR10-7R-6P,PLUGPANEL 6-POLE 2A 300V, HR10-7P-6S SOCKET 6-POLE
MOLEX 0874210000 @25.10.2 200 liittimet Connector Socket 24-26AWG Crimp Tin (with MOLEX 0874390600) Datasheet
MOLEX 0874390600 @25.10.2 20 liittimet Connector Housing 6POS 1.5mm W/RAMP (with MOLEX 0874210000) Datasheet
MTA-100 4-nap koiras PCB-liitin @29.4.5 80 liittimet 2.54mm TE 640456-4
MTA-100 6-nap koiras PCB-liitin @29.4.5 18 liittimet 2.54mm TE 640455-6
MTA-100 6-nap naaras liitin @29.4.5 62 liittimet 2.54mm 1x6-NAP IDC F/T 26AWG TE 3-644564-6
Nappiparistopidike @29.6.4 X liittimet Pariston pitimiä useita kokoja
Nappiparistopidike @29.6.5 X liittimet Pariston pitimiä useita kokoja
Paristonpitimiä AA @06.3.1 X liittimet AA
Paristonpitimiä CR24xx @06.3.1 X liittimet CR24xx
Patteriliitin 9V @17.6.2 8 liittimet
PCB liitin @61.7.3 X liittimet 6.3 x 8 x 0.8 mm
PCB liitin @61.7.3 X liittimet 6.3 x 14 x 0.8 mm
PCB liitin @65.2.2 X liittimet 6.3 x 14 x 0.8 mm
PCB Ruuviliittimiä @65.2.2 300 liittimet 5.0mm jako, 2-napainen, jatkettava DG306-5.0-02P-12-00A(H) DG306-5.0.pdf Kuva
Phoenix 2x5 pin naaras @46.8.3 45 liittimet DMC 1,5/5-GTF-3,5-LR P20THR
Piikkirima 2x1 2.0mm @29.3.5 7 liittimet
Piikkirima 2x1 90C 2.0mm @29.3.5 100 liittimet M22-2030205 Datasheet
Molex liitin @29.4.3 36 liittimet MOLEX 43045-0221 2-pos 3mm Connection Header R/A TIN 43045.pdf 43045_sd.pdf
Molex liitin @29.4.3 23 liittimet MOLEX 43045-0421 4-pos 3mm Connection Header R/A TIN 43045.pdf 43045_sd.pdf
Piikkirimoja naaras 2-rivinen @17.1.1 X liittimet
Piikkirimoja koiras 2-rivinen @17.1.2 X liittimet
Piikkirimoja naaras 1-rivinen @17.1.3 X liittimet
Piikkirimoja koiras 90C-kulma 2x34 @17.2.1 X liittimet
Piikkirimoja @17.2.2 X liittimet Piikkirimoja Arduino
Piikkirimoja @17.2.2 X liittimet Piikkirimoja 2-rivisiä uros pitkäpiikkisiä
Piikkirimoja 1x6-pin @17.2.3 20 liittimet Piikkirimoja Arduino
Piikkirimoja 1x10-pin @17.2.3 20 liittimet Piikkirimoja Arduino
Piikkirimoja 1x15-pin @17.2.3 20 liittimet Piikkirimoja Arduino
Piikkirimoja @29.1.1 X liittimet
Piikkirimoja @29.3.1 X liittimet Suora 1-rivinen
Piikkirimoja @29.3.2 X liittimet Suora 1-rivinen
Piikkirimoja @29.3.3 X liittimet Suora 1-rivinen
Piirilevyliitin PSS 254/2G @25.11.2 20 liittimet 2.54mm riviliitin piirilevylle, 2-pin, suora
Piirilevyliitin PSS 254/2W @25.11.2 20 liittimet 2.54mm riviliitin piirilevylle, 2-pin, kulma
Piirilevyliitin PSS 254/3W @25.11.2 20 liittimet 2.54mm riviliitin piirilevylle, 3-pin, kulma
Piirilevyliitin PSS 254/4G @25.11.2 20 liittimet 2.54mm riviliitin piirilevylle, 4-pin, suora
Piirilevyliitin PSS 254/4W @25.11.2 20 liittimet 2.54mm riviliitin piirilevylle, 4-pin, kulma
Piirilevyliitin PSS 254/5G @25.11.2 20 liittimet 2.54mm riviliitin piirilevylle, 5-pin, suora
Piirilevyliitin PSS 254/5W @25.11.3 20 liittimet 2.54mm riviliitin piirilevylle, 5-pin, kulma
Piirilevyliitin PSS 254/8G @25.11.3 20 liittimet 2.54mm riviliitin piirilevylle, 8-pin, suora
Piirilevyliitin PSS 254/8W @25.11.3 20 liittimet 2.54mm riviliitin piirilevylle, 8-pin, kulma
Piirilevyliitin PSS 254/10G @25.11.3 30 liittimet 2.54mm riviliitin piirilevylle, 10-pin, suora
Piirilevyliitin PSS 254/10W @25.11.3 20 liittimet 2.54mm riviliitin piirilevylle, 10-pin, kulma
Piirilevyliitin PSS 254/6G @25.11.3 5 liittimet 2.54mm riviliitin piirilevylle, 6-pin, suora
Piirilevyliitin PSS 254/6W @25.11.3 5 liittimet 2.54mm riviliitin piirilevylle, 6-pin, kulma
Piirilevyliitin PSS 254/20G @25.11.4 20 liittimet 2.54mm riviliitin piirilevylle, 20-pin, suora
Piirilevyn nastoja @29.7.1 X liittimet Testipinnejä, PCB-pinnejä yms.
Probe nastoja @29.7.1 X liittimet RSS-100-CR irtopinnejä RSS-100.pdf
Pinnejä RS-232 liittimeen @29.7.3 X liittimet
Pogo-pins @29.7.4 X liittimet
Pogo-pins @29.7.5 X liittimet
Pogo-pins @29.7.5 40 liittimet Nokia-1 Battery connector with pogo pins
PS2-liitin @60.2.2 3 liittimet Näppäimistö/Hiiriliitin
Retroliittimiä @28.2.1 X liittimet Sekalaisia vanhoja liittimiä
Rima 90° naaras 6x1 @29.2.4 10 liittimet
Rima 90° koiras @29.2.4 X liittimet
Rima 90° x 2 koiras @29.2.5 X liittimet
Rima, 1 rivinen @29.4.4 X liittimet
Rima, PCB 5-pin 1-rivi kanta @29.5.3 X liittimet
Riviliitin @13.1.1 X liittimet
Riviliitin @13.1.2 X liittimet
Riviliitin @13.1.3 X liittimet
Riviliitin @13.2.1 X liittimet
Riviliitin @13.2.2 X liittimet
Riviliitin @13.2.3 X liittimet
Riviliitin @37.1.2 X liittimet
Riviliitin @37.1.3 X liittimet
Riviliitin @37.2.2 X liittimet
Riviliitin @37.3.1 X liittimet
Riviliitin @37.3.3 X liittimet
Riviliitin @37.4.2 X liittimet
Riviliitin @37.4.3 X liittimet
Riviliitin @37.5.3 X liittimet
Riviliitin @37.6.1 X liittimet
Riviliitin @37.6.2 X liittimet
Riviliitin – Naaras @37.4.1 X liittimet
Riviliitin – Naaras @37.5.1 X liittimet
Riviliitin – Naaras @37.5.2 X liittimet
Riviliitin – Uros @37.2.1 X liittimet
Riviliitin – PCB @37.2.3 80 liittimet 3-napainen ruuviliitin
Riviliitin – PCB @37.2.3 27 liittimet 10-napainen ruuviliitin
Riviliitin – PCB @37.2.5 1 liittimet 7-napainen ruuviliitin
Riviliitin – PCB @37.2.5 4 liittimet 9-napainen ruuviliitin
Riviliitin – PCB @37.2.5 7 liittimet 12-napainen ruuviliitin
Riviliitin 2-nap @37.6.3 X liittimet
Riviliittimiä sekalaisia @37.1.1 X liittimet
Riviliittimiä sekalaisia @37.3.2 X liittimet
Riviliittimiä @25.12.1 X liittimet
Riviliittimiä 2.54mm @41.2.1 X liittimet
Ruuviliitin PCB 2-nap 5.0mm @65.2.2 200 liittimet DG306-5.0-02P-12-00A(H) 250V 15A 1.5mm2 DG306-5.0.pdf
Ruuviliitin PCB 4-nap 3.5mm @65.2.2 250 liittimet YO0401500000G 300V 10A 1.5mm2 YO0401500000G.pdf
Scotchlok UY2 liittimiä @37.8.1 300 liittimet Puristettava geeliliitin 2-nap Datasheet
Sekalaisia liittimiä @39.3.2 X liittimet
Sekalaisia liittimiä @41.2.1 X liittimet
Sokeripaloja @01.1.1 X liittimet
Sokeripaloja @01.1.2 X liittimet
Sokeripaloja @01.2.1 X liittimet
Sokeripaloja @01.2.2 X liittimet
Sokeripaloja @37.7.1 X liittimet
Sokeripaloja @37.7.2 X liittimet
Sokeripaloja @37.7.3 X liittimet
Tiheät rimat ja rungot @29.3.4 X liittimet
Testipinnit @21.10.1 X liittimet
Liitinpinnejä puristettavia @61.8.1 X liittimet 516290590.pdf
Wago 221-412 @38.1.2 X liittimet 2-paikkainen Datasheet
Wago 221-413 @38.1.2 X liittimet 3-paikkainen Datasheet
Wago 221-415 @38.1.2 X liittimet 5-paikkainen Datasheet
Wago Sekalaiset @37.3.2 X liittimet
0.1uH – 0.56uH @58.1.1 X kela
0.68uH – 2.7uH @58.1.2 X kela
4.7uH @58.1.3 120 kela 4.7uH 3.1A 22mOhm
4.7uH @58.1.4 13 kela 4.7uH 3.1A 22mOhm Bourns RLB0912-4R7M
10uH @58.1.4 8 kela 10uH 2.7A 48mOhm Bourns RLB0914-100K
3.3uH – 10uH @58.2.1 X kela
15uH – 68uH @58.2.2 X kela
82uH – 330uH @58.2.3 X kela
470uH – 2.2mH @58.2.4 X kela
82mH – 100mH @58.3.1 X kela
KS AL Fe @58.3.2 X kela
KS AL1 @58.3.3 X kela
KS AL2 @58.3.4 X kela
KS CU1 @58.4.1 X kela
KS S.ruuvi @58.4.2 X kela
KS S.ruuvi @58.4.3 X kela
Kelat AM/VHF @58.4.4 X kela
Kelat AM/VHF @58.5.1 X kela
Kelat Sekal. @58.5.2 X kela
Kelat VHF I-III @58.5.3 X kela
Potcoreruuvit @58.5.4 X kela
15uH @58.7.1 3 kela
22uH 3A @58.7.1 20 kela EPCOS 565-2
33uH @58.6.1 46 kela 33uH 3.5A INKOS IN77.50-330M-00 IN7750.pdf
75uH @58.6.4 4 kela
100uH @58.6.2 250 kela
100uH @58.8.4 500 kela 100 µH 1% 85mA RF B78108-T1104-K B78148T.pdf
200 µH @58.6.3 20 kela
200 µH @58.6.4 5 kela
270uH @58.7.1 5 kela
300uH @58.7.1 4 kela
0.68mH @58.7.2 10 kela
0.68mH @58.7.3 9 kela
0.68mH @58.7.4 8 kela
7446823003 2.7mH @58.8.1 1 kela Wurth Common Mode Choke Datasheet
744825510 10mH @58.8.1 2 kela Wurth Common Mode Choke Datasheet
RN112-4/02 @58.8.1 27 kela Current compensated choke Datasheet
RN212-4/02 @58.8.2 37 kela Current compensated choke Datasheet
RN212-4/02 @58.8.3 36 kela Current compensated choke Datasheet
Muuntaja @58.9.1 17 kela
Muuntajia 750312723 @58.9.1 3 kela Wurth Flyback Transformer 750312723.pdf
Ferriittejä @58.10.1 X kela
Ferriittejä @58.10.2 X kela
Ferriittejä @58.10.3 X kela
Ferriittejä @58.10.4 X kela
Toroids @58.11.1 X muut Toroid cores
Toroids @58.11.2 X muut Toroid cores
Toroids @58.12.1 X muut Toroid cores
Verkkosuodatin @58.12.2 18 muut Schaffner FN401-08/02
Kiteet ja oskillaattorit
32.768 kHz @27.8.1 49 kide
32.768 kHz @27.8.1 2 kide KDS0A
32.768 kHz @27.8.1 4 kide KDS1L
32.768 kHz @27.8.1 2 kide S333
32.768 kHz @27.8.1 1 kide S633
CX1H 10.000 kHz @27.8.2 8 kide 10.000H DX Tuning fork resonator Datasheet
CX1H 16.000 kHz @27.8.2 5 kide 16.000H FJ Tuning fork resonator Datasheet
CX1H 31.500 kHz @27.8.2 5 kide 31.500H BT Tuning fork resonator Datasheet
CX1H 100.00 kHz @27.8.2 4 kide 100.00V EU Tuning fork resonator Datasheet
CX1H 1.0 MHz @27.8.2 13 kide 1.0 Tuning fork resonator Datasheet
1.8432 MHz @27.8.2 7 kide 1.8432 MP-2 M-TRON
2.4576 MHz @27.8.3 35 kide 2.4576 KEY
2.4576 MHz @27.8.3 18 kide ECLIPTEK ECX-222 2.4576MHz
2.4576 MHz @27.8.3 3 kide TXC 2.4576 32
2.45760 MHz @27.8.3 1 kide 2457.60 4414168 11TQ86 K
2.4576 MHz @27.8.3 1 kide 105300 2.4576 TQE 8839
3.0000 MHz @27.8.4 3 kide Kideoskillaattori MCO-1415B 3.0000 MHz TQE 8850
3.579 MHz @27.8.4 3 kide I3.579H G7
3.5795 MHz @27.8.4 1 kide EQ 3579.5 17pF
3.579545 MHz @27.8.4 3 kide 3.579545 TQ5300
3.579545 MHz @27.8.4 2 kide 3.579545 Sunny
4.000 MHz @27.8.5 33 kide TQ5300 4.000
4.000 MHz @27.8.5 3 kide 4000.000kHz SEL2589
4.000 MHz @27.8.5 2 kide RALTRON 4.000 - S
4.000 MHz @27.8.5 2 kide 4.000 TQE
4.000 MHz @27.8.5 1 kide EQ 4000.00 20pF
4.000 MHz @27.8.5 1 kide 4.000 00 TEW84E
4.000 MHz @27.8.5 1 kide 4.000 ???
4.096 MHz @27.9.1 70 kide 4.096 TQ5300
4.0960 MHz @27.9.1 1 kide MC01500 B 4.0960TQG201
4.194304 MHz @27.9.1 20 kide VIGOR 4.194304
4.433 MHz @27.9.2 40 kide 4421 31-58 B///D
4.9152 MHz @27.9.3 7 kide TXC 4.9152 S
4.9152 MHz @27.9.3 3 kide T Q5330 4.9152
4.9152 MHz @27.9.3 11 kide RDX4.91 4.9152M RDX4.915
5.185 MHz @27.9.3 1 kide 5.185 TQ5300
6.000 MHz @27.9.3 2 kide
6.144 MHz @27.9.4 2 kide ECS-61-18-4XEN ECSC061ENX
6.144 MHz @27.9.4 2 kide Kideoskillaattori MC01425B 6.144 MHz TQG
6.144 MHz @27.9.4 40 kide
6.144 MHz @27.9.4 9 kide 6.144 TQ5300
6.400 MHz @27.9.4 2 kide Kideoskillaattori SRQ-0101/50 6.400 MHz
7.03000 MHz @27.9.5 10 kide BOMAR-06 NORCAL 7.03000
7.040 MHz @27.9.5 10 kide 7.040 CTZ 08
7.3728 MHz @27.9.5 29 kide Kideoskillaattori 7.3728 MHz KEY
7.3728 MHz @27.9.5 7 kide Kideoskillaattori CRYSTEK 7.3728CCO-21S
7.3728 MHz @27.9.5 1 kide 7.3728
8.000 MHz @27.10.1 1 kide A080F6F most likely 8.000 MHz
8.000 MHz @27.10.1 1 kide 8.000
8.000 MHz @27.10.1 2 kide KDS 8.000
8.000 MHz @27.10.1 1 kide ITT 8000.000 kHz
8.000 MHz @27.10.1 5 kide 8B000G1AA2 8B000G1AB2 most likely 8 MHz
8.000 MHz @27.10.1 16 kide 8B000G1AC2 most likely 8 MHz
8.0640 MHz @27.10.3 2 kide 11KVG90 8064.0 kHz 4414893
8.86720 MHz @27.10.2 1 kide 8.86720 TEW86L
9.830400 MHz @27.10.2 1 kide Kideoskillaattori CK1100MC 9.830400 MHz
10.000 MHz @27.10.2 2 kide 10.0000 IQDTZ, 10.000
10.000 MHz @27.10.2 2 kide AQ10.000
10.2400 MHz @27.10.2 5 kide A10.2400 SDK 7H3
10.24 MHz @27.10.2 1 kide 10.24MHz 86 4TK
11.0592 MHz @27.10.3 1 kide 11.0592
11.0592 MHz @27.10.3 5 kide 11.0592 NDK
11.0592 MHz @27.10.3 8 kide 11.0592 TQ5300 11.0592
12.000 MHz @27.10.5 1 kide Kideoskillaattori CK1100MC 12.000000MHz
12.000 MHz @27.10.5 2 kide 12.000, 12.000 SUNNY
12.288 MHz @27.10.5 1 kide Kideoskillaattori KX0-01-1 12.288 MHz
12.288 MHz @27.10.5 1 kide 12.288
12.288 MHz @27.10.5 20 kide 12.288 MHz KEY
12.288 MHz @27.10.5 2 kide M12.288
14.31818 MHz @27.11.2 2 kide AQ14.31818
14.7456 MHz @27.11.2 17 kide Kideoskillaattori 14.7456 MHz KEY
14.7456 MHz @27.11.2 11 kide Kideoskillaattori ECLIPTEK EC1100CHS 14.7456 MHz
15.000 MHz @27.11.3 41 kide TQ5300 15.000-30
16.000 MHz @27.11.4 6 kide 16.000
16.000 MHz @27.11.4 10 kide 160
16.000 MHz @27.11.4 60 kide XGH 16.0000AH3
16.000 MHz @27.11.4 37 kide MC 16.0000
16.000 MHz @27.11.4 9 kide H16.0000G7C
16.1280 MHz @27.11.5 1 kide Kideoskilaattori 1329 16.1280
16.3840 MHz @27.11.5 2 kide Kideoskilaattori AOR 16.3840 SCC
16.67 MHz @27.11.5 5 kide E16.670
16.90 MHz @27.11.5 14 kide 16.9SC6k ???
18.432 MHz @27.11.5 4 kide TQ5300 18.432
20.000 MHz @27.12.1 3 kide
22.1184 MHz @27.12.1 1 kide X22.1184
24.000 MHz @27.12.1 2 kide 24.000 TQ5300, 24.000
24.1920 MHz @27.12.1 1 kide 7050B JPN
25.000 MHz @27.12.1 2 kide 25.0F0K, 25.000
29.8 MHz @27.12.2 90 kide D289L1I
32.000 MHz @27.12.2 24 kide TXC 32.000 32FED
43.3916 MHz @27.12.2 100 kide D43.3L1I
48.000 MHz @27.12.2 1 kide 48.000
25.0000 MHz @27.12.3 6 kide Kideoskillaattori 1384 25.0000 64 1 CHN
30.00000 MHz @27.12.3 1 kide Kideoskillaattori CK1100MC 30.00000MHz
32.000 MHz @27.12.3 2 kide Kideoskillaattori IQXO-350C 32.0 Datasheet
33.333 MHz @27.12.3 1 kide Kideoskillaattori TXC 33.333MHz
40.000 MHz @27.12.3 2 kide Kideoskillaattori IQXO-500C 40.0 Datasheet
40.000 MHz @27.12.3 2 kide Kideoskillaattori CK1100MC 40.000000MHz
40.000 MHz @27.12.3 2 kide Kideoskillaattori MC0-1425B 40.000 MHz
44.000 MHz @27.12.3 1 kide Kideoskillaattori TCO-711A
50.0000 MHz @27.12.3 1 kide Kideoskillaattori IOXO-22C
50.0000 MHz @27.12.3 1 kide Kideoskillaattori IOXO-500C
60.0 MHz @27.12.3 6 kide Kideoskillaattori Dale XO-43B/60.0 MHz
Keraamiset suotimet @27.12.3 X kide
Kiteet @27.12.4 X kide Kiinnikkeet ja sekalaiset kiteet
Kiteet @27.12.5 X kide Sekalaiset kiteet
0.1 uF 50V @30.1.1 8 kondensaattori
0.1 uF 50V @30.1.1 13 kondensaattori
0.1 uF 63V @30.1.1 150 kondensaattori
0.33 uF 63V @30.1.1 4 kondensaattori
0.47 uF 100V @30.1.1 88 kondensaattori
1 uF 50V @30.1.2 3 kondensaattori
1 uF 50V @30.1.2 30 kondensaattori
1 uF 63V @30.1.2 12 kondensaattori
1 uF 100V @30.1.2 68 kondensaattori
2.2 uF 50V @30.1.3 16 kondensaattori
2.2 uF 50V @30.1.3 66 kondensaattori
2.2 uF 63V @30.1.3 13 kondensaattori
2.2 uF 250V @30.1.3 12 kondensaattori
2.2 uF 100V @30.1.3 200 kondensaattori
3.3 uF 50V @30.1.4 100 kondensaattori
3.3 uF 100V @30.1.4 18 kondensaattori
3.3 uF 200V @30.1.4 2 kondensaattori
4.7 uF 50V @30.2.1 170 kondensaattori
4.7 uF 50V @30.2.1 110 kondensaattori
4.7 uF 50V @30.2.2 12 kondensaattori
4.7 uF 50V @30.2.2 80 kondensaattori
4.7 uF 50V @30.2.2 24 kondensaattori
4.7 uF 63V @30.2.2 13 kondensaattori
4.7 uF 63V @30.2.2 50 kondensaattori
4.7 uF 100V @30.2.2 11 kondensaattori
10 uF 16V @30.2.3 25 kondensaattori
10 uF 25V @30.2.3 54 kondensaattori
10 uF 25V @30.2.3 127 kondensaattori
10 uF 35V @30.2.4 12 kondensaattori
10 uF 35V @30.2.4 9 kondensaattori
10 uF 40V @30.2.4 87 kondensaattori
10 uF 50V @30.2.4 60 kondensaattori
10 uF 63V @30.3.1 75 kondensaattori
10 uF 63V @30.3.1 4 kondensaattori
10 uF 63V @30.3.1 27 kondensaattori
10 uF 63V @30.3.2 28 kondensaattori
10 uF 100V @30.3.2 2 kondensaattori
10 uF 100V @30.3.2 15 kondensaattori
10 uF 100V @30.3.3 80 kondensaattori
22 uF 16V @30.4.1 75 kondensaattori
22 uF 16V @30.4.1 180 kondensaattori
22 uF 16V @30.4.2 150 kondensaattori
22 uF 16V @30.4.3 40 kondensaattori
22 uF 16V @30.4.3 100 kondensaattori
22 uF 16V @30.4.3 45 kondensaattori
22 uF 16V @30.4.3 33 kondensaattori
22 uF 25V @30.4.4 100 kondensaattori
22 uF 50V @30.4.4 67 kondensaattori
22 uF 50V @30.4.4 70 kondensaattori
22 uF 63V @30.4.4 51 kondensaattori
22 uF 50V @30.5.1 17 kondensaattori
22 uF 100V @30.5.1 18 kondensaattori
33 uF 16V @30.5.2 130 kondensaattori
33 uF 16V @30.5.3 2 kondensaattori
33 uF 25V @30.5.3 2 kondensaattori
33 uF 35V @30.5.4 110 kondensaattori
33 uF 50V @30.5.4 200 kondensaattori
47 uF 16V @30.6.1 16 kondensaattori
47 uF 16V @30.6.1 21 kondensaattori
47 uF 16V @30.6.1 250 kondensaattori
47 uF 16V @30.6.2 150 kondensaattori
47 uF 16V @30.6.3 9 kondensaattori
47 uF 16V @30.6.3 20 kondensaattori
47 uF 16V @30.6.3 11 kondensaattori
47 uF 16V @30.6.3 5 kondensaattori
47 uF 25V @30.6.4 2 kondensaattori
47 uF 35V @30.6.4 2 kondensaattori
47 uF 50V @30.6.4 22 kondensaattori
47 uF 63V @30.6.4 4 kondensaattori
47 uF 64V @30.6.4 8 kondensaattori
47 uF 100V @30.7.1 24 kondensaattori
47 uF 100V @30.7.1 5 kondensaattori
50 uF 15V @30.7.2 11 kondensaattori
50 uF 40V @30.7.2 10 kondensaattori
50 uF 100V @30.7.2 1 kondensaattori
68 uF 10V @30.7.3 5 kondensaattori
68 uF 25V @30.7.3 22 kondensaattori
68 uF 100V @30.7.3 11 kondensaattori
100 uF 10V @30.7.4 21 kondensaattori
100 uF 16V @30.7.4 78 kondensaattori
100 uF 16V @30.7.4 80 kondensaattori
100 uF 16V @30.7.4 16 kondensaattori
100 uF 16V @42.1.1 100 kondensaattori
100 uF 16V @42.1.2 88 kondensaattori
100 uF 16V @42.1.2 80 kondensaattori
100 uF 20V @30.8.1 3 kondensaattori
100 uF 25V @30.8.1 13 kondensaattori
100 uF 25V @30.8.1 2 kondensaattori
100 uF 25V @30.8.1 26 kondensaattori
100 uF 25V @30.8.1 3 kondensaattori
100 uF 35V @30.8.2 10 kondensaattori
100 uF 40V @30.8.2 28 kondensaattori
100 uF 40V @30.8.2 14 kondensaattori
100 uF 50V @30.8.3 7 kondensaattori
100 uF 63V @44.2.1 38 kondensaattori
100 uF 63V @30.8.3 5 kondensaattori
100 uF 64V @30.8.3 3 kondensaattori
100 uF 100V @30.8.3 2 kondensaattori
120 uF 16V @30.8.4 48 kondensaattori
120 uF 35V @30.8.4 84 kondensaattori
120 uF 35V @30.9.1 44 kondensaattori
120 uF 35V @30.9.1 70 kondensaattori
120 uF 35V @42.1.1 70 kondensaattori
150 uF 25V @30.9.2 2 kondensaattori
180 uF 25V @30.9.2 26 kondensaattori
200 uF 10V @42.1.3 150 kondensaattori
220 uF @30.9.4 5 kondensaattori
220 uF 16V @30.9.3 86 kondensaattori
220 uF 16V @30.9.3 32 kondensaattori
220 uF 16V @30.9.3 8 kondensaattori
220 uF 10V @30.9.3 13 kondensaattori
220 uF 16V @30.9.4 16 kondensaattori
220 uF 16V @30.9.4 2 kondensaattori
220 uF 16V @42.2.1 6 kondensaattori
220 uF 16V @42.2.1 3 kondensaattori
220 uF 16V @42.2.2 96 kondensaattori
220 uF 16V @42.2.3 94 kondensaattori
220 uF 25V @30.10.1 34 kondensaattori
220 uF 25V @30.10.1 10 kondensaattori
220 uF 25V @30.10.1 6 kondensaattori
220 uF 25V @30.10.1 3 kondensaattori
220 uF 25V @42.2.1 18 kondensaattori
220 uF 35V @30.10.2 9 kondensaattori
220 uF 35V @30.10.2 5 kondensaattori
220 uF 35V @30.10.2 70 kondensaattori
220 uF 35V @42.2.1 50 kondensaattori Rubycon 105C
220 uF 35V @42.2.2 150 kondensaattori
220 uF 50V @30.10.3 85 kondensaattori
220 uF 63V @30.10.3 6 kondensaattori
220 uF 70V @30.10.3 3 kondensaattori
250 uF 16V @42.3.1 85 kondensaattori
250 uF 70V @30.10.4 1 kondensaattori
330 uF 10V @30.11.1 3 kondensaattori
330 uF 16V @30.11.1 6 kondensaattori
330 uF 16V @30.11.2 70 kondensaattori
330 uF 25V @30.10.4 30 kondensaattori
330 uF 25V @30.10.4 40 kondensaattori
330 uF 25V @30.11.1 5 kondensaattori
330 uF 25V @30.11.3 160 kondensaattori
330 uF 35V @30.11.1 3 kondensaattori
330 uF 40V @30.11.1 4 kondensaattori
330 uF 50V @30.11.2 20 kondensaattori
470 uF 10V @42.3.2 70 kondensaattori
470 uF 10V @42.3.3 70 kondensaattori
470 uF 12V @31.6.4 13 kondensaattori
470 uF 16V @42.4.1 80 kondensaattori
470 uF 16V @30.11.4 29 kondensaattori
470 uF 16V @30.11.4 100 kondensaattori
470 uF 16V @30.12.1 100 kondensaattori
470 uF 16V @30.12.2 16 kondensaattori
470 uF 16V @30.12.2 10 kondensaattori
470 uF 16V @30.12.3 27 kondensaattori
470 uF 16V @30.12.3 8 kondensaattori
470 uF 16V @30.12.3 6 kondensaattori
470 uF 16V @30.12.3 40 kondensaattori
470 uF 16V @30.12.4 4 kondensaattori
470 uF 16V @30.12.4 2 kondensaattori
470 uF 16V @30.12.4 1 kondensaattori
470 uF 25V @31.6.1 30 kondensaattori
470 uF 25V @31.6.1 11 kondensaattori
470 uF 25V @31.6.2 14 kondensaattori
470 uF 25V @31.6.2 79 kondensaattori
470 uF 25V @42.4.2 32 kondensaattori
470 uF 35V @42.4.3 168 kondensaattori
470 uF 35V @31.6.3 7 kondensaattori
470 uF 35V @31.6.3 19 kondensaattori
470 uF 35V @31.6.3 20 kondensaattori
470 uF 40V @42.5.1 53 kondensaattori
470 uF 40V @42.5.2 8 kondensaattori
470 uF 40V @42.5.2 7 kondensaattori
470 uF 50V @42.5.2 26 kondensaattori
470 uF 63-64V @31.6.4 3 kondensaattori
560 uF 35V @31.7.1 2 kondensaattori
680 uF 16V @31.7.2 2 kondensaattori
680 uF 25V @31.7.2 2 kondensaattori
680 uF 40V @31.7.2 5 kondensaattori
680 uF 40V @42.5.3 38 kondensaattori
820 uF 35V @31.7.3 2 kondensaattori
820 uF 35V @31.7.3 60 kondensaattori
1000 uF 10V @31.7.4 20 kondensaattori
820 uF 35V @42.6.1 60 kondensaattori Radial
1000 uF 10V @42.6.1 118 kondensaattori Radial
1000 uF 10V @42.6.2 40 kondensaattori 1000/10V RDE EB-40...+85 C
1000 uF 10V @42.6.3 36 kondensaattori Radial
1000 uF 10V @42.6.3 1 kondensaattori Radial
1000 uF 15V @42.7.1 22 kondensaattori
1000 uF 16V @42.7.1 55 kondensaattori
1000 uF 16V @42.7.2 60 kondensaattori
1000 uF 16V @42.7.3 19 kondensaattori
1000 uF 16V @42.7.3 27 kondensaattori
1000 uF 16V @31.8.1 2 kondensaattori
1000 uF 16V @31.8.1 17 kondensaattori
1000 uF 16V @31.8.1 5 kondensaattori
1000 uF 16V @31.8.2 5 kondensaattori
1000 uF 16V @31.8.2 2 kondensaattori
1000 uF 16V @31.8.2 10 kondensaattori
1000 uF 25V @31.8.2 35 kondensaattori
1000 uF 25V @42.8.1 54 kondensaattori
1000 uF 25V @42.8.2 20 kondensaattori
1000 uF 25V @42.8.2 19 kondensaattori
1000 uF 25V @31.8.3 4 kondensaattori
1000 uF 25V @31.8.3 10 kondensaattori
1000 uF 25V @31.8.3 5 kondensaattori
1000 uF 25V @31.8.3 3 kondensaattori
1000 uF 25V @31.8.4 48 kondensaattori
1000 uF 25V @31.8.4 4 kondensaattori
1000 uF 25V @31.9.2 15 kondensaattori
1000 uF 25V @43.3.1 65 kondensaattori
1000 uF 25V @43.3.3 29 kondensaattori
1000 uF 25V @43.4.1 30 kondensaattori
1000 uF 35V @42.8.3 7 kondensaattori
1000 uF 35V @42.8.3 4 kondensaattori
1000 uF 40V @42.8.3 2 kondensaattori
1000 uF 40V @42.8.3 3 kondensaattori
1000 uF 40V @31.9.1 2 kondensaattori
1000 uF 40V @43.1.1 1 kondensaattori
1000 uF 50V @31.9.1 2 kondensaattori
1000 uF 50V @31.9.1 1 kondensaattori
1000 uF 50V @31.9.1 9 kondensaattori
1000 uF 63V @31.9.1 2 kondensaattori
1000 uF 63V @43.1.1 4 kondensaattori
1200 uF 12V @31.10.1 4 kondensaattori
1500 uF 10V @43.1.2 36 kondensaattori
1500 uF 10V @43.1.3 20 kondensaattori
1500 uF 10V @43.1.3 1 kondensaattori
1500 uF 16V @43.1.3 1 kondensaattori
1500 uF 35V @43.1.3 8 kondensaattori
2200 uF 10V @31.10.2 5 kondensaattori
2200 uF 16V @31.10.2 50 kondensaattori
2200 uF 16V @31.10.3 2 kondensaattori
2200 uF 16V @31.10.3 27 kondensaattori
2200 uF 16V @43.2.1 80 kondensaattori
2200 uF 25V @31.10.4 35 kondensaattori
2200 uF 25V @31.11.1 12 kondensaattori
2200 uF 25V @31.11.2 10 kondensaattori
2200 uF 35V @31.11.2 12 kondensaattori
2200 uF 40V @31.11.2 5 kondensaattori
2200 uF 50V @31.12.1 6 kondensaattori
2200 uF 50V @31.12.1 4 kondensaattori
2200 uF 50V @31.12.2 2 kondensaattori
2200 uF 63V @31.12.2 3 kondensaattori
2700 uF 10V @31.12.2 2 kondensaattori
3300 uF 6.3V @31.12.3 12 kondensaattori
3300 uF 10V @31.12.3 1 kondensaattori
3300 uF 16V @31.12.3 1 kondensaattori
3300 uF 25V @31.12.3 1 kondensaattori
3300 uF 25V @31.12.3 4 kondensaattori
4700 uF 6.3V @43.2.3 14 kondensaattori
4700 uF 10V @44.1.2 90 kondensaattori
4700 uF 16V @44.6.1 1 kondensaattori
4700 uF 16V @43.2.2 1 kondensaattori
4700 uF 25V @44.6.1 28 kondensaattori
4700 uF 25V @43.2.2 2 kondensaattori
4700 uF 35V @43.2.2 3 kondensaattori
4700 uF 40V @43.2.2 2 kondensaattori
4700 uF 50V @43.2.2 1 kondensaattori
4700 uF 63V @43.2.3 1 kondensaattori
6300 uF ??V @43.3.2 2 kondensaattori
6800 uF 50V @43.3.2 1 kondensaattori
6800 uF 63V @43.3.2 1 kondensaattori
10000 uF 16V @44.5.1 2 kondensaattori
10000 uF 25V @44.5.1 17 kondensaattori
10000 uF 35V @44.5.1 1 kondensaattori
10000 uF 40V @44.5.1 1 kondensaattori
15000 uF 40V @44.6.1 1 kondensaattori
18000 uF 40V @44.3.1 1 kondensaattori
22000 uF 25V @44.3.1 2 kondensaattori
22000 uF 40V @44.3.1 1 kondensaattori
30000 uF 40V @44.3.1 2 kondensaattori
30000 uF 40V @44.3.1 1 kondensaattori
33000 uF 63V @44.3.1 1 kondensaattori
3.3 F 2.7V superkond. @18.9.2 13x2 kondensaattori
10 F 2.5V superkond. @18.9.3 9 kondensaattori
100 F 2.5V superkond. @18.9.4 9 kondensaattori
5 uF 220V @44.4.1 8 kondensaattori
10 uF 450V @43.5.1 1 kondensaattori
12 uF/280V @43.5.1 2 kondensaattori
15 uF/450V @43.5.2 9 kondensaattori
16 uF/300V @43.5.3 27 kondensaattori
22 uF 250V @43.6.1 2 kondensaattori
22 uF 350V @43.6.1 2 kondensaattori
22 uF 450V @43.6.1 1 kondensaattori
30 uF 450V @44.4.2 5 kondensaattori
33 uF 200V @43.6.2 2 kondensaattori
33 uF 350V @43.6.2 2 kondensaattori
33 uF 450V @43.6.2 1 kondensaattori
47 uF 200V @43.6.3 1 kondensaattori
47 uF 400V @43.6.3 11 kondensaattori
50 uF 100V @43.4.2 41 kondensaattori
50 uF 100V @43.4.3 21 kondensaattori
50 uF 500V @43.6.3 1 kondensaattori
100 uF 160V @43.7.1 3 kondensaattori
100 uF 200V @43.7.1 1 kondensaattori
100 uF 400V @43.7.1 2 kondensaattori
150 uF 400V @43.7.1 24 kondensaattori
150 uF 385V @44.1.1 24 kondensaattori
180 uF 450V @43.7.2 1 kondensaattori
220 uF 100V @43.4.3 21 kondensaattori
220 uF 385V @43.7.2 1 kondensaattori
220 uF 400V @43.7.2 6 kondensaattori
220 uF 450V @43.7.3 6 kondensaattori
330 uF 180V @43.7.3 1 kondensaattori
330 uF 385V @43.7.3 4 kondensaattori
470 uF 250V @43.8.1 3 kondensaattori
470 uF 400V @43.8.3 2 kondensaattori
470 uF 500V @43.8.2 4 kondensaattori
560 uF 400V @43.8.1 1 kondensaattori
1000 uF 100V @43.8.3 1 kondensaattori
10000 uF 100V @43.8.3 2 kondensaattori
1 pF @19.1.1 20 kondensaattori
2 pF @19.1.1 20 kondensaattori
3 pF @19.1.1 20 kondensaattori
3.9 pF @19.1.1 20 kondensaattori
5 pF @19.1.1 20 kondensaattori
6 pF @19.1.1 20 kondensaattori
8 pF @19.1.1 20 kondensaattori
10 pF @19.1.1 20 kondensaattori
10 pF @19.1.1 5 kondensaattori
12 pF @19.1.1 20 kondensaattori
15 pF @19.1.1 20 kondensaattori
15 pF @19.1.1 5 kondensaattori
18 pF @19.1.1 20 kondensaattori
1.2 pF @19.1.2 10 kondensaattori
2.2 pF @19.1.2 10 kondensaattori
3.9 pF @19.1.2 10 kondensaattori
4.7 pF @19.1.2 10 kondensaattori
5.6 pF @19.1.2 10 kondensaattori
10 pF @19.1.2 10 kondensaattori
15 pF @19.1.2 10 kondensaattori
18 pF @19.1.2 10 kondensaattori
4.7 pF @19.1.3 30 kondensaattori
10 pF @19.1.4 4 kondensaattori
10 pF @19.1.4 30 kondensaattori
10 pF @19.1.4 8 kondensaattori
10 pF @19.1.4 2 kondensaattori
10 pF @19.1.4 90 kondensaattori
15 pF @19.1.5 44 kondensaattori
15 pF @19.1.5 100 kondensaattori
15 pF @19.1.5 47 kondensaattori philips pin up 563 ceramic
18 pF @19.2.1 70 kondensaattori
20 pF @19.2.1 5 kondensaattori
20 pF @19.2.1 18 kondensaattori
22 pF @19.2.2 26 kondensaattori
22 pF @19.2.2 23 kondensaattori
22 pF @19.2.2 33 kondensaattori
22 pF @19.2.2 40 kondensaattori 22pF +-5%
22 pF @19.2.2 39 kondensaattori SRC 22pF 5%
24 pF @19.2.3 20 kondensaattori
25 pF @19.2.3 20 kondensaattori
27 pF @19.2.4 27 kondensaattori
27 pF @19.2.4 20 kondensaattori
27 pF @19.2.4 60 kondensaattori
27 pF @19.2.4 19 kondensaattori
27 pF @19.2.4 86 kondensaattori
27 pF @19.2.4 2 kondensaattori
30 pF @19.2.5 5 kondensaattori
30 pF @19.2.5 20 kondensaattori
33 pF @19.2.5 5 kondensaattori
33 pF @19.2.5 8 kondensaattori
33 pF @19.2.5 28 kondensaattori SRC 33pF 5%
36 pF @19.3.1 20 kondensaattori
39 pF @19.3.1 10 kondensaattori
39 pF @19.3.1 20 kondensaattori
39 pF @19.3.1 78 kondensaattori
39 pF @19.3.1 26 kondensaattori 39PF +-5%
47 pF @19.3.2 200 kondensaattori
47 pF @19.3.2 50 kondensaattori 47p 100V
47 pF @19.3.2 60 kondensaattori
47 pF @19.3.3 160 kondensaattori
47 pF @19.3.3 100 kondensaattori
47 pF @19.3.3 200 kondensaattori 470J C0G100
47 pF @19.3.3 50 kondensaattori 47pF sekalaisia
47 pF @19.3.3 27 kondensaattori 47PF +-2% SRC 47PF 5%
47 pF @19.3.3 40 kondensaattori
50 pF @19.3.4 20 kondensaattori
56 pF @19.3.4 30 kondensaattori
56 pF @19.3.4 40 kondensaattori
56 pF @19.3.4 50 kondensaattori
68 pF @19.3.5 100 kondensaattori philips pin up 563 ceramic
68 pF @19.4.1 100 kondensaattori
68 pF @19.4.1 20 kondensaattori
68 pF @19.4.1 10 kondensaattori
68 pF @19.4.1 40 kondensaattori
68 pF @19.4.1 7 kondensaattori SRC 68PF 5%
82 pF @19.4.2 20 kondensaattori
82 pF @19.4.2 5 kondensaattori MUJ213 82 +-5%
82 pF @19.4.2 28 kondensaattori SRC 82PF 5%
100 pF @19.4.3 100 kondensaattori
100 pF @19.4.3 44 kondensaattori
100 pF @19.4.3 55 kondensaattori
100 pF @19.4.3 20 kondensaattori
100 pF @19.4.3 50 kondensaattori
100 pF @19.4.3 22 kondensaattori
100 pF @19.4.4 90 kondensaattori
100 pF @19.4.4 11 kondensaattori 100PF +-2%
100 pF @19.4.4 150 kondensaattori
120 pF @19.4.5 20 kondensaattori
150 pF @19.5.1 220 kondensaattori philips pin up 563 ceramic
150 pF @19.5.1 80 kondensaattori
150 pF @19.5.1 47 kondensaattori SRC 150PF 5%
150 pF @19.5.2 26 kondensaattori
150 pF @19.5.2 20 kondensaattori
150 pF @19.5.2 10 kondensaattori
180 pF @19.5.3 20 kondensaattori merkintä 181
180 pF @19.5.3 50 kondensaattori merkintä 180
180 pF @19.5.3 9 kondensaattori merkintä 180ITT
180 pF @19.5.3 20 kondensaattori merkintä n18
180 pF @19.5.3 11 kondensaattori merkintä 180J
200 pF @19.5.4 20 kondensaattori
220 pF 2kV @19.5.4 5 kondensaattori sininen
220 pF @19.5.5 90 kondensaattori
220 pF @19.5.5 40 kondensaattori
220 pF @19.5.5 130 kondensaattori
220 pF @19.5.5 100 kondensaattori
220 pF @19.5.5 18 kondensaattori
220 pF @19.6.1 75 kondensaattori
220 pF @19.6.1 150 kondensaattori
220 pF @19.6.1 4 kondensaattori SRC 220PF 5%
220 pF @19.6.1 180 kondensaattori
270 pF @19.6.2 6 kondensaattori
330 pF @19.6.3 400 kondensaattori
330 pF @19.6.3 50 kondensaattori
330 pF @19.6.3 11 kondensaattori
330 pF @19.6.3 45 kondensaattori
330 pF @19.6.3 2 kondensaattori SRC 330PF 5%
390 pF @19.6.4 60 kondensaattori
390 pF @19.6.4 100 kondensaattori
390 pF @19.6.4 18 kondensaattori
470 pF @19.6.5 40 kondensaattori
470 pF @19.6.5 100 kondensaattori
470 pF @19.6.5 44 kondensaattori
470 pF @19.6.5 18 kondensaattori
470 pF @19.6.5 65 kondensaattori
470 pF @19.6.5 5 kondensaattori
470 pF @19.7.1 80 kondensaattori
470 pF 2kV @19.7.1 10 kondensaattori
470 pF @19.7.1 20 kondensaattori
500 pF @19.7.2 20 kondensaattori
560 pF 2kV @19.7.3 10 kondensaattori 561 2KV
560 pF @19.7.3 50 kondensaattori
560 pF @19.7.3 20 kondensaattori
560 pF @19.7.3 10 kondensaattori
680 pF @19.7.4 60 kondensaattori
680 pF @19.7.4 50 kondensaattori
680 pF 2kV @19.7.4 13 kondensaattori 681 2KV BC RR 681K 2KV
680 pF @19.7.4 40 kondensaattori
680 pF @19.7.4 20 kondensaattori
680 pF @19.7.4 5 kondensaattori SRC 680PF 5%
820 pF @19.7.5 40 kondensaattori
820 pF @19.7.5 30 kondensaattori SRC 820PF 5%
1 nF @19.8.1 90 kondensaattori
1 nF @19.8.1 100 kondensaattori
1 nF @19.8.1 35 kondensaattori philips pin up 563 ceramic
1 nF 2kV @19.8.1 10 kondensaattori 102 2KV
1 nF @19.8.1 50 kondensaattori
1 nF @19.8.2 40 kondensaattori
1 nF @19.8.2 20 kondensaattori
1 nF @19.8.2 28 kondensaattori
1 nF 400V @19.8.2 100 kondensaattori
1 nF @19.8.2 6 kondensaattori
1 nF 400V @19.8.2 4 kondensaattori
1 nF @19.8.3 40 kondensaattori
1 nF @19.8.3 1500 kondensaattori
1.5 nF 2kV @19.8.4 10 kondensaattori 152 2KV
1.5 nF @19.8.4 40 kondensaattori
1.5 nF @19.8.4 20 kondensaattori
1.5 nF @19.8.4 7 kondensaattori
1.5 nF @19.8.4 13 kondensaattori
1.5 nF @19.8.4 1 kondensaattori philips pin up 563 ceramic
1.8 nF @19.8.5 69 kondensaattori
2.0 nF @19.9.1 20 kondensaattori
2.2 nF @19.9.2 60 kondensaattori
2.2 nF @19.9.2 80 kondensaattori
2.2 nF @19.9.2 20 kondensaattori
2.2 nF @19.9.2 85 kondensaattori philips pin up 563 ceramic
2.2 nF 2kV @19.9.3 10 kondensaattori 222 2KV sininen
2.2 nF @19.9.3 5 kondensaattori
2.2 nF @19.9.3 19 kondensaattori
2.2 nF @19.9.3 35 kondensaattori
2.2 nF @19.9.3 13 kondensaattori
2.7 nF @19.9.3 2 kondensaattori philips pin up 563 ceramic
3.3 nF @19.9.4 110 kondensaattori
3.3 nF @19.9.4 39 kondensaattori
3.3 nF @19.9.4 170 kondensaattori
3.3 nF @19.9.4 40 kondensaattori
3.3 nF @19.9.4 8 kondensaattori
3.3 nF @19.9.5 50 kondensaattori
3.3 nF @19.9.5 80 kondensaattori
3.3 nF 2kV @19.9.5 10 kondensaattori 332 2KV sininen
3.3 nF @19.9.5 6 kondensaattori
3.3 nF @19.9.5 20 kondensaattori 3300 ZK2
3.9 nF @19.10.1 9 kondensaattori
3.9 nF @19.10.1 50 kondensaattori
4.7 nF @19.10.2 270 kondensaattori
4.7 nF @19.10.2 100 kondensaattori
4.7 nF @19.10.2 46 kondensaattori
4.7 nF @19.10.2 20 kondensaattori
4.7 nF @19.10.2 14 kondensaattori
4.7 nF 2kV @19.10.3 10 kondensaattori 472 2KV sininen
4.7 nF @19.10.3 100 kondensaattori
4.7 nF @19.10.3 9 kondensaattori
4.7 nF @19.10.3 2 kondensaattori philips pin up 563 ceramic
4.7 nF @19.10.3 40 kondensaattori
4.7 nF @19.10.3 25 kondensaattori Lemco 4700
5.6 nF @19.10.4 16 kondensaattori
5.6 nF @19.10.4 100 kondensaattori
5.6 nF @19.10.4 6 kondensaattori
5.6 nF @19.10.4 11 kondensaattori
5.6 nF @19.10.4 3 kondensaattori
6.8 nF @19.10.5 20 kondensaattori
6.8 nF @19.10.5 2 kondensaattori
8.2 nF @19.10.5 40 kondensaattori philips pin up 563 ceramic
10 nF @19.11.1 36 kondensaattori
10 nF @19.11.1 37 kondensaattori
10 nF @19.11.1 18 kondensaattori
10 nF @19.11.1 14 kondensaattori
10 nF @19.11.1 90 kondensaattori
10 nF 2kV @19.11.1 9 kondensaattori 103 2KV sininen
10 nF @19.11.2 280 kondensaattori
10 nF @19.11.2 85 kondensaattori
10 nF @19.11.2 80 kondensaattori
10 nF @19.11.3 50 kondensaattori
10 nF @19.11.3 28 kondensaattori
10 nF @19.11.3 15 kondensaattori
10 nF @19.11.3 8 kondensaattori sekalaiset
10 nF @19.11.3 100 kondensaattori philips pin up 563 ceramic
10 nF @19.11.4 14 kondensaattori
15 nF @19.11.4 30 kondensaattori
20 nF @19.11.4 30 kondensaattori
22 nF @19.11.5 75 kondensaattori
22 nF @19.11.5 90 kondensaattori
22 nF @19.11.5 17 kondensaattori
22 nF @19.11.5 20 kondensaattori
22 nF @19.11.5 70 kondensaattori
22 nF @19.11.5 5 kondensaattori
22 nF @19.12.1 180 kondensaattori
33 nF @19.12.2 100 kondensaattori
33 nF @19.12.2 20 kondensaattori
33 nF @19.12.2 5 kondensaattori
47 nF @19.12.3 120 kondensaattori
47 nF @19.12.3 30 kondensaattori
47 nF @19.12.3 24 kondensaattori
47 nF @19.12.3 45 kondensaattori
47 nF @19.12.3 15 kondensaattori
47 nF @19.12.3 5 kondensaattori
68 nF @19.12.4 50 kondensaattori
68 nF @19.12.4 20 kondensaattori
100 nF 25V @19.12.4 370 kondensaattori 104Z 25V
100 nF @19.12.5 120 kondensaattori
100 nF @19.12.5 6 kondensaattori
100 nF @19.12.5 10 kondensaattori
100 nF @19.12.5 40 kondensaattori
100 nF @19.12.5 17 kondensaattori 0.1 uF 32V
100 nF @19.9.1 X kondensaattori 100nS KCK
220 nF @19.12.2 12 kondensaattori
330 nF @19.12.4 2 kondensaattori 334
1.0 uF @19.12.4 4 kondensaattori 105
1.0 uF @19.12.4 2 kondensaattori 1u 100
33 uF 16V X7R @19.12.4 70 kondensaattori keraaminen
100 pF 63V @20.1.1 80 kondensaattori
154 pF 63V @20.1.2 39 kondensaattori
316 pF 63V @20.1.3 7 kondensaattori
464 pF 63V @20.1.4 4 kondensaattori
1 nF 400V 5% @20.2.1 150 kondensaattori
1 nF 630V 2.5% @20.2.2 250 kondensaattori
1 nF 100V @20.2.3 95 kondensaattori
1 nF 100V 10% @20.2.3 7 kondensaattori
1 nF 100V @20.2.3 15 kondensaattori
1 nF 400V @20.2.3 90 kondensaattori
1.0 nF 400V @20.2.4 1 kondensaattori
1.0 nF 400V @20.2.4 2 kondensaattori
1.2 nF 100V @20.2.4 5 kondensaattori
1.5 nF 100V @20.2.4 16 kondensaattori
2.2 nF 63V @20.3.1 15 kondensaattori
2.2 nF 100V @20.3.1 35 kondensaattori
2.2 nF 100V @20.3.1 10 kondensaattori
2.2 nF 100V @20.3.1 26 kondensaattori
2.2 nF 250V~ Y2 @20.3.1 4 kondensaattori
2.7 nF 100V @20.3.1 3 kondensaattori
3.3 nF 63V @20.3.2 35 kondensaattori Evox
3.3 nF 100V @20.3.2 70 kondensaattori
3.3 nF 100V @20.3.2 8 kondensaattori
3.3 nF 100V @20.3.2 12 kondensaattori
3.3 nF 100V @20.3.2 10 kondensaattori
3.3 nF 400V 5% @20.3.2 50 kondensaattori
3.9 nF 100V @20.3.3 34 kondensaattori
3.9 nF 400V @20.3.3 100 kondensaattori
4.7 nF 400V 5% @20.3.3 75 kondensaattori
4.7 nF 63V @20.3.4 150 kondensaattori
4.7 nF 400V @20.3.4 77 kondensaattori
4.7 nF 63V @20.4.1 39 kondensaattori
4.7 nF 100V @20.4.1 48 kondensaattori
4.7 nF 100V @20.4.1 9 kondensaattori
4.7 nF 400V @20.4.1 25 kondensaattori
4.7 nF 250V~ Y @20.4.1 4 kondensaattori
4.7 nF 400V @20.4.1 23 kondensaattori
4.7 nF 400V @20.4.1 1 kondensaattori
5.6 nF 63V @20.4.2 30 kondensaattori
5.6 nF 250V @20.4.2 9 kondensaattori
6.8 nF 100V @20.4.2 5 kondensaattori
6.8 nF 250V @20.4.2 5 kondensaattori
6.8 nF 400V @20.4.2 75 kondensaattori
8.2 nF 63V @20.4.3 63 kondensaattori
10 nF 100V @20.4.4 18 kondensaattori EVOX
10 nF 160V 10% @20.4.4 14 kondensaattori ERD KT1800 0.01/10/160
10 nF 400V 10% @20.4.4 100 kondensaattori
10 nF 100V @20.5.1 180 kondensaattori
10 nF 100V @20.5.1 44 kondensaattori
10 nF 250V @20.5.1 28 kondensaattori
10 nF 400V @20.5.1 16 kondensaattori
10 nF 100V @20.5.1 5 kondensaattori
10 nF 100V @20.5.2 230 kondensaattori
10 nF 63V @20.5.2 450 kondensaattori
10 nF 63V @20.5.3 75 kondensaattori EVOX
10 nF 630V @20.5.3 2 kondensaattori EVOX
10 nF 400V 2.5% @20.5.3 80 kondensaattori
10 nF 63V 10% @20.5.4 90 kondensaattori WIMA 0.02 63- K1
15 nF 63V 5% @20.5.4 11 kondensaattori
15 nF 100V 10% @20.5.4 16 kondensaattori
15 nF 630V @20.5.4 2 kondensaattori
18 nF 630V @20.5.4 3 kondensaattori EVOX
22 nF @20.5.4 X kondensaattori Sekalaiset
22 nF 400V @20.5.4 11 kondensaattori
22 nF 630V @20.6.1 6 kondensaattori MMK EVOX
22 nF 400V @20.6.1 180 kondensaattori
33 nF 63V @20.6.2 120 kondensaattori
33 nF 100V @20.6.2 100 kondensaattori
33 nF 100V @20.6.2 170 kondensaattori
33 nF 100V @20.6.2 14 kondensaattori
33 nF 100V sekalaisia @20.6.2 15 kondensaattori
33 nF 250V @20.6.3 100 kondensaattori
33 nF 400V @20.6.4 15 kondensaattori
33 nF 100V @20.6.4 98 kondensaattori
39 nF @20.7.1 13 kondensaattori
47 nF 100V @20.7.2 13 kondensaattori
47 nF 100V @20.7.2 20 kondensaattori
47 nF 100V @20.7.2 30 kondensaattori
47 nF 100V 10% @20.7.2 130 kondensaattori
47 nF 250V @20.7.3 40 kondensaattori
47 nF 250V 10% @20.7.3 70 kondensaattori
47 nF 250V @20.7.4 200 kondensaattori
47 nF 400V @20.7.4 10 kondensaattori EVOX
47 nF 100V 2% @20.8.1 800 kondensaattori 47nG 100-
56 nF @20.8.2 70 kondensaattori 56nJ 100V
56 nF @20.8.2 60 kondensaattori
68 nF 63V @20.8.3 26 kondensaattori
68 nF 63V @20.8.3 45 kondensaattori
68 nF 100V 10% @20.8.3 180 kondensaattori
68 nF 250V @20.8.4 90 kondensaattori
68 nF 250V @20.8.4 50 kondensaattori
10 nF 630V @20.9.1 280 kondensaattori
82 nF @20.9.2 12 kondensaattori
100 nF 63V @20.9.3 28 kondensaattori
100 nF 100V @20.9.3 9 kondensaattori
100 nF 100V @20.9.3 20 kondensaattori
100 nF 100V @20.9.3 24 kondensaattori .1M100 MMK EVOX
100 nF 100V @20.9.3 60 kondensaattori
100 nF 100V @20.9.4 200 kondensaattori
100 nF 400V @20.10.1 3 kondensaattori
100 nF 400V 10% @20.10.1 10 kondensaattori
100 nF 100V @20.10.1 30 kondensaattori
100 nF 63V @20.10.1 300 kondensaattori
100 nF 100V @20.10.2 38 kondensaattori A100V 104M E8745
150 nF 63V @20.10.2 88 kondensaattori
150 nF 100V @20.10.2 27 kondensaattori EVOX
150 nF 100V @20.10.3 7 kondensaattori EVOX
150 nF 100V @20.10.3 10 kondensaattori
150 nF 275V~ X2 @20.10.3 1 kondensaattori
150 nF 250V~ @20.10.3 13 kondensaattori
150 nF 250V~ @20.10.3 4+2 kondensaattori
150 nF 275V~ X2 @20.10.3 14 kondensaattori
150 nF 630V @20.10.3 12 kondensaattori
220 nF 63V @20.10.4 40 kondensaattori
220 nF 63V @20.10.4 60 kondensaattori
220 nF 63V @20.10.4 15 kondensaattori
220 nF 63V @20.11.1 200 kondensaattori
220 nF 100V @20.11.1 150 kondensaattori
220 nF 100V @20.11.2 250 kondensaattori
220 nF 100V @20.11.3 20 kondensaattori
220 nF 100V @20.11.3 11 kondensaattori
220 nF 100V @20.11.3 16 kondensaattori
220 nF 250V @20.11.3 13 kondensaattori
220 nF 250V @20.11.4 24 kondensaattori
220 nF 250V @20.11.4 13 kondensaattori
220 nF 250V @20.11.4 1 kondensaattori
220 nF 400V @20.11.4 1 kondensaattori
220 nF 440V~ @20.11.4 1 kondensaattori
220 nF 630V @20.11.4 5 kondensaattori
330 nF 63V @20.12.1 550 kondensaattori EVOX 334 63XL MMK 5.0
330 nF 63V @20.12.2 450 kondensaattori EVOX 334 63XL MMK 5.0
330 nF 63V @20.12.3 130 kondensaattori
330 nF 63V @20.12.3 70 kondensaattori
330 nF 63V @20.12.3 90 kondensaattori .33K 63V- MKT 1826
330 nF 63V @20.12.3 31 kondensaattori
330 nF 63V @20.12.3 8 kondensaattori
330 nF 100V @20.12.4 170 kondensaattori
330 nF 100V @20.12.4 30 kondensaattori
330 nF 100V @32.1.1 32 kondensaattori
330 nF 100V @32.1.1 110 kondensaattori
330 nF 250V @32.1.1 4 kondensaattori
330 nF 275V X2 @32.1.1 6 kondensaattori
330 nF 400V @32.1.1 6 kondensaattori
330 nF 160V @32.1.1 50 kondensaattori
420 nF 250V @32.1.1 2 kondensaattori
470 nF @32.1.2 90 kondensaattori ASC 474
470 nF 63V @32.1.2 11 kondensaattori
470 nF 63V @32.1.2 17 kondensaattori
470 nF 63V @32.1.2 40 kondensaattori
470 nF 63V @32.1.2 38 kondensaattori
470 nF 160V @32.1.2 3 kondensaattori
470 nF 100V @32.1.3 130 kondensaattori
470 nF 100V @32.1.4 90 kondensaattori
470 nF 100V @32.2.1 19 kondensaattori
470 nF 100V @32.2.1 22 kondensaattori
470 nF 400V @32.2.2 20 kondensaattori 0.47/10/400 341-MC-WC6 Polyester
470 nF 400V @32.2.3 22 kondensaattori 0.47/10/400 34159474WB9 Polyester
470 nF 400V @32.2.4 11 kondensaattori 0.47/10/400 34159474WB9 Polyester
470 nF 400V @32.2.4 8 kondensaattori 0.47/10/400 341-MC-WC6 Polyester
560 nF 250V 5% @32.3.1 62 kondensaattori
560 nF 63V @32.3.2 28 kondensaattori
560 nF 250V 10% @32.3.2 2 kondensaattori
680 nF 63V @32.3.2 20 kondensaattori
680 nF 63V @32.3.2 10 kondensaattori
680 nF 63V @32.3.2 2 kondensaattori
680 nF 250V @32.3.2 5 kondensaattori
680 nF 250V @32.3.2 2 kondensaattori
680 nF 100V @32.3.3 100 kondensaattori
680 nF 63V @32.3.4 60 kondensaattori
680 nF 100V @32.3.4 5 kondensaattori
680 nF 100V @32.3.4 7 kondensaattori
680 nF 100V @32.3.4 3 kondensaattori
820 nF 250V @32.4.1 2 kondensaattori
1 uF 50V @32.4.2 15 kondensaattori
1 uF 63V @32.4.2 30 kondensaattori
1 uF 63V @32.4.2 80 kondensaattori
1 uF 63V @32.4.3 20 kondensaattori
1 uF 100V @32.4.3 10 kondensaattori
1 uF 100V @32.4.3 78 kondensaattori
1 uF 250V @32.4.4 22 kondensaattori Siemens B32535 1K 250 DIN 44122
1 uF 400V @32.4.4 12 kondensaattori
1 uF 100V @32.5.1 38 kondensaattori EVOX
1 uF 63V @32.5.1 39 kondensaattori 1u0 K 63V PH 9935 370
1 uF 250V @32.5.1 6 kondensaattori EVOX
1 uF 300V~ @32.5.2 8 kondensaattori
1 uF 250V @32.5.2 18 kondensaattori EVOX CMK M1
1.5 uF 63V @32.5.3 44 kondensaattori WIMA 1.5uF 63- S1 10
1.5 uF 63V @32.5.3 15 kondensaattori
1.5 uF 63V @32.5.3 1 kondensaattori
1.5 uF 100V @32.5.3 9 kondensaattori WIMA MKS 4
1.5 uF 100V @32.5.3 2 kondensaattori
1.5 uF 100V @32.5.4 65 kondensaattori
1.5 uF 100V @32.6.1 40 kondensaattori
2.2 uF 50V @32.6.2 2 kondensaattori
2.2 uF 63V @32.6.2 7 kondensaattori
2.2 uF 63V @32.6.2 20 kondensaattori
2.2 uF 100V @32.6.2 4 kondensaattori
2.2 uF 100V @32.6.2 8 kondensaattori
2.2 uF 100V @32.6.3 11 kondensaattori
2.2 uF 250V @32.6.3 4 kondensaattori
2.2 uF 250V @32.6.3 5 kondensaattori
2.2 uF 250V @32.6.4 18 kondensaattori
2.2 uF 250V @32.7.1 14 kondensaattori
2.2 uF 250V @32.7.2 13 kondensaattori
3.3 uF 63V @32.7.3 21 kondensaattori
3.3 uF 63V @32.7.3 40 kondensaattori
3.3 uF 100V @32.7.4 40 kondensaattori
3.3 uF 100V @32.8.1 18 kondensaattori
3.3 uF 100V @32.8.2 15 kondensaattori
3.3 uF 100V @32.12.3 12 kondensaattori
4.7 uF 50V @32.8.3 2 kondensaattori
4.7 uF 63V @32.8.3 3 kondensaattori
4.7 uF 100V @32.8.3 8 kondensaattori
4.7 uF 100V @32.8.3 1 kondensaattori
4.7 uF 250V @32.8.3 1 kondensaattori
4.7 uF 250V @32.8.4 20 kondensaattori
4.7 uF 250V @32.9.1 32 kondensaattori Siemens B33524 MKT 4u7 K250V FD
4.7 uF 250V @32.9.2 32 kondensaattori Siemens B33524 MKT 4u7 K250V FD
4.7 uF 250V @32.9.3 30 kondensaattori Siemens B33524 MKT 4u7 K250V FD
5.6 uF 100V @32.9.4 18 kondensaattori
5.6 uF 100V @32.10.1 18 kondensaattori
6.8 uF 63V @32.10.2 61 kondensaattori
6.8 uF 63V @32.10.3 21 kondensaattori
6.8 uF 100V @32.10.3 3 kondensaattori
6.8 uF 100V @32.10.3 11 kondensaattori
6.8 uF 275V~ @32.12.4 3 kondensaattori
10 uF 20V @32.10.4 130 kondensaattori
10 uF 63V @32.11.1 8 kondensaattori
10 uF 63V @32.11.1 9 kondensaattori
10 uF 100V @32.11.1 4 kondensaattori
10 uF 100V @32.11.2 14 kondensaattori
10 uF 100V @32.11.3 15 kondensaattori
10 uF 100V @32.11.4 9 kondensaattori
10 uF 250V @32.12.1 2 kondensaattori Polyester
10 uF 250V @32.12.1 12 kondensaattori Polyester
10 uF 250V @32.12.1 4 kondensaattori Polyester
10 uF 250V @32.12.2 6 kondensaattori RIFA 40/085/56
16 uF 250V @32.12.3 4 kondensaattori CBB6-1
22 uF 100V @32.12.4 2 kondensaattori
Kondensaattorit, Verkkosuodatin
0.10 uF 660V X2 @95.7.1 16 kondensaattori RIFA PME264NE 40/085/56 Datasheet
0.33 uF 250V X2 @95.7.2 27 kondensaattori RIFA PM271ME 40/085/56 Datasheet
154 pF 63V @95.7.2 39 kondensaattori
Kondensaattorit, Styroflex
100 pF @31.1.1 X kondensaattori
150 pF @31.1.1 X kondensaattori
230 pF @31.1.2 300 kondensaattori
300 pF @31.1.3 550 kondensaattori
300 pF @31.1.4 X kondensaattori
305 pF @31.1.4 X kondensaattori
348 pF @31.2.1 600 kondensaattori
470 pF @31.2.2 X kondensaattori
560 pF @31.2.2 9 kondensaattori
680 pF @31.2.3 700 kondensaattori
1 nF @31.2.4 10 kondensaattori
1.2 nF @31.2.4 39 kondensaattori
1.5 nF @31.2.4 31 kondensaattori
2.0 nF @31.3.1 34 kondensaattori
2.2 nF @31.3.2 230 kondensaattori
2.7 nF @31.3.1 42 kondensaattori
3.0 nF @31.3.3 62 kondensaattori
3.3 nF @31.3.4 130 kondensaattori
3.6 nF @31.4.1 45 kondensaattori
3.65 nF @31.4.1 60 kondensaattori
6.9 nF @31.4.2 64 kondensaattori
8.7 nF @31.4.3 250 kondensaattori
13.65 nF @31.4.4 32 kondensaattori
15.3 nF @31.5.1 21 kondensaattori
19.6 nF @31.5.1 8 kondensaattori
20.7 nF @31.5.2 14 kondensaattori
21.2 nF @31.5.2 3 kondensaattori
22 nF @31.5.3 10 kondensaattori
23.0 nF @31.5.3 1 kondensaattori
35.7 nF @31.5.3 4 kondensaattori
68 nF @31.5.4 20 kondensaattori
150 nF @31.5.4 5 kondensaattori
Kondensaattorit, Tantaalit
100 nF 35V @18.6.1 350 kondensaattori tantaali
100 nF 35V @18.6.1 70 kondensaattori tantaali
100 nF 35V @18.6.1 550 kondensaattori tantaali
220 nF @18.6.2 41 kondensaattori Tantaali 224L
220 nF 35V @18.6.2 1 kondensaattori Tantaali 224L
470 nF 35V @18.6.3 11 kondensaattori Tantaali
470 nF 35V @18.6.3 19 kondensaattori Tantaali
470 nF 35V @18.6.3 150 kondensaattori Tantaali 474L
1 uF @18.6.4 250 kondensaattori Tantaali 105L
1 uF 35V @18.6.4 450 kondensaattori Tantaali
1 uF 35V @18.6.4 900 kondensaattori Tantaali
1 uF 35V @18.6.4 75 kondensaattori Tantaali
2.2 uF 35V @18.7.1 600 kondensaattori Tantaali
2.2 uF 35V @18.7.1 15 kondensaattori Tantaali
2.2 uF @18.7.1 18 kondensaattori Tantaali 225L
2.2 uF 16V @18.7.1 1 kondensaattori Tantaali
4.7 uF 40V @18.7.2 300 kondensaattori Tantaali T340C475K040AS T340C475K040AS.pdf
4.7 uF 40V @18.7.3 300 kondensaattori Tantaali T340C475K040AS T340C475K040AS.pdf
6.8 uF 16V @18.7.4 1 kondensaattori Tantaali
6.8 uF 35V @18.7.4 9 kondensaattori Tantaali
10 uF 10V @18.7.4 5 kondensaattori tantaali
10 uF 16V @18.7.4 21 kondensaattori tantaali
22 uF 16V @18.7.4 70 kondensaattori tantaali
22 uF 20V @18.8.1 200 kondensaattori tantaali 20% T322D226M020AS T322D226M020AS.pdf
22 uF 20V @18.8.2 130 kondensaattori tantaali 20% T322D226M020AS T322D226M020AS.pdf
33 uF 25V @18.8.3 17 kondensaattori tantaali
33 uF 35V @18.8.3 6 kondensaattori tantaali
33 uF 35V @18.8.3 2 kondensaattori tantaali
47 uF 6V @18.8.4 100 kondensaattori tantaali
47 uF 16V @18.8.4 15 kondensaattori tantaali
47 uF 16V @18.8.4 3 kondensaattori tantaali
47 uF 20V @18.8.4 17 kondensaattori tantaali
47 uF 25V @18.8.4 5 kondensaattori tantaali
47 uF 35V @18.8.4 3 kondensaattori tantaali
100 uF 10V @18.9.1 14 kondensaattori tantaali
100 uF 16V @18.9.1 2 kondensaattori tantaali
100 uF 20V @18.9.1 1 kondensaattori tantaali
330 uF 6V @18.9.2 9 kondensaattori tantaali
Kondensaattorit, Trimmerit
Trimmeri 2.8 - 32 pF @18.10.1 2 kondensaattori
Trimmeri 1.8 - 20 pF @18.10.1 4 kondensaattori
Trimmeri 1.7 - 6.5 pF @18.10.1 1 kondensaattori
Trimmeri 1.0 - 3.5 pF @18.10.1 8 kondensaattori
Trimmeri 2.1 - 19.5 pF @18.10.1 4 kondensaattori
Trimmeri 0.3 - 1.2 pF @18.10.1 8 kondensaattori
Trimmerit 4-20 pF @18.10.2 X kondensaattori
Trimmerit 4-20 pF @18.10.3 X kondensaattori
Trimmerit 3-10 pF @18.10.4 X kondensaattori
Trimmerit 15 pF @18.11.1 X kondensaattori
Trimmeri 2.5-6 pF @18.11.2 X kondensaattori
Trimmeri 2.5-60 pF @18.11.2 2 kondensaattori
Trimmeri 5-110 pF @18.11.2 3 kondensaattori
Trimmeri 13 pF @18.11.3 X kondensaattori
Trimmeri 13 pF @18.11.3 9 kondensaattori
Trimmeri 6 pF @18.11.3 2 kondensaattori
Trimmeri 32 pF @18.11.3 4 kondensaattori
Trimmeri 1-20 pF @18.11.4 X kondensaattori
Trimmeri 3-60 pF @18.12.1 X kondensaattori
Trimmeri 10-100 pF @18.12.2 X kondensaattori
5.6 nF @18.1.1 X kondensaattori
10 nF @18.1.2 X kondensaattori
15 nF @18.1.3 20 kondensaattori
22 nF @18.1.3 X kondensaattori
33 nF @18.1.4 7 kondensaattori
39 nF @18.1.4 11 kondensaattori
47 nF @18.1.4 X kondensaattori
56 nF @18.2.1 X kondensaattori
68 nF @18.2.2 20 kondensaattori
82 nF @18.2.2 13 kondensaattori
100 nF @18.2.2 75 kondensaattori
120 nF @18.2.3 X kondensaattori
150 nF @18.2.4 X kondensaattori
220 nF @18.3.1 X kondensaattori
330 nF @18.3.2 X kondensaattori
680 nF @18.3.3 1 kondensaattori
1.0 uF @18.3.3 X kondensaattori
1.5 uF @18.3.4 1 kondensaattori
2.2 uF @18.3.4 1 kondensaattori
6.8 uF @18.3.4 2 kondensaattori
Kondensaattorit, HV 1000V+
47 pF 6000V @18.4.1 7 kondensaattori
100 pF 1000V @18.4.1 4 kondensaattori
100 pF 2000V @18.4.1 5 kondensaattori
100 pF 3000V @18.4.1 10 kondensaattori
100 pF 5400V @18.4.1 1 kondensaattori
150 pF 3000V @18.4.1 10 kondensaattori
220 pF 2000V @18.4.1 5 kondensaattori
220 pF 3000V @18.4.1 10 kondensaattori
470 pF 2000V @18.4.1 5 kondensaattori
680 pF 3000V @18.4.1 9 kondensaattori
1.0 nF 2000V @18.4.1 4 kondensaattori BC RR 102K 2KV
2.2 nF 1250V @18.4.1 1 kondensaattori
4.7 nF 1250V @18.4.1 2 kondensaattori
5.6 nF 1400V @18.4.1 3 kondensaattori
10 nF 1250V @18.4.1 1 kondensaattori
4.7 nF 1250V @18.4.1 20 kondensaattori
12 nF 1600V @18.4.1 9 kondensaattori
12 nF 1600V @18.4.1 3 kondensaattori
2.2 nF 1600V @18.4.2 3 kondensaattori
5.6 nF 1600V @18.4.2 1 kondensaattori
10 nF 1000V @18.4.2 4 kondensaattori
15 nF 1000V @18.4.2 4 kondensaattori
1.5 nF 1600V @18.4.2 1 kondensaattori
6.7 nF 1600V @18.4.2 1 kondensaattori
7.25 nF 1600V @18.4.2 1 kondensaattori
9.5 nF 1600V @18.4.2 1 kondensaattori
33 nF 1600V @18.4.2 1 kondensaattori
47 nF 1000V @18.4.2 1 kondensaattori
47 nF 1600V @95.11.1 62 kondensaattori WIMA MKP10 0.047uF 1600V- 650V~
100 nF 1000V @18.4.2 1 kondensaattori
100 nF 1000V @18.4.2 2 kondensaattori 100N 20% 1K VDC
22 nF 1600V @18.4.3 12 kondensaattori
33 nF 1600V @18.4.3 11 kondensaattori
10 nF 1000V @18.4.3 20 kondensaattori DE1005F103Z1K
47 nF 1000V @18.4.4 13 kondensaattori
47 nF 1600V @18.4.4 5 kondensaattori
47 nF 1600V @18.4.4 2 kondensaattori
68 nF 1000V @18.5.1 1 kondensaattori
68 nF 1000V @18.5.1 2 kondensaattori
68 nF 1000V @18.5.1 20 kondensaattori
2.2 nF 2000V @18.5.2 1 kondensaattori
6.8 nF 2000V @18.5.2 7 kondensaattori
7.5 nF 2000V @18.5.2 4 kondensaattori
7.7 nF 2000V @18.5.2 4 kondensaattori
9.1 nF 2000V @18.5.2 1 kondensaattori
10 nF 2000V @18.5.2 8 kondensaattori
39 nF 1000V @18.5.3 1 kondensaattori
68 nF 1000V @18.5.3 1 kondensaattori
82 nF 1000V @18.5.3 1 kondensaattori
100 nF 1000V @18.5.3 8 kondensaattori
100 nF 1000V @18.5.3 10 kondensaattori
100 nF 1250V @18.5.3 13 kondensaattori
220 nF 1250V @18.5.4 8 kondensaattori
220 nF 1600V @18.5.4 5 kondensaattori
Kytkimet
Cherry MX Brown @25.8.1 109 liittimet Cherry Mx.pdf
DIP-kytkin @25.10.1 X kytkimet Sekalaiset
DIP-kytkin @25.10.2 140 kytkimet 8-Pin DIP Dip kytkin 4xSPST
DIP-kytkin @25.11.1 X kytkimet 8-Pin DIP Dip kytkin sekalaiset
DIP kiertokytkin @25.8.2 400 kytkimet 6-Pin DIP MCRH3MAF-10R-V-B BCD-CODED MCR.pdf
DIP kiertokytkin @29.7.2 2 kytkimet 8-Pin DIP HEX-koodattu
DIP kiertokytkin @29.7.2 10 kytkimet HEX-koodattu
Erikoiskiertokytkin @29.7.2 10 kytkimet
Erikoiskytkin @29.7.2 X kytkimet
Kiertokytkimiä @61.4.1 X kytkimet
Kytkimiä @40.1.1 X kytkimet
Kytkimiä @40.1.2 X kytkimet
Kytkimiä @40.2.1 X kytkimet
Kytkimiä @40.3.1 X kytkimet
Kytkimiä @40.3.2 X kytkimet
Kytkimiä @40.4.2 X kytkimet
kytkimiä @40.5.1 X kytkimet
Kytkimiä @40.5.2 X kytkimet
Kytkimiä @40.6.2 X kytkimet
Liukukytkin @61.3.3 X kytkimet
liuskakytkin @29.7.2 X kytkimet
Mikrokytkimiä @40.4.1 X kytkimet
Painonappi @29.6.2 X kytkimet
Painokytkimiä @61.4.3 X kytkimet
Painokytkimiä @65.1.1 X kytkimet
Painokytkimiä @65.1.2 X kytkimet
Painokytkimiä UNIMEC 15501 @25.8.1 25 kytkimet https://nx2063.your-storageshare.de/s/ozX9MXZKzLKLSD2 Unimec.pdf
Painokytkimiä Hall-kytkin @61.4.3 X kytkimet
Ledit
7-segment x1 @17.3.1 X led
7-segment @17.3.2 X led
7-segment x2 @17.3.3 X led
7-segment @17.4.1 X led
7-segment @17.4.2 117 led FND507
7-segment "1+" @17.4.2 13 led M7928
LED Matrix 5x8 @06.2.1 2 led TBA24-22EGWA TBA24-22EGWA.pdf
LED Matrix 5x7 @06.2.1 2 led TA20-11EWA TA20-11EWA.pdf
LED Matrix 5x7 @06.2.1 2 led TA20-11GWA TA20-11GWA.pdf
LED Matrix 5x7 @06.2.1 1 led TA20-11HWA
LED Matrix 8x8 @06.2.1 8 led P-2388A3 RT-DA5388HRE 8x8 RED
LED Matrix 5x7 @06.2.2 6 led LTP2157AG LTP-2157AG.pdf
Infra ledit @16.5.2 X led
IR led @16.5.2 1 led LD271 Datasheet
IR led @16.5.2 2 led SFH485 Datasheet
Infra ledi-pareja @16.5.2 X led
Led RGB @06.1.8 70+ led
Led RGB 3W @06.1.8 2 led
Led RGB teho @06.1.8 2 led
Led keltainen 3mm @16.3.1 20 led Vishay 3mm keltainen led 1.9V/2mA TLLY4401
Led keltainen 3mm tasapäinen @16.3.1 100 led Kingbright L-424YDT
Led keltainen 3mm tasapäinen @16.3.1 X led
Led keltainen 3mm kynttiläledi @16.3.1 50 led
Led keltainen 5mm kynttiläledi @16.3.1 50 led
Led keltainen 5mm WP7113YT @16.3.2 X led WP7113YT Kingbright Standard LEDs Yellow Transparent
Led keltainen 5mm @16.3.2 13 led Kingbright 5mm keltainen led 5V/11.5mA L-53YD-5V
Led keltainen 5mm kirkas @16.3.2 X led
Led keltainen 5mm kirkas @16.3.2 90 led 2,2V 20mA 2000 mcd
Led keltainen 5mm matta @16.3.2 X led
Led keltainen 5mm kirkas @16.3.2 48 led L-7113SYC
Led keltainen/oranssi? 5mm matta @16.3.2 80 led Lyhyet johtimet
Led oranssi 5mm kirkas @16.3-2 140 led Lyhyet johtimet
Led keltainen 8mm @16.3.2 3 led 8mm keltainen led
Led keltainen 10mm @16.3.2 23 led 10mm keltainen 70mcd/20mA
Led keltainen 10mm @16.3.2 20 led
Led keltainen pyöreä iso @16.3.2 3 led P1100, Sisällä kuusi erillistä lediä
Led vihreä 3mm @16.4.1 16 led Vishay 3mm vihreä led 1.9V/2mA TLLG4401
Led vihreä 3mm tasapäinen @16.4.1 X led Kingbright L-424GDT
Led vihreä 5mm @16.4.1 14 led Kingbright 5mm vihreä led 5V/11.5mA L-53GD-5V
Led vihreä 5mm @16.4.1 9 led Kingbright 5mm vihreä led 12-14V/11.5mA L-53GD-12V
Led vihreä 5mm @16.4.1 X led Avago 5mm vihreä led HLMP-3507
Led vihreä 5mm @16.4.1 X led kaksi pussia
Led vihreä 5mm vilkkuled @16.4.1 190 led 3,5 - 13V vilkkuled
Led vihreä 5mm tasapäinen @16.4.1 X led
Led vihreä 5mm kulmakannassa @16.4.1 X led
Led vihreä 5mm kirkas @16.4.1 X led L-7113MGC
Led vihreä 10mm @16.4.1 47 led
Led vihreä pylväs 10-osainen @16.4.1 4 led DC-10EWA M
Led vihreä pylväs 4-osainen @16.4.1 10 led HLMP-2820
Led vihreä kulmikas @16.4.1 300 led L-113GDT
Led vihreä kulmikas @16.4.1 100 led L-153GDT
Led vihreä 5mm litteä @16.4.1 60 led Kingbright L-173GD
Led vihreä valopalkki 4-os. @16.4.1 5 led LTL2800G
Led punainen 3mm @xx.x.x 1000 led Tasapäinen 3mm CL120TR3B CL120TR3B.pdf
Led punainen 3mm vilkkuled @16.5.1 5 led Kingbright 3mm punainen vilkkuva 3-14.5V/25mA L-36 BSRD/B
Led punainen 5mm vilkkuled @16.5.1 1 led punainen vilkkuled 5V
Led punainen 5mm vilkkuled @16.5.1 180 led punainen vilkkuled 3,5 - 13V 300 mcd
Led punainen 5mm vilkkuled @16.5.1 X led punainen kirkas vilkkuled
Led vihreä 3mm tasapäinen @16.5.1 X led Kingbright L-424IDT
Led punainen 5mm @16.5.1 7 led Avago 5mm punainen 5V/12mA HLMP-3600
Led punainen 5mm @16.5.1 120 led 80 mcd
Led punainen 5mm @16.5.1 140 led 3,2 mcd
Led punainen 5mm kirkas @16.5.1 34 led 1,85V 20mA 4000 mcd
Led punainen suorakulmainen iso @16.5.1 13 led Sisällä kaksi erillistä lediä
Led punainen pyöreä iso @16.5.1 2 led P1100, Sisällä kuusi erillistä lediä
Led punainen pylväs 4-osainen @16.5.1 15 led HLMP-2620
Led punainen valopalkki 4-osainen @16.5.1 10 led MU08-2201 Datasheet
Led sininen 3mm @16.5.2 X led Sininen 3mm
Led sininen 5mm kirkas UV? @16.5.2 38 led Mahdollisesti Ultra-violet led
Led sininen 5mm kirkas @16.5.2 X led kaksi pussia
Led sininen 5mm kirkas @16.5.2 40 led 3,2V 20mA 8000 mcd
Led sininen 5mm kirkas @16.5.2 23 led Straw Hat kotelo
Led valkoinen 3mm @16.6.1 46 led NICHIA valkoinen kirkas 3.6V/20mA NSPW300
Led valkoinen 5mm @16.6.1 X led kaksi pussia
Led valkoinen 5mm kirkas @16.6.1 10 led Valkoinen kirkas 5mm 3V
Led valkoinen 5mm kirkas @16.6.1 4 led Valkoinen kirkas 5mm LED 5mm WHT 8000mCd
Led valkoinen 5mm kirkas @16.6.1 500 led Liteon LTL33BCWK5A WX50 5mm
Led valkoinen 10mm matta 10mm @16.6.1 14 led
Led valkoinen 10mm kirkas @16.6.1 37 led
Led punainen-vihreä suorakaide @16.6.1 10 led
Led 3mm punainen-vihreä @16.6.1 2 led
Led 3mm kulmakannassa @16.6.1 X led keltainen, vihreä, punainen
Led sekalaiset @16.6.1 X led kolme pussia
Led valikoima @16.6.1 X led rasia
Led 5mm punainen-vihreä @16.6.1 48 led LL-509SGM-2S-2C
Led sininen-vihreä-punainen kirkas 5mm @16.6.1 100 led
Led sininen-vihreä-punainen matta 5mm @16.6.1 15 led
Led sininen-vihreä-punainen kirkas dome @16.6.1 8 led OSTA71A1D-A kupera 7.62x7.62mm2
Led Väriä vaihtava, kirkas 5mm @16.6.1 80 led
Led Väriä vaihtava, matta 5mm @16.6.1 80 led
Ledinauhaa @17.3.2 X led
Led hexanäyttöjä @17.3.2 X led
Led laskinnäyttöjä @17.3.2 X led
Mekaniikkaosat
M1.5x10 @94.1.1 X mekaniikka PH Messinki
M1.5x16 @94.1.1 X mekaniikka URA Messinki
M1.5 M2 mutteri @94.1.1 X mekaniikka M1.5, M2 Mutteri
M2 aluslevy @94.1.1 X mekaniikka M2 Aluslevy
Lukkorenkaita @94.1.1 X mekaniikka Sekalaisia lukkorenkaita
M2x4 @94.1.2 X mekaniikka HEX
M2x5 @94.1.2 X mekaniikka URA uppo
M2x6 @94.1.2 X mekaniikka sekalaisia
M2x8 @94.1.2 X mekaniikka URA
M2x10 @94.1.3 X mekaniikka URA
M2x10 @94.1.3 X mekaniikka URA uppo messinki
M2x12 @94.1.3 X mekaniikka URA
M2x12 @94.1.3 X mekaniikka PHZ
M2x16 @94.1.4 X mekaniikka PHZ
M2x25 @94.1.4 X mekaniikka URA
M2x25 @94.1.4 X mekaniikka PH uppo
M2.5 mutteri @94.2.1 X mekaniikka M2.5 Mutteri
M2.5 aluslevy @94.2.1 X mekaniikka M2.5 Aluslevy
M2.5x3 @94.2.2 X mekaniikka URA messinki
M2.5x4 @94.2.2. X mekaniikka PH
M2.5x6 @94.2.2 X mekaniikka URA
M2.5x6 @94.2.2 X mekaniikka PH
M2.5x8 @94.2.2 X mekaniikka PHZ
M2.5x10 @94.2.3 X mekaniikka PHZ
M2.5x12 @94.2.3 X mekaniikka PH
M2.5x12 @94.2.3 X mekaniikka URA uppo
M2.5x15 @94.2.4 X mekaniikka URA uppo messinki
M2.5x20 @94.2.4 X mekaniikka URA
M2.5x20 @94.2.4 X mekaniikka PHZ
M2.5x6 @94.2.4 X mekaniikka URA
M3 mutteri @94.3.1 X mekaniikka M3 Mutterit
M3 aluslevyt @94.3.2 X mekaniikka M3 Aluslevyt
M3 aluslevyt @94.3.3 X mekaniikka M3 Aluslevyt
M3 nivel @94.3.4 X mekaniikka M3 Mutteri nivelellä
M3x5 @94.4.1 X mekaniikka URA uppo
M3x4 @94.4.1 X mekaniikka TORX
M3x6 @94.4.2 X mekaniikka PHZ
M3x6 @94.4.3 X mekaniikka PHZ uppo
M3x6 @94.4.3 X mekaniikka URA
M3x6 @94.4.3 X mekaniikka PH muovi
M3 @94.4.3 X mekaniikka M3 Mutteri muovi
M3x8 @94.4.4 X mekaniikka URA uppo
M3x8 @94.4.4 X mekaniikka PH uppo + sekalaiset
M3x10 @94.5.1 X mekaniikka URA uppo
M3x10 @94.5.1 X mekaniikka HEX uppo
M3x10 @94.5.2 X mekaniikka PHZ kupu
M3x10 @94.5.2 X mekaniikka URA
M3x10 @94.5.3 X mekaniikka URA Messinki
M3x10 @94.5.3 X mekaniikka HEX
M3x12 @94.5.4 X mekaniikka HEX
M3x13 @94.6.1 X mekaniikka URA
M3x16 @94.6.2 X mekaniikka URA uppo
M3x16 @94.6.3 X mekaniikka URA
M3x18 @94.6.4 X mekaniikka HEX
M3x20 @94.6.4 X mekaniikka HEX
M3x20 @94.7.1 X mekaniikka PHZ
M3x20 @94.7.2 X mekaniikka URA
M3x20 @94.7.2 X mekaniikka URA uppo
M3x25 @94.7.3 X mekaniikka PH
M3x25 @94.7.4 X mekaniikka URA
M3x30 @94.8.1 X mekaniikka PHZ
M3x30 @94.8.1 X mekaniikka URA uppo
M3x35 @94.8.2 X mekaniikka URA
M3x40 @94.8.3 X mekaniikka URA uppo
M3x40 @94.8.4 X mekaniikka URA uppo
M3x45 @94.8.4 X mekaniikka URA
M3x45 @94.8.4 X mekaniikka PHZ
M3x50 @94.9.1 X mekaniikka URA uppo
M3x50 @94.9.2 X mekaniikka URA
M3x75 @94.9.2 X mekaniikka URA
M3x8 @94.9.3 X mekaniikka URA
M3x12 @94.9.3 X mekaniikka URA
M3x10 @94.9.4 X mekaniikka URA RST Kaulusruuvi
M3.5 mutteri @94.10.1 X mekaniikka M3.5 Mutteri
M3.5 aluslevy @94.10.2 X mekaniikka M3.5 Aluslevyt
M3.5x8 @94.10.3 X mekaniikka URA
M3.5x10 @94.10.3 X mekaniikka URA
M3.5x10 @94.10.3 X mekaniikka URA uppo
M3.5x12 @94.10.3 X mekaniikka URA uppo
M3.5x14 @94.10.4 X mekaniikka URA
M3.5x14 @94.10.4 X mekaniikka URA uppo
M3.5x18 @94.10.4 X mekaniikka URA uppo
M3.5x20 @94.11.1 X mekaniikka URA uppo
M3.5x30 @94.11.1 X mekaniikka URA uppo
Messinki @94.11.2 X mekaniikka Messinkiosia
PC-ruuvit @94.11.3 X mekaniikka Sekalaisia PC-ruuveja
M4 mutteri @95.1.1 X mekaniikka M4 Mutteri
M4 mutteri @95.1.2 X mekaniikka M4 Lukkomutteri
M4 mutteri @95.1.2 X mekaniikka M4 mutteri messinki
M4 aluslevy @95.1.3 X mekaniikka M4 aluslevy
M4 aluslevy @95.1.4 X mekaniikka M4 aluslevy
M4x5 @95.2.1 X mekaniikka URA
M4x6 @95.2.1 X mekaniikka URA
M4x6 @95.2.1 X mekaniikka PHZ uppo
M4x8 @95.2.2 X mekaniikka PHZ
M4x8 @95.2.2 X mekaniikka URA
M4x10 @95.2.3 X mekaniikka HEX uppo
M4x10 @95.2.4 X mekaniikka URA
M4x10 @95.2.4 X mekaniikka URA uppo
M4x10 @95.2.4 X mekaniikka PHZ
M4x12 @95.3.1 X mekaniikka URA uppo
M4x14 @95.3.1 X mekaniikka URA
M4x16 @95.3.2 X mekaniikka PH
M4x16 @95.3.2 X mekaniikka URA
M4x16 @95.3.3 X mekaniikka PHZ
M4x20 @95.3.4 X mekaniikka URA
M4x20 @95.4.1 X mekaniikka PH
M4x20 @95.4.1 X mekaniikka HEX
M4x20 @95.4.1 X mekaniikka TORX
M4x20 @95.4.2 X mekaniikka URA uppo
M4x20 @95.4.3 X mekaniikka PH
M4x20 @95.4.3 X mekaniikka mutteri
M4x25 @95.4.4 X mekaniikka PH uppo
M4x25 @95.5.1 X mekaniikka URA
M4x30 @95.5.2 X mekaniikka URA uppo
M4x30 @95.5.3 X mekaniikka PH uppo
M4x35 @95.5.4 X mekaniikka PH
M4x40 @95.5.4 X mekaniikka PHZ
M4x63 @95.6.2 X mekaniikka URA
Kiinnitystarvikkeita @65.7.2 X mekaniikka kytkimiin tms.
Kiinnitysmuttereita @65.7.3 X mekaniikka Potentiometrien muttereita
Aluslevyjä @65.7.3 X mekaniikka Potentiometrien aluslevyjä
Kiinnitysmuttereita @65.8.1 X mekaniikka Potentiometrien ja kytkimien muttereita
Kiinnitysmuttereita @65.8.2 X mekaniikka Potentiometrien ja kytkimien muttereita
Kiinnitysmuttereita @65.8.3 X mekaniikka Potentiometrien ja kytkimien muovimuttereita
Kiinnitysjalka @64.3.1 X mekaniikka Muovia
Kiinnityslenkki tarralla @64.3.1 X mekaniikka Muovia
Kiinnitystappi tarralla @64.3.1 X mekaniikka Muovia
Kiinnitysjalka @64.3.2 X mekaniikka Muovia
Painokiinnike 4mm x 5mm @64.3.3 X mekaniikka Muovia
Painokiinnike 4mm x 7mm @64.3.3 X mekaniikka Muovia
Muovikiinnikkeitä @64.3.3 X mekaniikka Muovia
Korotusholkki ledille @64.4.1 X mekaniikka 5mm ledille, 1/4 in korotus
Korotusholkki 3mm @64.4.1 X mekaniikka 3mm sisähalk./5mm ulkohalkaisija
Korotusholkki transistorille TO-92 @64.4.2 X mekaniikka Transistorin korotusholkki
Kiinnitysholkki ja kaulus 3mm ledille @64.4.2 X mekaniikka Ledin kiinnityskaulus
Kiinnitysholkki ja kaulus 5mm ledille @64.4.3 X mekaniikka Ledin kiinnityskaulus
Kiinnitysholkki 5mm ledille @65.6.1 X mekaniikka Ledin kiinnitysholkki ja heijastin
Kiinnitysholkki 5mm ledille @65.6.2 X mekaniikka Ledin kiinnitysholkki ja heijastin
Korotusholkki @64.5.1 130 mekaniikka M3 ruuville, 3mm
Korotusholkki @64.5.1 50 mekaniikka M3 ruuville, 5mm
Korotusholkki @64.5.1 120 mekaniikka M3 ruuville, 10mm
Korotusholkki @64.5.1 46 mekaniikka M3 ruuville, 12mm
Korotusholkki @64.5.1 100 mekaniikka M3 ruuville, 15mm
Korotusholkki @64.5.2 50 mekaniikka M3 ruuville, 18mm
Korotusholkki @64.5.2 50 mekaniikka M3 ruuville, 20mm
Korotusholkki @64.5.2 50 mekaniikka M3 ruuville, 25mm
Korotusholkki @64.5.2 50 mekaniikka M3 ruuville, 30mm
Korotusholkki @64.5.3 600 mekaniikka M3 ruuville, 21mm
Korotusholkki @64.6.1 600 mekaniikka M3 ruuville, 21mm
Korotuspala @64.6.2 X mekaniikka transistoreille tms. sininen
Korotuspala @64.6.2 X mekaniikka transistoreille tms. punainen
Läpivientiholkki @64.6.2 X mekaniikka
Sekalaisia holkkeja @64.6.2 X mekaniikka
Lattakaapelin tarrakiinnitin @64.6.3 47 mekaniikka 12.7mm leveys
Piirilevyn tarrakiinnike @64.6.3 100 mekaniikka 12.7x12.7mm, piirilevyn 3mm reikään
Korotusholkki @64.7.1 600 mekaniikka M2.5 12mm kierteellä pyöreä metallia
Korotusmutteri @64.7.1 75 mekaniikka M2.5 23.5mm kierteellä metallia
Jatkomutteri M2.5 x 6mm @64.7.1 800 mekaniikka pyöreä
Sekalaisia holkkeja yms. @64.7.2 X mekaniikka
Jatkomutteri M3 x 20mm @64.8.1 400 mekaniikka
Jatkomutteri M3 x 15mm @64.8.1 89 mekaniikka
Jatkomutteri M3 x 8mm @64.8.1 3 mekaniikka
Jatkomutteri M3 x 10mm @64.8.1 22 mekaniikka
Jatkomutteri M3 x 11mm @64.8.1 11 mekaniikka
Jatkomutteri M3 x 12mm @64.8.1 3 mekaniikka
Jatkomutteri M3 x 14mm @64.8.1 5 mekaniikka
Jatkomutteri M3 x 16mm @64.8.1 6 mekaniikka
Jatkomutteri M3 x 18mm @64.8.1 10 mekaniikka
Jatkomutteri M3 x 25mm @64.8.1 11 mekaniikka
Jatkomutteri M3 x 30mm @64.8.1 8 mekaniikka
Jatkomutteri M3 x 35mm @64.8.1 8 mekaniikka
Jatkomutteri M3 x 18mm @64.8.2 92 mekaniikka Messinkiä
Jatkomutteri M3 x 18mm @64.8.2 46 mekaniikka Muovia
Jatkomutteri M4 x 15mm @64.8.2 20 mekaniikka Messinkiä
Jatkomutteri M4 x 19mm @64.8.2 15 mekaniikka Muovia, metallikierteet
Jatkomutteri M4 @64.8.2 X mekaniikka
Kulmakiinnike M3 @64.6.3 X mekaniikka
Aluslevyjä @65.8.3 X mekaniikka Potentiometrien ja kytkimien aluslevyjä
Aluslevyjä ja muttereita @64.7.3 X mekaniikka
Muoviruuveja ja muoviholkkeja @64.8.3 X mekaniikka Rasia/Lajitelma
Messinkiholkkeja ja jatkomuttereita @64.8.3 X mekaniikka Rasia/Lajitelma
Läpivientiholkkeja @64.7.3 X mekaniikka
Kiille-eristeitä @64.1.1 X mekaniikka Pyöreitä, neliskulmaisia, TO-3
Alumiinioksidi-eristeitä @64.1.1 18 mekaniikka TO-220 Seifert KU-904 1.5mm Seifert_Electronic Page 51
Alumiinioksidi-eristeitä @64.1.1 8 mekaniikka TO-247 Seifert KU-909 3mm Seifert_Electronic Page 51
Eristeholkkeja @64.1.2 X mekaniikka
TO-3 kansia @64.1.3 X mekaniikka Eristekansia
TO220 + sekal heatsinks @64.2.1 X mekaniikka jäähdytysripa jäähdytyslevy
TO220 heatsink @64.2.2 X mekaniikka jäähdytysripa jäähdytyslevy
Heatsink @64.2.3 X mekaniikka jäähdytysripa jäähdytyslevy
Merkkilamput ja Polttimot
Glim @60.6.3 12 merkkilamput
LS polttimo @60.6.3 11 merkkilamput ????
Merkkilamput pitimet + polttimot @60.6.2 60 merkkilamput
Merkkilamput @60.6.2 X merkkilamput
Polttimo @60.6.2 X merkkilamput 28-24 24V?
Polttimo @60.6.2 2 merkkilamput 14V 40mA
Merkkilamput LED Keltainen @60.5.1 20 merkkilamput LED keltainen 5/32" kaulus ja johto
Merkkilamput LED Punainen @60.5.1 2 merkkilamput Merkkivalo 12V kannalla ja johdolla
Merkkilamput LED Sininen @60.5.1 5 merkkilamput Merkkivalo 12V kannalla ja johdolla
Merkkilamput LED Vihreä @60.5.1 3 merkkilamput Merkkivalo 12V kannalla ja johdolla
Merkkilamput LED Vihreä @60.5.1 4 merkkilamput Merkkivalo kannalla
Merkkilamput LED Vihreä @60.5.1 2 merkkilamput Merkkivalo 24V kannalla
Merkkilamput LED Punainen @60.6.1 30 merkkilamput Punainen LED johdolla
Merkkilamput 220V @60.6.1 X merkkilamput Merkkivalo 220V johdolla
Pienoishehkulamppuja @60.6.3 X merkkilamput
Polttimo @60.7.1 11 merkkilamput Halogeeni 12V 50W G6.35-kanta BRL1400
Polttimo @60.7.2 20 merkkilamput 756 14V 0.08A 1W T3.25/Ba9s
Polttimo @60.7.2 20 merkkilamput 24V 2W T3.25/Ba9s
Polttimo @60.7.2 20 merkkilamput STANLEY 24V 0.125A 3W Ba9s
Polttimo @60.7.2 9 merkkilamput PHILIPS 8024 NIMP.X 6.3V 0.3A Ba9s
Polttimo @60.7.2 12 merkkilamput 24V 0.05A Ba9s Klöckner&Moeller
Polttimo @60.7.3 400 merkkilamput OSHINO T1 1/4 12V 40mA OL-4031 TPL Pienoishehkulamppuja
Polttimo @60.7.3 X merkkilamput 24V 40mA ???
Polttimo @60.7.3 X merkkilamput 12V 30mA ???
Polttimo @60.7.3 2 merkkilamput 100W 6.6A Halogen
Polttimo @60.7.3 12 merkkilamput 8741 24V 25mA
Polttimo @60.7.3 10 merkkilamput 24V 30mA T5 C5 WB-kanta
Polttimo Sekalaisia @60.8.1 X merkkilamput
Polttimo Sekalaisia @60.8.2 X merkkilamput
Polttimo Sekalaisia @60.8.3 X merkkilamput
Polttimo EVD36V400W Halogen @60.8.3 1 merkkilamput Projektorin 36V/400W lamppu
Mikropiirit
10116N @54.1.1 1 mikropiiri 16-Pin DIP Line Receiver Datasheet
10937PE-40 @54.1.1 56 mikropiiri 40-Pin DIP 16 Segment 16 character display driver (led,vfd) Datasheet
10937PE-40 @54.1.2 67 mikropiiri 40-Pin DIP 16 Segment 16 character display driver (led,vfd) Datasheet
11C90DC @54.1.3 1 mikropiiri 11C90DC F8407
12451-001 @54.1.3 1 mikropiiri 14-Pin DIP
1310P @54.1.3 18 mikropiiri
1741C @54.1.3 1 mikropiiri
1820 @54.1.3 25 mikropiiri SOT-92 1-Wire Digital Temperature Sensor
18B20 @54.1.3 23 mikropiiri SOT-92 1-Wire Digital Temperature Sensor
2102PC @54.1.4 3 mikropiiri
221-464 @54.1.4 4 mikropiiri Siemens 221-464
2900 7B1 @54.1.4 2 mikropiiri
302AL @54.1.4 14 mikropiiri
312AJ @54.1.4 4 mikropiiri
312CJ @54.1.4 1 mikropiiri
321AL @54.2.1 12 mikropiiri
321CJ @54.2.1 13 mikropiiri
322AL @54.2.1 14 mikropiiri
322CJ @54.2.1 1 mikropiiri
3341APC @54.2.1 12 mikropiiri
3341PC @54.2.1 25 mikropiiri
342AJ @54.2.2 9 mikropiiri
342CJ @54.2.2 2 mikropiiri
370AL @54.2.2 12 mikropiiri
370CJ @54.2.2 2 mikropiiri
370CL @54.2.2 1 mikropiiri
3403CP @54.2.3 3 mikropiiri
3844 @54.2.3 32 mikropiiri UC3844N
3N165 @54.2.3 2 mikropiiri
4558CP @54.2.3 1 mikropiiri
4724 @54.2.4 40 mikropiiri 4724BCP 8-bit addressable latch
4724 @54.2.4 20 mikropiiri CD4724BCN 8-bit addressable latch
4724 @54.2.4 2 mikropiiri CD4724BE 8-bit addressable latch
4724 @54.2.4 42 mikropiiri HEF4724BP 8-bit addressable latch
4753 @54.2.4 1 mikropiiri HEF4753VD Timer
4753 @54.2.4 3 mikropiiri HEF4753VP Timer
53C80 @54.3.1 1 mikropiiri SCSI Controller Datasheet
53CF94-2 @54.3.1 2 mikropiiri SCSI-2 Controller Datasheet
725C @54.3.1 4 mikropiiri Operational Amplifier
741CE @54.3.1 3 mikropiiri Operational Amplifier
741HC @54.3.1 48 mikropiiri Operational Amplifier
741HC @54.3.2 20 mikropiiri Operational Amplifier
741TC @54.3.2 7 mikropiiri Operational Amplifier
747HC @54.3.2 1 mikropiiri Operational Amplifier
747DC @54.3.2 7 mikropiiri Operational Amplifier
748CP @54.3.2 1 mikropiiri Operational Amplifier
748HC @54.3.2 5 mikropiiri Operational Amplifier
75107 @54.3.3 6 mikropiiri DS75107N Balanced Line Receiver
75107 @54.3.3 10 mikropiiri SN75107BN Balanced Line Receiver
75109 @54.3.3 6 mikropiiri 75109PC Dual Line Drivers
75109 @54.3.3 2 mikropiiri SN75109AN Dual Line Drivers
75110 @54.3.4 1 mikropiiri SN75110AN Dual Line Drivers
75183 @54.3.4 1 mikropiiri Dual Line Drivers
75188 @54.3.4 12 mikropiiri SN75188N RS-232 Line Drivers
75189 @54.3.4 7 mikropiiri SN75189N RS-232 Line Receivers
75189 @54.3.4 1 mikropiiri SN75189AN RS-232 Line Receivers
753 @54.4.1 3 mikropiiri 8-Pin DIP 753TC FM Gain Block Databook p.433
75324 @54.4.1 4 mikropiiri SN75324N Core Memory Driver SN75324.pdf ti-core-mem-1973.pdf
7534 @54.4.1 1 mikropiiri MC7534L Dual Sense Amplifiers With Inverted Outputs Databook p. 602
75452 @54.4.2 1 mikropiiri SNB75452BP Peripheral Drivers
75461 @54.4.2 60 mikropiiri DS75461N Peripheral Drivers
75461 @54.4.2 1 mikropiiri MC75461 Peripheral Drivers
75461 @54.4.2 6 mikropiiri SN75461P Peripheral Drivers
75462 @54.4.3 37 mikropiiri 75462TC Peripheral Drivers
75462 @54.4.3 10 mikropiiri MC75462P Peripheral Drivers
75464 @54.4.3 28 mikropiiri DS75464N Peripheral Drivers
75464 @54.4.3 3 mikropiiri SN75464P Peripheral Drivers
75468 @54.4.3 4 mikropiiri SN75468N Darlington Transistor Array
6510 @54.4.4 1 mikropiiri 40-Pin DIP 600mil MOS 6510 CBM 1086 S
68000 @54.4.4 2 mikropiiri 64-Pin DIP 900mil MC68000P10
TODO: Move: 68681 @54.3.1 1 mikropiiri PLCC44 68C681CJ CMOS Dual Channel UART Datasheet
68692 @54.4.4 1 mikropiiri PLCC44 SCC68692 DUART Datasheet
8031 @54.5.1 6 mikropiiri 40-Pin DIP 600mil P-80C31-12 P8031AH
8031 @54.5.1 18 mikropiiri PLCC44 N80C31BH S-80C31
8031 @54.5.1 5 mikropiiri 40-Pin DIP 600mil M80C31
8032 @54.5.1 7 mikropiiri 40-Pin DIP 600mil P-80C32 P8032AH
8048 @54.5.1 1 mikropiiri D8048C146
8742 @54.5.1 1 mikropiiri D8742
8748 @54.5.1 1 mikropiiri Intel D4748
8748 @54.5.1 1 mikropiiri NEC D8748D
8749 @54.5.1 1 mikropiiri Fujitsu 8749 6MHz MBL8749N.pdf
8051 @54.5.1 1 mikropiiri DS80C320 8051 clone DS80C320.pdf
8051 @54.5.1 1 mikropiiri DS85000 8051 clone DS5000.pdf
8080 @54.5.2 1 mikropiiri D8080AFC
8080 @54.5.2 5 mikropiiri P8080A
8080 @54.5.2 3 mikropiiri TMS8080ANL
8085 @54.5.2 1 mikropiiri D8085A
8085 @54.5.2 2 mikropiiri D8085AH-2
8085 @54.5.2 4 mikropiiri P8085AH-2 SAB8085AH-P D8085AHC-2
8085 @54.5.3 22 mikropiiri P8085AH
8085 @54.5.3 5 mikropiiri D8085AH
8086 @54.5.3 1 mikropiiri SAB8086-1-P
8088 @54.5.3 1 mikropiiri QD8088
8155 @54.5.3 1 mikropiiri P8155H 256 x 8 SRAM with I/O Ports and Timer
8185 @54.5.4 3 mikropiiri P8185 1kx8 SRAM
8203-1 @92.12.1 1 mikropiiri D8203-1
8205 @54.5.4 26 mikropiiri 16-Pin DIP 300-mil Intel P8205 High Speed 1 Out of 8 Binary Decoder Databook Page 519.
8205 @54.5.4 10 mikropiiri 16-Pin DIP 300-mil SAB8205P High Speed 1 Out of 8 Binary Decoder
8212 @54.5.4 13 mikropiiri 24-Pin DIP 600-mil Intel D8212 8-Bit Input/Output Port
8212 @54.5.4 2 mikropiiri 24-Pin DIP 600-mil DP8212N 8-Bit Input/Output Port Databook Page 525.
8212 @54.5.4 2 mikropiiri 24-Pin DIP 600-mil Intel P8212 8-Bit Input/Output Port Databook Page 525.
8216 @54.6.1 1 mikropiiri D8216 4-Bit Bidirectional Bus Driver
8216 @54.6.1 4 mikropiiri DP8216N 4-Bit Bidirectional Bus Driver
8216 @54.6.1 9 mikropiiri M5L8216P 4-Bit Bidirectional Bus Driver
8216 @54.6.1 13 mikropiiri P8216 4-Bit Bidirectional Bus Driver
8224 @54.6.2 1 mikropiiri DP8224N Clock Generator for 8080A
8224 @54.6.2 7 mikropiiri P8224 Clock Generator for 8080A
8226 @54.6.2 12 mikropiiri DP8226N 4-Bit Bidirectional Bus Driver
8251A @54.6.3 35 mikropiiri P8251A Intel USART
8251A @54.6.3 1 mikropiiri P8251A Amd USART
8251A @54.6.3 4 mikropiiri Siemens SAB82C51A-P USART
8253 @54.6.4 4 mikropiiri 24-Pin DIP 600-mil NEC D8253C-5 INS8253N Programmable Timer Databook Page 573.
8253 @54.6.4 38 mikropiiri 24-Pin DIP 600-mil Intel P8253-5 Programmable Timer Databook Page 573.
8254 @54.6.4 13 mikropiiri P8254 Programmable Interval Timer
8254 @54.6.4 6 mikropiiri P8254-5 Programmable Interval Timer
8254 @54.6.4 8 mikropiiri SAB82C54-2-P P82C54 CA82C54-10CN Programmable Interval Timer
8255 @54.7.1 4 mikropiiri PLCC44 CSS82C55A Programmable Peripheral Interface
8255 @54.7.1 2 mikropiiri D8255AC-2 Programmable Peripheral Interface
8255 @54.7.1 3 mikropiiri D71055C-10,M5M82C55AP-5 = 8255 clone Programmable Peripheral Interface UPD71055.pdf M5M82C55AP.pdf
8255 @54.7.1 4 mikropiiri INS8255D P82C55/I-2 P8255A-5 Programmable Peripheral Interface
8257 @54.7.1 1 mikropiiri P8257-5 Programmable DMA Controller
8259 @54.7.1 4 mikropiiri P8259A P8259 Programmable Interrupt Controller
8259A-8 @54.7.2 1 mikropiiri P8259A-8 Programmable Interrupt Controller
8274 @54.7.2 5 mikropiiri P8274 Multi-Protocol Serial Controller
8275 @54.7.2 1 mikropiiri P8275 Programmable CRT Controller
8279 @54.7.2 0 mikropiiri P8279 Programmable Keyboard/Display Interface
8282 @54.7.2 8 mikropiiri D8282 Octal Latch
8282 @54.7.2 9 mikropiiri P8282 Octal Latch
8286 @54.7.3 33 mikropiiri MBL8286 Octal Bus Transceiver
8286 @54.7.3 11 mikropiiri P8286 Octal Bus Transceiver
8286 @54.7.3 7 mikropiiri SAB8286P Octal Bus Transceiver
8286 @54.7.3 1 mikropiiri uPB8286C Octal Bus Transceiver
80186 @54.7.3 2 mikropiiri PLCC86 N80C186-16 N80C186XL12
80286 @54.7.3 1 mikropiiri CG80286-8
80287 @54.7.3 2 mikropiiri D80287-6 D80C287A-12
80386 @54.7.4 2 mikropiiri Intel A80386DX-25
80386 @54.7.4 1 mikropiiri AMD A80386DX-33
9315PC @54.8.1 6 mikropiiri 1-10 Decoder
935PC @54.8.1 2 mikropiiri DTL Triple input NAND
9368PC @54.8.1 8 mikropiiri 7-Segment Decoder/Driver/Latch with Constant Current Source Outputs (hexadecimal) DM9368.pdf
93L14PC @54.8.1 12 mikropiiri Quad Latch
9316PC @57.12.3 17 mikropiiri Synchronous 4-Bit Counter
9318PC @57.12.3 14 mikropiiri DM9318 Priority Encoder
9334PC 9338PC 9348PC @57.12.3 13 mikropiiri DM93xx
9400 @54.8.1 11 mikropiiri 9600CJ 9600PC Voltage-To-Freq./Frequency-To-Volt.
9601PC 9602PC N9602N @54.8.1 13 mikropiiri Single Retriggerable Monostable
96LS02PC @57.12.3 9 mikropiiri Dual Monostable Multivibator
96LS488D @54.7.4 3 mikropiiri 48-Pin DIP 600-mil IEEE-488 GPIB Controller
A1005 @54.8.2 1 mikropiiri Sony 5L27 A1005
A5307 @54.8.2 220 mikropiiri DING DONG DOOR BELL IC a5307.pdf
A1010A @54.8.2 7 mikropiiri PLCC-44 FPGA 1000-gates Datasheet
A1020B @54.8.2 8 mikropiiri PLCC-44 FPGA 2000-gates Datasheet
AD517JH @54.8.2 10 mikropiiri TO-99 Precision OpAmp AD517.pdf
AD521KD @54.8.3 5 mikropiiri 14-Pin DIP 300-mil Precision Instrumentation Amplifier AD521.pdf
AD532KD @54.8.3 3 mikropiiri Analog Multiplier/Divider AD532.pdf
AD536AKD @54.8.3 4 mikropiiri True RMS to DC converter AD536A.pdf
AD545JH @54.8.3 1 mikropiiri FET-input OpAmp AD545.pdf
AD559KD @54.8.3 1 mikropiiri 16-Pin DIP 300-mil 8-Bit DAC AD559.pdf
AD580JH @54.8.3 7 mikropiiri TO-52 2.5V 0.4% Voltage Reference AD580.pdf
AD590IH @54.8.4 10 mikropiiri Temperature Transducer AD590.pdf
AD590JH @54.8.4 2 mikropiiri Temperature Transducer AD590.pdf
AD623AN @54.8.4 8 mikropiiri Single/Dual-Supply, Rail-to-Rail, Instr. Amplifier AD623.pdf
AD630JN @54.8.4 2 mikropiiri Balanced Modulator/Demodulator AD630.pdf
AD636JH @54.8.4 1 mikropiiri Low Level, True RMS-to-DC Converter AD636.pdf
AD654JN @54.8.4 30 mikropiiri Voltage to Frequency Converter AD654.pdf
AD693AQ @54.9.1 1 mikropiiri Loop-Powered 4–20 mA Sensor Transmitter AD693.pdf
AD7008JP50 @25.6.2 3 mikropiiri PLCC44 Direct Digital Synthesis Modulator AD7008.pdf
AD7226KN @54.9.1 1 mikropiiri Quad 8-Bit D/A Converter AD7226.pdf
AD741CH @54.9.1 2 mikropiiri High Accuracy IC Op Amps AD741.pdf
AD7521JN @57.12.4 2 mikropiiri 18-Pin DIP 300-mil 12-Bit Multiplying DAC AD7520-7521.pdf
AD7524JN @54.9.1 2 mikropiiri 16-Pin DIP 300-mil CMOS 8-Bit Buffered Multiplying DAC AD7524.pdf
AD7531JN @54.9.1 1 mikropiiri 10-Bit, 12-Bit, Multiplying D/A Converters AD7520.pdf
AD7886JD @25.6.2 3 mikropiiri 28-Pin DIP 600-mil 12-Bit, 750 kHz/1 MHz, Sampling ADC AD7886.pdf
AD9632N @25.6.2 3 mikropiiri 8-Pin DIP 300-mil Ultralow Distortion, Wide Bandwidth Voltage Feedback Op Amps AD9631_9632.pdf
AD974AN @54.9.1 1 mikropiiri 28-Pin DIP 300-mil 4-Channel, 16-Bit, 200 kSPS Data Acquisition System AD974.pdf
ADC0804 @54.9.2 27 mikropiiri 20-Pin DIP ADC0804CN, ADC0804LCN 8-Bit ADC ADC0804.pdf
ADC0808CCN @54.9.2 1 mikropiiri 8-Bit A/D Converters with 8-Channel Multiplexer ADC0808.pdf
ADC0809 @54.9.2 3 mikropiiri ADC0809CCV ADC0809CCN 8-Bit A/D Converters with 8-Channel Multiplexer ADC0808.pdf
ADC-305-1 @54.9.2 14 mikropiiri 24-Pin DIP 400-mil 8-Bit, 20MHz CMOS A/D Converters ADC-305.pdf
ADD3501CCN @54.9.2 1 mikropiiri 3-1/2 Digit DVM With Multiplexed 7-Seg. Output ADD3501.pdf
ADG211AKN @54.9.2 30 mikropiiri Quad Analog SPST Switches ADG211A_212A.pdf
ADG508AKN @54.9.3 11 mikropiiri CMOS 8-Channel Analog Multiplexers ADG508A_509A.pdf
ADM691AN @54.9.3 19 mikropiiri Microprocessor Supervisory Circuit ADM691A_693A_800LM.pdf
ADV476 @54.9.3 3 mikropiiri ADV476KN35 RAM-DAC ADV476.pdf
AF100-1CJ @54.9.3 2 mikropiiri
AM26LS31CN @54.9.3 7 mikropiiri
AM26LS31PC @54.9.3 12 mikropiiri
AM26LS32AN @54.9.4 1 mikropiiri
AM26LS32ACN @54.9.4 6 mikropiiri
AM26LS32PC @54.9.4 3 mikropiiri
AN0140AN @54.9.4 1 mikropiiri 18-Pin DIP 8-Channel N-Chan Enh MOSFET ARRAY Datasheet
AN210C @54.9.4 1 mikropiiri
AN214Q @54.9.4 1 mikropiiri (AN2146?)
AN7108 @54.10.1 1 mikropiiri
AN7161N @54.10.1 1 mikropiiri
AN7173K @25.5.1 15 mikropiiri
AN82526 @54.10.1 30 mikropiiri PLCC44 CAN Controller AN82526.pdf
AT89C2051-24PC @54.10.1 5 mikropiiri
AT89C51-24PC @54.10.1 6 mikropiiri
AT89C52-12PC @54.10.1 5 mikropiiri
AT89S51-24PU @54.10.2 10 mikropiiri
AT90S1200 @54.10.2 2 mikropiiri AT90S1200-12PI AT90S1200-16PU
AT90S2313-10PC @54.10.2 3 mikropiiri
AT90S2313-10PI @54.11.3 11 mikropiiri
AT90S8515-8PC @54.10.2 1 mikropiiri
AT93C46D @92.12.1 8 mikropiiri Merkintä ATMLU818
ATMEGA 163-8PC @54.10.2 1 mikropiiri
ATMEGA @54.10.2 6 mikropiiri ATMEGA8-16PI ATMEGA8-16PU ATMEGA328-PU ATMEGA328P-PU
ATMEGA8515 @54.10.4 7 mikropiiri ATMEGA8525-16PI
ATMEGA8515L @54.10.4 1 mikropiiri ATMEGA8515L-8U-35571D
ATTINY2313A-PU @54.10.3 1 mikropiiri
AY-5-1013 @54.10.3 2 mikropiiri 40-Pin DIP 600-mil UART Datasheet
BA521 @54.10.3 1 mikropiiri 10-Pin SIL 5.8W/4 Ohm Audio Amplifier Databook pg 41
BA664 @54.10.3 1 mikropiiri
BD1428 @54.10.3 1 mikropiiri
BEBEK-1 @54.10.3 1 mikropiiri
C1060C @54.10.4 13 mikropiiri 8-Pin DIP 300-mil NEC C1060C 2.5V 1% Reference UPC1060.pdf
CA723CE @54.10.4 1 mikropiiri
CA741 @54.10.4 8 mikropiiri CA741T CA741CT
CA10 @54.10.4 1 mikropiiri RETICON MD CA10 SN 3418
CA3014 @54.11.1 3 mikropiiri
CA3015 @54.11.1 4 mikropiiri
CA3030 @54.11.1 14 mikropiiri
CA3040 @54.11.1 5 mikropiiri
CA3041 @54.11.1 1 mikropiiri
CA3046 @54.11.1 2 mikropiiri
CA3059 @54.11.2 1 mikropiiri
CA3060E @54.11.2 3 mikropiiri
CA3080A @54.11.2 1 mikropiiri
CA3085AE @54.11.2 1 mikropiiri
CA3085E @54.11.2 1 mikropiiri
CA3086 @54.11.2 9 mikropiiri CA3086 CA3086F
CA3130E @54.11.3 10 mikropiiri
CA3130T @54.11.3 1 mikropiiri
CA3140T @54.11.3 9 mikropiiri
CA3140E @54.11.3 7 mikropiiri
CA3146E @54.11.3 17 mikropiiri Datasheet
CA3161E @54.11.4 49 mikropiiri
CA3162E @54.11.4 57 mikropiiri
CA324E @54.11.4 6 mikropiiri
CA3240E @54.11.4 4 mikropiiri
CA3260E @54.11.4 1 mikropiiri
CA3420EZ @54.11.4 12 mikropiiri
CA555CE @54.12.1 2 mikropiiri
CA81 @54.12.1 23 mikropiiri
CDP1852CD @54.12.1 1 mikropiiri
CDP1853E @54.12.1 19 mikropiiri
CDP1854ACE @54.12.1 5 mikropiiri
CIC4821E @54.12.1 7 mikropiiri
CIC806E RCPL @54.12.2 27 mikropiiri 3.5 Digit A/D converter, compatible with icl7126?
CIC9104 @54.12.2 1 mikropiiri
COM2017 @54.12.2 1 mikropiiri UART
COP8782CN 2017 @54.12.2 1 mikropiiri 20-Pin DIP 8-Bit One-Time Programmable Microcontroller Datasheet
CY7B991 @57.11.1 1 mikropiiri PLCC32 CY7B991-5JC Programmable Skew Clock Buffer Datasheet
D4990AC @54.12.3 6 mikropiiri 14-Pin DIP Serial IO Calendar and Clock Datasheet
D5C060-45 @54.12.3 3 muisti 24-pin DIL 300mil 16 Macrocell CMOS PLD D5C060.pdf
D71059C @54.12.3 1 mikropiiri 28-Pin DIP 600-mil Interrupt Control Unit UPD71059.pdf
D7201C @54.12.3 25 mikropiiri
DAC03 @54.12.4 4 mikropiiri DAC03 PMI BD XI
DAC0808LCN @54.12.4 16 mikropiiri
DAC0832LCJ @54.12.4 2 mikropiiri
DAC16EP @54.12.4 5 mikropiiri
DAC9356-12 @54.12.4 1 mikropiiri
DEC741P @54.12.4 2 mikropiiri
DG211CJ @55.1.1 29 mikropiiri
DG211CJ-4 @55.1.1 20 mikropiiri
DG419DJ @55.1.1 15 mikropiiri
DG441DJ @55.1.1 3 mikropiiri
DG442DJ DG445DJ @55.1.1 2+1 mikropiiri
DG508ACJ @55.1.1 23 mikropiiri 16-Pin DIP CMOS analog multiplexer Datasheet
DM541 @55.1.2 1 mikropiiri 8-Pin DIP 300 mil
DM8090N @57.12.1 19 mikropiiri 16-Pin DIP 300-mil
DM8091N @57.12.1 18 mikropiiri 14-Pin DIP 300-mil
DM8123N @57.12.1 3 mikropiiri 16-Pin DIP 300-mil
DM8130N @57.12.1 2 mikropiiri 24-Pin DIP 600-mil
DM8160N @57.12.1 2 mikropiiri 16-Pin DIP 300-mil
DM8230N @57.12.1 2 mikropiiri 16-Pin DIP 300-mil
DM8601N DM8602N @55.1.2 1 mikropiiri
DM8810N @57.12.2 3 mikropiiri 14-Pin DIP 300-mil Quad 2-input TTL-MOS interface gate DM8810.pdf
DM8820N @55.1.2 1 mikropiiri 14-Pin DIP 300 mil Dual Differential Line Receiver DM8820.pdf
DM8831N @55.1.2 1 mikropiiri 16-Pin DIP 300 mil Three-State Line Driver DM8831.pdf
DM8840N @55.1.2 2 mikropiiri BCD-to-Decimal Nixie driver
DP8304BN @55.1.2 2 mikropiiri Octal 3-State Bidirectional Bus Driver AM7303.pdf
DP8572AV @57.11.1 1 PLCC28 mikropiiri Real time clock Datasheet
DS0026CN @55.1.3 10 mikropiiri 8-Pin DIP 300 mil Dual High-Speed MOS Driver DS0026.pdf
DS1307 @55.1.3 15 mikropiiri 8-Pin DIP 300 mil I2C RTC and NVRAM DS1307.pdf
DS1672-2 @55.1.3 2 mikropiiri 8-Pin DIP 300 mil I2C 32-Bit Binary Counter RTC DS1672.pdf
DS1672-3 @55.1.3 2 mikropiiri 8-Pin DIP 300 mil I2C 32-Bit Binary Counter RTC DS1672.pdf
DS1672-33 @55.1.3 4 mikropiiri 8-Pin DIP 300 mil I2C 32-Bit Binary Counter RTC DS1672.pdf
DS1820 @55.1.3 2 mikropiiri 8-Pin DIP 300 mil Lämpötila-anturi 2-wire DS18s20.pdf
DS26LS31CN @55.1.4 27 mikropiiri 16-Pin DIP 300 mil Quad Differential Line Driver DS26LS31.pdf
DS26LS32CN @55.1.4 44 mikropiiri 16-Pin DIP 300 mil Quad Differential Line Receivers DS26LS32.pdf
DS34C86 @55.1.4 2 mikropiiri DS34C86N,DS34C86TN RS-422 RS-423 Line receiver Databook page 61.
DS3487N @55.1.4 1 mikropiiri Quad TRI-STATE® RS-422 Line Driver Databook page 63.
DS3631N @55.1.4 5 mikropiiri 8-Pin DIP 300-mil CMOS Dual Peripheral Drivers DS3631.pdf
DS75176BN @55.1.4 1 mikropiiri 8-Pin DIP 300 mil Multipoint RS-485/RS-422 Transceivers DS75176.pdf
DS75492 @55.2.1 2 mikropiiri 14-Pin DIP 300 mil MOS-to-LED Hex Digit Driver DS75491.pdf
DS8820A @55.2.1 7 mikropiiri 14-Pin DIP 300 mil Dual Differential Line Receiver DS8820.pdf
DS8820AN @55.2.1 12 mikropiiri 14-Pin DIP 300 mil Dual Differential Line Receiver DS8820.pdf
DS8830N @55.2.1 11 mikropiiri 14-Pin DIP 300 mil Dual Differential Line Driver DS7830.pdf
DS8833N @55.2.1 4 mikropiiri 16-Pin DIP 300 mil Quad TRI-STATE Bus Transceivers DS7833.pdf
DS8835N @55.2.1 2 mikropiiri 16-Pin DIP 300 mil Quad TRI-STATE Bus Transceivers DS7833.pdf
DTI2222 @55.2.2 1 mikropiiri CTV Color Processor
EF6821 @55.2.2 3 mikropiiri 40-Pin DIP 600-mil EF6821P EF68B21P EF6821.pdf
EF68B09P @55.2.2 1 mikropiiri 40-Pin DIP 8-Bit microprocessor EF6809E.pdf
EF68B50P @55.2.2 5 mikropiiri 24-Pin DIP 600-mil Async. Comm. Interface Adapter (ACIA) Datasheet
EPC1441PC8 @55.2.2 23 mikropiiri 8-Pin DIP Altera Configuration devices for SRAM-based LUT devices EPC1441PC8.pdf
FDC765AC @55.2.2 1 mikropiiri Floppy Disk Controller FDC765A.pdf
FX105P @56.11.4 4 mikropiiri 16-Pin DIP 300-mil Tone Detector FX105P.pdf
FX429J @56.11.4 2 mikropiiri 24-Pin DIP 600-mil FFSK Modem for Trunked Radio Systems FX429J.pdf
GM16C550 @55.2.4 1 mikropiiri 40-Pin DIP 600 mil UART
HA2-2630-8 @55.2.3 2 mikropiiri
HA2-2645-5 @55.2.3 1 mikropiiri
HA2-5195-5 @55.2.3 2 mikropiiri
HA5221-02 @55.2.4 29 mikropiiri 18-Pin DIP 300-mil Precision Operational Amplifier HA5221.pdf
H113D1 @55.2.4 2 mikropiiri
H117D6 @55.2.4 4 mikropiiri
H111D6 @55.2.4 1 mikropiiri
H13-201-5 @55.2.4 3 mikropiiri
H7555IPA @55.3.1 1 mikropiiri
H7660CPA @55.3.1 2 mikropiiri
HA12017 @55.3.1 4 mikropiiri
HA13158A @25.5.1 12 mikropiiri 4x35 BTL (Bridge Tied Load) Amplifier
HA1457W @55.3.1 1 mikropiiri Crystal Clock Oscillator
HA17741 @55.3.1 2 mikropiiri
HCTL-2020 @55.3.1 1 mikropiiri
HD3-6402R-9 @55.3.2 1 mikropiiri 40-Pin DIP UART
HD6809EP @55.3.2 2 mikropiiri 40-Pin DIP 8-Bit microprocessor
HD6845P @55.3.2 1 mikropiiri 8-bit CRT Controller
HI1-201-5 @55.3.2 4 mikropiiri
HI1-524-5 @55.3.2 1 mikropiiri
HI3-508A-5 @55.3.2 2 mikropiiri
HIN232 @55.3.3 3 mikropiiri HIN232CP HIN232ACP
HIN238CP @55.3.3 2 mikropiiri
HK228-1 @55.3.3 1 mikropiiri
HK527 @55.3.3 27 mikropiiri Ding Dong Module
HM-11 @55.3.3 3 mikropiiri HM-11 Module (CC2541)
HM1-0410-5 @55.3.4 1 mikropiiri
HM2055-D3 @55.3.4 4 mikropiiri
ICL232CPE @55.3.4 1 mikropiiri 16-Pin DIP 300-mil Dual RS-232 Trans./Rec. +5V powered Datasheet
ICL7107CPL @55.3.4 8 mikropiiri ICL7107CPL ICL7107CPLZ
ICL7109CPL @55.3.4 11 mikropiiri
ICL7129CPL @55.4.1 2 mikropiiri
ICL7136CPL @55.4.1 3 mikropiiri
ICL7600CPD ICL7605CJN @55.4.1 2 mikropiiri
ICL7611DCPA @55.4.1 3 mikropiiri
ICL7650CPD @55.4.1 3 mikropiiri
ICL7660SCPA @55.4.1 7 mikropiiri ICL7660SCPA ICL7660SPA
ICL8007CTV @55.4.2 1 mikropiiri
ICL8038CC @55.4.2 1 mikropiiri
ICL8038CCPD @55.4.2 1 mikropiiri
ICL8048CC @55.4.2 8 mikropiiri
ICL8048BCPE @55.4.2 4 mikropiiri
ICL8048CCDE @55.4.3 2 mikropiiri
ICL8048CCPD @55.4.3 8 mikropiiri
ICL8048CCPE @55.4.3 3 mikropiiri
ICL8212CPA @55.4.3 2 mikropiiri
ICM7216BIPI @55.4.3 1 mikropiiri Intersil
ICM7218CIJI @55.4.3 1 mikropiiri Intersil
ICM7555IPA @55.4.4 1 mikropiiri
ICM7556IPD @55.4.4 9 mikropiiri
IH5019CPA @55.4.4 1 mikropiiri
IH5021CPA @55.4.4 2 mikropiiri
IH5042BCPE @55.4.4 1 mikropiiri
IR2183 @55.4.4 3 mikropiiri 8-Pin DIP Half-bridge driver Datasheet
ISD1016AP @55.5.1 30 mikropiiri
ISD1420P @55.5.1 21 mikropiiri Voice Recorder/Playback 20s
ISD2560P @55.5.1 10 mikropiiri
ISD2560PY @55.5.1 1 mikropiiri
ITS1103 @55.5.2 3 mikropiiri
IXDP631PI @55.5.2 1 mikropiiri
JRC0355 @55.5.2 1 mikropiiri 8-Pin DIP 4560D JRC 0355
KA22066 @55.5.2 12 mikropiiri 4.0W Dual Audio Power Amplifier KA22066.pdf
KAD0820AIN @55.5.2 2 mikropiiri
KEMO 170 IF3 @55.5.2 5 mikropiiri
KIA6282K @55.5.3 2 mikropiiri Dual 4.6W Power Amplifier
KTY10-6 @55.5.3 28 mikropiiri
L202 @55.5.3 9 mikropiiri 1x7 Darlington Array
L292 @55.5.3 2 mikropiiri SWITCH-MODE DRIVER FOR DC MOTORS L292.pdf
L293DNE @55.5.3 1 mikropiiri Quad 600mA half h-bridge driver L293.pdf
L298 @55.6.1 1 mikropiiri Dual Half-bridge driver L298.pdf
L6202 @55.5.3 14 mikropiiri FULL BRIDGE DRIVER Datasheet
L6203 @55.5.4 11 mikropiiri FULL BRIDGE DRIVER Datasheet
L6219 @55.5.4 1 mikropiiri Stepper Motor Driver L6219.pdf
L6506 @55.5.4 1 mikropiiri Current Controller for stepper motors L6506.pdf
LA6531 @55.5.4 8 mikropiiri 2-Channel BTL (Bridge Tied Load)-Use Drivers LA6530.pdf
LA7824 @55.5.4 1 mikropiiri Color CRT Sync. & Deflection Datasheet
LF347N @55.5.4 4 mikropiiri PDIP-14 JFET-input VCC:+-18V Quad Operational Amplifier
LF351N @55.6.1 30 mikropiiri PDIP-8 JFET-input VCC:+-18V single Operational Amplifier
LF352D @55.6.1 21 mikropiiri Operational Amplifier
LF353N @55.6.1 14 mikropiiri PDIP-8 JFET-input VCC:+-18V dual Operational Amplifier
LF356 @55.6.1 11 mikropiiri PDIP-8 JFET-input VCC:+-18V single LF356N LF356T LF356DP LF356J Operational Amplifier
LF441CN @55.6.1 30 mikropiiri PDIP-8 JFET-input VCC:+-18V single Operational Amplifier
LF442CN @57.12.4 11 mikropiiri PDIP-8 JFET-input VCC:+-18V dual Operational Amplifier
LF444CN @55.6.2 80 mikropiiri PDIP-14 JFET-input VCC:+-18V quad Operational Amplifier
LH0002CH @55.6.2 2 mikropiiri High speed unity gain buffer
LH0042CH @55.6.2 6 mikropiiri Operational Amplifier
LH0044CH @57.11.2 3 mikropiiri Precision Low Noice Operational Amplifier LH0044.pdf
LH0062CH @55.6.2 1 mikropiiri Operational Amplifier
LM10CH @55.6.2 17 mikropiiri TO-99-8 BJT-input VCC:1.2-40V dual Operational amplifier and voltage reference
LM10CLH @55.6.3 3 mikropiiri Operational amplifier
LM101ADE @55.6.3 2 mikropiiri Operational amplifier
LM101AH @55.6.3 10 mikropiiri TO-99-8 BJT-input VCC:+-22V single Operational amplifier
LM124J @55.6.3 10 mikropiiri CDIP-14 BJT-input VCC:+32V quad Operational amplifier
LM1292N @55.7.4 1 mikropiiri VIdeo PLL Datasheet
LM1310N @55.6.3 11 mikropiiri Phase-Locked Loop FM Stereo Demodulator
LM13600 @55.6.3 1 mikropiiri Dual Operational Transconductance Amplifiers
LM13700 @55.6.1 3 mikropiiri Dual Operational Transconductance Amplifiers LM13700.pdf
LM1458N @57.12.4 1 mikropiiri Dual Operational Amplifier LM1458.pdf
LM158J @55.11.1 5 mikropiiri LM158.pdf
LM1812N @55.6.4 4 mikropiiri ULTRASONIC TRANSCEIVER
LM1881N @55.6.4 12 mikropiiri Video Sync Separator
LM201AN @55.6.4 42 mikropiiri PDIP-8 BJT-input VCC:+-22V Single operational amplifier Datasheet
LM224J @55.6.4 2 mikropiiri CDIP-14 BJT-input VCC:+32V quad Operational amplifier
LM258N @55.7.4 1 mikropiiri PDIP-8 BJT-input VCC:+-16V dual Operational amplifier
LM2901N @55.6.4 4 mikropiiri Quad Differential Comparator
LM2902N @55.6.4 1 mikropiiri Operational amplifier
LM2904N @55.7.1 550 mikropiiri PDIP-8 BJT-input VCC:+-13V dual Operational amplifier LM2904.pdf
LM2907N LM2907N-8 @55.7.1 8 mikropiiri 16/8 DIP Frequency to Voltage Converter Datasheet
LM301AH @55.7.2 64 mikropiiri TO-99-8 BJT-input VCC:+-18V single operational amplifier Datasheet
LM301AN @55.7.2 2 mikropiiri Single operational amplifier Datasheet
LM301AP @55.7.2 9 mikropiiri Single operational amplifier Datasheet
LM302H @55.7.2 2 mikropiiri Voltage Follower LM102-302.pdf
LM308AH @57.11.2 4 mikropiiri Precision Operational Amplifier LM108-308.pdf
LM308N @57.12.4 9 mikropiiri Precision Operational Amplifier LM108-308.pdf
LM310H @57.11.2 1 mikropiiri Voltage Follower LM110-310.pdf
LM311H @55.7.2 4 mikropiiri LM311H LM311N LM311P Differential Comparator
LM318H @55.7.3 9 mikropiiri Operational Amplifier
LM318N @55.7.3 22 mikropiiri Operational Amplifier
LM319N @55.7.3 2 mikropiiri Dual Comparator
LM324N @55.7.3 109 mikropiiri Operational Amplifier LM324M.pdf
LM324AN LM324P @55.7.3 4 mikropiiri Operational Amplifier LM324M.pdf
TODO: Separate: LM325N LM327N @57.12.3 4 mikropiiri Dual +-15V/100mA voltage regulator LM325.pdf
TODO: Separate: LM325N LM327N @57.12.3 4 mikropiiri Dual +-15V/100mA voltage regulator Reference table LM327.pdf
LM329DH @55.7.4 2 mikropiiri 6.9V Temperature compensated zener reference LM329.pdf
LM331N @55.7.4 10 mikropiiri VOLTAGE-FREQUENCY CONVERTER
LM334Z LM336H @55.7.4 4 mikropiiri 3% Adjustable Current Source, Shunt regulator LM334.pdf
LM336Z-2.5 @55.7.4 35 mikropiiri 2.5V Programmable Shunt Regulator LM336.pdf
LM339 @55.8.1 2 mikropiiri LM339AN LM339J Quad Differential Comparator
LM339D @55.8.1 3 mikropiiri Quad Differential Comparator
LM339N @55.8.1 15 mikropiiri Quad Differential Comparator
LM3401N @55.8.1 5 mikropiiri Operational Amplifier
LM346J @55.8.1 1 mikropiiri Operational Amplifier
LM346N @55.8.1 6 mikropiiri Operational Amplifier
LM348N @55.8.2 11 mikropiiri Operational Amplifier
LM358N @55.8.2 11 mikropiiri Operational Amplifier
LM358P @55.8.2 71 mikropiiri Operational Amplifier
LM35CZ @55.8.3 1 mikropiiri Operational Amplifier LM35CZ.pdf
LM360N @55.8.2 5 mikropiiri Differential Comparator
LM363H-100 @57.11.1 9 mikropiiri Precision Instrumentation Amplifier LM363.pdf
TODO: Separate?: LM370N @57.12.4 7? mikropiiri AGC/Squelch Amplifier LM370H.pdf
TODO: Separate?: LM376N @57.12.4 7? mikropiiri 30mA/4.5-40V Voltage Regulator0jj LM376.pdf
LM380N @55.8.2 35 mikropiiri Audio Power Amplifier
LM381 @55.8.2 10 mikropiiri LM381AN LM381A LM381N Dual Preamplifier
LM385Z-2.5 @55.8.2 1 mikropiiri 2.5V 3% Micropower voltage reference LM385Z.pdf
LM386 @55.8.3 48 mikropiiri AUDIO AMPLIFIER
LM386N-1 @55.8.3 9 mikropiiri AUDIO AMPLIFIER
LM382N @55.8.3 2 mikropiiri Low Noise Dual Preamplifier LM382.pdf
LM3886TF @55.8.3 2 mikropiiri Audio Power Amplifier
LM389N @55.8.4 160 mikropiiri Audio Power Amplifier with NPN trans. array LM389N.pdf
LM389N @55.8.4 56 mikropiiri Audio Power Amplifier with NPN trans. array LM389N.pdf
LM3900N @55.8.4 7 mikropiiri Operational Amplifier
LM3911 @55.8.4 4 mikropiiri Temperature Controller
LM3914N @55.9.1 7 mikropiiri DIP-18 Dot/Bar Display Driver 10 leds, lin. scale Datasheet
LM3914N-1 @55.9.1 24 mikropiiri DIP-18 Dot/Bar Display Driver
LM3915N @55.9.1 1 mikropiiri DIP-18 Dot/Bar Display Driver 10 leds, log. scale Datasheet
LM3915N-1 @55.9.1 8 mikropiiri DIP-18 Dot/Bar Display Driver 10 leds, log. scale Datasheet
LM393N @55.9.1 20 mikropiiri Dual Differential Comparator
LM393P @55.9.1 10 mikropiiri Dual Differential Comparator
LM394H @55.9.2 2 mikropiiri Supermatch Transistor Pair
LM4250CN @55.9.2 15 mikropiiri Programmable Operational Amplifier LM4250.pdf
LM555CN @55.9.2 5 mikropiiri 555 Timer
LM556CN @55.9.2 10 mikropiiri LM556CN LM556J Dual 555 Timer
LM567CN @55.9.2 6 mikropiiri one Decoder
LM607CN @55.9.2 40 mikropiiri Operational Amplifier
LM613CN @25.6.3 1 mikropiiri Operational Amplifier LM613.pdf
LM709CN @55.9.3 26 mikropiiri Operational Amplifier
LM6132BIN @55.9.3 1 mikropiiri Operational Amplifier
LM723CN @55.9.3 3 mikropiiri Operational Amplifier
LM741 @55.9.3 12 mikropiiri LM741C LM741CH LM741H Operational Amplifier
LM741 @55.9.3 26 mikropiiri LM741CN Operational Amplifier
LM78S40CN @92.12.1 7 mikropiiri Universal Switching Regulator Subsystem LM78S40.pdf
LMC660CN @55.9.3 1 mikropiiri Operational Amplifier Datasheet
LMC7101BIN @55.9.4 1 mikropiiri Operational Amplifier
LMF100CCN @25.6.3 1 mikropiiri Dual Switched Capacitor Filter LMF100.pdf
LP324N @25.6.3 12 mikropiiri Ultra Low Power Operational Amplifier LP324.pdf
LPC660IN @25.6.3 1 mikropiiri Operational Amplifier LPC660.pdf
LS1241 @55.9.4 1 mikropiiri Two-Tone Ringer Datasheet
LS141CB @55.9.4 8 mikropiiri Operational Amplifier
LT1014DN @55.9.4 5 mikropiiri 8-Pin DIP 300mil Operational Amplifier
LT1078CN8 @55.9.4 1 mikropiiri 8-Pin DIP 300mil Operational Amplifier
LT1097CN8 @55.9.4 7 mikropiiri 8-Pin DIP 300mil Low power precision op amp Datasheet
LTC1042CN @55.10.1 1 mikropiiri 18-Pin DIP 300mil Intrumentation capacitor switch Datasheet
LTC1044ACN8 @55.10.1 2 mikropiiri Voltage Converter
LTC1046CN8 @55.10.1 2 mikropiiri Voltage Converter
LTC1144CN8 @55.10.1 2 mikropiiri
LTC485CN8 @55.10.1 5 mikropiiri RS485 Interface Transceiver
LTC690CN8 @55.10.1 10 mikropiiri Power Monitor
M120D-B1 @55.10.2 2 mikropiiri
M252 @55.10.2 1 mikropiiri M252 D1AA
M66T-228 @55.10.2 43 mikropiiri Melody generator - Mendelsonin häämarssi Datasheet
MAB8441P @55.10.2 1 mikropiiri 8-bit 4kB ROM CPU
MACH110 @55.10.2 5 mikropiiri 44-Pin PLCC CMOS Programmable Logic Datasheet
MACH210 @55.10.2 3 mikropiiri 44-Pin PLCC CMOS Programmable Logic Datasheet
MACH215 @55.10.3 16 mikropiiri 44-Pin PLCC CMOS Programmable Logic Datasheet
MAX121CPE @55.10.3 2 mikropiiri 14-bit ADC Datasheet
MAX230CPP @55.10.3 2 mikropiiri 20-pin DIP +5V Powered multi-channel RS232 Trans./Rec. Datasheet
MAX232CPE @55.10.3 19 mikropiiri
MAX232EPE @55.10.3 9 mikropiiri
MAX233CPP @55.10.3 12 mikropiiri
MAX238CNG @55.10.4 2 mikropiiri
MAX3232CPE @55.10.4 21 mikropiiri
MAX412CPA @55.10.4 3 mikropiiri
MAX485CPA @55.10.4 1 mikropiiri
MAX487ECPA @55.10.4 2 mikropiiri
MAX680CPA @55.11.1 5 mikropiiri
MAX7219CNG @55.11.1 3 mikropiiri Serial Interface 8-digit 7-seg led driver MAX7219.pdf
MAX7221CNG @55.11.1 1 mikropiiri SPI 8-digit 7-seg led driver
MAX7400CSA @55.11.1 1 mikropiiri
MAX776 @55.11.1 2 mikropiiri
MB8116H @55.11.2 17 mikropiiri
MC10101L (=4001) @55.11.2 20 mikropiiri
MC10103L @55.11.2 20 mikropiiri
MC10116P @55.11.2 2 mikropiiri MC10116P MC10116PD
MC10125L @55.11.2 16 mikropiiri
MC1305P @55.11.3 2 mikropiiri
MC1309P @55.11.3 2 mikropiiri
MC1310 @55.11.3 5 mikropiiri
MC1310P @55.11.3 5 mikropiiri
MC1314P MC1315P @55.11.3 2 mikropiiri
MC1327PQ @55.11.3 3 mikropiiri
MC1349P @55.11.4 1 mikropiiri
MC1355P @55.11.4 4 mikropiiri
MC1358P @55.11.4 2 mikropiiri
MC1439G @55.11.4 1 mikropiiri
MC145436P1 @55.11.2 1 mikropiiri Dual Tone Multiple Frequency Receiver MC145436.pdf
MC146818ACP @55.11.4 1 mikropiiri 24-Pin DIP 600-mil RTC and RAM Datasheet
MC146818PGC6 @55.11.4 2 mikropiiri 24-Pin DIP 600-mi RTC and RAM Datasheet
MC1558U @55.12.1 4 mikropiiri
MC1566L @55.12.1 3 mikropiiri
MC1590G @55.12.1 3 mikropiiri
MC1648L @55.12.1 3 mikropiiri
MC1709CG @55.12.1 1 mikropiiri
MC1710CG @55.12.1 2 mikropiiri
MC1723CG @55.12.2 4 mikropiiri
MC1741CG @55.12.2 3 mikropiiri
MC1741CP1 @55.12.2 14 mikropiiri
MC1741CP2 @55.12.2 2 mikropiiri
MC1741G @55.12.2 3 mikropiiri
MC1741 @55.12.2 5 mikropiiri MC1741SCP1 MC1741U
MC1748CP1 @57.12.4 2 mikropiiri
MC3005P @55.12.3 2 mikropiiri
MC33079P @55.12.3 5 mikropiiri Quad OpAmp, Low Noise Datasheet
MC3340P @55.12.3 7 mikropiiri
MC34001P @55.12.3 3 mikropiiri JFET Single OpAmp (roughly TL071/081)
MC34002P @55.12.3 27 mikropiiri JFET Dual OpAmp (roughly TL072/082)
MC3401P @55.12.3 1 mikropiiri
MC34182P @55.12.4 1 mikropiiri Datasheet
MC3470P @55.12.4 2 mikropiiri
MC3486N @25.6.1 1 mikropiiri 16-Pin DIP 300mil Quad 422/423 Line Receiver with 3-State Outputs MC3486.pdf
MC4741CP @55.12.4 6 mikropiiri
MC660L @55.12.4 11 mikropiiri
MC672L @55.12.4 9 mikropiiri
MC672P @55.12.4 2 mikropiiri
MC6809P @56.1.1 3 mikropiiri 40-Pin DIP 8-Bit microprocessor Datasheet
MC6821P @56.1.1 29 mikropiiri 40-Pin DIP 600-mil Peripheral interface adapter (PIA) Datasheet
MC68340RP16B @56.1.1 1 mikropiiri Integrated Processor with DMA Datasheet
MC6850P @56.1.2 12 mikropiiri 24-Pin DIP 600-mil Async. Comm. Interface Adapter (ACIA) Datasheet
MC6888L @56.1.2 2 mikropiiri
MC68901FN @56.1.2 2 mikropiiri
MC68HC000FN8 @56.1.2 39 mikropiiri PLCC68 MC68HC000FN8 68000 8MHz CPU M68000UM.pdf
MC68HC11A0FN @56.1.3 3 mikropiiri 8-Bit HCMOS Microprocessor Datasheet
MC8304P @56.1.3 6 mikropiiri
MC831P @57.12.2 2 mikropiiri MC831P MC8310P
MC838P @57.12.2 1 mikropiiri
MC849P @57.12.2 4 mikropiiri
MC890P @56.1.3 5 mikropiiri
MC899P @57.12.2 1 mikropiiri
MC9802P @56.1.3 2 mikropiiri
MCM6810AP @56.1.3 2 mikropiiri
MCP2221 I/P @56.12.2 2 mikropiiri
MCP23?17-E/SP @56.1.4 7 mikropiiri MCP23017-E/SP MCP23S17-E/SP
MCP4821 @56.1.4 2 mikropiiri 8-DIP 300mil 12-Bit DACs with Internal VREF and SPI Interface Datasheet
MCP602 @56.1.4 3 mikropiiri
MD4368 @56.1.4 2 mikropiiri
MDA2062 @56.1.4 3 mikropiiri
MF10CN @56.1.4 12 mikropiiri
MF4CN-50 @56.12.4 7 mikropiiri
MF5CN @56.12.4 8 mikropiiri
MF6CN @56.12.4 14 mikropiiri 14-Pin DIP MF6CN-50 MF6CN-100 Switched Capacitor Filter MF6.pdf
MFC6030A @56.2.1 2 mikropiiri
MFC8070 @56.2.1 6 mikropiiri
MIC4422CT @56.2.1 2 mikropiiri 9A-Peak Low-Side MOSFET Driver
MK3801N-4 @56.2.1 1 mikropiiri UART TIC
MK38P70 @56.2.1 1 mikropiiri MK38P70/02H
MK50242P @56.2.1 2 mikropiiri Top-Octave audio frequence generator Datasheet
MK50250N @56.2.2 1 mikropiiri Digital Alarm Clock
MK5089N @56.2.2 2 mikropiiri Tone Decoder Datasheet
MK50992N @56.2.2 2 mikropiiri Pulse Dialer with Redial
MK5098N @56.2.2 1 mikropiiri Pulse Dialer
MK5103N @56.2.2 2 mikropiiri Tone Decoder
MK5170N @56.2.2 1 mikropiiri Repertory Dialer
ML308T @56.2.3 19 mikropiiri
ML709 @56.2.3 3 mikropiiri
ML741CT @56.2.3 2 mikropiiri
ML741T @56.2.3 2 mikropiiri
MM5055N @56.2.3 6 mikropiiri Quad 128-bit shift register
MM80C95N @56.2.3 13 mikropiiri 3-State Hex Buffers
MN1280-M @56.2.4 2 mikropiiri CMOS LSI for supply voltage detection Datasheet
MN1380-L @56.2.4 38 mikropiiri CMOS LSI for supply voltage detection Datasheet
MP7226KN @56.2.4 2 mikropiiri
MSI7010 @57.12.2 1 mikropiiri
MSM5502RS @56.2.4 3 mikropiiri
MSP430F2013T @56.12.3 1 mikropiiri 14-Pin DIP 2KB+256B Flash Memory 128B RAM MSP430X20X1.pdf
MSP430G2211 @56.12.3 2 mikropiiri 14-Pin DIP 128B RAM/2kB ROM 16MHz MCU Datasheet
MSP430G2432 @56.12.3 1 mikropiiri 20-Pin DIP 256B RAM/8kB ROM 16MHz MCU Datasheet
MSP430G2452 @56.12.3 1 mikropiiri 20-Pin DIP 256B RAM/8kB ROM 16MHz MCU Datasheet
MT8870 @56.3.3 3 mikropiiri MT8870BC MT8870BE DTMF Receiver {https://nx2063.your-storageshare.de/s/j44QmZZYsno5JB9 MT8870.pdf]
MX614P @56.2.4 10 mikropiiri Bell 202 compatible modem chip
MX7226KN @56.2.4 2 mikropiiri
N80C188 @56.1.3 3 mikropiiri Datasheet
N82050 @57.11.1 1 mikropiiri PLCC28 Asynchronous Serial Controller Datasheet
N8261A @56.3.1 10 mikropiiri
N8T97N @56.3.1 3 mikropiiri
NAT7210BCP @54.7.4 1 mikropiiri IEEE 488.2 Controller NAT7210.pdf
NE5050N @56.3.1 24 mikropiiri
NE531N @56.3.1 13 mikropiiri 8-Pin DIP 300-mil High Slew Rate Operational Amplifier Datasheet
NE544N @56.3.1 7 mikropiiri
NE5512N @56.3.1 2 mikropiiri
NE5530N @56.3.2 1 mikropiiri
NE5532N @56.3.2 0 mikropiiri
NE5532P @56.3.2 6 mikropiiri
NE5534AH @56.3.2 1 mikropiiri
NE5534N @56.3.2 11 mikropiiri Single operational amplifier Datasheet
NE5534 @56.3.2 6 mikropiiri NE5534AN NE5534AP NE5534P
NE555JG @56.3.3 2 mikropiiri
NE555N @56.3.3 100 mikropiiri NE555.pdf
NE555P @56.3.3 57 mikropiiri
NE555T @56.3.3 1 mikropiiri
NE556N @56.3.4 106 mikropiiri NE556.pdf
NE561B @56.3.4 1 mikropiiri
NE565A @56.3.4 2 mikropiiri
NE565N NE567N NE570N @56.3.4 4 mikropiiri
NE592N14 @56.3.4 6 mikropiiri
OP07DZ OP177CP @56.4.1 5 mikropiiri Operational Amplifier Datasheet Datasheet
OP27EP @56.4.1 4 mikropiiri Operational Amplifier Datasheet
OP27G @56.4.1 2 mikropiiri Operational Amplifier Datasheet
OP400GP @56.4.1 18 mikropiiri PMI OP400 GP Operational Amplifier Datasheet
OP490GP @56.4.1 1 mikropiiri Operational Amplifier
OPA2134PA @56.4.1 0 mikropiiri Operational Amplifier Datasheet
P2012AL @56.4.2 1 mikropiiri
P8X32A-D40 @56.3.3 1 mikropiiri 40-Pin DIL 600 mil 8-Cog Multiprocessor Microcontroller
PBD3534 @56.12.3 9 mikropiiri 16-Pin DIP DTMF generator PBD3534.pdf
PCA82C200P @56.12.4 1 mikropiiri 28-Pin DIP 600 mil CAN Controller PCA82C200.pdf
PCA9554N @56.12.4 1 mikropiiri 16-Pin DIP 8-bit I2C and SMBus I/O port Datasheet
PCD3311CP @56.12.4 2 mikropiiri DTMF Tone generator
PCE2111P @56.4.3 2 mikropiiri LCD Driver
PCF2112P @56.4.3 4 mikropiiri LCD Driver
PE-64101 @56.5.4 1 mikropiiri
PIC12F508 @56.4.3 3 mikropiiri 8-Pin DIP 8-Bit Flash Microcontroller 512B ROM/25B RAM Datasheet
PIC16C55A-04/P @56.4.3 1 mikropiiri 28-Pin 8-Bit CMOS Microcontroller 512B ROM/24B RAM Datasheet
PIC16C56A @56.4.3 1 mikropiiri 18-Pin
PIC16C58B-04/P @56.4.3 18 mikropiiri
PIC16C74A-04I/P @56.4.4 15 mikropiiri 40-Pin DIP 8-Bit CMOS Microcontroller 4k ROM/192B RAM Datasheet
PIC16C765/JW @92.12.1 2 mikropiiri
PIC16C7xxx @56.4.4 2 mikropiiri PIC16C73A-04/SP PIC16C74/JW 8-Bit CMOS Microcontroller Datasheet
PIC16F @56.4.4 3 mikropiiri PIC16F1788 PIC16F84A-04I/SP PIC16F84-10/P
PIC16F873 @56.4.4 12 mikropiiri 28-Pin DIP 300-mil -04I/SP -04/SP 8-Bit CMOS FLASH Microcontroller 4k ROM/192B RAM Datasheet
PIC17C42A-16/P @56.4.4 1 mikropiiri
PIC18F2455-1/SP @56.5.1 3 mikropiiri 28-Pin DIP 300-mil Flash USB MCU 24k ROM/2k RAM Datasheet
PM7226KN @56.5.1 2 mikropiiri
PS2001 @56.5.1 11 mikropiiri
R323 @56.5.1 1 mikropiiri GE R323 002
R80C186 @56.1.3 1 mikropiiri
RC4200ADE @56.5.1 1 mikropiiri 8-Pin DIP Precision Analog Multiplier Datasheet
RC725T @56.5.1 7 mikropiiri
RTS993-9A @56.5.2 2 mikropiiri 1024 Notes Dual Tone Melody Generator Datasheet
S0273BC @56.5.2 1 mikropiiri 16-Pin DIP
S042P @56.5.2 56 mikropiiri Siemens mixer
S0436 @56.5.2 1 mikropiiri 6-Pin DIP Siemens Fixed 1:64 Frequency Divider Datasheet
S2559E @25.6.2 4 mikropiiri 16-Pin DIP DTMF Tone Generator S2559F.pdf
S566B @56.5.2 1 mikropiiri Siemens
S576B @56.5.2 13 mikropiiri Siemens
S6551AD @57.11.1 6 mikropiiri ACIA Async Comm Interface Adapter S6551AD.pdf
SA602N @56.11.4 5 mikropiiri 8-Pin DIP 300-mil SA602.pdf
SA604N @56.5.3 1 mikropiiri 16-Pin DIP 300-mil High Performance Low Power FM IF System Datasheet
SA614AN @56.5.3 2 mikropiiri 16-Pin DIP 300-mil Low Power FM IF System Datasheet
SAA1099P @56.5.3 104 mikropiiri 18-Pin DIP 300-mil Stereo Sound Generator Datasheet
SAA5020 @56.5.3 36 mikropiiri 24-Pin DIP 600-mil Videotext Controller Datasheet
SAA5030 @56.5.4 33 mikropiiri 24-Pin DIP 600-mil Teletext Video Processor Datasheet
SAA5041 @56.5.4 1 mikropiiri 28-Pin DIP 600-mil Teletext data acq. and control Datasheet
SAA5050 @56.5.4 6 mikropiiri 28-Pin DIP 600-mil Teletext Character Generator / English Datasheet
SAA5051 @56.5.4 9 mikropiiri 28-Pin DIP 600-mil Teletext character generator / German Datasheet
SAA5052 @56.6.1 6 mikropiiri 28-Pin DIP 600-mil Teletext character generator / German Datasheet
SAA5053 @56.6.1 1 mikropiiri 28-Pin DIP 600-mil Teletext character generator / Italian Datasheet
SAB0600 @56.6.1 220 mikropiiri 8-Pin DIP 300-mil SAB0600RD? Three-Tone Chime Datasheet
SAK140 @56.6.1 6 mikropiiri 16-Pin DIP Revolution Counter SAK140.pdf
SAS560 @56.6.2 3 mikropiiri 16-Pin DIP 300-mil Switching Amplifier for 4-Channel Touch Tuning Datasheet
SAS570 @56.6.2 4 mikropiiri 16-Pin DIP 300-mil Switching Amplifier for 4-Channel Touch Tuning Datasheet
SAS580 @56.6.2 2 mikropiiri 18-Pin DIP 300-mil Switching Amplifier for 4-Channel Touch Keys Datasheet
SAS590 @56.6.2 2 mikropiiri 18-Pin DIP 300-mil Switching Amplifier for 4-Channel Touch Keys Datasheet
SCB68172 @56.6.2 20 mikropiiri VME Bus controller SBC68172.pdf
SCA610-C28H1A @56.6.3 2 mikropiiri 8-Pin DIP VTI Accelerometer/Inclinometer SCA610-C28H1A.pdf
SE5534AN @56.6.1 23 mikropiiri SE5534AN.pdf
SFC2101A @56.6.3 11 mikropiiri Operational Amplifier SFC2101A.pdf
SFC2101AG @56.6.3 5 mikropiiri Operational Amplifier SFC2101A.pdf
SFC2741EC SFC2741C @56.6.3 2 mikropiiri Operational Amplifier SFC2741.pdf
SFC2741T @56.6.3 2 mikropiiri Operational Amplifier SFC2741.pdf
SFC2748C @56.6.3 7 mikropiiri Operational Amplifier SFC2741.pdf
SG3524N @56.6.4 30 mikropiiri 16-Pin DIP Regulating Pulse Width Modulator SG3524.pdf
SHC298AM @56.6.4 88 mikropiiri Sample and Hold Amplifier SHC298.pdf
SHM-IC-1 @56.6.4 24 mikropiiri 14-Pin DIP Sample-and-Hold SHM-IC-1.pdf
SL386N @56.6.4 3 mikropiiri
SLAxxxx @56.7.1 4 mikropiiri SLA5054 SLA5058 SLA7026M
SN151800N @56.7.1 5 mikropiiri DTL Dual 5-input NAND
SN15302N @56.7.1 2 mikropiiri Quad 2-input NAND
SN15312N @56.7.1 2 mikropiiri Dual J-K Flip-Flop
SN15830N @56.7.1 1 mikropiiri DTL Dual 4-input NAND
SN15845N @56.7.1 4 mikropiiri DTL Gated J-K/R-S Flip-Flop
SN16862AN @56.7.2 1 mikropiiri Sensor for 4 keys
SN29764AN @56.7.2 2 mikropiiri 7-Segment Decoder
SN29772AN @56.7.2 1 mikropiiri Sensor
SN72440N @56.7.2 9 mikropiiri Zero-Voltage Switch
SN72709P @56.7.2 2 mikropiiri Operational Amplifier
SN72741 @56.7.3 1 mikropiiri SN72741L Operational Amplifier SN72741.pdf
SN72741 @56.7.3 3 mikropiiri 8-Pin DIP 300-mil SN72741P 72741 Operational Amplifier SN72741.pdf
SN72747N @56.7.3 1 mikropiiri Operational Amplifier
SN75150P @56.7.3 5 mikropiiri Dual Line Driver
SN75153N @56.7.3 15 mikropiiri RS422 Line Driver
SN75ALS172N @56.7.4 1 mikropiiri RS-422,485 Line Driver
SN75ALS173N @56.7.4 1 mikropiiri RS-422,423,485 Line Receiver
SN75ALS174N @56.7.4 1 mikropiiri RS-422,485 Line Driver
SN75ALS175N @56.7.4 1 mikropiiri RS-422,423,485 Line Receiver
SN75ALS176 @56.7.4 1 mikropiiri RS-422,485 Line Transceivers
SN75ALS180N @56.7.4 1 mikropiiri RS-422,485 DRIVER AND RECEIVER PAIRS
SN75172N @56.8.1 2 mikropiiri RS422, 485 Line Driver
SN75173N @56.8.1 1 mikropiiri RS422,423,485 Line Receiver
SN75176BP @56.8.1 28 mikropiiri RS422 Bus Transceiver
SN75179BP @56.8.1 4 mikropiiri 8-Pin DIP RS422/RS485 Driver/Reveiver SN75179B.pdf
SN75234N @56.8.1 4 mikropiiri core mem amplifier SN75234.pdf Databook p.177
SN76622N @56.8.1 1 mikropiiri Sound I.F. amplifier/demodulator for TV
SN76660N @56.8.2 5 mikropiiri Sound I.F. amplifier/demodulator for TV
SNX96533NL @56.8.2 1 mikropiiri Datasheet not found
SP0102892 @25.6.3 1 mikropiiri 9-Pin SIL Datasheet not found
SP232ACP @56.8.2 13 mikropiiri 16-Pin DIP 300-mil Enhanced RS-232 Line Drivers/Receivers Datasheet
SP483CS @56.8.2 1 mikropiiri 8-Pin DIP Low Power Half-Duplex RS-485 Transceivers Datasheet
SP574B @56.8.2 2 mikropiiri 28-Pin DIP 12–Bit Sampling A/D Converters Datasheet
SP9687 @56.8.2 1 mikropiiri 16-Pin DIP Ultra fast comparator SP9687.pdf
SPH4692 @56.8.3 1 mikropiiri 18-Pin DIP 300-mil Power Hybrid for SMPS Datasheet
SS68212 @56.8.3 20 mikropiiri
SSM2110 @56.8.3 4 mikropiiri
SSM2120 @56.8.3 2 mikropiiri
ST16C650CP @56.8.3 1 mikropiiri USART ST16C650CP.pdf
ST232CN @56.8.3 1 mikropiiri 16-Pin DIP 300 mil 5 V powered RS-232 drivers and receivers ST232C.pdf
ST62T60C6 @56.8.3 1 mikropiiri 8-BIT OTP/EPROM MCU Datasheet
T1B7334 @56.8.4 1 mikropiiri
T2550 @56.8.4 1 mikropiiri
T3011001 @56.8.4 1 mikropiiri
T3017013 @56.8.4 1 mikropiiri
T5675CP @56.8.4 52 mikropiiri 8-Pin DIP Dual Line Driver Datasheet
TA7089P @56.9.1 3 mikropiiri
TA7092AP-B @56.9.1 2 mikropiiri TABS-T-10B 4.8W/4Ohm Databook pg. 68,471
TA8217P @56.9.1 1 mikropiiri
TAA263 @56.9.1 6 mikropiiri TO-72 Low-Level Amplifier Datasheet
TAA293 @56.9.1 3 mikropiiri
TAA300 @56.9.2 48 mikropiiri
TAA310A @56.9.2 5 mikropiiri
TAA450 @56.9.2 22 mikropiiri 10-Pin TO-74 FM Channel Amplifier Datasheet
TAA522 @56.9.2 1 mikropiiri
TAA550 @56.9.3 9 diodi zener TO-18 2-pin 30-36V/15mA Voltage Stabilizer Datasheet
TAA560 @56.9.3 3 mikropiiri TO-72 Level Detector Datasheet
TAA570 @56.9.3 6 mikropiiri
TAA611B12 @56.9.3 4 mikropiiri Power Plastic Split-DIP 14-Pin Audio Amplifier Datasheet
TAA640 @56.9.3 1 mikropiiri
TAA710 @56.9.4 1 mikropiiri 14-Pin DIP TV IF Sound Amplifier Datasheet
TAA761A @56.9.4 1 mikropiiri
TAA861A @56.9.4 2 mikropiiri
TAA970 @56.9.4 2 mikropiiri
TAD100 @56.9.4 1 mikropiiri 14-Pin DIP Integrated A.M.Radio Receiver Circuit Datasheet
TBA120 @56.10.1 1 mikropiiri 14-Pin DIP 300-mil FM IF Amplifier with Demodulator Datasheet
TBA120A @56.10.1 5 mikropiiri 14-Pin DIP 300-mil FM IF Amplifier with Demodulator Datasheet
TBA120AS @56.10.1 5 mikropiiri 14-Pin DIP 300-mil FM IF Amplifier with Demodulator Datasheet
TBA120S @56.10.1 73 mikropiiri 14-Pin DIP 300-mil FM IF Amplifier with Demodulator Datasheet
TBA120T,TBA120U @56.10.1 6 mikropiiri 14-Pin DIP 300-mil TBA120T TBA120U FM IF Amplifier with Demodulator Datasheet
TBA221 @56.10.2 50 mikropiiri 8-Pin DIP 300-mil Single Operational Amplifier Datasheet
TBA231 @56.10.2 110 mikropiiri 14-Pin DIP 300-mil Dual Low Noise OpAmp Datasheet
TBA2800 @56.10.2 16 mikropiiri 14-Pin DIP 300-mil Infrared Preamplifier Datasheet
TBA281 @56.10.2 6 mikropiiri TO-100 Jänniteregulaattori TBA281.pdf
TBA395 @56.10.3 1 mikropiiri 14-Pin DIP Chrominance Combination Circuit Datasheet
TBA396 @56.10.3 3 mikropiiri 14-Pin DIP Luminance and Chrominance Combination Circuit Datasheet
TBA440C @56.10.3 1 mikropiiri 16-Pin DIP Monolitic Video IF Amplifier Datasheet
TBA480 @56.10.3 1 mikropiiri 16-Pin DIP IF Amplifier and FM Demodulator
TBA500P @56.10.3 2 mikropiiri 16-Pin DIP 300-mil TV Luminance Combination Datasheet
TBA520 @56.10.4 2 mikropiiri 16-Pin DIP PAL TV Chroma Demodulator Datasheet
TBA530 @56.10.4 4 mikropiiri 16-Pin DIP 300-mil RGB Matrix Pre-amplifier Datasheet
TBA540 @56.10.4 5 mikropiiri 16-Pin DIP 300-mil Reference Combination Datasheet
TBA560C @56.10.4 6 mikropiiri 16-Pin DIP Luminance and Chrominance Control Combination Datasheet
TBA810P @56.10.4 30 mikropiiri 16-Pin DIP 300-mil 7W Audio Amplifier TBA810P.pdf
TBA810S @56.11.1 1 mikropiiri 16-Pin DIP 300-mil 7W Audio Amplifier TBA810S.pdf
TBA820M @56.11.1 200 mikropiiri 14-Pin DIP 2W Audio Amplifier Datasheet
TBA920 @56.11.2 1 mikropiiri 16-Pin DIP Television Horizontal Oscillators Datasheet
TBA970 @56.11.2 2 mikropiiri 16-Pin DIP Television Video Amplifier Datasheet
TBB1331A @56.11.2 1 mikropiiri 6-Pin DIP Operational Amplifier Datasheet
TCA160B @56.11.3 10 mikropiiri 16-Pin DIP 300-mil 1.2W Audio Amplifier Circuit Databook pg 294,516
TCA160C @56.11.3 5 mikropiiri 16-Pin DIP 300-mil 1.2W Audio Amplifier Circuit Databook pg 294,516
TCA270S @56.11.3 1 mikropiiri 16-Pin DIP 300-mil Television Signal Processing Circuit Datasheet
TCA365 @56.11.3 1 mikropiiri TO-220 Power Operational Amplifier TCA365B.pdf
TCA440 @56.11.3 7 mikropiiri 16-Pin DIP 300-mil AM Receiver Circuit Datasheet
TCA511 @56.11.4 3 mikropiiri 16-Pin DIP TV Horizontal and Vertical Processor Datasheet
TCA530 @56.11.4 4 mikropiiri 16-Pin DIP Integrated Voltage Stabilizer Datasheet
TCA5500 @56.11.4 1 mikropiiri Tone Control
TCA730 @56.12.1 12 mikropiiri 16-Pin DIP 300-mil D.C. Volume and Balance Stereo Control Circuit Datasheet
TCA730A @56.12.1 2 mikropiiri 16-Pin DIP 300-mil D.C. Volume and Balance Stereo Control Circuit Datasheet
TCA740 @56.12.1 6 mikropiiri 16-Pin DIP 300-mil D.C. Treble and Bass Stereo Control Circuit Datasheet
TCA740A @56.12.1 2 mikropiiri 16-Pin DIP 300-mil D.C. Treble and Bass Stereo Control Circuit Datasheet
TCA760B @56.12.1 2 mikropiiri 16-Pin DIP 300-mil
TCA800 @56.12.1 6 mikropiiri 16-Pin DIP Colour Demodulator With Feedback Clamps Datasheet
TCA940 @56.12.2 3 mikropiiri
TCA965 @56.12.2 15 mikropiiri 14-Pin DIP 300-mil Window Discriminator Datasheet
TCM320AC37CN @56.12.2 2 mikropiiri 20-Pin DIP Voice-Band Audio Processor TCM320AC36.pdf
TCM320AC46CN @56.12.2 1 mikropiiri 20-Pin DIP General Purpose Audio Interface for DSP TCM320AC46.pdf
TCM5089ANS @56.12.2 1 mikropiiri 16-Pin DIP Tone Decoder Datasheet
TD62003A @56.12.2 4 mikropiiri 16-Pin DIP 7ch Darlington driver
TDA1001 @57.1.1 2 mikropiiri 16-Pin DIP Interference and Noise Suppression for FM Receivers Datasheet
TDA1002 @57.1.1 2 mikropiiri 16-Pin DIP 300-mil Recording and Playback Amplifier Datasheet
TDA1003A @57.1.1 1 mikropiiri 16-Pin DIP 300-mil Motor Regulator and Bias/Erase Oscillator Circuit Datasheet
TDA1004 @57.1.1 10 mikropiiri 16-Pin DIP 300-mil 6W Audio Amplifier Datasheet
TDA1006A @57.1.1 1 mikropiiri 16-Pin DIP Motor Regulator with Automatic Tape-End Indicator Datasheet
TDA1011 @57.1.2 8 mikropiiri 9-Pin SIL 2 to 6W Audio Power Amplifier with Preamplifier Datasheet
TDA1011A @57.1.2 5 mikropiiri 9-Pin SIL 2 to 6W Audio Power Amplifier with Preamplifier Datasheet
TDA1023 @57.1.2 1 mikropiiri 16-Pin DIP 300-mil Proportional-control Triac Triggering Circuit Datasheet
TDA1029 @57.1.2 7 mikropiiri 16-Pin DIP 300-mil Signal-sources switch TDA1029.pdf
TDA1034 @57.1.2 2 mikropiiri Operational Amplifier TDA1034.pdf]
TDA1060 @57.1.3 22 mikropiiri 16-Pin DIP 300-mil Control Circuit for SMPS Datasheet
TDA1170SH @57.1.3 3 mikropiiri TDA1170 TDA1170SH 12-Pin Quad in-Line TV Vertical Deflection System Datasheet
TDA1236 @57.1.3 1 mikropiiri 18-Pin DIP 300-mil Sound Channel IC for TV Receivers Datasheet
TDA1510 @57.1.3 1 mikropiiri 13-Pin SIL 24W or 2x12W Stereo Car Radio Power Amplifier Datasheet
TDA1517 @57.1.3 1 mikropiiri
TDA1524 @57.1.4 5 mikropiiri 18-Pin DIP 300-mil TDA1524 TDA1524A Stereo-tone/volume Control Datasheet
TDA1576 @57.1.4 1 mikropiiri 18-Pin DIP 300-mil FM/IF Amplifier/Demodulator Circuit Datasheet
TDA1594 @57.1.4 2 mikropiiri LED Bargraph Driver
TDA1670A @57.1.4 2 mikropiiri Multiwatt-15 Vertical Deflection Circuit Datasheet
TDA1904 @57.1.4 1 mikropiiri 16-Pin DIP 300-mil 4W Audío Amplifier Datasheet
TDA2003 @57.2.1 26 mikropiiri Pentawatt 10W Car Radio Audio Amplifier Datasheet
TDA2003 @57.2.1 27 mikropiiri Pentawatt 10W Car Radio Audio Amplifier Datasheet
TDA2003 @57.2.1 5 mikropiiri Pentawatt 10W Car Radio Audio Amplifier Datasheet
TDA2030 @57.2.1 8 mikropiiri Pentawatt 14W Hi-Fi Audio Amplifier Datasheet
TDA2545A @57.2.1 1 mikropiiri 16-Pin DIP 300-mil Quasi-split-sound Circuit Datasheet
TDA2560 @57.2.2 1 mikropiiri 16-Pin DIP 300-mil
TDA2579 @57.2.2 1 mikropiiri 18-Pin DIP 300-mil Horizontal/vertical Synchronization Circuit Datasheet
TDA2590 @57.2.2 1 mikropiiri
TDA2593 @57.2.2 2 mikropiiri 16-Pin DIP 300-mil Synchro and Horizontal Deflection for Color TV Datasheet
TDA2610 @57.2.2 2 mikropiiri 16-Pin DIP 300-mil 4W Audio Amplifier Circuit Datasheet
TDA2640 @57.2.2 1 mikropiiri 16-Pin DIP 300-mil Switched Mode Power Supplies IC Datasheet
TDA2652 @57.2.3 1 mikropiiri 16-Pin DIP TV Vertical Deflection Output Datasheet
TDA2795 @57.2.3 2 mikropiiri 18-Pin DIP 300-mil TV Stereo/Dual Sound Identification Decoder Datasheet
TDA3810 @57.2.3 3 mikropiiri 18-Pin DIP 300-mil Spatia, Stereo and Pseudo-stereo Sound Circuit Datasheet
TDA3950 @57.2.3 2 mikropiiri 16-Pin DIP Chroma Processor for PAL Color TV Receivers Datasheet
TDA4292 @25.5.2 60 mikropiiri 24-Pin DIP 600-mil Stereo Tone Control IC wit Base Width Switch TDA4292.pdf
TDA440 @57.2.3 13 mikropiiri 16-Pin DIP 300-mil Video IF Amplifier Datasheet
TDA7000 @57.2.3 16 mikropiiri 18-Pin DIP 300-mil FM Radio Circuit Datasheet
TDA7056B @57.2.4 32 mikropiiri
TDA7270S @57.2.4 1 mikropiiri 16-Pin DIP 300-mil Multifunction System for Tape Players Datasheet
TDA7294 @57.2.4 4 mikropiiri 100 W audio amp
TDA7370 @57.2.4 22 mikropiiri Quad car audio amp 4*6.5 W or 2*20W
TDB0556A @57.2.4 19 mikropiiri
TDB0139DP @57.3.1 45 mikropiiri 14-Pin DIP 300-mil Quad Comparator (Equiv. LM339)
TDE0084DP @57.3.1 4 mikropiiri
TFK/U143 @57.3.2 276 mikropiiri 7-segment Decoder Driver Datasheet
TFK/U420B @57.3.2 12 mikropiiri
TFK/U420B2 @57.3.3 50 mikropiiri 1W audio power amp
TFK/U821B @57.3.3 4 mikropiiri
THAT2150A @57.3.3 2 mikropiiri
TL061CP @57.3.3 1 mikropiiri JFET opamp
TL062CP @57.3.3 3 mikropiiri Dual JFET opamp
TL071CP @57.3.4 29 mikropiiri PDIP-8 JFET-input VCC:+-20V single Operational Amplifier
TL071ACP @57.3.4 2 mikropiiri PDIP-8 JFET-input VCC:+-20V single Operational Amplifier
TL071JG @57.3.4 2 mikropiiri JFET opamp
TL072CN @57.3.4 6 mikropiiri PDIP-8 JFET-input VCC:+-20V dual Operational Amplifier
TL072CP @57.3.4 76 mikropiiri PDIP-8 JFET-input VCC:+-20V dual Operational Amplifier
TL074CN TL074IJ @57.3.4 32 mikropiiri PDIP-14 JFET-input VCC:+-20V quad Operational Amplifier
TL081 @57.4.1 1 mikropiiri Single JFET opamp, 30-V, 3-MHz, 13-V/µs
TL082CDP @57.4.1 12 mikropiiri Dual JFET opamp, 30-V, 3-MHz, 13-V/µs
TL082CP @57.4.1 13 mikropiiri PDIP-8 JFET-input VCC:+-20V dual Operational Amplifier 3-MHz, 13-V/µs
TL083CN @57.4.1 3 mikropiiri
TL084CN @57.4.1 20 mikropiiri PDIP-14 JFET-input VCC:+-20V quad Operational Amplifier 3-MHz, 13-V/µs
TL084IN @57.4.1 18 mikropiiri
TL16C550 @57.11.1 1 mikropiiri Asynchronous Communications Element Datasheet
TL170C @57.4.1 1 mikropiiri
TL440CN @57.4.2 3 mikropiiri
TL489CP @57.4.2 2 mikropiiri
TL494CN @57.4.2 3 mikropiiri Switch mode PWM controller
TL500CN @57.4.2 9 mikropiiri
TL502CN @57.4.2 13 mikropiiri
TL505CN @57.4.2 2 mikropiiri
TL7702AIP @57.4.3 33 mikropiiri
TL7705ACP @57.11.2 34 mikropiiri
TLC271CP @57.4.3 2 mikropiiri
TLC27L4CN @57.4.3 12 mikropiiri Datasheet
TLC27 @25.6.4 2 mikropiiri TLC27L7CP TLC27M2CP
TLC272 @25.6.4 2 mikropiiri TLC272CP TLC272M4CN
TLC274CN @25.6.4 1 mikropiiri TLC274CN
TLC339CN @25.6.4 1 mikropiiri
TLC3704CN @25.6.4 1 mikropiiri
TLC372CP @25.6.4 1 mikropiiri
TLC549IP @25.6.4 1 mikropiiri
TLC32044CN @25.6.2 3 mikropiiri Voice-Band Analog Interface TLC32044C.pdf
TLC555CP @57.4.3 8 mikropiiri CMOS 555 timer
TLC555IP @57.4.3 22 mikropiiri CMOS 555 timer
TLC5916IN @57.4.3 1 mikropiiri
TLE2024CN @57.4.4 5 mikropiiri
TMC453-PI @57.5.3 5 mikropiiri TRINAMIC MOTION CONTROL CHIP TMC453.pdf
TMP36GZ @57.4.4 1 mikropiiri Low Voltage Temperature Sensor -40 - +125 C
TMS320C25FNL @25.6.1 7 mikropiiri PLCC-44 DSP processor TMS320.pdf
TMS320C25FNL50 @25.6.1 40 mikropiiri PLCC-44 DSP processor TMS320.pdf
TMS320C26FNL @25.6.1 8 mikropiiri PLCC-44 DSP processor TMS320.pdf
TMS5501NL @57.4.4 5 mikropiiri 40-Pin DIP 600 mil
TMS7000NL-2 @57.4.4 1 mikropiiri
TMS9914ANL @54.7.4 3 mikropiiri GPIB IEEE-488 Controller
TMX3534ANS @57.4.4 1 mikropiiri
TND903 @57.4.4 39 mikropiiri 16-Pin DIP 1x8 Diode Array
TP43450BN @57.5.1 1 mikropiiri
TPC1010AFN-044C @57.12.3 7 mikropiiri PLCC-44 1000-Series FPGA TPC1010AFN-44C.pdf
TS555CN @57.5.1 22 mikropiiri
TS272CN @25.7.4 2 mikropiiri
TS68230CFN8 @57.5.1 4 mikropiiri PLCC52 Parallel Interface/Timer (PIT) Datasheet
TS68HC901 @57.5.1 70 mikropiiri PLCC52 TS68HC901CFN4B Multi-Function Peripheral for 68000 (UART, GPIO, IRQ, Timer) TS68HC901.pdf
TSC232CPE @57.5.2 2 mikropiiri Dual RS232 Transm./Recvr & Power supply TSC232.pdf
TSC7106RCPL @57.5.2 2 mikropiiri
TSC8700CJ @57.5.2 4 mikropiiri
TSC87C52-12CB @57.5.2 1 mikropiiri One–Time–Programmable C51 microcontroller Datasheet
TTuL6940 TTuL6941 TTuL6942 @57.5.2 4 mikropiiri TTuL6940 TTuL6941 TTuL6942
TTuL7015 @57.5.2 1 mikropiiri TTuL7015
TTuL7122 @57.5.3 1 mikropiiri TTuL7122
U5B7741393 @57.5.3 6 mikropiiri
U5B7749394 @57.5.3 2 mikropiiri
U5F747393 @57.5.3 1 mikropiiri
U5T7725393 @57.5.3 2 mikropiiri
uA2740 @57.5.4 41 mikropiiri
uA324PC uA307TC @57.5.4 7 mikropiiri Operational Amplifier
uA339DC @57.5.4 4 mikropiiri
uA4136DC @57.5.4 4 mikropiiri
uA709PC @57.6.1 6 mikropiiri
uA715HC @57.6.1 10 mikropiiri
uA723CN @57.6.1 2 mikropiiri
uA723H @57.6.1 1 mikropiiri
uA723HC @57.6.1 2 mikropiiri
uA725HC @57.6.1 5 mikropiiri
uA739PC @57.6.2 2 mikropiiri
uA741CN @57.6.2 20 mikropiiri
uA741CP @57.6.2 5 mikropiiri
uA741HC @57.6.2 1 mikropiiri
uA741PC @57.6.2 50 mikropiiri
uA741RC @57.6.2 2 mikropiiri
uA747PC @57.6.3 11 mikropiiri
uA749DHC @57.6.3 1 mikropiiri
uAA145 @57.6.3 19 mikropiiri
uAA170 @57.6.3 41 mikropiiri
uAA180 @57.6.3 5 mikropiiri
UA9636ACP uA9637ATC @57.6.3 10 mikropiiri
UC2843AN @57.6.4 50 mikropiiri
UC3657V @57.6.4 6 mikropiiri
UC3842AN UC3844N UC3845N @57.6.4 4 mikropiiri
UCC2570N @57.7.3 25 mikropiiri
UCN5832EP @57.6.4 7 mikropiiri PLCC44
UDN2983A @57.6.4 2 mikropiiri
UDN2987A @57.6.4 1 mikropiiri
UDN2962W @57.7.1 37 mikropiiri
UGN-3013U @57.7.1 12 mikropiiri
UGN-3501T @57.7.1 2 mikropiiri
UGS-3040U @57.7.1 2 mikropiiri
ULN2002A @57.7.2 15 mikropiiri
ULN2003A @57.7.2 9 mikropiiri Datasheet
ULN2003AN @57.7.2 32 mikropiiri Datasheet
ULN2003 AG/APG @57.7.2 12 mikropiiri ULN2003AG ULN2003APG Datasheet
ULN2004A @57.7.2 2 mikropiiri Datasheet
ULN2004AN @57.7.2 2 mikropiiri Datasheet
ULN2013A @57.7.3 9 mikropiiri
ULN2023A @57.7.3 3 mikropiiri
ULN2046A @57.7.3 4 mikropiiri
ULN2069B @57.7.3 3 mikropiiri
ULN2111A @57.7.4 2 mikropiiri
ULN2204A @57.7.4 3 mikropiiri
ULN2283 @57.8.1 90 mikropiiri 1.2W Audio Amplifier pg.360 5000-IC-Power-Audio-Amplifiers.pdf
ULN2283B @57.8.1 300 mikropiiri 1.2W Audio Amplifier pg.360 5000-IC-Power-Audio-Amplifiers.pdf
ULN2803A @57.8.2 39 mikropiiri
ULN2803 AG/APG @57.8.2 32 ULN2803APG ULN2803AG mikropiiri
ULN2804A @57.8.2 37 mikropiiri
ULN2823A @57.8.2 6 mikropiiri
ULN2824A @57.8.2 1 mikropiiri
ULN3718M @57.8.2 77 mikropiiri
uPB10101D @57.8.3 20 mikropiiri
uPB10180 @57.8.3 15 mikropiiri
UPC458C @57.8.3 9 mikropiiri
VL82C50-PC @57.8.3 1 mikropiiri
W78E058DDG @57.8.4 1 mikropiiri Datasheet
WD2143M-03 @57.8.4 2 mikropiiri
WE48101 @57.8.4 1 mikropiiri
WE4822 @57.8.4 2 mikropiiri
X2444P @57.8.4 3 mikropiiri
X9503P @57.8.4 1 mikropiiri
XC2018 @57.9.1 1 mikropiiri Logic Cell Array XC2018-70 PC44 Datasheet
XC2018 @57.9.1 1 mikropiiri Logic Cell Array XC2018-70 PC68C Datasheet
XC3030A FPGA @57.9.1 18 mikropiiri XILINX 3000 Series Datasheet
XC3030A FPGA @57.9.2 18 mikropiiri XILINX 3000 Series Datasheet
XC3042A FPGA @57.9.3 13 mikropiiri XILINX 3000 Series Datasheet
XC95144XL @57.9.3 1 mikropiiri XC95144XL-TQG100
XC9536 @57.9.3 4 mikropiiri XC9536-PCG44
XC9536 @57.9.3 1 mikropiiri XC9536-VQG44
XC9536XL @57.9.3 1 mikropiiri XC9536XL-PCG44
XC9572 @57.9.3 1 mikropiiri XC9572-PCG84
XC9572 @57.9.3 1 mikropiiri XC9572XL-TQG100
XCF02S @57.9.3 1 mikropiiri XILINX XCF02SVOG20C Platform Flash In-System Programmable Configuration PROMs Datasheet
XC3S200 FPGA @26.5.1 1 mikropiiri XILINX SPARTAN-3 series, Break-out board Datasheet
XC9536 CPLD @26.5.1 1 mikropiiri Break-out board Datasheet
XC9572XL CPLD @26.5.1 1 mikropiiri Break-out board Datasheet
XR2203CP @57.9.4 8 mikropiiri
XR2206CP @57.9.4 10 mikropiiri
XR2211CP @57.9.4 3 mikropiiri
XR2211D @57.9.4 5 mikropiiri
XR2524 @57.9.4 3 mikropiiri XR2524P XR2524
XR2556CP @57.9.4 14 mikropiiri 14-Pin DIP 300mil Dual 555 Datasheet
XR2567CP @57.10.1 1 mikropiiri 2567CP
XR3403CP @57.10.1 2 mikropiiri
XR5532AN @57.10.1 5 mikropiiri
XR5533P @57.10.1 2 mikropiiri
XR5534ACP @57.10.1 1 mikropiiri
XR567CP @57.10.1 2 mikropiiri
Z80180 @57.10.2 7 mikropiiri ZILOG Z8018010VSC Z180 MPU Datasheet
Z8530H-4PC @57.10.2 1 mikropiiri
Z85C30 @57.10.2 53 mikropiiri Zilog Z85C3008VSC SCC Controller Datasheet
Z80 @57.10.2 3 mikropiiri Z84C0004PEC Z80 CPU
Z80180 @57.10.2 1 mikropiiri ZILOG Z8018006VSC Z180 MPU Datasheet
Z84C1008PEG @57.10.2 1 mikropiiri Z84C1008PEG Z80 DMA
ZN414 @57.10.3 8 mikropiiri AM Radio Receiver ZN414, ZN414Z
ZN414Z @57.10.3 40 mikropiiri AM Radio Receiver ZN414, ZN414Z
ZN415E @57.10.3 7 mikropiiri
Sekalaisia @57.10.4 X mikropiiri
Mikropiirit 1400
MC1403U @91.11.1 8 mikropiiri 1400 8-Pin DIP 300-mil 2.5V 1% Low Voltage Reference Datasheet
MC1406L @91.11.1 8 mikropiiri 1400 14-Pin DIP 300-mil D/A Converter Datasheet
LM1408N-8 @91.11.1 3 mikropiiri 1400 16-Pin DIP 300-mil 8-bit multiplying D/A converter Databook p.181
MC1408-8N @91.11.1 3 mikropiiri 1400 16-Pin DIP 300-mil 8-bit multiplying D/A converter Datasheet
MC1414L @91.11.1 1 mikropiiri 1400 14-Pin DIP 300-mil Dual Differential Comparator Datasheet
MC1438R @91.11.2 12 mikropiiri 1400 9-Pin 614 Operational Amplifiers Power Booster Datasheet
MC1439G @91.11.2 3 mikropiiri 1400 Operational Amplifier Databook p.74
MC1455P @91.11.2 11 mikropiiri 1400 8-Pin DIP 300-mil Timer (NE555 replacement) Datasheet
MC1456CG @91.11.2 3 mikropiiri 1400 8-Pin DIP 300-mil Operational Amplifier Datasheet
1458 @91.11.3 4 mikropiiri 1400 CA1458G MC1458CG MC1458G RC1458N Dual Operational Amplifier Databook p.88
CA1458T @91.11.3 6 mikropiiri 1400 Dual Operational Amplifier Datasheet
MC1458CP1 @91.11.3 80 mikropiiri 1400 8-Pin DIP 300-mil Dual Operational Amplifier Datasheet
MC1458N @91.11.3 4 mikropiiri 1400 8-Pin DIP 300-mil Dual Operational Amplifier Datasheet
MC1458P @91.11.3 7 mikropiiri 1400 8-Pin DIP 300-mil Dual Operational Amplifier Datasheet
MC1463R @91.11.4 3 mikropiiri 1400 Negative Voltage Regulator Databook p.226
MC1469G @91.11.4 1 mikropiiri 1400 Voltage Regulator Databook p.258
MC1488 @91.11.4 12 mikropiiri 1400 14-Pin DIP 300-mil Quad EIA-232D Line Driver Datasheet
MC1488L @91.11.4 10 mikropiiri 1400 14-Pin DIP 300-mil Quad EIA-232D Line Driver Datasheet
MC1488 @91.11.4 8 mikropiiri 1400 14-Pin DIP 300-mil MC1488N MC1488P Quad EIA-232D Line Driver Datasheet
DS14C88N @91.11.4 24 mikropiiri 1400 14-Pin DIP 300-mil Quad EIA-232D Line Driver Datasheet
1489AP @91.11.5 13 mikropiiri 1400 14-Pin DIP 300-mil Quad EIA-232D Line Receivers Datasheet
MC1489 @91.11.5 31 mikropiiri 1400 14-Pin DIP 300-mil Quad EIA-232D Line Receivers Datasheet
MC1489A @91.11.5 17 mikropiiri 1400 14-Pin DIP 300-mil Quad EIA-232D Line Receivers Datasheet
MC1489AN @91.11.5 37 mikropiiri 1400 14-Pin DIP 300-mil Quad EIA-232D Line Receivers Datasheet
MC1489AP @91.11.5 39 mikropiiri 1400 14-Pin DIP 300-mil Quad EIA-232D Line Receivers Datasheet
uA1489APC @91.11.5 19 mikropiiri 1400 14-Pin DIP 300-mil Quad EIA-232D Line Receivers
MC1489N @91.12.1 131 mikropiiri 1400 14-Pin DIP 300-mil Quad EIA-232D Line Receivers Datasheet
MC1489P @91.12.1 16 mikropiiri 1400 14-Pin DIP 300-mil Quad EIA-232D Line Receivers Datasheet
DS14C89AN @91.12.1 1 mikropiiri 1400 14-Pin DIP 300-mil Quad EIA-232D Line Receivers Datasheet
MC1494L @91.12.2 2 mikropiiri 1400 16-Pin DIP 300-mil Linear Four-Quadrant Multiplier Datasheet
MC1496G @91.12.2 1 mikropiiri 1400 14-Pin DIP 300-mil Balanced Modulators/Demodulators Datasheet
MC14410 @91.12.3 2 mikropiiri 1400 16-Pin DIP 300-mil 2-OF-8 Tone Encoder Datasheet
MC14411 @91.12.3 2 mikropiiri 1400 24-Pin DIP 600-mil MC14411L MC14411P Bit Rate Generator Datasheet
14412VP @91.12.3 1 mikropiiri 1400 16-Pin DIP 300-mil 14412VP FSK Modem System Datasheet
MC14419P @91.12.3 9 mikropiiri 1400 16-Pin DIP 300-mil 2-OF-8 Keypad-To-Binary Encoder Datasheet
MC14433P @91.12.3 11 mikropiiri 1400 24-Pin DIP 600-mil 3-1/2 Digit A/D Converter Datasheet
MC14435EVL @91.12.3 2 mikropiiri 1400 16-Pin DIP 300-mil 3-1/2 Digit A/D Logic Subsystem Datasheet
MC14469P @91.12.4 5 mikropiiri 1400 40-Pin DIP Async. Receiver/Transmitter Datasheet
MC14490FL @91.12.4 1 mikropiiri 1400 16-Pin DIP 300-mil Hex Contact Bounce Eliminator Datasheet
MC14490FP @91.12.4 1 mikropiiri 1400 16-Pin DIP 300-mil Hex Contact Bounce Eliminator Datasheet
MC145151FN2 @91.12.4 6 mikropiiri 1400 PLCC28 Frequency Synthesizer MC145151FN2.pdf
Mikropiirit 4000
4000 @90.1.1 18 mikropiiri 4000 CD4000BE Dual 3-input NOR gate + One inverter gate
4000 @90.1.1 9 mikropiiri 4000 CD4000CN Dual 3-input NOR gate + One inverter gate
4000 @90.1.1 16 mikropiiri 4000 CD4000UBF Dual 3-input NOR gate + One inverter gate
4000 @90.1.1 7 mikropiiri 4000 HCF4000BE Dual 3-input NOR gate + One inverter gate
4000 @90.1.1 2 mikropiiri 4000 MC14000CP Dual 3-input NOR gate + One inverter gate
4001 @90.1.2 6 mikropiiri 4000 4001BDC Quad 2-input NOR gate
4001 @90.1.2 53 mikropiiri 4000 CD4001BCN Quad 2-input NOR gate Datasheet
4001 @90.1.2 34 mikropiiri 4000 CD4001BE Quad 2-input NOR gate Datasheet
4001 @90.1.2 4 mikropiiri 4000 CD4001BF Quad 2-input NOR gate Datasheet
4001 @90.1.2 5 mikropiiri 4000 CD4001UBE Quad 2-input NOR gate
4001 @90.1.3 1 mikropiiri 4000 CD4001UBF Quad 2-input NOR gate
4001 @90.1.3 28 mikropiiri 4000 HCF4001BE Quad 2-input NOR gate
4001 @90.1.3 6 mikropiiri 4000 HCF4001BETH Quad 2-input NOR gate
4001 @90.1.3 2 mikropiiri 4000 HEF4001BP Quad 2-input NOR gate
4001 @90.1.3 19 mikropiiri 4000 MC14001B Quad 2-input NOR gate
4001 @90.1.3 19 mikropiiri 4000 MC14001BCP Quad 2-input NOR gate
4001 @90.1.4 1 mikropiiri 4000 MC14001BCPT Quad 2-input NOR gate
4001 @90.1.4 18 mikropiiri 4000 MC14001CP Quad 2-input NOR gate
4001 @90.1.4 4 mikropiiri 4000 SCL4001AE Quad 2-input NOR gate
4001 @90.1.4 9 mikropiiri 4000 TC4001BP Quad 2-input NOR gate Datasheet
4001 @90.1.4 2 mikropiiri 4000 CD4001AE Quad 2-input NOR gate Datasheet
4001 @90.1.4 5 mikropiiri 4000 34001PC Quad 2-input NOR gate
4002 @90.1.5 7 mikropiiri 4000 34002PC Dual 4-input NOR gate
4002 @90.1.5 1 mikropiiri 4000 CD4002AF Dual 4-input NOR gate Datasheet
4002 @90.1.5 9 mikropiiri 4000 HCF4002BE Dual 4-input NOR gate
4002 @90.1.5 3 mikropiiri 4000 MC14002AL MC14002BCP MC14002CP Dual 4-input NOR gate
4002 @90.1.5 3 mikropiiri 4000 SCL4002BE Dual 4-input NOR gate
4004 @90.1.5 1 mikropiiri 4000 14-Pin DIP TC40H004P Hex Inverter
4007 @90.2.1 5 mikropiiri 4000 CD4007AE Dual enh. MOS transistor pair + 1 inverter gate Datasheet
4007 @90.2.1 5 mikropiiri 4000 CD4007CN Dual enh. MOS transistor pair + 1 inverter gate Datasheet
4007 @90.2.1 1 mikropiiri 4000 CD4007UBE Dual enh. MOS transistor pair + 1 inverter gate Datasheet
4007 @90.2.1 1 mikropiiri 4000 HCF4007UBE Dual enh. MOS transistor pair + 1 inverter gate
4007 @90.2.1 1 mikropiiri 4000 MC14007BCP Dual enh. MOS transistor pair + 1 inverter gate
4007 @90.2.1 1 mikropiiri 4000 MC14007UBCP Dual enh. MOS transistor pair + 1 inverter gate
4009 @90.2.2 9 mikropiiri 4000 CD4009AE Hex inverter (replaced by 4049) Datasheet
4009 @90.2.2 20 mikropiiri 4000 CD4009CN Hex inverter (replaced by 4049) Datasheet
4009 @90.2.2 3 mikropiiri 4000 CD4009UBE Hex inverter (replaced by 4049) Datasheet
4009 @90.2.2 16 mikropiiri 4000 CD4009UBF Hex inverter (replaced by 4049) Datasheet
4009 @90.2.2 1 mikropiiri 4000 MC14009CL Hex inverter (replaced by 4049) Datasheet
4009 @90.2.2 3 mikropiiri 4000 TC4009UBP Hex inverter (replaced by 4049) Datasheet
4010 @90.2.3 7 mikropiiri 4000 CD4010BF Hex buffer (replaced by 4050) Datasheet
4010 @90.2.3 8 mikropiiri 4000 CD4010CN CD4010BF Hex buffer (replaced by 4050) Datasheet
4010 @90.2.3 4 mikropiiri 4000 SIL4010BE CD4010BF Hex buffer (replaced by 4050) Datasheet
4010 @90.2.3 15 mikropiiri 4000 TP4010BN CD4010BF Hex buffer (replaced by 4050) Datasheet
4011 @90.2.4 2 mikropiiri 4000 4011BPC Quad 2-input NAND gate Datasheet
4011 @90.2.4 23 mikropiiri 4000 CD4011AE Quad 2-input NAND gate Datasheet
4011 @90.2.4 2 mikropiiri 4000 CD4011AF Quad 2-input NAND gate Datasheet
4011 @90.2.4 75 mikropiiri 4000 CD4011BCN Quad 2-input NAND gate Datasheet
4011 @90.2.4 22 mikropiiri 4000 CD4011BCP Quad 2-input NAND gate Datasheet
4011 @90.2.5 22 mikropiiri 4000 CD4011BE Quad 2-input NAND gate Datasheet
4011 @90.2.5 22 mikropiiri 4000 CD14011BCP Quad 2-input NAND gate Datasheet
4011 @90.2.5 4 mikropiiri 4000 CD4011UBE D4011UBF Quad 2-input NAND gate Datasheet
4011 @90.2.5 14 mikropiiri 4000 34011PC Quad 2-input NAND gate
4011 @90.2.5 77 mikropiiri 4000 HCF4011BE Quad 2-input NAND gate
4011 @90.3.1 12 mikropiiri 4000 HEF4011BP Quad 2-input NAND gate
4011 @90.3.1 27 mikropiiri 4000 MC14011B Quad 2-input NAND gate
4011 @90.3.1 20 mikropiiri 4000 MC14011UBCP Quad 2-input NAND gate
4011 @90.3.1 7 mikropiiri 4000 SIL4011AE SIL4011BE Quad 2-input NAND gate
4011 @90.3.1 40 mikropiiri 4000 TC4011BP Quad 2-input NAND gate
4011 @90.3.1 4 mikropiiri 4000 SCL4011AE MC14011CP SSS4011AE
4012 @90.3.2 1 mikropiiri 4000 CD4012AE Dual 4-input NAND gate Datasheet
4012 @90.3.2 2 mikropiiri 4000 CD4012AF Dual 4-input NAND gate Datasheet
4012 @90.3.2 14 mikropiiri 4000 CD4012BE Dual 4-input NAND gate Datasheet
4012 @90.3.2 21 mikropiiri 4000 CD4012BF Dual 4-input NAND gate Datasheet
4012 @90.3.2 7 mikropiiri 4000 CD4012BFX Dual 4-input NAND gate Datasheet
4012 @90.3.2 1 mikropiiri 4000 CD4012CN Dual 4-input NAND gate
4012 @90.3.3 22 mikropiiri 4000 HCF4012BE Dual 4-input NAND gate
4012 @90.3.3 7 mikropiiri 4000 34012PC Dual 4-input NAND gate
4012 @90.3.3 1 mikropiiri 4000 HEF4012BP Dual 4-input NAND gate
4012 @90.3.3 1 mikropiiri 4000 MC14012BCP Dual 4-input NAND gate
4012 @90.3.3 2 mikropiiri 4000 MC14012CP Dual 4-input NAND gate
4012 @90.3.3 1 mikropiiri 4000 SIL4012BE Dual 4-input NAND gate
4013 @90.3.4 4 mikropiiri 4000 4013BPC Dual D-type flip-flop, pos.-edge trigger, async. set and reset Datasheet
4013 @90.3.4 4 mikropiiri 4000 CD4013AF Dual D-type flip-flop, pos.-edge trigger, async. set and reset Datasheet
4013 @90.3.4 36 mikropiiri 4000 CD4013BCN Dual D-type flip-flop, pos.-edge trigger, async. set and reset Datasheet
4013 @90.3.4 16 mikropiiri 4000 CD4013BE Dual D-type flip-flop, pos.-edge trigger, async. set and reset Datasheet
4013 @90.3.4 18 mikropiiri 4000 D4013BC Dual D-type flip-flop, pos.-edge trigger, async. set and reset
4013 @90.3.4 6 mikropiiri 4000 HCF4013BE Dual D-type flip-flop, pos.-edge trigger, async. set and reset
4013 @90.3.5 4 mikropiiri 4000 HEF4013BP Dual D-type flip-flop, pos.-edge trigger, async. set and reset
4013 @90.3.5 54 mikropiiri 4000 MC14013BCP Dual D-type flip-flop, pos.-edge trigger, async. set and reset
4013 @90.3.5 13 mikropiiri 4000 MC14013BCL Dual D-type flip-flop, pos.-edge trigger, async. set and reset
4013 @90.3.5 7 mikropiiri 4000 MC14013CP MC14013CL Dual D-type flip-flop, pos.-edge trigger, async. set and reset
4013 @90.3.5 5 mikropiiri 4000 SIL4013BE CD4013BCJ Dual D-type flip-flop, pos.-edge trigger, async. set and reset
4014 @90.4.1 1 mikropiiri 4000 MC14014CP 8-stage parallel in shift register (sync. parallel load, serial in)
4015 @90.4.1 3 mikropiiri 4000 CD4015CN Dual 4-stage shift register
4015 @90.4.1 23 mikropiiri 4000 HCF4015BE Dual 4-stage shift register
4015 @90.4.1 15 mikropiiri 4000 HCF4015BF Dual 4-stage shift register
4015 @90.4.1 5 mikropiiri 4000 MC14015BCP 34015PC Dual 4-stage shift register
4015 @90.4.1 4 mikropiiri 4000 SIL4015BE Dual 4-stage shift register
4016 @90.4.2 17 mikropiiri 4000 CD4016AE Quad bilateral switch
4016 @90.4.2 9 mikropiiri 4000 CD4016BCN CD4016CN Quad bilateral switch
4016 @90.4.2 11 mikropiiri 4000 HCF4016BE Quad bilateral switch
4016 @90.4.2 47 mikropiiri 4000 HCF4016BF Quad bilateral switch
4016 @90.4.2 2 mikropiiri 4000 MC14016CP Quad bilateral switch
4017 @90.4.3 17 mikropiiri 4000 CD4017AE 5-stage Johnson counter with 10-output decoder
4017 @90.4.3 72 mikropiiri 4000 CD4017BCN 5-stage Johnson counter with 10-output decoder
4017 @90.4.3 16 mikropiiri 4000 CD4017BE 5-stage Johnson counter with 10-output decoder
4017 @90.4.3 24 mikropiiri 4000 HCF4017BE 5-stage Johnson counter with 10-output decoder
4017 @90.4.3 9 mikropiiri 4000 SCL4017ABE 4017BDC 4017BPC MC14017CP 5-stage Johnson counter with 10-output decoder
4017 @90.4.4 72 mikropiiri 4000 HEF4017BP 5-stage Johnson counter with 10-output decoder
4017 @90.4.4 55 mikropiiri 4000 MC14017BCP 5-stage Johnson counter with 10-output decoder
4017 @90.4.4 7 mikropiiri 4000 SIL4017BE 5-stage Johnson counter with 10-output decoder
4017 @90.4.4 15 mikropiiri 4000 TC4017BP 5-stage Johnson counter with 10-output decoder
4018 @90.4.5 5 mikropiiri 4000 MC14018B SIL4018BE Presettable divide-by-N counter
4019 @90.4.5 3 mikropiiri 4000 CD4019AE Quad AND-OR select gate
4019 @90.4.5 41 mikropiiri 4000 CD4019BCN Quad AND-OR select gate
4019 @90.4.5 43 mikropiiri 4000 CD4019BE Quad AND-OR select gate
4019 @90.4.5 9 mikropiiri 4000 CD4019BF Quad AND-OR select gate
4019 @90.4.5 1 mikropiiri 4000 SIL4019BE Quad AND-OR select gate
4020 @90.5.1 10 mikropiiri 4000 CD4020BCN 14-stage binary ripple counter
4020 @90.5.1 10 mikropiiri 4000 HCF4020BE 14-stage binary ripple counter
4020 @90.5.1 2 mikropiiri 4000 MC14020BCP 14-stage binary ripple counter
4021 @90.5.1 15 mikropiiri 4000 4021PC 8-stage parallel in shift register
4021 @90.5.1 2 mikropiiri 4000 CD4021BE 8-stage parallel in shift register
4022 @90.5.2 40 mikropiiri 4000 CD4022BE Octal 4-stage Johnson counter with 8-output decoder
4022 @90.5.2 58 mikropiiri 4000 HCF4022BE Octal 4-stage Johnson counter with 8-output decoder
4022 @90.5.2 4 mikropiiri 4000 HEF4022BP Octal 4-stage Johnson counter with 8-output decoder
4023 @90.5.3 3 mikropiiri 4000 4023BCP CD4023AE HEF4023BP Triple 3-input NAND gate
4023 @90.5.3 29 mikropiiri 4000 CD4023BCN Triple 3-input NAND gate
4023 @90.5.3 16 mikropiiri 4000 CD4023UBF Triple 3-input NAND gate
4023 @90.5.3 2 mikropiiri 4000 MC14023BCP Triple 3-input NAND gate
4023 @90.5.3 2 mikropiiri 4000 SIL4023BE Triple 3-input NAND gate
4023 @90.5.3 2 mikropiiri 4000 4023PC Triple 3-input NAND gate
4024 @90.5.4 42 mikropiiri 4000 CD4024BCN 7-stage binary ripple counter
4024 @90.5.4 6 mikropiiri 4000 CD4024BF CD4024BCJ HEF4024P TC4024BP 7-stage binary ripple counter
4024 @90.5.4 33 mikropiiri 4000 HEF4024BP 7-stage binary ripple counter
4024 @90.5.4 25 mikropiiri 4000 MC14024BCP 7-stage binary ripple counter
4024 @90.5.4 23 mikropiiri 4000 MC14024BCPD 7-stage binary ripple counter
4024 @90.5.4 20 mikropiiri 4000 SIL4024BE 7-stage binary ripple counter
4025 @90.5.5 4 mikropiiri 4000 CD4025AE SCL4025AE MC14025BCP Triple 3-input NOR gate
4025 @90.5.5 31 mikropiiri 4000 CD4025BCN Triple 3-input NOR gate
4025 @90.5.5 4 mikropiiri 4000 CD4025BE Triple 3-input NOR gate
4025 @90.5.5 2 mikropiiri 4000 HEF4025BP Triple 3-input NOR gate
4025 @90.5.5 2 mikropiiri 4000 MC14025CP Triple 3-input NOR gate
4025 @90.5.5 6 mikropiiri 4000 SIL4025BE Triple 3-input NOR gate
4027 @90.6.1 37 mikropiiri 4000 CD4027BCN Dual J-K master-slave flip-flop, asynchronous set and reset
4027 @90.6.1 9 mikropiiri 4000 CD4027BE Dual J-K master-slave flip-flop, asynchronous set and reset
4027 @90.6.1 10 mikropiiri 4000 HCF4027BE Dual J-K master-slave flip-flop, asynchronous set and reset
4027 @90.6.1 37 mikropiiri 4000 MC14027BCP Dual J-K master-slave flip-flop, asynchronous set and reset
4027 @90.6.1 5 mikropiiri 4000 SIL4027BE 34027PC Dual J-K master-slave flip-flop, asynchronous set and reset
4027 @90.6.1 5 mikropiiri 4000 TC4027BP 4027BCP HEF4027BP MC14027CP Dual J-K master-slave flip-flop, asynchronous set and reset
4028 @90.6.2 49 mikropiiri 4000 CD4028BCN 4-bit BCD to 10-output decoder (also 3-bit binary to 8-output decoder)
4028 @90.6.2 10 mikropiiri 4000 CD4028BE 4-bit BCD to 10-output decoder (also 3-bit binary to 8-output decoder)
4028 @90.6.2 91 mikropiiri 4000 HCF4028BE 4-bit BCD to 10-output decoder (also 3-bit binary to 8-output decoder)
4028 @90.6.3 72 mikropiiri 4000 HEF4028BP 4-bit BCD to 10-output decoder (also 3-bit binary to 8-output decoder)
4028 @90.6.3 65 mikropiiri 4000 MC14028BCP 4-bit BCD to 10-output decoder (also 3-bit binary to 8-output decoder)
4028 @90.6.3 14 mikropiiri 4000 SIL4028BE 4-bit BCD to 10-output decoder (also 3-bit binary to 8-output decoder)
4028 @90.6.3 3 mikropiiri 4000 34028PC 4-bit BCD to 10-output decoder (also 3-bit binary to 8-output decoder)
4029 @90.6.4 3 mikropiiri 4000 CD4029AE Presettable up/down counter, binary or BCD-decade
4029 @90.6.4 21 mikropiiri 4000 CD4029BE Presettable up/down counter, binary or BCD-decade
4029 @90.6.4 9 mikropiiri 4000 CD4029BF Presettable up/down counter, binary or BCD-decade
4029 @90.6.4 44 mikropiiri 4000 HCF4029BE Presettable up/down counter, binary or BCD-decade
4029 @90.6.4 5 mikropiiri 4000 HEF4029BP HEF4029BF TC4029BP Presettable up/down counter, binary or BCD-decade
4029 @90.6.4 27 mikropiiri 4000 CD4029BCN Presettable up/down counter, binary or BCD-decade
4029 @90.6.4 3 mikropiiri 4000 Presettable up/down counter, binary or BCD-decade
4030 @90.6.5 5 mikropiiri 4000 CD4030CN Quad XOR gate (replaced by 4070)
4030 @90.6.5 13 mikropiiri 4000 HCF4030BE Quad XOR gate (replaced by 4070)
4030 @90.6.5 4 mikropiiri 4000 HEF4030BP Quad XOR gate (replaced by 4070)
4031 @90.6.5 1 mikropiiri 4000 CD4031BCN 64-stage shift register
4035 @90.7.1 9 mikropiiri 4000 CD4035BCN 4-stage parallel-in/parallel-out shift register
4035 @90.7.1 4 mikropiiri 4000 CD4035AE CD4035BE 4-stage parallel-in/parallel-out shift register
4035 @90.7.1 6 mikropiiri 4000 CD4035BF 4-stage parallel-in/parallel-out shift register
4035 @90.7.1 8 mikropiiri 4000 SIL4035BE HCF4035BE MC14035CP 4-stage parallel-in/parallel-out shift register
4038 @90.7.1 100 mikropiiri 4000 MC14038BCP Triple Serial Adder
4040 @90.7.2 28 mikropiiri 4000 CD4040BCN 12-stage binary ripple counter
4040 @90.7.2 23 mikropiiri 4000 CD4040BE 12-stage binary ripple counter
4040 @90.7.2 9 mikropiiri 4000 HCF4040BE 12-stage binary ripple counter
4040 @90.7.2 6 mikropiiri 4000 4040PC HEF4040BP 12-stage binary ripple counter
4040 @90.7.2 26 mikropiiri 4000 MC14040BCP 12-stage binary ripple counter
4040 @90.7.2 6 mikropiiri 4000 MC4040CP SCL4040AE CD4040BF 12-stage binary ripple counter
4040 @90.7.3 55 mikropiiri 4000 TC4040BP 12-stage binary ripple counter
4041 @90.7.3 2 mikropiiri 4000 4041PC 8-Bit Shift Register
4042 @90.7.3 1 mikropiiri 4000 MC14042BCP Quad D-type latch, pos./neg. edge trigger, shared clock
4042 @90.7.3 3 mikropiiri 4000 SIL4042BE Quad D-type latch, pos./neg. edge trigger, shared clock
4042 @90.7.3 3 mikropiiri 4000 34042PC Quad D-type latch, pos./neg. edge trigger, shared clock
4043 @90.7.4 48 mikropiiri 4000 CD4043AE Quad NOR R-S latch, Q outputs, three-state outputs
4043 @90.7.4 33 mikropiiri 4000 CD4043BE Quad NOR R-S latch, Q outputs, three-state outputs
4043 @90.7.4 14 mikropiiri 4000 HCF4043BE Quad NOR R-S latch, Q outputs, three-state outputs
4043 @90.7.4 63 mikropiiri 4000 HEF4043BP Quad NOR R-S latch, Q outputs, three-state outputs
4043 @90.7.5 17 mikropiiri 4000 MC14043BCP Quad NOR R-S latch, Q outputs, three-state outputs
4043 @90.7.5 35 mikropiiri 4000 SIL4043BE Quad NOR R-S latch, Q outputs, three-state outputs
4044 @90.8.1 10 mikropiiri 4000 CD4044BE Quad NAND R-S latch, Q outputs, three-state outputs
4044 @90.8.1 24 mikropiiri 4000 CD4044BF Quad NAND R-S latch, Q outputs, three-state outputs
4044 @90.8.1 48 mikropiiri 4000 HCF4044BE Quad NAND R-S latch, Q outputs, three-state outputs
4044 @90.8.1 3 mikropiiri 4000 SIL4044BE Quad NAND R-S latch, Q outputs, three-state outputs
4046 @90.8.2 11 mikropiiri 4000 CD4046BCN Phase-locked loop with VCO
4046 @90.8.2 25 mikropiiri 4000 CD4046BE Phase-locked loop with VCO
4046 @90.8.2 8 mikropiiri 4000 CD4046BF Phase-locked loop with VCO
4046 @90.8.2 21 mikropiiri 4000 HEF4046BP Phase-locked loop with VCO
4046 @90.8.2 19 mikropiiri 4000 MC14046BCP Phase-locked loop with VCO
4046 @90.8.2 2 mikropiiri 4000 MC14046CP Phase-locked loop with VCO
4047 @90.8.3 32 mikropiiri 4000 HEF4047BP Monostable/astable multivibrator, external RC oscillator
4047 @90.8.3 1 mikropiiri 4000 TC4047BP Monostable/astable multivibrator, external RC oscillator
4049 @90.8.4 15 mikropiiri 4000 4049BPC Hex inverter
4049 @90.8.4 5 mikropiiri 4000 4049PC Hex inverter
4049 @90.8.4 8 mikropiiri 4000 CD4049AE Hex inverter
4049 @90.8.4 2 mikropiiri 4000 CD4049CN Hex inverter
4049 @90.8.4 34 mikropiiri 4000 CD4049UBE Hex inverter
4049 @90.8.4 6 mikropiiri 4000 CD4049UBF Hex inverter
4049 @90.8.5 6 mikropiiri 4000 HCF4049BETH Hex inverter
4049 @90.8.5 67 mikropiiri 4000 HCF4049UBE Hex inverter
4049 @90.8.5 2 mikropiiri 4000 HCF4049UBF Hex inverter
4049 @90.8.5 2 mikropiiri 4000 HEF4049BD Hex inverter
4049 @90.8.5 27 mikropiiri 4000 HEF4049BP Hex inverter
4049 @90.9.1 6 mikropiiri 4000 HEF4049P Hex inverter
4049 @90.9.1 48 mikropiiri 4000 MC14049BCP Hex inverter
4049 @90.9.1 8 mikropiiri 4000 MC14049CP Hex inverter
4049 @90.9.1 57 mikropiiri 4000 MC14049UBCP Hex inverter
4049 @90.9.2 1 mikropiiri 4000 MN4049B Hex inverter
4049 @90.9.2 3 mikropiiri 4000 SCL4049UBE Hex inverter
4049 @90.9.2 1 mikropiiri 4000 SIL4049BE Hex inverter
4049 @90.9.2 1 mikropiiri 4000 TC4049BP Hex inverter
4049 @90.9.2 1 mikropiiri 4000 TP4049UBN Hex inverter
4049 @90.9.2 2 mikropiiri 4000 CD4049UBFX Hex inverter
4050 @90.9.3 22 mikropiiri 4000 CD4050AE Hex buffer
4050 @90.9.3 10 mikropiiri 4000 CD4050BCN Hex buffer
4050 @90.9.3 12 mikropiiri 4000 CD4050BE Hex buffer
4050 @90.9.3 26 mikropiiri 4000 CD4050BF Hex buffer
4050 @90.9.3 57 mikropiiri 4000 HCF4050BE Hex buffer
4050 @90.9.4 4 mikropiiri 4000 HEF4050BP Hex buffer
4050 @90.9.4 2 mikropiiri 4000 HEF4050P Hex buffer
4050 @90.9.4 24 mikropiiri 4000 MC14050BCP Hex buffer
4050 @90.9.4 12 mikropiiri 4000 MC14050CP Hex buffer
4050 @90.9.4 6 mikropiiri 4000 GD4050B Hex buffer
4050 @90.9.4 1 mikropiiri 4000 CD4050BFX Hex buffer
4051 @90.9.5 4 mikropiiri 4000 4051PC 8-channel analog multiplexer/demultiplexer
4051 @90.9.5 8 mikropiiri 4000 CD4051BCN 8-channel analog multiplexer/demultiplexer
4051 @90.9.5 8 mikropiiri 4000 CD4051BF 8-channel analog multiplexer/demultiplexer
4051 @90.9.5 27 mikropiiri 4000 HCF4051BE 8-channel analog multiplexer/demultiplexer
4051 @90.9.5 4 mikropiiri 4000 HEF4051BP 8-channel analog multiplexer/demultiplexer
4051 @90.9.5 2 mikropiiri 4000 MC14051BCP 8-channel analog multiplexer/demultiplexer
4052 @90.10.1 2 mikropiiri 4000 4052PC MC14052B Dual 4-channel analog multiplexer/demultiplexer
4052 @90.10.1 4 mikropiiri 4000 CD4052CN Dual 4-channel analog multiplexer/demultiplexer
4053 @90.10.1 3 mikropiiri 4000 CD4053BCN Triple 2-channel analog multiplexer/demultiplexer
4053 @90.10.1 8 mikropiiri 4000 HCF4053BE Triple 2-channel analog multiplexer/demultiplexer
4053 @90.10.1 4 mikropiiri 4000 SIL4053BE Triple 2-channel analog multiplexer/demultiplexer
4053 @90.10.1 10 mikropiiri 4000 CD4053BE MC14053BCP TC4053BP Triple 2-channel analog multiplexer/demultiplexer
4056 @90.10.2 17 mikropiiri 4000 HCF4056BE BCD to 7-segment decoder/LCD driver with strobed-latch function
4060 @90.10.2 59 mikropiiri 4000 CD4060BCN 14-stage ripple counter, ext. RC/crystal osc. (32.768 kHz compatible), schmitt trigger inputs
4060 @90.10.2 7 mikropiiri 4000 CD4060BE 14-stage ripple counter, ext. RC/crystal osc. (32.768 kHz compatible), schmitt trigger inputs
4060 @90.10.2 34 mikropiiri 4000 CD4060BF 14-stage ripple counter, ext. RC/crystal osc. (32.768 kHz compatible), schmitt trigger inputs
4060 @90.10.2 6 mikropiiri 4000 CD4060AE 14-stage ripple counter, ext. RC/crystal osc. (32.768 kHz compatible), schmitt trigger inputs
4060 @90.10.3 25 mikropiiri 4000 HEF4060BD 14-stage ripple counter, ext. RC/crystal osc. (32.768 kHz compatible), schmitt trigger inputs
4060 @90.10.3 13 mikropiiri 4000 HEF4060BP 14-stage ripple counter, ext. RC/crystal osc. (32.768 kHz compatible), schmitt trigger inputs
4060 @90.10.3 1 mikropiiri 4000 HCF4060BE MC14060BCP CD4060CDN 14-stage ripple counter, ext. RC/crystal osc. (32.768 kHz compatible)
4060 @90.10.3 2 mikropiiri 4000 SCL4060BE 14-stage ripple counter, ext. RC/crystal osc. (32.768 kHz compatible), schmitt trigger inputs
4063 @90.10.3 4 mikropiiri 4000 HCF4063BE 4-bit magnitude comparator
4066 @90.10.4 1 mikropiiri 4000 4066BPC Quad analog switch (low "ON" resistance)
4066 @90.10.4 12 mikropiiri 4000 CD4066BCN CD4066BE Quad analog switch (low "ON" resistance)
4066 @90.10.4 37 mikropiiri 4000 HCF4066BE Quad analog switch (low "ON" resistance)
4066 @90.10.4 3 mikropiiri 4000 HEF4066BP Quad analog switch (low "ON" resistance)
4066 @90.10.4 19 mikropiiri 4000 MC14066BCP Quad analog switch (low "ON" resistance)
4066 @90.10.4 1 mikropiiri 4000 TC4066BP Quad analog switch (low "ON" resistance)
4067 @90.10.5 2 mikropiiri 4000 CD4067BE 16-channel analog multiplexer/demultiplexer (1-of-16 switch)
4067 @90.10.5 5 mikropiiri 4000 HEF4067BP 16-channel analog multiplexer/demultiplexer (1-of-16 switch)
4068 @90.11.1 17 mikropiiri 4000 CD4068BE 8-input NAND/AND gate (2 outputs per gate)
4068 @90.11.1 27 mikropiiri 4000 HCF4068BE 8-input NAND/AND gate (2 outputs per gate)
4068 @90.11.1 5 mikropiiri 4000 4068PC 8-input NAND/AND gate (2 outputs per gate)
4068 @90.11.1 1 mikropiiri 4000 MC14068BCP 8-input NAND/AND gate (2 outputs per gate)
4069 @90.11.2 1 mikropiiri 4000 C54069UBE Hex inverter
4069 @90.11.2 63 mikropiiri 4000 CD4069CN Hex inverter
4069 @90.11.2 100 mikropiiri 4000 HCF4069UBE Hex inverter
4069 @90.11.3 30 mikropiiri 4000 CD4069UBE Hex inverter
4069 @90.11.3 4 mikropiiri 4000 HEF4069UBP TP4069BP CD4069UBF Hex inverter
4069 @90.11.3 22 mikropiiri 4000 MC14069UBCP Hex inverter
4069 @90.11.3 130 mikropiiri 4000 TC4069UBP Hex inverter
4070 @90.11.4 5 mikropiiri 4000 4070PC Quad XOR Gates
4070 @90.11.4 46 mikropiiri 4000 14-Pin DIP 300-mil CD4070BCN Quad XOR Gates Datasheet
4070 @90.11.4 8 mikropiiri 4000 CD4070BE Quad XOR Gates
4070 @90.11.4 36 mikropiiri 4000 14-Pin DIP 300-mil HCF4070BE Quad XOR Gates Datasheet
4070 @90.11.4 1 mikropiiri 4000 HCF4070BF Quad XOR Gates
4070 @90.11.5 22 mikropiiri 4000 HEF4070BP Quad XOR Gates
4070 @90.11.5 1 mikropiiri 4000 MC14070BAL Quad XOR Gates
4070 @90.11.5 9 mikropiiri 4000 14-Pin DIP 300-mil MC14070BCP Quad XOR Gates Datasheet
4071 @90.12.1 11 mikropiiri 4000 4071PC Quad 2-input OR gate
4071 @90.12.1 25 mikropiiri 4000 CD4071BCN Quad 2-input OR gate
4071 @90.12.1 5 mikropiiri 4000 CD4071BE Quad 2-input OR gate
4071 @90.12.1 17 mikropiiri 4000 HCF4071BE Quad 2-input OR gate
4071 @90.12.1 9 mikropiiri 4000 HEF4071BP Quad 2-input OR gate
4071 @90.12.1 7 mikropiiri 4000 TC4071BP Quad 2-input OR gate
4071 @90.12.2 2 mikropiiri 4000 MC14071BPC Quad 2-input OR gate
4072 @90.12.2 23 mikropiiri 4000 CD4072BCN Dual 4-input OR gate
4072 @90.12.2 13 mikropiiri 4000 CD4072BE Dual 4-input OR gate
4072 @90.12.2 1 mikropiiri 4000 MC14072BCP Dual 4-input OR gate
4072 @90.12.2 1 mikropiiri 4000 MC14072UBCP Dual 4-input OR gate
4073 @90.12.3 4 mikropiiri 4000 4073PC Triple 3-input AND gate
4073 @90.12.3 62 mikropiiri 4000 CD4073BCN Triple 3-input AND gate
4073 @90.12.3 2 mikropiiri 4000 CD4073BE Triple 3-input AND gate
4073 @90.12.3 10 mikropiiri 4000 CD4073BF Triple 3-input AND gate
4073 @90.12.3 26 mikropiiri 4000 MC14073BCP Triple 3-input AND gate
4075 @90.12.4 4 mikropiiri 4000 4075PC Triple 3-input OR gate
4075 @90.12.4 28 mikropiiri 4000 CD4075BCN Triple 3-input OR gate
4075 @90.12.4 1 mikropiiri 4000 CD4075BE Triple 3-input OR gate
4075 @90.12.4 24 mikropiiri 4000 HCF4075BE Triple 3-input OR gate
4075 @90.12.4 1 mikropiiri 4000 HEF4075BP Triple 3-input OR gate
4076 @90.12.5 36 mikropiiri 4000 CD4076BCN Quad D-type register, three-state outputs
4076 @90.12.5 10 mikropiiri 4000 HCF4076BE Quad D-type register, three-state outputs
4077 @91.1.1 5 mikropiiri 4000 4077PC MC14077BAL Quad Exclusive NOR
4077 @91.1.1 10 mikropiiri 4000 CD4077BE Quad Exclusive NOR
4077 @91.1.1 14 mikropiiri 4000 14-Pin DIP 300-mil HEF4077BP Quad Exclusive NOR Datasheet
4077 @91.1.1 99 mikropiiri 4000 14-Pin DIP 300-mil MC14077BCP Quad Exclusive NOR Datasheet
4078 @91.1.2 5 mikropiiri 4000 4078PC Single 8-input NOR/OR gate (2 outputs per gate)
4078 @91.1.2 1 mikropiiri 4000 4078BPC Single 8-input NOR/OR gate (2 outputs per gate)
4078 @91.1.2 23 mikropiiri 4000 HCF4078BE Single 8-input NOR/OR gate (2 outputs per gate)
4078 @91.1.2 10 mikropiiri 4000 34078PC Single 8-input NOR/OR gate (2 outputs per gate)
4081 @91.1.3 8 mikropiiri 4000 4081BPC Quad 2-input AND gate
4081 @91.1.3 15 mikropiiri 4000 CD4081BCN Quad 2-input AND gate
4081 @91.1.3 50 mikropiiri 4000 CD4081BE Quad 2-input AND gate
4081 @91.1.3 23 mikropiiri 4000 HCF4081BE Quad 2-input AND gate
4081 @91.1.3 42 mikropiiri 4000 HEF4081BP Quad 2-input AND gate
4081 @91.1.4 15 mikropiiri 4000 MC14081BCP Quad 2-input AND gate
4081 @91.1.4 2 mikropiiri 4000 MC14081CL Quad 2-input AND gate
4081 @91.1.4 12 mikropiiri 4000 MC14081CP Quad 2-input AND gate
4081 @91.1.4 7 mikropiiri 4000 TC4081BP Quad 2-input AND gate
4081 @91.1.4 1 mikropiiri 4000 34081PC Quad 2-input AND gate
4081 @91.1.4 1 mikropiiri 4000 CD4081BFX Quad 2-input AND gate
4082 @91.1.5 25 mikropiiri 4000 CD4082BCN Dual 4-input AND gate
4082 @91.1.5 12 mikropiiri 4000 HCF4082BE Dual 4-input AND gate
4082 @91.1.5 5 mikropiiri 4000 MC14082BCP Dual 4-input AND gate
4082 @91.1.5 2 mikropiiri 4000 SCL4082A/BE Dual 4-input AND gate
4082 @91.1.5 2 mikropiiri 4000 SCL4082AE Dual 4-input AND gate
4082 @91.1.5 3 mikropiiri 4000 SCL4082BE Dual 4-input AND gate
4089 @91.2.1 24 mikropiiri 4000 CD4089BF Binary rate multiplier
4093 @91.2.1 52 mikropiiri 4000 CD4093BCN Quad 2-input NAND gate, schmitt trigger inputs
4093 @91.2.1 4 mikropiiri 4000 CD4093BE Quad 2-input NAND gate, schmitt trigger inputs
4093 @91.2.1 3 mikropiiri 4000 CD4093BF Quad 2-input NAND gate, schmitt trigger inputs
4093 @91.2.1 33 mikropiiri 4000 HCF4093BE Quad 2-input NAND gate, schmitt trigger inputs
4093 @91.2.2 10 mikropiiri 4000 HEF4093BP Quad 2-input NAND gate, schmitt trigger inputs
4093 @91.2.2 59 mikropiiri 4000 MC14093BCP Quad 2-input NAND gate, schmitt trigger inputs
4093 @91.2.2 15 mikropiiri 4000 MC14093BCPD Quad 2-input NAND gate, schmitt trigger inputs
4093 @91.2.2 3 mikropiiri 4000 SCL4093BE Quad 2-input NAND gate, schmitt trigger inputs
4093 @91.2.2 8 mikropiiri 4000 TC4093BP Quad 2-input NAND gate, schmitt trigger inputs
4094 @91.2.3 1 mikropiiri 4000 CD4094BE 8-stage shift-and-store bus
4094 @91.2.3 2 mikropiiri 4000 HEF4094BP 8-stage shift-and-store bus
4098 @91.2.4 34 mikropiiri 4000 CD4098BE Dual one-shot monostable
4098 @91.2.4 11 mikropiiri 4000 CD4098BF Dual one-shot monostable
4098 @91.2.4 23 mikropiiri 4000 HCF4098BE Dual one-shot monostable
4099 @91.2.5 14 mikropiiri 4000 CD4099BCN 8-bit addressable latch
4099 @91.2.5 56 mikropiiri 4000 CD4099BE 8-bit addressable latch
4099 @91.2.5 37 mikropiiri 4000 MC14099BCP 8-bit addressable latch
4104 @91.2.5 25 mikropiiri 4000 HEF4104BP Quad low to high voltage translator with 3-state outputs
40014 @91.3.1 10 mikropiiri 4000 40014BDC Hex Schmitt trigger
40014 @91.3.1 11 mikropiiri 4000 40014BPC Hex Schmitt trigger
40097 @91.3.2 142 mikropiiri 4000 HEF40097BP 3-state hex non-inverting buffer
40098 @91.3.2 29 mikropiiri 4000 HEF40098BP 3-state hex inverting buffer
40098 @91.3.2 3 mikropiiri 4000 HEF40098P 3-state hex inverting buffer
40102 @91.3.3 7 mikropiiri 4000 CD40102BE Presettable 2-decade BCD down counter
40103 @91.3.3 9 mikropiiri 4000 16-Pin DIP 300-mil CD40103BE 8-Stage Presettable Synchronous Down Counter Datasheet
40103 @91.3.3 6 mikropiiri 4000 CD40103BF 8-Stage Presettable Synchronous Down Counter
40106 @91.3.3 26 mikropiiri 4000 CD40106BCN Hex inverter gate, schmitt trigger inputs
40106 @91.3.3 11 mikropiiri 4000 CD40106BE Hex inverter gate, schmitt trigger inputs
40106 @91.3.3 9 mikropiiri 4000 HCF40106BE Hex inverter gate, schmitt trigger inputs
40106 @91.3.4 13 mikropiiri 4000 HEF40106BP Hex inverter gate, schmitt trigger inputs
40107 @91.3.4 8 mikropiiri 4000 CD40107BE Dual 2-input NAND gate, 136 mA open drain output driver
40109 @91.3.4 8 mikropiiri 4000 CD40109BE Quad voltage level translator, three-state outputs, dual power rails
40109 @91.3.4 1 mikropiiri 4000 HCF40109BE Quad voltage level translator, three-state outputs, dual power rails
40160 @91.3.4 30 mikropiiri 4000 340160PC 4-bit sync. decade counter, async. clear, load, ripple carry output
40174 @91.3.5 11 mikropiiri 4000 CD40174BCN Hex D-type flip-flop, pos.-edge trigger, shared clock and clear
40174 @91.3.5 10 mikropiiri 4000 CD40174BE Hex D-type flip-flop, pos.-edge trigger, shared clock and clear
40175 @91.4.1 64 mikropiiri 4000 40175BPC Quad D-type flip-flop, pos.-edge trigger, shared clock and clear
40175 @91.4.1 1 mikropiiri 4000 40175PC Quad D-type flip-flop, pos.-edge trigger, shared clock and clear
40175 @91.4.1 30 mikropiiri 4000 HEF40175BP Quad D-type flip-flop, pos.-edge trigger, shared clock and clear
40192 @91.4.1 5 mikropiiri 4000 340192 4-Bit Sync. Count Up/Down
Mikropiirit 4500
4501 @91.5.1 84 mikropiiri 4500 MC14501UBCP Triple Gate dual 4–Input NAND,2–Input NOR/OR, 8–Input AND/NAND MC14501UBCP.pdf
4501 @91.5.1 2 mikropiiri 4500 MC14501CP Triple Gate dual 4–Input NAND,2–Input NOR/OR, 8–Input AND/NAND MC14501UBCP.pdf
4503 @91.5.1 28 mikropiiri 4500 CD4503BCN Hex buffer, three-state outputs
4503 @91.5.1 10 mikropiiri 4500 MC14503BAL CD4503BE Hex buffer, three-state outputs
4504 @91.5.1 1 mikropiiri 4500 MC14504BCP Hex voltage translator
4505 @91.5.2 40 mikropiiri 4500 HEF4505BP 64x1-bit RAM
4505 @91.5.2 1 mikropiiri 4500 MC14505BCP 64x1-bit RAM
4505 @91.5.2 37 mikropiiri 4500 MCM14505CL 64x1-bit RAM
4507 @91.5.2 30 mikropiiri 4500 MC14507BCP Quad XOR Gate
4507 @91.5.2 38 mikropiiri 4500 MC14507CP Quad XOR Gate
4508 @91.5.3 65 mikropiiri 4500 HCF4508BE Dual 4-bit latch, three-state outputs
4508 @91.5.3 14 mikropiiri 4500 MC14508BCP Dual 4-bit latch, three-state outputs
4508 @91.5.3 1 mikropiiri 4500 SCL4508BE Dual 4-bit latch, three-state outputs
4510 @91.5.4 12 mikropiiri 4500 CD4510BE Presettable 4-bit BCD up/down counter
4510 @91.5.4 3 mikropiiri 4500 HCF4510BE Presettable 4-bit BCD up/down counter
4510 @91.5.4 1 mikropiiri 4500 HEF4510BP Presettable 4-bit BCD up/down counter
4510 @91.5.4 3 mikropiiri 4500 MC14510CP Presettable 4-bit BCD up/down counter
4510 @91.5.4 12 mikropiiri 4500 SIL4510BE Presettable 4-bit BCD up/down counter
4511 @91.5.5 3 mikropiiri 4500 CD4511BCN BCD to 7-segment latch/decoder/LED driver Datasheet
4511 @91.5.5 43 mikropiiri 4500 HCF4511BE BCD to 7-segment latch/decoder/LED driver
4511 @91.5.5 17 mikropiiri 4500 HEF4511BP BCD to 7-segment latch/decoder/LED driver
4511 @91.5.5 8 mikropiiri 4500 MD4511BE BCD to 7-segment latch/decoder/LED driver
4512 @91.5.5 13 mikropiiri 4500 CD4512BF 8-input multiplexer (data selector), three-state output
4512 @91.5.5 17 mikropiiri 4500 CD4512CN 8-input multiplexer (data selector), three-state output
4512 @91.6.1 87 mikropiiri 4500 HEF4512BP 8-input multiplexer (data selector), three-state output
4512 @91.6.1 7 mikropiiri 4500 MC14512BCP 8-input multiplexer (data selector), three-state output
4512 @91.6.1 8 mikropiiri 4500 MC14512CP 8-input multiplexer (data selector), three-state output
4512 @91.6.1 4 mikropiiri 4500 SIL4512BE 8-input multiplexer (data selector), three-state output
4512 @91.6.1 35 mikropiiri 4500 TP4512AN 8-input multiplexer (data selector), three-state output
4514 @91.6.2 66 mikropiiri 4500 CD4514BCN 4-Bit Latch/4-to-16 line decoder/demultiplexer, active HIGH output
4514 @91.6.2 3 mikropiiri 4500 CD4514BE 4-Bit Latch/4-to-16 line decoder/demultiplexer, active HIGH output
4514 @91.6.2 12 mikropiiri 4500 HEF4514BP HEF4514P 4-Bit Latch/4-to-16 line decoder/demultiplexer, active HIGH output
4514 @91.6.3 68 mikropiiri 4500 MC14514BCP 4-Bit Latch/4-to-16 line decoder/demultiplexer, active HIGH output
4514 @91.6.3 3 mikropiiri 4500 MC14514CL MC14514CP 4-Bit Latch/4-to-16 line decoder/demultiplexer, active HIGH output
4514 @91.6.3 2 mikropiiri 4500 24-Pin DIP TC4514BP 4-Bit Latch/4-to-16 line decoder (Output active high) Datasheet
4515 @91.6.4 3 mikropiiri 4500 CD4515BCN 4-Bit Latch/4-to-16 line decoder/demultiplexer, active LOW output
4515 @91.6.4 2 mikropiiri 4500 HEF4515PB 4-Bit Latch/4-to-16 line decoder/demultiplexer, active LOW output
4515 @91.6.4 3 mikropiiri 4500 SCL4515A/BE 4-Bit Latch/4-to-16 line decoder/demultiplexer, active LOW output
4516 @91.6.4 2 mikropiiri 4500 4516BDC MC14516CP Presettable 4-bit binary up/down counter
4516 @91.6.4 5 mikropiiri 4500 HCF4516BE Presettable 4-bit binary up/down counter
4516 @91.6.4 27 mikropiiri 4500 MC14516BCP Presettable 4-bit binary up/down counter
4518 @91.6.5 26 mikropiiri 4500 4518BPC Dual BCD up counter
4518 @91.6.5 21 mikropiiri 4500 CD4518BCN Dual BCD up counter
4518 @91.6.5 25 mikropiiri 4500 CD4518BE Dual BCD up counter
4518 @91.6.5 12 mikropiiri 4500 CD4518BF Dual BCD up counter
4518 @91.6.5 9 mikropiiri 4500 CD4518BPC Dual BCD up counter
4518 @91.6.5 18 mikropiiri 4500 HCF4518BE Dual BCD up counter
4518 @91.7.1 23 mikropiiri 4500 HEF4518BP Dual BCD up counter
4518 @91.7.1 1 mikropiiri 4500 SIL4518BE Dual BCD up counter
4518 @91.7.1 10 mikropiiri 4500 MC14518BCP Dual BCD up counter
4518 @91.7.1 11 mikropiiri 4500 TP4518AN Dual BCD up counter
4519 @91.7.1 3 mikropiiri 4500 TP4519AN 4-bit AND-OR select gates
4520 @91.7.2 5 mikropiiri 4500 4520BPC Dual 4-bit binary up counter
4520 @91.7.2 1 mikropiiri 4500 16-Pin DIP 300-mil 4520PC Dual 4-bit binary up counter
4520 @91.7.2 55 mikropiiri 4500 16-Pin DIP 300-mil CD4520BCN Dual 4-bit binary up counter
4520 @91.7.2 5 mikropiiri 4500 16-Pin DIP 300-mil CD4520BE Dual 4-bit binary up counter
4520 @91.7.2 20 mikropiiri 4500 16-Pin DIP 300-mil CD4520BF Dual 4-bit binary up counter
4520 @91.7.2 3 mikropiiri 4500 16-Pin DIP 300-mil HCF4520BE Dual 4-bit binary up counter
4520 @91.7.3 1 mikropiiri 4500 16-Pin DIP 300-mil MC14520CP Dual 4-bit binary up counter
4520 @91.7.3 4 mikropiiri 4500 MC14520BCL Dual 4-bit binary up counter
4520 @91.7.3 14 mikropiiri 4500 MC14520BCP Dual 4-bit binary up counter
4520 @91.7.3 63 mikropiiri 4500 16-Pin DIP 300-mil SIL4520BE Dual 4-bit binary up counter
4520 @91.7.3 35 mikropiiri 4500 16-Pin DIP 300-mil TC4520BP Dual 4-bit binary up counter
4521 @91.7.4 1 mikropiiri 4500 34021PC 8-Bit Static Shift Register
4522 @91.7.4 26 mikropiiri 4500 MC14522BCP BCD divide-by-N counter
4522 @91.7.4 3 mikropiiri 4500 MC14522CP BCD divide-by-N counter
4522 @91.7.4 9 mikropiiri 4500 SCL4522BE BCD divide-by-N counter
4522 @91.7.4 2 mikropiiri 4500 CD4522BCN BCD divide-by-N counter
4526 @91.8.1 5 mikropiiri 4500 CD4526BCN Binary divide-by-N counter
4526 @91.8.1 6 mikropiiri 4500 MC14526BCL Binary divide-by-N counter
4526 @91.8.1 4 mikropiiri 4500 SCL4526BE Binary divide-by-N counter
4527 @91.8.1 4 mikropiiri 4500 MC14527CP BCD Rate Multiplier
4528 @91.8.2 6 mikropiiri 4500 4528BCP Dual Monostable Multivibrator
4528 @91.8.2 6 mikropiiri 4500 4528BDC Dual Monostable Multivibrator
4528 @91.8.2 6 mikropiiri 4500 CD4528BCN Dual Monostable Multivibrator
4528 @91.8.2 4 mikropiiri 4500 HCF4528BETH SIL4528BE Dual Monostable Multivibrator
4528 @91.8.2 32 mikropiiri 4500 HEF4528BP Dual Monostable Multivibrator
4528 @91.8.2 43 mikropiiri 4500 MC14528BCP Dual Monostable Multivibrator
4530 @91.8.3 1 mikropiiri 4500 MC14530CP Dual 5-Input Majority Logic Gate
4532 @91.8.3 2 mikropiiri 4500 4532BCP 8-bit priority encoder, 3-bit output
4532 @91.8.3 13 mikropiiri 4500 CD4532BE 8-bit priority encoder, 3-bit output
4532 @91.8.3 11 mikropiiri 4500 MC14532BCP 8-bit priority encoder, 3-bit output
4538 @91.8.4 22 mikropiiri 4500 CD4538BCN Dual retriggerable precision monostable multivibrator
4538 @91.8.4 2 mikropiiri 4500 CD4538BE Dual retriggerable precision monostable multivibrator
4538 @91.8.4 4 mikropiiri 4500 MC14538BCL Dual retriggerable precision monostable multivibrator
4538 @91.8.4 14 mikropiiri 4500 MC14538BCP Dual retriggerable precision monostable multivibrator
4541 @91.8.5 2 mikropiiri 4500 HEF4541BP Programmable timer, ext. clock/RC oscillator, divider of 8 / 10 / 13 / 16 stages
4541 @91.8.5 33 mikropiiri 4500 MC14541BCP Programmable timer, ext. clock/RC oscillator, divider of 8 / 10 / 13 / 16 stages
4541 @91.8.5 3 mikropiiri 4500 MC14541BCL Programmable timer, ext. clock/RC oscillator, divider of 8 / 10 / 13 / 16 stages
4543 @91.8.5 30 mikropiiri 4500 MC14543BCP BCD-7-Segment LCD Latch/Decoder/Driver
4543 @91.8.5 8 mikropiiri 4500 CD4543BCN BCD-7-Segment LCD Latch/Decoder/Driver
4553 @91.9.5 28 mikropiiri 4500 MC14553BAL BCD to 7-segment latch/decoder/LCD driver, phase input
4553 @91.9.5 2 mikropiiri 4500 MC14553BCP BCD to 7-segment latch/decoder/LCD driver, phase input
4554 @91.9.5 150 mikropiiri 4500 MC14554BCP 2-Bit by 2-Bit Parallel Binary Multiplier
4555 @91.10.1 19 mikropiiri 4500 4555BPC Dual 1-of-4 decoder/demultiplexer, active HIGH output
4555 @91.10.1 6 mikropiiri 4500 CD4555BE Dual 1-of-4 decoder/demultiplexer, active HIGH output
4555 @91.10.1 1 mikropiiri 4500 CD4555BFX Dual 1-of-4 decoder/demultiplexer, active HIGH output
4555 @91.10.1 1 mikropiiri 4500 MC4555CP Dual 1-of-4 decoder/demultiplexer, active HIGH output
4556 @91.10.2 22 mikropiiri 4500 CD4556BE Dual 1-of-4 decoder/demultiplexer. active LOW output
4558 @91.10.2 1 mikropiiri 4500 MC14558BCP BCD-to-Seven Segment (7-segment) Decoder
4569 @91.10.2 33 mikropiiri 4500 MC14569BCL MC14569BCP Divide-By-N Dual 4-Bit Binary/BC Down Counter
4572 @91.10.2 4 mikropiiri 4500 MC14572CP Hex gates: quad inverter, 2-input NAND gate, 2-input NOR gate
4572 @91.10.2 13 mikropiiri 4500 MC14572UB Hex gates: quad inverter, 2-input NAND gate, 2-input NOR gate
4584 @91.10.3 1 mikropiiri 4500 MC14584BAL Hex inverter gate, schmitt trigger inputs
4584 @91.10.3 2 mikropiiri 4500 SCL4584BE Hex inverter gate, schmitt trigger inputs
4584 @91.10.3 40 mikropiiri 4500 MC14584BCP Hex inverter gate, schmitt trigger inputs
4585 @91.10.4 4 mikropiiri 4500 HCF4585BE 4-Bit comparator
4585 @91.10.4 11 mikropiiri 4500 HEF4585BP 4-Bit comparator
4585 @91.10.4 28 mikropiiri 4500 MC14585BCP 4-Bit comparator
4585 @91.10.4 49 mikropiiri 4500 SCL4585A/BE 4-Bit comparator
4585 @91.10.4 3 mikropiiri 4500 SCL4585BE 4-Bit comparator
4585 @91.10.4 19 mikropiiri 4500 16-Pin DIP 300-mil TC4585BP 4-Bit comparator Datasheet
4585 @91.10.5 39 mikropiiri 4500 CD4585BE 4-Bit comparator
4585 @91.10.5 3 mikropiiri 4500 CD4585BF 4-Bit comparator
45106 @91.10.5 6 mikropiiri 4500 MC145106P PLL Frequency Synthesizer MC145106.pdf
Mikropiirit 54
5400 @89.11.4 7 mikropiiri 54 SN54LS00J quad 2-input NAND gate
5408 @89.11.4 1 mikropiiri 54 SN54LS08J
5438 @89.11.4 2 mikropiiri 54 DM54LS38N quad 2-input NAND gate OC
5473 @89.11.4 2 mikropiiri 54 SN54LS73AJ
54193 @89.11.5 1 mikropiiri 54 SN54LS193J synchronous presettable up/down 4-bit binary counter, clear
54193 @89.11.5 3 mikropiiri 54 SNJ54LS193J synchronous presettable up/down 4-bit binary counter, clear
54240 @89.11.5 9 mikropiiri 54 SN54S240J Octal 3-STATE Buffer/Line Driver/Line Receiver
544060 @89.11.5 14 mikropiiri 54 MC54HC4060J 14-stage binary ripple counter with oscillator
Mikropiirit 74-Series
7400 @86.1.1 22 mikropiiri 74 SN74HC00N quad 2-input NAND gate
7400 @86.1.1 5 mikropiiri 74 74LS00N quad 2-input NAND gate Datasheet
7400 @86.1.1 19 mikropiiri 74 SN74S00N quad 2-input NAND gate Datasheet
7400 @86.1.1 32 mikropiiri 74 SN74LS00N quad 2-input NAND gate Datasheet
7400 @86.1.1 21 mikropiiri 74 SN7400N quad 2-input NAND gate Datasheet
7400 @86.1.1 13 mikropiiri 74 74F00PC quad 2-input NAND gate
7400 @86.1.2 4 mikropiiri 74 SN74S00J quad 2-input NAND gate Datasheet
7400 @86.1.2 19 mikropiiri 74 PC74HCT00P quad 2-input NAND gate
7400 @86.1.2 27 mikropiiri 74 DM74LS00N quad 2-input NAND gate
7400 @86.1.2 15 mikropiiri 74 DM7400N quad 2-input NAND gate
7400 @86.1.2 4 mikropiiri 74 74LS00PC quad 2-input NAND gate Datasheet
7400 @86.1.2 3 mikropiiri 74 M74HC00B1 quad 2-input NAND gate
7400 @86.1.3 7 mikropiiri 74 SG7400N 7400N 7400PC FJH131/7400N quad 2-input NAND gate
7400 @86.1.3 4 mikropiiri 74 DM74S00N MM74C00N MB74LS00 MC74HC00 quad 2-input NAND gate
7400 @86.1.3 4 mikropiiri 74 SN74ALS00AN DM74ALS00AN CD74AC00E uPB74LS00C quad 2-input NAND gate Datasheet
7400 @86.1.3 13 mikropiiri 74 7400 quad 2-input NAND gate
7400 @86.1.3 4 mikropiiri 74 MM74HCT00N CD74HCT00E quad 2-input NAND gate
7400 @86.1.3 6 mikropiiri 74 N74LS00A MC7400P N7400A quad 2-input NAND gate Datasheet
7400 @86.1.4 150 mikropiiri 74 MC74HC00AN quad 2-input NAND gate
7400 @86.1.4 15 mikropiiri 74 MC74HC00N quad 2-input NAND gate
7400 @86.1.4 49 mikropiiri 74 74HC00N quad 2-input NAND gate
7400 @86.1.5 48 mikropiiri 74 74VHCTAN00N quad 2-input NAND gate
7400 @86.1.5 25 mikropiiri 74 DM74S00J0 quad 2-input NAND gate
7400 @86.1.5 6 mikropiiri 74 SN74L00N quad 2-input NAND gate
7400 @86.1.5 3 mikropiiri 74 HD74LS00P SN74F00N quad 2-input NAND gate
7400 @86.1.5 15 mikropiiri 74 MM74C00N quad 2-input NAND gate
7400 @86.1.5 4 mikropiiri 74 SN74AHCT00N quad 2-input NAND gate
7401 @86.2.1 68 mikropiiri 74 SN74LS01N quad 2-input NAND gate, open-collector
7401 @86.2.1 12 mikropiiri 74 SN7401N quad 2-input NAND gate, open-collector
7401 @86.2.1 6 mikropiiri 74 T74LS01B1 quad 2-input NAND gate, open-collector
7401 @86.2.1 5 mikropiiri 74 7401 quad 2-input NAND gate, open-collector
7402 @86.2.2 25 mikropiiri 74 MC74HC02AN
7402 @86.2.2 20 mikropiiri 74 MC74HC02N
7402 @86.2.2 5 mikropiiri 74 SN74F02N SN74S02N
7402 @86.2.2 32 mikropiiri 74 DM74LS02N
7402 @86.2.2 34 mikropiiri 74 DM7402N
7402 @86.2.2 20 mikropiiri 74 SN7402N
7402 @86.2.3 53 mikropiiri 74 SN74LS02N
7402 @86.2.3 47 mikropiiri 74 74LS02N
7402 @86.2.3 71 mikropiiri 74 SN74LS02N
7402 @86.2.3 4 mikropiiri 74 HD74LS02P
7402 @86.2.4 29 mikropiiri 74 MC74HC02N
7402 @86.2.4 28 mikropiiri 74 SN74HC02N
7402 @86.2.4 7 mikropiiri 74 M74HC02B1
7402 @86.2.4 2 mikropiiri 74 SN74AHCT02N
7402 @86.2.4 4 mikropiiri 74 74LS02PC 74LS02 KS74HCTLS02N
7402 @86.2.4 2 mikropiiri 74 7402N
7402 @86.2.5 50 mikropiiri 74 SN74HC02N
7402 @86.2.5 49 mikropiiri 74 CD74HC02E
7402 @86.2.5 26 mikropiiri 74 74HC02N
7402 @86.2.5 9 mikropiiri 74 MM74C02N
7403 @86.3.1 30 mikropiiri 74 SN74LS03N
7403 @86.3.1 15 mikropiiri 74 DM74LS03N
7403 @86.3.1 14 mikropiiri 74 DM7403N
7403 @86.3.1 5 mikropiiri 74 SN7403N
7403 @86.3.1 23 mikropiiri 74 N7403A
7403 @86.3.1 3 mikropiiri 74 74LS03PC 7403
7403 @86.3.2 50 mikropiiri 74 SN74HC03N
7404 @86.3.3 23 mikropiiri 74 74HCU04AP
7404 @86.3.3 48 mikropiiri 74 SN74LS04N
7404 @86.3.3 21 mikropiiri 74 SN7404N
7404 @86.3.3 26 mikropiiri 74 DM7404N
7404 @86.3.3 16 mikropiiri 74 74AC04PC
7404 @86.3.3 28 mikropiiri 74 HD74LS04P
7404 @86.3.4 70 mikropiiri 74 74HC04N
7404 @86.3.4 140 mikropiiri 74 MC74HC04AN
7404 @86.3.4 28 mikropiiri 74 T74LS04B1
7404 @86.3.5 51 mikropiiri 74 SN74S04N
7404 @86.3.5 76 mikropiiri 74 74LS04PC
7404 @86.3.5 13 mikropiiri 74 74LS04 74LS04N GD74LS04
7404 @86.3.5 19 mikropiiri 74 7404
7404 @86.4.1 2 mikropiiri 74 SN74ALS04BN
7404 @86.4.1 4 mikropiiri 74 GD74HC04
7404 @86.4.1 5 mikropiiri 74 PC74HCT04P
7404 @86.4.1 10 mikropiiri 74 SN74L04N
7404 @86.4.1 4 mikropiiri 74 74F04N SN74F04N
7404 @86.4.1 9 mikropiiri 74 7404PC MC7404P 7404N T7404DIC
7404 @86.4.2 5 mikropiiri 74 MC74HC04N M74HC04B1 CD74HC04E
7404 @86.4.2 24 mikropiiri 74 SN74HC04J
7404 @86.4.2 22 mikropiiri 74 SN74S04J
7404 @86.4.2 12 mikropiiri 74 SN74LS04J SN74L04J SN7404J
7404 @86.4.2 5 mikropiiri 74 SN74AHCT04N 74HCT04N MC74HCT04N
7404 @86.4.2 6 mikropiiri 74 74HCU04N DM74S04N
7405 @86.4.3 120 mikropiiri 74 SN74HC05N
7405 @86.4.3 39 mikropiiri 74 T74LS05B1
7405 @86.4.3 80 mikropiiri 74 SN74LS05N
7405 @86.4.4 103 mikropiiri 74 74LS05N
7405 @86.4.4 19 mikropiiri 74 DM7405N
7405 @86.4.4 11 mikropiiri 74 DM74LS05N
7405 @86.4.4 7 mikropiiri 74 SN74ALS05AN
7405 @86.4.5 3 mikropiiri 74 SN7405N
7405 @86.4.5 2 mikropiiri 74 MB74LS05
7405 @86.4.5 1 mikropiiri 74 uPB7405C
7406 @86.5.1 15 mikropiiri 74 DM7406N
7406 @86.5.1 6 mikropiiri 74 DEC7406
7406 @86.5.1 113 mikropiiri 74 SN7406N
7406 @86.5.1 45 mikropiiri 74 7406N
7406 @86.5.2 17 mikropiiri 74 7406N
7406 @86.5.2 10 mikropiiri 74 M74LS06P
7406 @86.5.2 3 mikropiiri 74 GD74LS06
7406 @86.5.2 2 mikropiiri 74 7406PC
7407 @86.5.3 21 mikropiiri 74 74HC07AP
7407 @86.5.3 16 mikropiiri 74 SN7407N
7407 @86.5.3 15 mikropiiri 74 7407PC
7407 @86.5.3 18 mikropiiri 74 DM7407N
7407 @86.5.3 10 mikropiiri 74 M74LS07P
7407 @86.5.3 2 mikropiiri 74 SN74LS07N
7408 @86.5.4 80 mikropiiri 74 MC74HC08AN
7408 @86.5.4 12 mikropiiri 74 MC74HC08N
7408 @86.5.4 5 mikropiiri 74 DM74LS08J
7408 @86.5.4 23 mikropiiri 74 SN7408N
7408 @86.5.4 15 mikropiiri 74 74F08PC
7408 @86.5.5 107 mikropiiri 74 SN74ALS08N
7408 @86.5.5 54 mikropiiri 74 74LS08N SN74LS08N
7408 @86.5.5 42 mikropiiri 74 74HC08AP
7408 @86.5.5 5 mikropiiri 74 74LS08PC SN74S08N 74LS08
7409 @86.6.1 12 mikropiiri 74 SN74LS09N
7409 @86.6.1 9 mikropiiri 74 74LS09PC
7409 @86.6.1 9 mikropiiri 74 DM74LS09N
7409 @86.6.1 1 mikropiiri 74 7409
7409 @86.6.1 1 mikropiiri 74 SN7409N
7410 @86.6.2 2 mikropiiri 74 SN74S10N
7410 @86.6.2 12 mikropiiri 74 74LS10PC
7410 @86.6.2 19 mikropiiri 74 74LS10N
7410 @86.6.2 47 mikropiiri 74 SN74HC10N
7410 @86.6.2 25 mikropiiri 74 SN74LS10N
7410 @86.6.2 40 mikropiiri 74 SN7410N
7410 @86.6.3 50 mikropiiri 74 T74LS10B1
7410 @86.6.3 45 mikropiiri 74 DM74LS10N
7410 @86.6.3 28 mikropiiri 74 7410
7410 @86.6.3 3 mikropiiri 74 MC74HC10 SN74H10N MC7410P
7410 @86.6.3 5 mikropiiri 74 7410N SG7410N RD7410N
7410 @86.6.4 45 mikropiiri 74 SN74LS10N
7410 @86.6.4 75 mikropiiri 74 DM7410N
7410 @86.6.4 25 mikropiiri 74 74F10DC
7410 @86.6.4 5 mikropiiri 74 MM74C10N
7410 @86.6.4 5 mikropiiri 74 7410PC
7411 @86.6.5 35 mikropiiri 74 MC74HC11N
7411 @86.6.5 15 mikropiiri 74 74HC11N
7411 @86.6.5 61 mikropiiri 74 CD74HC11E
7411 @86.6.5 11 mikropiiri 74 DM7411N 7411
7411 @86.6.5 9 mikropiiri 74 SN74LS11N
7412 @86.7.1 24 mikropiiri 74 SN74LS12N
7412 @86.7.1 23 mikropiiri 74 SN7412N
7412 @86.7.1 14 mikropiiri 74 DM74LS12N
7412 @86.7.1 7 mikropiiri 74 7412
7413 @86.7.2 42 mikropiiri 74 SN74LS13N
7413 @86.7.2 5 mikropiiri 74 7413-N
7413 @86.7.2 17 mikropiiri 74 SN7413N
7413 @86.7.2 3 mikropiiri 74 7413
7413 @86.7.2 2 mikropiiri 74 uPB7413C
7413 @86.7.2 3 mikropiiri 74 7413PC N7413A
7414 @86.7.3 27 mikropiiri 74 SN74HC14N
7414 @86.7.3 6 mikropiiri 74 MC74HC14AN
7414 @86.7.3 10 mikropiiri 74 MC74HC14N
7414 @86.7.3 3 mikropiiri 74 CD74AC14E
7414 @86.7.3 41 mikropiiri 74 SN74LS14N
7414 @86.7.3 2 mikropiiri 74 74LS14N 74LS14
7414 @86.7.4 54 mikropiiri 74 74HC14N
7414 @86.7.4 7 mikropiiri 74 7414PC
7414 @86.7.4 5 mikropiiri 74 MC74HCT14AN
7414 @86.7.4 2 mikropiiri 74 KS74HCTLS14N
7414 @86.7.4 4 mikropiiri 74 CD74HC14E
7414 @86.7.5 4 mikropiiri 74 MM74HC14N
7414 @86.7.5 4 mikropiiri 74 SN7414N
7414 @86.7.5 4 mikropiiri 74 DM74LS14N GD74LS14 HD74LS14P
7414 @86.7.5 2 mikropiiri 74 MM74C14N
7414 @86.7.5 2 mikropiiri 74 7414N M74HC14B1
7415 @86.8.1 9 mikropiiri 74 SN74LS15N
7416 @86.8.1 1 mikropiiri 74 7416
7416 @86.8.1 1 mikropiiri 74 SN7416N
7416 @86.8.1 1 mikropiiri 74 N7416A
7417 @86.8.2 1 mikropiiri 74 DM7417N
7417 @86.8.2 2 mikropiiri 74 SN7417N
7420 @86.8.3 28 mikropiiri 74 74HC20N
7420 @86.8.3 24 mikropiiri 74 SN7420N
7420 @86.8.3 21 mikropiiri 74 SN74LS20N
7420 @86.8.3 26 mikropiiri 74 DM74L20N
7420 @86.8.3 9 mikropiiri 74 N7420A
7420 @86.8.3 6 mikropiiri 74 N74LS20A
7420 @86.8.4 2 mikropiiri 74 74LS20N
7420 @86.8.4 2 mikropiiri 74 7420N DM7420N
7420 @86.8.4 2 mikropiiri 74 DM74S20N
7420 @86.8.4 4 mikropiiri 74 MC74F20N
7420 @86.8.4 1 mikropiiri 74 DM74LS20N
7420 @86.8.4 5 mikropiiri 74 MM74C20N
7421 @86.8.5 25 mikropiiri 74 SN74ALS21AN
7421 @86.8.5 50 mikropiiri 74 DM74ALS21AN
7421 @86.8.5 64 mikropiiri 74 HD74LS21P
7421 @86.8.5 20 mikropiiri 74 74HC21N
7421 @86.9.1 5 mikropiiri 74 SN74LS21JDS
7421 @86.9.1 4 mikropiiri 74 SN74LS21N
7421 @86.9.1 10 mikropiiri 74 SN74ALS21N
7421 @86.9.1 1 mikropiiri 74 74LS21N
7421 @86.9.1 1 mikropiiri 74 M74LS21P
7422 @86.9.2 3 mikropiiri 74 SN7422N
7422 @86.9.2 22 mikropiiri 74 DM74LS22N
7425 @86.9.3 5 mikropiiri 74 SN7425N
7425 @86.9.3 2 mikropiiri 74 7425PC
7425 @86.9.3 2 mikropiiri 74 7425J
7426 @86.9.4 1 mikropiiri 74 SN7426N
7427 @86.9.5 29 mikropiiri 74 HD74LS27P
7427 @86.9.5 25 mikropiiri 74 DM74ALS27N
7427 @86.9.5 20 mikropiiri 74 DM74ALS27N
7427 @86.9.5 14 mikropiiri 74 SN74LS27N
7427 @86.9.5 8 mikropiiri 74 74LS27PC
7427 @86.9.5 4 mikropiiri 74 SN7427N
7427 @86.10.1 3 mikropiiri 74 7427PC
7427 @86.10.1 3 mikropiiri 74 7427N
7427 @86.10.1 2 mikropiiri 74 7427
7427 @86.10.1 2 mikropiiri 74 N7427A
7427 @86.10.1 1 mikropiiri 74 74LS27N
7428 @86.10.2 20 mikropiiri 74 SN74S28ON
7428 @86.10.2 9 mikropiiri 74 74LS28PC
7430 @86.10.3 53 mikropiiri 74 74HC30AP
7430 @86.10.3 25 mikropiiri 74 SN7430N
7430 @86.10.3 16 mikropiiri 74 DM7430N
7430 @86.10.3 6 mikropiiri 74 7430N
7430 @86.10.4 17 mikropiiri 74 DM74LS30N
7430 @86.10.4 4 mikropiiri 74 SN74S30N
7430 @86.10.4 4 mikropiiri 74 SN74LS30N
7430 @86.10.4 1 mikropiiri 74 SG7430N
7432 @86.10.5 108 mikropiiri 74 MC74HC32AN
7432 @86.10.5 48 mikropiiri 74 74HC32AP
7432 @86.10.5 18 mikropiiri 74 74AC32PC
7432 @86.11.1 17 mikropiiri 74 SN7432N
7432 @86.11.1 46 mikropiiri 74 SN74LS32N
7432 @86.11.1 33 mikropiiri 74 MC74HC32N 74HC32N
7432 @86.11.1 6 mikropiiri 74 74HCT32N M74HCT32B1
7432 @86.11.1 9 mikropiiri 74 SN74AHCT32N
7432 @86.11.1 12 mikropiiri 74 7432 74S32N DM74S32N DM74LS32N MM74C32N
7437 @86.11.2 32 mikropiiri 74 DM74LS37N
7437 @86.11.2 20 mikropiiri 74 SN74LS37N
7437 @86.11.2 15 mikropiiri 74 DM7437N
7437 @86.11.2 10 mikropiiri 74 74LS37N
7437 @86.11.2 13 mikropiiri 74 SN7437N N7437A
7437 @86.11.2 6 mikropiiri 74 T74LS37B1
7438 @86.11.3 84 mikropiiri 74 DM74LS38N
7438 @86.11.3 58 mikropiiri 74 SN74LS38N
7438 @86.11.3 6 mikropiiri 74 74LS38N 74LS38PC
7438 @86.11.3 6 mikropiiri 74 N7438A 7438N 7438-N
7440 @86.11.4 24 mikropiiri 74 SN7440N
7440 @86.11.4 34 mikropiiri 74 SN74LS40N
7440 @86.11.4 7 mikropiiri 74 DM74LS40N
7440 @86.11.4 5 mikropiiri 74 N74LS40A
7440 @86.11.4 6 mikropiiri 74 SN74S40N SG7440N
7440 @86.11.4 2 mikropiiri 74 7441
7442 @86.11.5 4 mikropiiri 74 SN7442AN
7442 @86.11.5 17 mikropiiri 74 MH7442 SN74LS42N 7442 7442PC MM74C42N
7442 @86.11.5 9 mikropiiri 74 N7442B N74LS42B
7442 @86.11.5 46 mikropiiri 74 DM74LS42N
7442 @86.11.5 35 mikropiiri 74 74LS42N
7442 @86.11.5 5 mikropiiri 74 SN74LS42AN
7445 @86.12.1 1 mikropiiri 74 7445PC
7445 @86.12.1 3 mikropiiri 74 7445
7445 @86.12.1 1 mikropiiri 74 DM7445N
7445 @86.12.1 2 mikropiiri 74 SN7445N
7446 @86.12.2 2 mikropiiri 74 DM7446AN
7447 @86.12.3 7 mikropiiri 74 SN74LS47N
7447 @86.12.3 6 mikropiiri 74 SN7447AN
7447 @86.12.3 1 mikropiiri 74 DM74LS47N
7448 @86.12.4 2 mikropiiri 74 7448
7448 @86.12.4 2 mikropiiri 74 SN7448N
7448 @86.12.4 4 mikropiiri 74 MM74C48N
7448 @86.12.4 10 mikropiiri 74 SN74LS48N
7448 @86.12.4 2 mikropiiri 74 DM74LS48N
7449 @86.12.4 2 mikropiiri 74 DM74LS49N
7451 @86.12.5 1 mikropiiri 74 74LS51N
7451 @86.12.5 5 mikropiiri 74 SN7451N
7451 @86.12.5 11 mikropiiri 74 SN74LS51N
7453 @88.1.1 2 mikropiiri 74 SN7453A
7453 @88.1.1 3 mikropiiri 74 SN7453N
7454 @88.1.1 4 mikropiiri 74 SN7454N
7470 @88.1.1 5 mikropiiri 74 SN7470A
7470 @88.1.1 5 mikropiiri 74 SN7470N
7472 @88.1.1 10 mikropiiri 74 SN7472N
7473 @88.1.2 15 mikropiiri 74 CD74HC73E
7473 @88.1.2 4 mikropiiri 74 DM74LS73AN
7473 @88.1.2 8 mikropiiri 74 MM74C73N
7473 @88.1.2 10 mikropiiri 74 SN74LS73N
7473 @88.1.2 13 mikropiiri 74 SN7473N
7473 @88.1.2 9 mikropiiri 74 DM74L73N SF7473N
7474 @88.1.3 70 mikropiiri 74 MC74HC74AN
7474 @88.1.3 12 mikropiiri 74 7474PC
7474 @88.1.3 8 mikropiiri 74 74LS74N
7474 @88.1.3 5 mikropiiri 74 SN74HCT74N N7474A SF7474N SN74LS74N 74LS74AN
7474 @88.1.3 7 mikropiiri 74 SN7474N 74LS74 74F74 DM74LS74N
7474 @88.1.4 33 mikropiiri 74 DM7474N
7474 @88.1.4 138 mikropiiri 74 DM74LS74AN
7474 @88.1.4 16 mikropiiri 74 PC74HC74P
7474 @88.1.5 60 mikropiiri 74 SN74LS74AN
7474 @88.1.5 35 mikropiiri 74 T74LS74BI
7474 @88.1.5 24 mikropiiri 74 74VHC74N
7474 @88.1.5 24 mikropiiri 74 SN74S74N
7474 @88.1.5 11 mikropiiri 74 MM74HC74AN
7474 @88.2.1 16 mikropiiri 74 SN74HC74N
7474 @88.2.1 10 mikropiiri 74 74ACT74PC
7474 @88.2.1 10 mikropiiri 74 SN74AHCT74N
7474 @88.2.1 20 mikropiiri 74 74HC74N
7474 @88.2.1 8 mikropiiri 74 7474N M74HC74B1
7475 @88.2.2 43 mikropiiri 74 SN74LS75N
7475 @88.2.2 55 mikropiiri 74 DM74LS75N
7475 @88.2.2 28 mikropiiri 74 SN7475N
7475 @88.2.2 20 mikropiiri 74 74LS75N
7475 @88.2.2 5 mikropiiri 74 RD7475N
7475 @88.2.2 4 mikropiiri 74 TC74HC75P
7476 @88.2.3 6 mikropiiri 74 SN74HC76N
7476 @88.2.3 62 mikropiiri 74 MC74HC76N
7476 @88.2.3 11 mikropiiri 74 SN7476N
7476 @88.2.3 7 mikropiiri 74 RD7476N
7476 @88.2.3 3 mikropiiri 74 SN74LS76AN
7476 @88.2.4 24 mikropiiri 74 M74HC76B1
7476 @88.2.4 2 mikropiiri 74 D3476A
7481 @88.2.5 3 mikropiiri 74 SN7481N
7483 @88.3.1 9 mikropiiri 74 MC7483P
7483 @88.3.1 4 mikropiiri 74 SN7483AN
7483 @88.3.1 33 mikropiiri 74 74LS83AN
7483 @88.3.1 10 mikropiiri 74 74LS83ANA
7483 @88.3.1 31 mikropiiri 74 SN74LS83AN
7483 @88.3.1 6 mikropiiri 74 DM74LS83AN
7485 @88.3.2 50 mikropiiri 74 SN74LS85N
7485 @88.3.2 10 mikropiiri 74 SN7485N
7485 @88.3.2 5 mikropiiri 74 7485PC
7485 @88.3.2 8 mikropiiri 74 74HCT85N T74LS85B1
7485 @88.3.2 27 mikropiiri 74 DM74LS85N
7486 @88.3.3 35 mikropiiri 74 DM74LS86N
7486 @88.3.3 12 mikropiiri 74 SN74S86N
7486 @88.3.3 8 mikropiiri 74 7486PC
7486 @88.3.3 30 mikropiiri 74 SN7486N
7486 @88.3.3 3 mikropiiri 74 7486
7486 @88.3.3 26 mikropiiri 74 SN74LS86N
7486 @88.3.4 22 mikropiiri 74 SN74HC86N
7486 @88.3.4 18 mikropiiri 74 PC74HCT86P
7486 @88.3.4 15 mikropiiri 74 DM74LS86N
7486 @88.3.4 50 mikropiiri 74 74F86PC
7486 @88.3.4 8 mikropiiri 74 M74HC86B1
7486 @88.3.5 3 mikropiiri 74 74HCT86N
7486 @88.3.5 3 mikropiiri 74 GD74LS86
7486 @88.3.5 2 mikropiiri 74 DM7486N
7486 @88.3.5 22 mikropiiri 74 MC74HC86N
7486 @88.3.5 2 mikropiiri 74 SN74LS86AN
7486 @88.3.5 2 mikropiiri 74 T74LS86B1 N74LS86A
7489 @88.4.1 12 mikropiiri 74 SN7489N
7489 @88.4.1 6 mikropiiri 74 MM74C89N
7490 @88.4.2 5 mikropiiri 74 MC7490P
7490 @88.4.2 95 mikropiiri 74 SN74LS90N
7490 @88.4.2 20 mikropiiri 74 SN7490AN
7490 @88.4.2 5 mikropiiri 74 SN74LS90J
7490 @88.4.2 3 mikropiiri 74 SN7490N
7490 @88.4.3 3 mikropiiri 74 7490APC
7490 @88.4.3 2 mikropiiri 74 DM7490AN DM7490N
7490 @88.4.3 10 mikropiiri 74 MM74C90N
7490 @88.4.3 2 mikropiiri 74 7490N 7490PC
7490 @88.4.3 1 mikropiiri 74 RD7490N
7491 @88.4.4 2 mikropiiri 74 SN74LS91J
7492 @88.4.5 23 mikropiiri 74 SN74LS92N
7492 @88.4.5 13 mikropiiri 74 SN74LS92J
7492 @88.4.5 3 mikropiiri 74 SN7492AN
7492 @88.4.5 1 mikropiiri 74 DM7492N
7492 @88.4.5 1 mikropiiri 74 7492N
7493 @88.5.1 43 mikropiiri 74 SN74LS93N
7493 @88.5.1 24 mikropiiri 74 SN7493AN
7493 @88.5.1 11 mikropiiri 74 N7493A
7493 @88.5.1 35 mikropiiri 74 DM74LS93N
7493 @88.5.1 3 mikropiiri 74 7493N
7493 @88.5.1 1 mikropiiri 74 7493PC
7493 @88.5.2 25 mikropiiri 74 DM7493AN
7493 @88.5.2 7 mikropiiri 74 GD74LS93
7493 @88.5.2 4 mikropiiri 74 7493AN
7493 @88.5.2 1 mikropiiri 74 FLJ181/7493
7494 @88.5.3 23 mikropiiri 74 SN7494N
7495 @88.5.4 18 mikropiiri 74 SN74LS95BN
7495 @88.5.4 22 mikropiiri 74 SN74LS95AN
7495 @88.5.4 7 mikropiiri 74 SN7495AN
7495 @88.5.4 4 mikropiiri 74 SN7495N
7495 @88.5.4 7 mikropiiri 74 74LS95BN
7495 @88.5.4 7 mikropiiri 74 4xSN74L95N 3x7495A
7496 @88.5.5 29 mikropiiri 74 SN7496N
7496 @88.5.5 25 mikropiiri 74 SN74LS96N
74100 @88.6.1 4 mikropiiri 74 SN74100N
74104 @88.6.1 1 mikropiiri 74 SN74104N
74107 @88.6.3 48 mikropiiri 74 DM74LS107N
74107 @88.6.3 2 mikropiiri 74 SN74HC107N
74107 @88.6.3 5 mikropiiri 74 SN74107N
74107 @88.6.3 19 mikropiiri 74 74107
74107 @88.6.3 5 mikropiiri 74 74LS107N
74107 @88.6.3 7 mikropiiri 74 SN74LS107AN SN74LS107N
74109 @88.6.4 1 mikropiiri 74 SN74LS109AN
74109 @88.6.4 2 mikropiiri 74 SN74HC109N
74109 @88.6.4 44 mikropiiri 74 DM74LS109N
74109 @88.6.4 5 mikropiiri 74 SN74LS109N
74110 @88.6.4 1 mikropiiri 74 SN74110N
74112 @88.6.5 150 mikropiiri 74 74HC112N
74112 @88.6.5 10 mikropiiri 74 DM74LS112AN
74112 @88.6.5 1 mikropiiri 74 DM74S112N
74112 @88.6.5 5 mikropiiri 74 SN74LS112N
74113 @88.7.1 1 mikropiiri 74 SN74S113N
74118 @88.7.2 9 mikropiiri 74 hex set/reset latch, common reset SN74118N
74118 @88.7.2 2 mikropiiri 74 hex set/reset latch, common reset 74118N
74119 @88.7.3 1 mikropiiri 74 24-Pin DIP 600mil 74119
74119 @88.7.3 6 mikropiiri 74 24-Pin DIP 600mil SN74119N
74120 @88.7.4 24 mikropiiri 74 SN74120N
74121 @88.7.5 20 mikropiiri 74 SN74121N
74121 @88.7.5 13 mikropiiri 74 DM74121N
74121 @88.7.5 3 mikropiiri 74 MC74121P
74121 @88.7.5 2 mikropiiri 74 74121N
74121 @88.7.5 1 mikropiiri 74 D34121A
74122 @88.8.1 25 mikropiiri 74 SN74LS122N
74122 @88.8.1 13 mikropiiri 74 SN74LS122J
74122 @88.8.1 6 mikropiiri 74 SN74122N
74122 @88.8.1 9 mikropiiri 74 74LS122N
74123 @88.8.2 16 mikropiiri 74 MC74HC123AN
74123 @88.8.2 11 mikropiiri 74 SN74123N
74123 @88.8.2 13 mikropiiri 74 PC74HC123P
74123 @88.8.2 11 mikropiiri 74 DM74123N
74123 @88.8.2 9 mikropiiri 74 74123PC
74123 @88.8.2 2 mikropiiri 74 N74123B
74123 @88.8.3 56 mikropiiri 74 SN74LS123N
74123 @88.8.3 35 mikropiiri 74 DM74LS123N
74123 @88.8.3 1 mikropiiri 74 74123N
74123 @88.8.3 1 mikropiiri 74 74123PC
74123 @88.8.3 1 mikropiiri 74 74HC123AP
74123 @88.8.3 1 mikropiiri 74 M74LS123P
74124 @88.8.4 9 mikropiiri 74 SN74S124N
74125 @88.8.5 99 mikropiiri 74 MC74HC125AN
74125 @88.8.5 5 mikropiiri 74 SN74HC125N
74125 @88.8.5 4 mikropiiri 74 PC74HC125P
74125 @88.8.5 16 mikropiiri 74 M74HC125B1
74125 @88.9.1 88 mikropiiri 74 74HC125AP
74125 @88.9.1 53 mikropiiri 74 MC74HC125N
74125 @88.9.1 33 mikropiiri 74 SN74125N
74125 @88.9.2 4 mikropiiri 74 SN74LS125AN
74125 @88.9.2 2 mikropiiri 74 SN74HCT125N
74125 @88.9.2 1 mikropiiri 74 74LS125AN
74125 @88.9.2 1 mikropiiri 74 74LS125N
74125 @88.9.2 1 mikropiiri 74 74LS125PC
74125 @88.9.2 1 mikropiiri 74 SN74LS125N
74126 @88.9.3 50 mikropiiri 74 SN74LS126AN
74126 @88.9.3 16 mikropiiri 74 SN74126N
74126 @88.9.3 8 mikropiiri 74 SN74LS126N
74132 @88.9.4 68 mikropiiri 74 DM74LS132N
74132 @88.9.4 8 mikropiiri 74 TC74HC132P
74132 @88.9.4 25 mikropiiri 74 SN74132N
74132 @88.9.4 25 mikropiiri 74 74LS132N
74132 @88.9.4 9 mikropiiri 74 SN74S132N
74132 @88.9.5 52 mikropiiri 74 SN74LS132N
74132 @88.9.5 7 mikropiiri 74 DM74132N
74132 @88.9.5 3 mikropiiri 74 SN74HC132N MC74HC132N
74132 @88.9.5 2 mikropiiri 74 74132N 74132PC
74132 @88.9.5 2 mikropiiri 74 SN74LS132J
74133 @88.10.1 49 mikropiiri 74 MC74HC133N
74133 @88.10.1 1 mikropiiri 74 M74LS133P
74136 @88.10.2 20 mikropiiri 74 SN74136N
74136 @88.10.2 8 mikropiiri 74 SN74LS136N
74136 @88.10.2 1 mikropiiri 74 74LS136N
74138 @88.10.3 115 mikropiiri 74 MC74HC138AN
74138 @88.10.3 33 mikropiiri 74 MC74HC138N M74HC138B1(2kpl)
74138 @88.10.3 45 mikropiiri 74 M74HC138B1
74138 @88.10.3 44 mikropiiri 74 CD74HCT138E
74138 @88.10.4 10 mikropiiri 74 CD74HC138E
74138 @88.10.4 32 mikropiiri 74 SN74HC138N
74138 @88.10.4 3 mikropiiri 74 PC74HCT138P
74138 @88.10.4 2 mikropiiri 74 MC74HCT138N
74138 @88.10.4 3 mikropiiri 74 SN74HCT138N 74HCT138N
74138 @88.10.4 4 mikropiiri 74 74F138PC
74138 @88.10.5 17 mikropiiri 74 DM74LS138N
74138 @88.10.5 15 mikropiiri 74 74LS138N
74138 @88.10.5 6 mikropiiri 74 DM74ALS138N
74138 @88.10.5 3 mikropiiri 74 CD74ACT138E
74138 @88.10.5 1 mikropiiri 74 SN74AHC138N
74138 @88.10.5 2 mikropiiri 74 74HC138AP
74138 @88.11.1 23 mikropiiri 74 74AC138PC
74138 @88.11.1 18 mikropiiri 74 74HC138N
74138 @88.11.1 151 mikropiiri 74 SN74LS138N
74138 @88.11.2 2 mikropiiri 74 SN74S138N
74138 @88.11.2 3 mikropiiri 74 HD74LS138P GD74HCT138 74LS138
74138 @88.11.2 40 mikropiiri 74 74LS138NA
74138 @88.11.2 28 mikropiiri 74 74LS138PC
74138 @88.11.2 45 mikropiiri 74 T74LS138B1
74138 @88.11.2 3 mikropiiri 74 74AHCT138N
74139 @88.11.3 7 mikropiiri 74 MC74F139N
74139 @88.11.3 10 mikropiiri 74 74LS139N
74139 @88.11.3 10 mikropiiri 74 74LS139PC
74139 @88.11.3 6 mikropiiri 74 DM74LS139N
74139 @88.11.3 9 mikropiiri 74 SN74LS139N
74139 @88.11.3 5 mikropiiri 74 GD74LS139 CD74HC139E
74139 @88.11.4 17 mikropiiri 74 SN74HC139N
74139 @88.11.4 1 mikropiiri 74 SN74AHCT139N
74141 @88.11.5 10 mikropiiri 74 DM74141N
74141 @88.11.5 3 mikropiiri 74 SN74141N
74145 @88.12.1 59 mikropiiri 74 SN74LS145N
74145 @88.12.1 4 mikropiiri 74 SN74145N
74145 @88.12.1 2 mikropiiri 74 74LS145N
74147 @88.12.2 4 mikropiiri 74 74HCT147N
74147 @88.12.2 8 mikropiiri 74 DM74147N
74147 @88.12.2 11 mikropiiri 74 SN74LS147N
74148 @88.12.3 52 mikropiiri 74 SN74HC148N
74148 @88.12.3 37 mikropiiri 74 M74HC148B1
74148 @88.12.3 47 mikropiiri 74 SN74LS148N
74148 @88.12.3 24 mikropiiri 74 SN74148N
74148 @88.12.3 1 mikropiiri 74 DM74148N
74150 @88.12.4 35 mikropiiri 74 DM74150N
74150 @88.12.4 4 mikropiiri 74 SN74150N
74150 @88.12.4 1 mikropiiri 74 74150N
74151 @88.12.5 21 mikropiiri 74 SN74151AN
74151 @88.12.5 12 mikropiiri 74 DM74LS151N
74151 @88.12.5 21 mikropiiri 74 SN74LS151J
74151 @88.12.5 3 mikropiiri 74 SN74151N
74151 @88.12.5 3 mikropiiri 74 N74151B
74151 @88.12.5 11 mikropiiri 74 SN74LS151N
74151 @87.1.1 20 mikropiiri 74 CD74HC151E
74151 @87.1.1 10 mikropiiri 74 T74LS151BI
74151 @87.1.1 5 mikropiiri 74 74LS151PC
74151 @87.1.1 4 mikropiiri 74 74151
74151 @87.1.1 2 mikropiiri 74 HD74LS151P 74LS151N
74151 @87.1.1 1 mikropiiri 74 74151N
74153 @87.1.2 19 mikropiiri 74 SN74LS153N
74153 @87.1.2 14 mikropiiri 74 SN74153N
74153 @87.1.2 9 mikropiiri 74 DM74LS153N
74153 @87.1.2 2 mikropiiri 74 SN74LS153J
74153 @87.1.2 3 mikropiiri 74 74LS153N SN74F153N
74153 @87.1.2 8 mikropiiri 74 SN74HC153N
74154 @87.1.3 10 mikropiiri 74 SN74154N
74154 @87.1.3 5 mikropiiri 74 74LS154N
74154 @87.1.3 2 mikropiiri 74 HD74LS154P
74154 @87.1.3 3 mikropiiri 74 DM74LS154N
74154 @87.1.3 1 mikropiiri 74 CD74HC154EN
74155 @87.1.4 24 mikropiiri 74 SN74LS155N
74155 @87.1.4 3 mikropiiri 74 SN74155N
74155 @87.1.4 4 mikropiiri 74 74155PC
74155 @87.1.4 1 mikropiiri 74 74155N
74156 @87.1.5 1 mikropiiri 74 SN74LS156N
74157 @87.2.1 31 mikropiiri 74 SN74LS157N
74157 @87.2.1 21 mikropiiri 74 SN74157N
74157 @87.2.1 13 mikropiiri 74 74F157APC
74157 @87.2.1 17 mikropiiri 74 SN74LS157J
74157 @87.2.1 8 mikropiiri 74 DM74157N
74157 @87.2.1 1 mikropiiri 74 74LS157N
74158 @87.2.2 4 mikropiiri 74 74LS158PC
74158 @87.2.2 1 mikropiiri 74 DM74LS158N
74158 @87.2.2 1 mikropiiri 74 SN74LS158N
74160 @87.2.3 12 mikropiiri 74 SN74160N
74160 @87.2.3 8 mikropiiri 74 DM74LS160N
74160 @87.2.3 5 mikropiiri 74 SN74LS160N
74160 @87.2.3 1 mikropiiri 74 MC74HC160N
74161 @87.2.4 39 mikropiiri 74 SN74LS161AN
74161 @87.2.4 24 mikropiiri 74 MC74HC161N
74161 @87.2.4 20 mikropiiri 74 74LS161PC
74161 @87.2.4 2 mikropiiri 74 HD74LS161P
74161 @87.2.4 2 mikropiiri 74 DM74161AN
74161 @87.2.4 3 mikropiiri 74 74LS161AN
74161 @87.2.5 100 mikropiiri 74 SN74F161AN
74161 @87.2.5 2 mikropiiri 74 SN74HC161N SN74S161N
74161 @87.2.5 2 mikropiiri 74 M74LS161AP
74162 @87.2.5 6 mikropiiri 74 SN74LS162N
74163 @87.3.1 45 mikropiiri 74 SN74LS163AN
74163 @87.3.1 14 mikropiiri 74 DM74LS163N
74163 @87.3.1 16 mikropiiri 74 MC74HC163N
74163 @87.3.1 2 mikropiiri 74 CD74HCT163E
74163 @87.3.1 1 mikropiiri 74 SN74163N
74164 @87.3.2 26 mikropiiri 74 SN74HC164N
74164 @87.3.2 8 mikropiiri 74 SN74LS164N
74164 @87.3.2 6 mikropiiri 74 SN74164N
74164 @87.3.2 26 mikropiiri 74 MC74HC164N
74164 @87.3.2 4 mikropiiri 74 SN74LS164J
74164 @87.3.2 4 mikropiiri 74 DM74LS164N 74LS164N M74HC164B1
74165 @87.3.3 45 mikropiiri 74 MC74HC165N
74165 @87.3.3 13 mikropiiri 74 SN74HC165N
74165 @87.3.3 8 mikropiiri 74 PC74HC165P
74165 @87.3.3 4 mikropiiri 74 SN74LS165N SN74LS165AN
74165 @87.3.3 3 mikropiiri 74 CD74HCT165E
74165 @87.3.3 1 mikropiiri 74 74165
74166 @87.3.4 3 mikropiiri 74 SN74166N
74166 @87.3.4 2 mikropiiri 74 SN74LS166AN
74166 @87.3.4 2 mikropiiri 74 M74LS166AP
74167 @87.3.4 10 mikropiiri 74 SN74167N
74173 @87.3.5 50 mikropiiri 74 M74HC173B1
74173 @87.3.5 5 mikropiiri 74 DM74LS173N
74173 @87.3.5 3 mikropiiri 74 74LS173PC
74173 @87.3.5 30 mikropiiri 74 SN74173N
74173 @87.3.5 5 mikropiiri 74 SN74LS173N
74174 @87.4.1 36 mikropiiri 74 MC74HC174AN
74174 @87.4.1 8 mikropiiri 74 M74HC174P
74174 @87.4.1 10 mikropiiri 74 SN74HC174N
74174 @87.4.1 3 mikropiiri 74 CD74HC174E
74174 @87.4.1 6 mikropiiri 74 SN74LS174N
74174 @87.4.1 5 mikropiiri 74 GD74LS174
74174 @87.4.2 8 mikropiiri 74 SN74174J
74174 @87.4.2 2 mikropiiri 74 SN74174N
74174 @87.4.2 2 mikropiiri 74 74LS174N
74174 @87.4.2 1 mikropiiri 74 M74LS174P
74174 @87.4.2 1 mikropiiri 74 DM74LS174N
74175 @87.4.3 86 mikropiiri 74 SN74LS175N
74175 @87.4.3 54 mikropiiri 74 74F175PC MC74F175N
74175 @87.4.3 7 mikropiiri 74 DM74175N
74175 @87.4.3 7 mikropiiri 74 74175
74175 @87.4.4 4 mikropiiri 74 DM74LS175N
74175 @87.4.4 2 mikropiiri 74 SN74175N
74176 @87.4.4 1 mikropiiri 74 DM74176N
74180 @87.4.5 68 mikropiiri 74 D34180A
74180 @87.4.5 10 mikropiiri 74 SN74180N
74180 @87.4.5 2 mikropiiri 74 FJH281/74180N
74181 @87.5.1 1 mikropiiri 74 SN74181N
74184 @87.5.2 8 mikropiiri 74 DM74184N
74184 @87.5.2 10 mikropiiri 74 SN74184N
74185 @87.5.2 9 mikropiiri 74 SN74185AN
74185 @87.5.2 5 mikropiiri 74 DM74185AN
74188 @87.5.3 16 mikropiiri 74 DM74S188N
74188 @87.5.3 3 mikropiiri 74 SN74S188N
74189 @87.5.3 1 mikropiiri 74 DM74S189N
74190 @87.5.4 5 mikropiiri 74 DM74LS190N
74190 @87.5.4 3 mikropiiri 74 SN74190N
74190 @87.5.4 3 mikropiiri 74 74LS190PC
74190 @87.5.4 1 mikropiiri 74 SN74LS190N
74190 @87.5.4 1 mikropiiri 74 DM74LS190N
74191 @87.5.5 15 mikropiiri 74 DM74LS191N
74191 @87.5.5 3 mikropiiri 74 SN74LS191N
74192 @87.6.1 39 mikropiiri 74 T74LS192B1
74192 @87.6.1 17 mikropiiri 74 DM74LS192N
74192 @87.6.1 23 mikropiiri 74 SN74LS192N
74192 @87.6.1 15 mikropiiri 74 SN74192N
74192 @87.6.1 10 mikropiiri 74 DM74192N
74192 @87.6.1 4 mikropiiri 74 74LS192PC
74193 @87.6.2 26 mikropiiri 74 SN74193N
74193 @87.6.2 17 mikropiiri 74 SN74HC193N
74193 @87.6.2 105 mikropiiri 74 74LS193N
74193 @87.6.2 29 mikropiiri 74 DM74193N
74193 @87.6.3 71 mikropiiri 74 SN74LS193N
74193 @87.6.3 3 mikropiiri 74 74193
74193 @87.6.3 2 mikropiiri 74 N74193B 74193N
74193 @87.6.3 16 mikropiiri 74 DM74LS193N
74193 @87.6.3 38 mikropiiri 74 T74LS193B1
74194 @87.6.4 75 mikropiiri 74 74F194PC
74194 @87.6.4 3 mikropiiri 74 GD74LS1944A
74195 @87.6.5 18 mikropiiri 74 74195PC
74195 @87.6.5 16 mikropiiri 74 SN74195N
74195 @87.6.5 2 mikropiiri 74 SN74S195N
74196 @87.7.1 11 mikropiiri 74 SN74LS196N
74196 @87.7.1 2 mikropiiri 74 SN74196N
74197 @87.7.2 2 mikropiiri 74 SN74S197N
74197 @87.7.2 1 mikropiiri 74 SN74LS197N
74198 @87.7.3 3 mikropiiri 74 SN74198N
74199 @87.7.3 8 mikropiiri 74 SN74198N
74221 @87.7.4 47 mikropiiri 74 CD74HCT221E
74221 @87.7.4 21 mikropiiri 74 DM74LS221N
74221 @87.7.4 6 mikropiiri 74 SN74LS221N
74238 @87.7.5 10 mikropiiri 74 CD74HCT238E
74238 @87.7.5 1 mikropiiri 74 74HC238N
74240 @87.8.1 46 mikropiiri 74 MC74HC240AN
74240 @87.8.1 10 mikropiiri 74 MC74HC240N
74240 @87.8.1 5 mikropiiri 74 SN74HC240N
74240 @87.8.1 33 mikropiiri 74 SN74LS240N
74240 @87.8.2 10 mikropiiri 74 SN74S240N
74240 @87.8.2 7 mikropiiri 74 MM74C240N
74240 @87.8.2 2 mikropiiri 74 DM74LS240N
74240 @87.8.2 2 mikropiiri 74 74LS240NA
74240 @87.8.2 1 mikropiiri 74 T74LS240BI
74240 @87.8.2 3 mikropiiri 74 SN74ALS240AN
74241 @87.8.3 110 mikropiiri 74 SN74LS241N
74241 @87.8.3 20 mikropiiri 74 PC74HCT241P
74241 @87.8.3 41 mikropiiri 74 SN74HC241N
74241 @87.8.4 10 mikropiiri 74 MC74HC241N
74241 @87.8.4 5 mikropiiri 74 M74LS241P
74241 @87.8.4 2 mikropiiri 74 SN74S241N
74241 @87.8.4 1 mikropiiri 74 SN74HCT241N
74243 @87.8.4 26 mikropiiri 74 SN74LS243N
74244 @87.8.5 53 mikropiiri 74 MC74HC244AN
74244 @87.8.5 17 mikropiiri 74 CD74HC244E
74244 @87.8.5 12 mikropiiri 74 74LS244N
74244 @87.8.5 5 mikropiiri 74 74LS244NA 74LS244PC
74244 @87.8.5 2 mikropiiri 74 GD74LS244 74HCT244AP
74244 @87.9.1 40 mikropiiri 74 SN74LS244N
74244 @87.9.1 136 mikropiiri 74 DM74LS244N
74244 @87.9.1 14 mikropiiri 74 MM74C244N
74244 @87.9.2 65 mikropiiri 74 M74HC244B1
74244 @87.9.2 22 mikropiiri 74 SN74HC244N
74244 @87.9.2 5 mikropiiri 74 SN74HCT244N
74244 @87.9.2 2 mikropiiri 74 PC74HCT244P
74244 @87.9.2 3 mikropiiri 74 GD74HCT244 MC74HC244
74244 @87.9.3 2 mikropiiri 74 SN74ALS244AN
74244 @87.9.3 25 mikropiiri 74 SN74LS244N
74244 @87.9.3 19 mikropiiri 74 74HC244AP
74244 @87.9.3 14 mikropiiri 74 74AC244PC
74244 @87.9.3 40 mikropiiri 74 SN74S244N
74245 @87.9.4 134 mikropiiri 74 MC74HC245AN
74245 @87.9.4 37 mikropiiri 74 SN74HC245N
74245 @87.9.5 60 mikropiiri 74 M74HC245B1
74245 @87.9.5 16 mikropiiri 74 74AC245PC
74245 @87.9.5 8 mikropiiri 74 20-Pin DIP MC74AC245N
74245 @87.9.5 37 mikropiiri 74 20-Pin DIP 74HC245AP
74245 @87.10.1 170 mikropiiri 74 SN74LS245N
74245 @87.10.1 7 mikropiiri 74 20-Pin DIP KS74HCTLS245N
74245 @87.10.2 45 mikropiiri 74 SN74HCT245N
74245 @87.10.2 16 mikropiiri 74 SN74LVC245AN
74245 @87.10.2 10 mikropiiri 74 SN74AHCT245N
74245 @87.10.2 5 mikropiiri 74 GD74HCT245E GD74HCT245 MC74ACT245N
74245 @87.10.2 6 mikropiiri 74 DM74LS245N GD74LS245 MB74LS245 PC74HC245P
74245 @87.10.3 9 mikropiiri 74 74F245PCN
74245 @87.10.3 6 mikropiiri 74 SN74ALS245A-1N
74247 @87.10.3 2 mikropiiri 74 DM74LS247N
74247 @87.10.3 3 mikropiiri 74 SN74LS247N
74248 @87.10.3 1 mikropiiri 74 DM74LS248N
74249 @87.10.3 2 mikropiiri 74 DM74LS249N
74251 @87.10.4 84 mikropiiri 74 MC74HC251N
74251 @87.10.4 12 mikropiiri 74 SN74HC251N
74251 @87.10.4 6 mikropiiri 74 CD74HC251E
74251 @87.10.4 4 mikropiiri 74 TC74HC251P
74251 @87.10.4 2 mikropiiri 74 SN74LS251J SN74LS251N
74253 @87.10.5 29 mikropiiri 74 SN74HC253N
74253 @87.10.5 10 mikropiiri 74 SN74LS253N
74253 @87.10.5 1 mikropiiri 74 DM74LS253N
74257 @87.11.1 40 mikropiiri 74 MC74HC257N
74257 @87.11.1 75 mikropiiri 74 SN74F257N
74257 @87.11.1 5 mikropiiri 74 SN74LS257AN
74257 @87.11.1 5 mikropiiri 74 74LS257PC
74259 @87.11.2 72 mikropiiri 74 MC74HC259N
74259 @87.11.2 1 mikropiiri 74 SN74LS259N
74265 @87.11.3 3 mikropiiri 74 SN74265N
74266 @87.11.4 12 mikropiiri 74 SN74LS266N
74266 @87.11.4 3 mikropiiri 74 DM74LS266N
74266 @87.11.4 1 mikropiiri 74 74LS266
74273 @87.11.5 35 mikropiiri 74 74LS273AN
74273 @87.11.5 20 mikropiiri 74 MC74HC273AN
74273 @87.11.5 10 mikropiiri 74 74LS273PC 74LS273NA
74273 @87.11.5 5 mikropiiri 74 PC74HC273P
74273 @87.11.5 5 mikropiiri 74 SN74HC273N 74HC273AP
74279 @87.12.1 3 mikropiiri 74 SN74279N
74279 @87.12.1 2 mikropiiri 74 SN74LS279N
74283 @87.12.1 2 mikropiiri 74 SN74283N
74287 @87.12.2 1 mikropiiri 74 DM74S287AN
74287 @87.12.2 1 mikropiiri 74 SN74S287N
74290 @87.12.3 1 mikropiiri 74 SN74290N
74290 @87.12.3 1 mikropiiri 74 SN74LS290N
74293 @87.12.4 2 mikropiiri 74 SN74293N
74293 @87.12.4 9 mikropiiri 74 SN74LS293N
74297 @87.12.5 1 mikropiiri 74 SN74LS297N
74352 @89.1.1 1 mikropiiri 74 SN74LS352N
74365 @89.1.1 1 mikropiiri 74 SN74LS365AN
74366 @89.1.2 18 mikropiiri 74 DM74LS366N
74367 @89.1.3 15 mikropiiri 74 DM74367N SN74367AN
74367 @89.1.3 7 mikropiiri 74 SN74LS367AN
74367 @89.1.3 56 mikropiiri 74 SN74HC367N
74367 @89.1.3 146 mikropiiri 74 SN74HC367N
74368 @89.1.4 9 mikropiiri 74 SN74368AN
74373 @89.1.5 38 mikropiiri 74 74HC373AP
74373 @89.1.5 66 mikropiiri 74 SN74HC373N
74373 @89.1.5 46 mikropiiri 74 T74LS373B1
74373 @89.2.1 41 mikropiiri 74 M74HC373B1
74373 @89.2.1 11 mikropiiri 74 MC74HC373N
74373 @89.2.1 6 mikropiiri 74 74HCT373N
74373 @89.2.1 16 mikropiiri 74 DM74LS373N
74373 @89.2.1 16 mikropiiri 74 MM74C373N
74373 @89.2.2 10 mikropiiri 74 MM74C373N
74373 @89.2.2 2 mikropiiri 74 GD74LS373 HD74LS373P
74373 @89.2.2 5 mikropiiri 74 MC74HCT373AN
74373 @89.2.2 7 mikropiiri 74 SN74LS373N 74LS373N
74373 @89.2.2 1 mikropiiri 74 SN74LS373J
74373 @89.2.2 1 mikropiiri 74 MC74HC373 TC74HC373P
74374 @89.2.3 30 mikropiiri 74 MC74HC374AN
74374 @89.2.3 12 mikropiiri 74 MC74HC374N
74374 @89.2.3 19 mikropiiri 74 M74HC374B1
74374 @89.2.3 4 mikropiiri 74 TC74HC374P MM74C374N
74374 @89.2.3 18 mikropiiri 74 74LS374N DM74LS374N
74374 @89.2.3 21 mikropiiri 74 SN74LS374N
74375 @89.2.4 65 mikropiiri 74 SN74HC375N
74375 @89.2.4 63 mikropiiri 74 SN74LS375N
74375 @89.2.4 9 mikropiiri 74 M74LS375P
74377 @89.2.5 61 mikropiiri 74 SN74LS377N
74390 @89.3.1 10 mikropiiri 74 SN74HC390N
74390 @89.3.1 38 mikropiiri 74 SN74LS390N
74390 @89.3.1 24 mikropiiri 74 MC74HC390N
74390 @89.3.1 3 mikropiiri 74 74HC390AP
74390 @89.3.1 2 mikropiiri 74 CD74HC390E
74390 @89.3.1 1 mikropiiri 74 SN74390N
74390 @89.3.2 16 mikropiiri 74 74LS390N
74390 @89.3.2 9 mikropiiri 74 74LS390PC
74390 @89.3.2 5 mikropiiri 74 74HCT390N
74393 @89.3.3 20 mikropiiri 74 DM74LS393N
74393 @89.3.3 13 mikropiiri 74 MC74HC393N
74393 @89.3.3 15 mikropiiri 74 SN74HC393N
74393 @89.3.3 126 mikropiiri 74 74LS393N
74393 @89.3.4 11 mikropiiri 74 SN74LS393N
74393 @89.3.4 45 mikropiiri 74 PC74HCT393P
74393 @89.3.4 89 mikropiiri 74 SN74HC393N
74393 @89.3.4 9 mikropiiri 74 M74HC393B1
74393 @89.3.4 5 mikropiiri 74 M74LS393P SN74393N
74395 @89.3.5 5 mikropiiri 74 SN74LS395N
74490 @89.4.1 3 mikropiiri 74 SN74490N
74490 @89.4.1 16 mikropiiri 74 SN74LS490N
74520 @89.4.2 8 mikropiiri 74 74ACT520PC
74521 @89.4.2 1 mikropiiri 74 P74PCT521APC
74533 @89.4.3 21 mikropiiri 74 SN74HC533N
74540 @89.4.4 3 mikropiiri 74 CD74HCT540E
74541 @89.4.5 45 mikropiiri 74 MC74HC541N
74541 @89.4.5 1 mikropiiri 74 MC74HCT541N
74541 @89.4.5 4 mikropiiri 74 CD74HC541E
74541 @89.4.5 7 mikropiiri 74 SN74LS541N
74573 @89.5.1 78 mikropiiri 74 MC74HC573AN
74573 @89.5.1 5 mikropiiri 74 MC74HCT573AN
74573 @89.5.1 10 mikropiiri 74 SN74HC573AN
74573 @89.5.1 6 mikropiiri 74 SN74HCT573N
74573 @89.5.2 8 mikropiiri 74 SN74AHCT573N
74573 @89.5.2 2 mikropiiri 74 PC74HC573P
74573 @89.5.2 1 mikropiiri 74 MC74HC573N
74573 @89.5.2 1 mikropiiri 74 M74HC573B1
74573 @89.5.2 1 mikropiiri 74 PC74HCT573P
74573 @89.5.2 1 mikropiiri 74 CD74HCT573E
74574 @89.5.3 6 mikropiiri 74 DM74ALS574AN
74574 @89.5.3 5 mikropiiri 74 CD74HCT574E
74574 @89.5.3 4 mikropiiri 74 SN74HC574N
74574 @89.5.3 4 mikropiiri 74 SN74AHCT574N
74574 @89.5.3 2 mikropiiri 74 M74HCT574B1
74574 @89.5.3 1 mikropiiri 74 MC74HC574AN
74595 @89.5.4 40 mikropiiri 74 SN74HC595N
74595 @89.5.4 3 mikropiiri 74 MC74HC595AN
74595 @89.5.4 5 mikropiiri 74 SN74AHCT595N
74595 @89.5.4 12 mikropiiri 74 M74HC595B1
74597 @89.5.5 12 mikropiiri 74 MC74HC597AN
74629 @89.6.1 2 mikropiiri 74 SN74LS629N
74640 @89.6.2 19 mikropiiri 74 PC74HC640P
74641 @89.6.3 3 mikropiiri 74 SN74LS641N
74643 @89.6.4 20 mikropiiri 74 SN74LS643N
74646 @89.6.5 4 mikropiiri 74 SN74LS646NT
74688 @89.7.1 19 mikropiiri 74 SN74LS688N
74688 @89.7.1 10 mikropiiri 74 74HC688AP
74688 @89.7.1 3 mikropiiri 74 MM74HC688N
74688 @89.7.1 2 mikropiiri 74 SN74HC688N
74688 @89.7.1 1 mikropiiri 74 74HC688N
74688 @89.7.1 1 mikropiiri 74 M74LS688P
74901 @89.7.2 1 mikropiiri 74 MM74C901N
74902 @89.7.2 1 mikropiiri 74 MM74C902N
74906 @89.7.2 24 mikropiiri 74 MM74C906N
74922 @89.7.3 6 mikropiiri 74 MM74C922N
74923 @89.7.4 80 mikropiiri 74 MM74C923N
74925 @89.7.5 11 mikropiiri 74 MM74C925N
74943 @89.8.1 mikropiiri 74 74VHC943N
741000 @89.8.2 124 mikropiiri 74 SN74AS1000AN
741000 @89.8.2 3 mikropiiri 74 SN74ALS1000N
742257 @89.8.3 50 mikropiiri 74 PI74FCT2257TPA
744002 @89.8.4 25 mikropiiri 74 74HC4002AP
744002 @89.8.4 9 mikropiiri 74 TC74HC4002P
744017 @89.8.5 24 mikropiiri 74 74HC4017N
744040 @89.9.1 87 mikropiiri 74 MC74HC4040N
744040 @89.9.1 14 mikropiiri 74 SN74HC4040N
744049 @89.9.2 2 mikropiiri 74 74HC4049N
744051 @89.9.3 15 mikropiiri 74 PC74HC4051P
744051 @89.9.3 1 mikropiiri 74 74HCT4051N
744051 @89.9.3 1 mikropiiri 74 MC74HC4051N
744052 @89.9.4 24 mikropiiri 74 74HC4052N
744052 @89.9.4 22 mikropiiri 74 MC74HC4052N
744052 @89.9.4 7 mikropiiri 74 CD74HC4052E
744052 @89.9.4 4 mikropiiri 74 CD74HCT4052E
744053 @89.9.5 21 mikropiiri 74 74VHC4053N
744060 @89.10.1 22? mikropiiri 74 MC74HC4060N
744075 @89.10.2 19 mikropiiri 74 74HC4075AP
744078 @89.10.3 55 mikropiiri 74 MC74HC4078N
744094 @89.10.4 38 mikropiiri 74 PC74HC4094P
744094 @89.10.4 25 mikropiiri 74 74HC4094N
744511 @89.10.5 2 mikropiiri 74 74HC4511N
744515 @89.11.1 46 mikropiiri 74 M74HC4515B1
744538 @89.11.2 35 mikropiiri 74 MC74HC4538AN
744538 @89.11.2 25 mikropiiri 74 74HC4538N
744543 @89.11.3 2 mikropiiri 74 74HCT4543N
7422106 @89.11.3 1 mikropiiri 74 CD74HC22106E CD74HC22106.pdf
Mikropiirit regulaattorit
278R12 @12.4.3 1 mikropiiri regul. TO-220F-4 4 Terminal 2A Voltage Regulator Datasheet
42050 – 055 @12.4.3 8 mikropiiri regul. TO-3 5V 5A Datasheet
42050 - 510 @12.4.3 2 mikropiiri regul. TO-3 5V 10A Datasheet
42050 – 055 @11.2.3 14 mikropiiri regul. Custom 5A/5V 40V Positive Voltage Regulator Datasheet
42050 – 158 @11.2.3 13 mikropiiri regul. Custom 8A/15V 40V Positive Voltage Regulator Datasheet
42051 – 154 @11.2.3 15 mikropiiri regul. Custom 4A/-15V -40V Negative Voltage Regulator Datasheet
723BE @12.4.4 21 mikropiiri regul.
723CE @12.4.4 3 mikropiiri regul. 150mA/1.2-37V Voltage Regulator
723CJ @12.4.4 2 mikropiiri regul.
723HC @12.4.4 1 mikropiiri regul. 150mA/1.2-37V Voltage Regulator
723HM @12.4.4 2 mikropiiri regul.
LM723N @12.4.4 35 mikropiiri regul. LM723.pdf
TL431CLP @12.3.4 3 mikropiiri regul. TO-92 Adjustable Output Shunt Regulator Datasheet
7805 @12.1.1 100 mikropiiri regul. TO-92 WS78L05
7805 @12.1.1 15 mikropiiri regul. TO-92 78L05 78L05C L78L05
7805 @12.1.1 6 mikropiiri regul. TO-92 LM78L05ACZ
7805 @12.1.1 6 mikropiiri regul. TO-92 MC78L05ACP MC78L05AC
7805 @12.1.1 1 mikropiiri regul. TO-92 uA78L05AWC
7805 @12.1.3 50 mikropiiri regul. I7805T
7805 @12.1.3 11 mikropiiri regul. 7805
7805 @12.1.3 4 mikropiiri regul. 7805CV MC7805CP
7805 @12.1.3 8 mikropiiri regul. GL7805
7805 @12.1.3 5 mikropiiri regul. L78S05CV
7805 @12.1.4 8 mikropiiri regul. LM7805C
7805 @12.1.4 10 mikropiiri regul. MC7805C
7805 @12.1.4 9 mikropiiri regul. MC7805CT
7805 @12.1.4 2 mikropiiri regul. uA7805C KA78M05
7805 @12.1.4 5 mikropiiri regul. uA78H05
7806 @12.7.1 50 mikropiiri regul. 78L06
7808 @12.2.1 27 mikropiiri regul. L7808CV
7808 @12.2.1 8 mikropiiri regul. MC7808CT
7808 @12.2.1 10 mikropiiri regul. uA78M08UC uA78M08HC uA7808
7809 @12.2.1 6 mikropiiri regul. L7809CV MC7809CT TSC78L09 L78S09CV
7809 @12.9.2 22 mikropiiri regul. 78L09
7809 @12.9.2 30 mikropiiri regul. L78L09
7809 @12.9.2 15 mikropiiri regul. LM78L09
7809 @12.9.2 2 mikropiiri regul. TSC78L09
7812 @12.2.1 26 mikropiiri regul. L7812CV TSL7812CV
7812 @12.2.1 4 mikropiiri regul. 7812UC
7812 @12.2.2 11 mikropiiri regul. MC7812C
7812 @12.2.2 15 mikropiiri regul. MC7812CT
7812 @12.2.2 2 mikropiiri regul. MC78T12C
7812 @12.1.2 12 mikropiiri regul. uA78L12AWC uA78M12HC
7812 @12.2.2 1 mikropiiri regul. TO-3 uA7812KC
7812 @12.1.2 1 mikropiiri regul. WS78L12
7815 @12.1.1 5 mikropiiri regul. MC78L15ACP L78L15A 78L15A
7815 @12.2.2 30 mikropiiri regul. uA7815UC
7815 @12.2.2 14 mikropiiri regul. 7815C 7815CT
7815 @12.2.3 10 mikropiiri regul. MC7815CK MC7815CSK
7815 @12.2.3 6 mikropiiri regul. uA7815KC
7815 @12.2.3 9 mikropiiri regul. MC7815C
7815 @12.2.4 3 mikropiiri regul. MC7815CT
7815 @12.2.4 5 mikropiiri regul. uA78M15
7818 @12.2.4 10 mikropiiri regul. MC7818CT
7818 @12.2.4 4 mikropiiri regul. UGJ7818393
7824 @12.2.4 5 mikropiiri regul. 7824UC
7824 @12.2.4 3 mikropiiri regul. LM7824CK
7824 @12.3.1 5 mikropiiri regul. MC7824C
7824 @12.3.1 19 mikropiiri regul. MC7824CT
7824 @12.3.1 3 mikropiiri regul. uA7824UC uA78M24
7824 @12.9.3 200 mikropiiri regul. L7824CV
78XX @12.3.1 8 mikropiiri regul. Sekal. 7815xx
78XX @12.3.1 7 mikropiiri regul. Sekal. 78xx
7905 @12.1.2 11 mikropiiri regul. 79L05
7905 @12.1.2 3 mikropiiri regul. 79L05CP 79L05AC MC79L05ACP
7905 @12.3.2 3 mikropiiri regul. 7905C
7905 @12.3.2 17 mikropiiri regul. L7905CV
7905 @12.3.2 5 mikropiiri regul. LM7905CT
7905 @12.3.2 7 mikropiiri regul. MC7905C
7905 @12.3.2 16 mikropiiri regul. MC7905CT
7905 @12.3.2 4 mikropiiri regul. MC7905CP uA7905C uA7905UC
7908 @12.3.3 2 mikropiiri regul. uA79M08AHC MC7908CT uA79M08
7909 @12.3.3 1 mikropiiri regul. KA7909
7910 @12.3.3 1 mikropiiri regul. 7910C
7912 @12.3.3 3 mikropiiri regul. 7912C
7912 @12.3.3 8 mikropiiri regul. L7912CV
7912 @12.3.3 4 mikropiiri regul. MC7912C
7912 @12.3.4 1 mikropiiri regul. MC7912CP
7912 @12.3.4 6 mikropiiri regul. MC7912CT
7912 @12.3.4 1 mikropiiri regul. TO-3 uA7912KC
7912 @12.3.4 6 mikropiiri regul. uA7912UC uA79M12AHC
7912 @12.3.4 2 mikropiiri regul. 79M12A 7912P
7912 @12.1.2 4 mikropiiri regul. MC79L12ACP
7915 @12.1.2 3 mikropiiri regul. TO-92 79L15 79L15AC
7915 @12.4.1 8 mikropiiri regul. 7915C
7915 @12.4.1 9 mikropiiri regul. 79015P
7915 @12.4.1 1 mikropiiri regul. GL79015
7915 @12.4.1 4 mikropiiri regul. LM7915CT
7915 @12.4.1 2 mikropiiri regul. MC7915C
7915 @12.4.1 2 mikropiiri regul. MC7915CK
7915 @12.4.2 16 mikropiiri regul. MC7915CT
7915 @12.4.2 1 mikropiiri regul. uA7915K0
7915 @12.4.2 9 mikropiiri regul. uA7915UC
7915 @12.4.2 4 mikropiiri regul. uA79M15
7924 @12.4.2 4 mikropiiri regul. MC7924CP
AP7381-33V-A @12.5.1 2 mikropiiri regul. LDO CMOS Regulator
BA50DD0T @12.10.4 2 mikropiiri regul. 5.0V LDO Regulator
EZ1583CM @12.5.1 3 mikropiiri regul.
L200C @12.5.1 11 mikropiiri regul.
L4941BV @12.5.1 10 mikropiiri regul. TO-220 5V 1A
L9480 @12.5.1 1 mikropiiri regul. Car Alternator Regulator
LD33CV @12.5.1 8 mikropiiri regul. TO-220 IC Regulator LDO 3.3V
LM217K @12.5.2 7 mikropiiri regul. TO-3 Adj. 1.2-37V 2.5A
LM2576T-ADJ @12.5.3 3 mikropiiri regul.
LM2931CT @12.7.2 73 mikropiiri regul.
LM2940CT-5.0 @12.5.2 100 mikropiiri regul. TO-220 LDO 5V 1A
LM2940CT-12 @12.5.2 3 mikropiiri regul. TO-220 LDO 12V 1A
LM2990T-12 @12.7.2 1 mikropiiri regul.
LM304H @12.5.3 2 mikropiiri regul. LM304H uA304HC Neg. Adj. -40V 500mW
LM305AH @12.5.3 35 mikropiiri regul. Pos. Adj. 4.5-40V 30mA
LM305H @12.5.3 17 mikropiiri regul. Pos. Adj. 4.5-40V 30mA
LM309H @12.5.3 4 mikropiiri regul. TO-39 5V 1A
LM309K @12.5.3 3 mikropiiri regul. TO-3 5V 3A
LM317H @12.5.4 40 mikropiiri regul. TO-39 Adj. 1.2-37V 0.5A LM317N.pdf
LM317 @12.5.4 2 mikropiiri regul. LM317HVT LM317K LM317N.pdf
LM317LZ @12.5.4 10 mikropiiri regul. TO-92 Adj. 1.2-37V 0.1A LM317N.pdf
KA317 @12.5.4 8 mikropiiri regul. Same as LM317 LM317N.pdf
LM317T @12.5.4 16 mikropiiri regul. TO-220 Adj. 1.2-37V 1A LM317N.pdf
LM323K @12.4.3 5 mikropiiri regul. TO-3
LM330T-5.0 @12.6.1 2 mikropiiri regul.
LM335Z @12.6.1 4 mikropiiri regul.
LM337 @12.6.1 7 mikropiiri regul. TO-220 Adj. Neg -1.2 - -37V 1A
LM337T @12.6.1 3 mikropiiri regul. TO-220 Adj. Neg -1.2 - -37V 1A
LM338K @12.6.1 2 mikropiiri regul. TO-3
LM338T @12.6.1 10 mikropiiri regul. TO-220
LM340K @12.6.2 4 mikropiiri regul.
LM340T12 @12.6.2 16 mikropiiri regul.
LT1054CN8 @12.9.4 3 mikropiiri regul. Switched-Capacitor Voltage Converter with Regulator LT1054.pdf
LT1071CT#PBF @12.6.2 35 mikropiiri regul. 2.5A/60V Switching Regulators Datasheet
LT1085CT @12.6.3 2 mikropiiri regul. TO-220 3A Regulator Datasheet
LT1086CT @12.6.3 3 mikropiiri regul. TO-220 1.5A Regulator Datasheet
LT1172CT @12.6.2 30 mikropiiri regul. 1.25A/60V High Efficiency Switching Regulators LT1172.pdf
LT1172HVCT @12.7.4 1 mikropiiri regul.  100kHz, 1.25A/75V High Efficiency Switching Regulator LT1172.pdf
MC1466L @12.6.3 19 mikropiiri regul. 14-Pin DIP 300-mil Precision Voltage and Current Regulator Datasheet
MC1723CP @12.6.3 4 mikropiiri regul. 14-Pin DIP Adj. 2-37V 150mA MC1723C.pdf
MC34063 @12.6.3 5 mikropiiri regul. 8-Pin Dip 300mil 1.5A/40V Adjustable Buck, Boost and Inverting Regulator Datasheet
MC78M12 @12.6.3 3 mikropiiri regul. MC78M12 78M12A
RC4195NB @12.6.4 1 mikropiiri regul. 8-Pin DIP Fixed +-15V Dual Tracking Voltage Regulator Datasheet
SG309K +5V reg. @12.6.4 1 mikropiiri regul.
SG320K -5V reg. @12.6.4 3 mikropiiri regul.
SG320K -15V reg. @12.6.4 1 mikropiiri regul.
SG340K +24V reg. @12.6.4 1 mikropiiri regul.
SH323 SC @12.6.4 2 mikropiiri regul. TO-3 3A/5V Fixed voltage regulator
TDA1412T @12.10.1 1 mikropiiri regul. 12V/500mA Fixed Voltage Regulator TDA1412.pdf
UA78GU1C @12.7.2 3 mikropiiri regul.
UA79GU1C @12.7.2 1 mikropiiri regul. uA79MGU1C uA79GU1C
UA78S40PC @12.7.2 2 mikropiiri regul.
7812CU @12.7.1 7 mikropiiri regul.
L78S12CV @12.7.1 5 mikropiiri regul.
UA7812C @12.7.1 26 mikropiiri regul.
ML7812 @12.7.1 14 mikropiiri regul.
ML7812A @12.7.1 24 mikropiiri regul.
7805 @12.7.3 110 mikropiiri regul. L7805CV
7815 @12.7.3 99 mikropiiri regul. L78M15CV
7815 @12.7.4 150 mikropiiri regul. MC78M15CT
L123B1 @12.8.1 6 mikropiiri regul. TO116 150mA/2-37V Voltage Regulator L123B1.pdf
L123CT @12.8.1 1 mikropiiri regul. 150mA/2-37V Voltage Regulator L123CT.pdf
7812 @12.8.1 20 mikropiiri regul. TA7812S
LM1086IT-ADJ @12.8.1 48 mikropiiri regul. TO-220 1.5A/29V Adjustable LOD Regulator Datasheet
LM1086IT-ADJ @12.8.1 39 mikropiiri regul. TO-220 1.5A/29V Adjustable LOD Regulator Datasheet
7812 @12.8.2 28 mikropiiri regul. TO-3 MC7812CK 1.5A 5V MC7812CK.pdf
7812 @12.8.3 30 mikropiiri regul. TO-3 MC7812CK 1.5A 5V MC7812CK.pdf
7812 @12.8.4 22 mikropiiri regul. TO-3 MC7812CK 1.5A 5V MC7812CK.pdf
LM2575T-5.0 P+ @12.10.1 1 mikropiiri regul. TO-220 1A/40V 5.0V Regulator, Step-Down Switching regulator LM2575.pdf
LM2940CT-15 P+ @12.9.1 48 mikropiiri regul. TO-220 1A/26V LDO regulator Datasheet
LM2940CT-15 P+ @12.9.1 32 mikropiiri regul. TO-220 1A/26V LDO regulator Datasheet
LM2941T P+ @12.9.1 48 mikropiiri regul. TO-220 1A/26V LDO regulator Datasheet
LM2941T P+ @12.9.1 42 mikropiiri regul. TO-220 1A/26V LDO regulator Datasheet
LM350 @12.9.1 1 mikropiiri regul. TO-220 3A/33V adjustable regulator Datasheet
LP2950 @12.9.1 10 mikropiiri regul. TO-92 5V 1.0% regulator Datasheet
LP2951CN @12.10.1 1 mikropiiri regul. 100mA/2-30V LDO regulator LP2950.pdf
URAM2CS3 @12.9.2 1 mikropiiri regul. 20A/30V Output Ripple Attenuation Module URAM2C3S.pdf
MAX667EPA @12.9.4 280 mikropiiri reg. 8-pin DIP +5V LDO Regulator MAX667.pdf
MAX667EPA @12.9.4 10 mikropiiri reg. 8-pin DIP +5V LDO regulator MAX667.pdf
TOP202YAI @12.6.4 38 mikropiiri regul. TO-220 Three-terminal Off-line PWM Switch TOP200.pdf
TDA0200SP @12.10.1 1 mikropiiri regul. TO-220
SUNTAI ST-I05A (5V) @12.10.2 10 mikropiiri regul. 5V/100V DC/DC Converter ST-I05A.png
Muistit EPROM UV-Erasable 27xxx 57xxx
1702 @21.1.1 15 muisti AM1702ADC AM1702ADC.pdf
2708 @21.1.1 3 muisti AM2708DC
2708 @21.1.1 1 muisti Intel B2708
2708 @21.1.1 1 muisti 24-Pin DIP 600mil TMS2708JL Datasheet
2708 @21.1.1 1 muisti Intel D2758 1kx8 D2708.pdf
2716 @21.1.2 3 muisti Intel D2716
2716 @21.1.2 2 muisti NEC D2716
2716 @21.1.2 1 muisti NEC D2716D
2716 @21.1.2 4 muisti MM2716Q
2716 @21.1.2 31 muisti ST M2716-IFI
2716 @21.1.3 3 muisti ET 2716Q-1
2716 @21.1.3 2 muisti MBM2716
2716 @21.1.3 1 muisti MB8516
2716 @21.1.3 1 muisti Motorola MCM2716C
2716 @21.1.3 1 muisti TI TMS2516JL-45
2732 @21.1.4 4 muisti Intel D2732A
2732 @21.1.4 5 muisti Intel D2732A-2
2732 @21.1.4 1 muisti Intel D2732A-3
2732 @21.1.4 2 muisti HN462732 HN462732G
2732 @21.1.4 3 muisti HN482732AG-20
2732 @21.1.4 2 muisti MSL2732K
2732 @21.2.1 1 muisti TI TMS2532JL
2764 @21.2.2 13 muisti Intel D2764
2764 @21.2.2 2 muisti Intel D2764A
2764 @21.2.2 1 muisti AM2764-4DC
2764 @21.2.2 1 muisti HN482764AG
2764 @21.2.2 2 muisti MBM2764-30
2764 @21.2.3 21 muisti MBM2764-25
2764 @21.2.3 1 muisti NMC27C64Q200
2764 @21.2.3 4 muisti Intel TD27C64
2764 @21.2.4 47 muisti Intel LD27C64-20
27128 @21.3.1 3 muisti Intel D27128
27128 @21.3.1 20 muisti SEEQ DQ27128-25
27128 @21.3.1 4 muisti ST M27128A-2FI
27128 @21.3.1 1 muisti ST M27128AFI
27128 @21.3.1 1 muisti NMC27CP128Q200
27256 @21.3.2 29 muisti Intel D27256
27256 @21.3.2 2 muisti Intel D27256-1
27256 @21.3.2 8 muisti Intel D27256-2
27256 @21.3.2 1 muisti Intel D27256-25
27256 @21.3.2 1 muisti Intel D27256D-2
27256 @21.3.3 3 muisti 27256-25 Microchip
27256 @21.3.3 1 muisti 27256G-17 GI
27256 @21.3.3 3 muisti 28-Pin DIP 600mil Microchip 27HC256-70/J
27256 @27.3.3 5 muisti AM27C256-200
27256 @27.3.3 5 muisti 28-Pin DIP 600mil AM27C256-70DC
27256 @27.3.3 5 muisti 28-Pin DIP 600mil AM27C256-IDC
27256 @21.3.4 2 muisti HN27256G-25
27256 @21.3.4 7 muisti Intel LD27C256-20
27256 @21.3.4 2 muisti 28-Pin DIP 600mil M27C256B-12F1
27256 @21.3.4 1 muisti 28-Pin DIP 600mil NMC27C256Q200 NMC27C256BQ250
27256 @21.3.4 26 muisti 28-Pin DIP 600mil MBM27256-20 ERASED
27256 @21.4.1 12 muisti 28-Pin DIP 600mil MBM27256-25
27256 @21.4.1 9 muisti 28-Pin DIP 600mil TMS27C256-12
27256 @21.4.1 1 muisti 28-Pin DIP 600mil TMS27C256-20JL
27256 @21.4.1 2 muisti 28-Pin DIP 600mil TMS27C256-2JL
27256 @21.4.1 1 muisti 28-Pin DIP 600mil TS27C256-25CQ
27512 @21.4.2 4 muisti AM27C512-255DC ERASE
27512 @21.4.2 8 muisti TMS27C512-10 TMS27C512-12
27512 @21.4.2 3 muisti M27512-25FI M27C512-10FI M27C512-15FI
27512 @21.4.2 1 muisti M5L27512K
27512 @21.4.2 1 muisti MBM27C512-25
27512 @21.4.2 1 muisti NM27C512Q-150
27010 @21.4.3 7 muisti AM27C010-150DC ERASE
27010 @21.4.3 38 muisti AM27C010-200DC
27010 @21.4.3 3 muisti AM27C010-205DC
27010 @21.4.3 1 muisti AM27C010-55DC AM27C100-200DC
27010 @21.4.4 1 muisti AM27H010-55DC
27010 @21.4.4 1 muisti AT27C010-45DC
27010 @21.4.4 4 muisti D27C010-200V10
27010 @21.4.4 1 muisti HN27C101G-20
27010 @21.4.4 1 muisti M5M27C100K-2
27010 @21.4.4 1 muisti NM27C010Q-120 ERASE
27010 @21.5.1 9 muisti NM27C010Q-150 ERASE
27010 @21.5.1 15 muisti TMS27C010A-12 TMS27C010A-15
27010 @21.5.1 2 muisti TMS27C010A-12 TMS27C010A-15
27010 @21.5.1 6 muisti TMS27C010A-20
27010 @21.5.2 79 muisti AM27C010-120DC ERASE
27020 @21.5.3 3 muisti AM27C020-120DC ERASE
27020 @21.5.3 22 muisti AM27C020-200DC ERASE
27020 @21.5.3 2 muisti D27C020-200V10
271000 @21.5.4 1 muisti TC571000D-15
271000 @21.5.4 2 muisti TC571000D-20
271001 @21.5.4 1 muisti TC571001D-15
271001 @21.5.4 1 muisti TC571001D-20
271001 @21.5.4 2 muisti TC571001D-200
271001 @21.6.1 1 muisti M27C1001-10FI ERASE
271001 @21.6.1 10 muisti M27C1001-15FI ERASE
271001 @21.6.1 4 muisti M27C1001-20FI
271001 @21.6.1 2 muisti M27C1001-20XFI
272001 @21.6.2 1 muisti M27C2001-12F1 M27c2001.pdf
272001 @21.6.2 12 muisti M27C2001-20F1 M27c2001.pdf
272001 @21.6.2 5 muisti M27C2001-70XFI M27c2001.pdf
27201 @21.6.3 20 muisti PLCC-32 M5M27C201JK UV-EPROMeja käytettyjä, tyhjentämättä Datasheet
274001 @21.6.3 3 muisti M27C4001-10F1
274002 @21.6.3 1 muisti M27C4002-15F1
WS57C49B @21.6.4 16 muisti 24-pin DIL 300mil WSI WS57C49B-35 8x8k EEPROM WS57C49B.pdf
Muistit RAM
2114 @27.1.1 2 muisti 18-Pin DIP 300mil 2114UCB 1024x4 bit static N-MOS RAM Datasheet
2114 @27.1.1 13 muisti 18-Pin DIP 300mil HM472114P-4 1024x4 bit static RAM Datasheet
2114 @27.1.1 9 muisti 18-Pin DIP 300mil P2114 P2114A-6 Pg. 126 1978_Intel_Component_Data_Catalog.pdf
2125 @27.1.1 2 muisti 16-Pin DIP 300mil D2125H-4 1024x1 Static RAM p.91 1976_Intel_Data_Catalog.pdf
2141 @27.1.1 8 muisti 18-Pin DIP 300mil D2141-5 P2141-5 4096x1 bit static N-MOS RAM Datasheet
2148 @27.1.1 2 muisti 18-Pin DIP 300mil D2148H H-MOS 1024 x 4 Static RAM M2148.pdf
2533DC @27.1.2 1 muisti 8-Pin DIP 1024-Bit Static MOS Shift Register Datasheet
7132155J @27.1.2 1 muisti PLCC52 HIGH SPEED 2K X 8 DUAL-PORT STATIC RAM Datasheet
7188 @27.1.2 2 muisti 7188S25P 9113M Cache Ram
8464 @27.1.2 24 muisti 8464A-10L 8kx8 Static CMOS RAM
AM2130-70PC @27.1.3 7 muisti 48-Pin DIP 1024x8 Dual-Port Static RAM AM2130.pdf
AM91L14BCP @27.1.3 2 muisti 18-Pin DIP 1024x4 Static RAM Datasheet
AS6C1008-55PCN @27.1.3 1 muisti 32-Pin 600-mil 128k x 8 SRAM AS6C1008.pdf
CY62256LL-70PC @27.1.4 1 muisti 28-Pin 600-mil 32k x 8 SRAM CY62256.pdf
CY7C199-45PC @27.1.4 9 muisti 28-Pin 300-mil 32k x 8 SRAM CYC199.pdf
D4364C-15L @27.1.4 5 muisti 28-Pin 600-mil 8k x 8 CMOS STATIC RAM UPD4364.pdf
D43256AC-12L @27.1.4 18 muisti 28-Pin 600-mil 32k x 8 CMOS STATIC RAM UPD43256A.pdf
DS1213C @27.1.5 1 muisti 256k SmartSocket DS1213D.pdf
DS1220AD-150+ @27.1.5 1 muisti 24-Pin 600-mils 2k x 8 NVRAM DS1220Y.pdf
DS1220Y-200 @27.1.5 7 muisti 24-Pin 600-mils 2k x 8 NVRAM DS1220Y.pdf
DS1225Y @27.1.5 1 muisti 28-Pin 600-mils 8k x 8 NVRAM DS1225Y.pdf
DS1225Y-200 @27.1.5 3 muisti 28-Pin 600-mils 8k x 8 NVRAM DS1225Y.pdf
GM76C88AL-15 @27.2.1 2 muisti 28-Pin DIP 600-mil 8k x 8 Static RAM Datasheet
HM1-6514-9 @27.4.3 37 muisti 18-Pin DIP 300-mil 1k x 4 Static RAM HM6514.pdf
HM3-2064-5 @27.2.1 5 muisti 28-Pin DIP 600-mil 8k x 8 Static RAM HM2064.pdf
HM6116P-4 @27.2.2 5 muisti 24-Pin DIP 600-mil 2k x 8 Static RAM HM6116.pdf
HM6116LP-4 @27.2.2 69 muisti 24-Pin DIP 600-mil 2k x 8 Static RAM HM6116.pdf
HM62256LP-12 @27.2.3 7 muisti 28-Pin DIP 600-mil 32k x 8 CMOS Static RAM
HM6264ALP-12 @27.2.3 2 muisti 28-Pin DIP 600-mil 8k x 8 CMOS Static RAM Datasheet
HM6264AP-12 @27.2.3 9 muisti 28-Pin DIP 600-mil 8k x 8 CMOS Static RAM Datasheet
HM6264LP-15 @27.2.3 1 muisti 28-Pin DIP 600-mil HM6264LPO-15 8k x 8 CMOS Static RAM Datasheet
HM6264P-10 @27.2.3 2 muisti 28-Pin DIP 600-mil HM6264P-10 8k x 8 CMOS Static RAM Datasheet
HM6264P @27.2.3 3 muisti 28-Pin DIP 600-mil HM6264P-15 8k x 8 CMOS Static RAM Datasheet
HM628128LP-10 @27.2.4 1 muisti 32-Pin DIP 600-mil HM628128LP-10 128k x 8 CMOS Static RAM HM628128LP.pdf
HM62832HP-35 @27.2.4 3 muisti 28-Pin DIP 300-mil HM62832HP-35 32k x 8 High speed CMOS Static RAM HM62832.pdf
HY53C256LS-80 @27.2.4 71 muisti 16-Pin DIP 300-mil 256k x 1 DRAM HY53C256.pdf
HY6264ALP-10 @27.2.4 5 muisti 28-Pin DIP 600-mil 8k x 8 Static RAM HY6264A.pdf
IDT7201 @27.5.3 1 muisti PLCC32 512 x 9 CMOS Asyncronous FIFO IDT7201.pdf
IDT7204 @27.5.3 1 muisti PLCC32 4096 x 9 CMOS Asyncronous FIFO IDT7204.pdf
IDT7132SA55J @27.2.5 7 muisti 2k x 8 dual port Static Ram IDT7132SA.pdf
IDT7140SA55J @27.2.5 2 muisti 2k x 8 dual port Static Ram IDT7140SA.pdf
IS61C64-25N @27.2.5 8 muisti 8k x 8 Static Cache Ram IS61C64B.pdf
IS61C64-30N @27.2.5 8 muisti 8k x 8 Static Cache Ram IS61C64B.pdf
IS61C68-25N @27.2.5 3 muisti
IS61C256A-20N @27.2.5 3 muisti 32k x 8 Static RAM IS61x256.pdf
IS61M256-15N @27.3.1 1 muisti 32k x 8 Static RAM IS61x256.pdf
KM681000ALP-8 @27.3.1 2 muisti 32-Pin DIP 600-mil 128k x 8 Static RAM Datasheet
M5M5165P-10 @27.3.1 7 muisti 28-Pin DIP 600-mil 8k x 8 Static RAM M5M5165P.pdf
M5M5178AP-20 @27.3.1 1 muisti 8k x 8 Cache Ram M5M5178AP.pdf
M5M5178BP-20 @27.3.1 9 muisti 8k x 8 Cache Ram M5M5178BP.pdf
MB8116H @27.3.1 43 muisti 18-pin DIP 16k x 1 NMOS Dynamic RAM MB8116H.pdf
MB8128-10 @27.3.2 59 muisti 24-Pin DIP 2kx8 Static RAM MB8128.pdf
MB81C1000A-70P @27.3.2 22 muisti 1024kx1 Dynamic RAM Datasheet
MB84256-12 @27.3.2 2 muisti
MCM60L256APC10 @27.3.3 4 muisti 28-Pin DIP 600-mil 32k x 8 CMOS SRAM MCM60L256A-C.pdf
MK4116J-2GP @27.3.3 43 muisti 16k x 1 NMOS Dynamic RAM MK4116J.pdf
MK4118N-4 @27.3.3 1 muisti 1k x 8 Static RAM MK4118.pdf
MM2102AN @27.3.3 5 muisti 1024x1 Static RAM MM2102A.pdf
MS6264L-10PC @27.3.3 2 muisti 28-Pin DIP 600-mil 8k x 8 CMOS Static RAM MS6264.pdf
MT1259-15 @27.3.4 5 muisti 16-Pin DIP 256k x 1 DRAM Page Mode Datasheet
MT5C2561-35 @27.3.4 3 muisti 24-Pin DIP 256k x 1 Static RAM Databook Page 40
MT5C6408-25 @27.3.4 1 muisti 28-Pin DIP 8k x 8 Static RAM Databook Page 140
MT52C9022-35 @27.3.4 1 muisti 28-Pin DIP 2k x 9 FIFO Databook Page 450
MWS5101 @27.3.4 1 muisti 256 x 4-Bit LSI Static RAM MWS5101.pdf
MWS5114E @27.3.4 1 muisti 1024 x 4-Bit LSI Static RAM MWS5114.pdf
P21010-07 @27.3.5 18 muisti 18-Pin 300-mil Intel 1Mx1bit DRAM 21010.pdf
P21014-08 @27.3.5 20 muisti 18-Pin 300-mil Intel 1Mx1bit DRAM 21014.pdf
P21256-10 @27.3.5 100 muisti 16-Pin 300-mil Intel 256k x 1bit DRAM 21256.pdf
P5164SL-10 @27.3.5 6 muisti 28-Pin DIP 600-mil 8k x 8 Slow Static RAM Datasheet
SRM20256LC12 @27.4.1 12 muisti 28-Pin DIP 600-mil 32k x 8 Static RAM SRM20256LC12.pdf
TC524258AZ-10 @27.4.1 8 muisti 28-Pin ZIP 256k x 4 Multiport Video DRAM TC524258AZ-10.pdf
TC551001BPL-70L @27.4.2 1 muisti 32-Pin DIP 128k x 8 Bit static ram Datasheet
TC551001BPL-85 @27.4.2 5 muisti 32-Pin DIP 128k x 8 Bit static ram Datasheet
TC5517AP @27.4.2 1 muisti 24-Pin DIP 600-mil 2kx8 CMOS Static RAM TC5517CP.pdf
TC5517AP-8 @27.4.2 6 muisti 24-Pin DIP 600-mil 2kx8 CMOS Static RAM TC5517CP.pdf
TC5565APL-10 @27.4.2 2 muisti 28-Pin DIP 600-mil 8k x 8 CMOS Static RAM Datasheet
TC5565APL-15 @27.4.2 2 muisti 28-Pin DIP 600-mil 8k x 8 CMOS Static RAM Datasheet
TMM2016 @27.4.3 102 muisti 24-Pin DIP 2k x 8 Bit static ram Datasheet
TMM2016 @27.4.4 13 muisti 24-Pin DIP 2k x 8 Bit static ram Datasheet
TMS4416-15NL @27.4.4 3 muisti 18-Pin DIP
TMS4416-20NL @27.4.4 3 muisti 18-Pin DIP
UM4164-15 @27.4.5 1 muisti 16-Pin DIP 300mil
UM6164BK-20 @27.4.5 1 muisti 28-Pin DIP 300mil 8k x 8 Static RAM UM6164.pdf
UM61256FK-15 @27.4.5 4 muisti 28-Pin DIP 300mil 32k x 8 Static RAM
UM611024BK-15 @27.4.5 3 muisti 32-Pin DIP 300mil 128k x 8 Static RAM
UM62256D-70LL @27.4.5 1 muisti 28-Pin DIP 600mil 32 x 8 Static RAM
SD-rammeja @27.5.1 X muisti
D43256BCZ-70LL @27.5.2 1 muisti
HM3-7681-5 @27.5.2 1 muisti
LH5164D-10L @27.5.2 6 muisti
MCM7681DC @27.5.2 2 muisti
TBP28S86AN @27.5.2 4 muisti
SD-rammeja @27.5.2 X muisti
Muistit EEPROM FLASH
24AA1025 @21.7.1 3 muisti 8-Pin DIP 128k x 8 I2C Serial EEPROM Datasheet
24LC01B @21.7.1 2 muisti 8-Pin DIP 1k-bit I2C Serial EEPROM Datasheet
24C02 @21.7.1 1 muisti 8-Pin DIP 300mil I2C SERIAL 2Kb (256 x 8) EEPROM Datasheet
24C08WP @21.7.1 8 muisti 8-Pin DIP 24LC04B 24LC16B
24LCxxx @21.7.1 2 muisti 8-Pin DIP 24LC04B 24LC16B
25LC256 @21.7.1 3 muisti 8-Pin DIP 256k-bit SPI Serial EEPROM Datasheet
901226-01 @21.7.2 1 muisti 24-Pin DIP 600mil 901226-01 CBM Commodore 64 Basic ROM
A25L040-F @21.7.2 1 muisti 8-Pin DIP 4Mbit SPI 3.3V, Serial Flash Memory Datasheet
A290021TL @21.7.2 10 muisti 32-Pin PLCC A290021TL-70F 256kx8 EEPROM A29002.pdf
AM28F256-200PI @21.8.3 1 muisti 32-Pin DIP 32kx8 CMOS 12.0 Volt, Bulk Erase Flash Memory AM28F256.pdf
AM29F010-90JC @21.7.2 5 muisti 32-Pin PLCC 128kx8 FlashROM AM29F010.pdf
AM29F010-120JC @21.7.2 31 muisti 32-Pin PLCC -90JC -120JC -150JC 128kx8 FlashROM AM29F010.pdf
AM29F010-150JC @21.7.2 2 muisti 32-Pin PLCC 128kx8 FlashROM AM29F010.pdf
AM29F040-90JC @21.7.3 24 muisti 32-Pin PLCC 512kx8 FlashROM AM29F040.pdf
AT27C256R-20C @21.7.3 2 muisti 28-Pin DIP 600mil AT27C256R-20PC
AT28C64-30PI @21.7.3 1 muisti 28-Pin DIP 600mil AT28C64-30PI AT28C64.pdf
AT49F010-70PC @21.7.3 3 muisti 32-Pin DIP 600mil 128k x 8 CMOS Flash Memory AT49F010.pdf
bq4010YMA-150 @21.7.3 1 muisti 28-Pin DIP 600mil AT28C64.pdf
CAT28F010N-20 @21.7.3 5 muisti PLCC32 128k x 8 CMOS flash memory Datasheet
CAT28F020N-15 @21.7.4 1 muisti PLCC32 256k x 8 CMOS flash memory CAT28F020.pdf
EPM7064LI44-15 @21.7.4 2 muisti 44-Pin PLCC PLD 1250 gates/64 macrocells
M28C64160 @21.8.4 1 muisti PLCC32 8k x 8 Parallel EEPROM M28C64.pdf
M28C64C-15K1 @21.7.4 19 muisti PLCC32 8k x 8 Parallel EEPROM Datasheet
M29F010B-70K1 @21.7.4 1 muisti 32-Pin PLCC 128k x 8 Flash Memory M29F010B.pdf
MHB2526 @21.7.4 2 muisti DIP 8-Pin 300 mil Serial EEPROM ???
MMI6306-IJ @21.7.4 9 muisti 16-pin DIP 512x4 PROM 6309PROM.pdf
MX26C1000APC-12 @21.7.4 0 muisti 32-Pin DIP 600mil 128k x 8 EEPROM MX26C1000A.pdf
N28F010-150 @21.8.1 2 muisti 32-Pin PLCC 128kx8 FlashROM 28F010.pdf
N28F020-90 @21.8.1 4 muisti 32-Pin PLCC 256kx8 FlashROM 28F020.pdf
N82S123F @21.8.1 17 muisti 16-pin DIP 256-bit bipolar PROM N83S23.pdf
P4001 @21.8.1 1 muisti 16-pin DIP Intel 4004 series 256x8bit ROM Page 70 MCS-40_Users_Manual_Nov74.pdf
SST39SF020 @21.8.1 3 muisti 32-Pin DIP 600mil, PLCC32 256k x 8 Flash Memory Datasheet
SST39SF040 @21.8.1 1 muisti 32-Pin DIP 600mil 512k x 8 Flash Memory Datasheet
TBP18S030N @21.8.2 47 muisti 16-Pin DIP 300-mil 32x8 PROM TBP18S030.pdf
TBP18SA030MJ @21.8.2 3 muisti 16-Pin DIP 300-mil 32x8 PROM TBP18S030.pdf
TBP18SA030N @21.8.2 61 muisti 16-Pin DIP 300-mil 32x8 PROM TBP18S030.pdf
TBP24S10N @21.8.2 49 muisti 16-Pin DIP 300-mil 256x4 PROM TBP24S10.pdf
TC531000CP-F721 @21.8.2 4 muisti 32-Pin DIP 600mil 128k x 8 Bit Mask PROM TC531000AP.pdf
UPD23C512EC-191 @21.8.3 1 muisti 28-Pin DIP 600mil 64kx8 Mask-Programmable CMOS ROM UPD23C512E.pdf
W29C040-90 @21.8.3 2 muisti 32-Pin DIP 300mil 512K × 8 CMOS FLASH MEMORY Datasheet
Pm29F002T-12PC @21.8.3 1 muisti 32-Pin DIP 300mil 256K × 8 CMOS FLASH MEMORY PM29F002.pdf
V29C51002T @21.8.3 1 muisti 32-Pin DIP 300mil 256K × 8 CMOS FLASH MEMORY V29C51002T.pdf
XLS2816AP-250 @21.8.3 1 muisti 24-Pin DIP 600mil 2 × 8 CMOS EEPROM XL2816A.pdf.pdf
Muistit PAL - piirit
F16V8B-15PU @21.11.1 3 mikropiiri ATMEL PAL
F22V10C-15PU @21.11.1 3 mikropiiri ATMEL PAL
GAL16V8QS @21.11.1 1 mikropiiri GAL16V8QS-25LNC
GAL20V8B @21.11.1 5 mikropiiri
GAL20V8A @21.11.1 6 mikropiiri PLCC28
GAL22V10C @21.11.1 15 mikropiiri PLCC28
GAL26CV12B @21.11.2 10 mikropiiri
PAL16L8BNC @21.11.2 6 mikropiiri 20-Pin DIP 300 mil PAL Circuits PAL16.pdf
PAL16R4ANC @21.11.2 6 mikropiiri 20-Pin DIP 300 mil PAL Circuits PAL16.pdf
PAL16R6A2NC @21.11.2 6 mikropiiri 20-Pin DIP 300 mil PAL Circuits PAL16.pdf
PAL20L10ANC @21.11.2 2 mikropiiri 24-Pin DIP 300 mil PAL Datasheet
PALC16L8-25WC @21.11.2 3 mikropiiri 20-Pin DIP 300 mil Reprogrammable PAL Circuits PALC16.pdf
PALC16L8-35PC @21.11.3 6 mikropiiri 20-Pin DIP 300 mil Reprogrammable PAL Circuits PALC16.pdf
PALCE20RA10H-20PC @21.11.3 3 mikropiiri 24-Pin DIP 300 mil PAL Datasheet
PALCE20V8H-15PC @21.11.3 1 mikropiiri 24-Pin DIP 300 mil PAL Datasheet
PALCE22V10H-25PC @21.11.3 13 mikropiiri 24-Pin DIP 300 mil PAL
PALCE22V10H-7JC/5 @21.11.3 30 mikropiiri PLCC-28 PAL Datasheet
PALCE24V10H-25PC @21.11.3 5 mikropiiri 28-Pin DIP 300 mil PAL Datasheet
TIBPAL16L8-12CN @21.11.4 7 mikropiiri 20-Pin DIP 300-mil PAL Circuits TIBPAL16.pdf
TIBPAL16L8-15CN @21.11.4 21 mikropiiri 20-Pin DIP 300-mil PAL Circuits TIBPAL16.pdf
TIBPAL16R4-25CN @21.11.4 6 mikropiiri 20-Pin DIP 300-mil PAL Circuits TIBPAL16.pdf
TIBPAL16R6-12CN @21.11.4 8 mikropiiri 20-Pin DIP 300-mil PAL Circuits TIBPAL16.pdf
TIBPAL16R8-15CN @21.11.4 4 mikropiiri 20-Pin DIP 300-mil PAL Circuits TIBPAL16.pdf
Muut komponentit
AMPHENOL CAP-WBBFSMA1 @29.5.5 3 muut
AMPHENOL CAP-WBBMSMA1 @29.5.5 4 muut
AMPHENOL VENT-PS2NBK-O8001 @29.5.5 5 muut
AMPHENOL 8AP-04AMMM-SL7A01 @35.6.1 2 muut M8 4-pin Cable Male conn./Male pins Datasheet
Antureita sekal. @26.1.2 X muut
Breadboard wires male-male @26.8.2 X muut Hyppylankoja, leipälautaan
Breadboard wires female-female @26.8.3 X muut Hyppylankoja, leipälautaan
Buzzer @01.3.1 X muut Piippari, äänimerkki
Buzzer @35.5.1 X muut Piippari, äänimerkki
Buzzer @61.4.2 X muut Piippari, äänimerkki
Buzzer @61.5.2 X muut Piippari, äänimerkki
Kaasuantureita @26.3.1 7 muut NO2, CO, SO2, O2+NO2
Kosteusantureita @26.7.1 5 muut Capacitive Soil Moisture Sensor v2.0 Capacitive Soil Moisture Sensor V2.0 .pdf
CO2-anturi @26.7.1 4 muut
CO2-anturi @26.7.2 X muut
CP40336 @26.3.1 1 muut Peltier elementti Datasheet
CT-131 Barcode Scanner @13.3.2 X muut Viivakoodinlukumoduli Summary CT-13x_barcode_reader.pdf CT-131_ProgrammingGuide.pdf
DC/DC muunnin @13.5.1 1 muut DC/DC muunnin 8-55V/1-36V 10A/15Amax
DC/DC muunnin @13.7.1 3 muut DC/DC muunnin 9.2V-18V/5V 3A SD-15A-05
DC/DC muunnin @13.7.2 5 muut SMD DC/DC muunnin 5V DC - 100V DC/12.5mA PICO 5SMV100 Datasheet
DC/DC muunnin @13.7.2 1 muut DC/DC muunnin 24V DC - 6.5KV DC
DC/DC muunnin @13.7.2 1 muut GSP-2465AN-5627 24V - 6.5kV
DC/DC muunnin @13.7.2 1 muut Parrot AR-DRONE Lipo Charger
DC/DC muunnin @13.7.2 1 muut DKMW30F-12 9-36V/+-12V 1250mA
DC/DC muunnin @13.7.2 1 muut TVM1212DEN 12Vin +-12VOut 40mA DC/DC muunnin
DC/DC muunnin @13.7.2 1 muut RU-050505 5Vin 2 x 5VOut 100mA DC/DC muunnin
DC/DC muunnin @13.7.2 4 muut K7812W-500R 24V/12V 0.5A DC/DC muunnin K7012W-500R3.pdf
DC/DC muunnin @13.7.3 2 muut PKA 4231C EriPOWER DC/DC muunnin 25W +5V,+12V,-12V
DC/DC muunnin @13.7.3 2 muut QAW24D15-40 Wall Industries DC/DC muunnin
DC/DC muunnin @13.7.3 1 muut QAW24S5-40 Wall Industries DC/DC muunnin
DC Parrot AR-Drone Charger @13.7.2 1 muut DC Lipo Balance Charger 1A 3S
Enkooderit yms. @26.6.3 X muut
Hauenleuat @65.2.1 30 muut
Hauenleukajohtoja @65.2.1 6 muut
Hihnaa @26.7.3 X muut 5m pieniin moottoreihin
Hihnapyöriä @26.7.3 X muut pieniin moottoreihin
Hihnoja @26.7.3 0 muut pieniin moottoreihin
Holkkitiivisteet @38.1.1 X muut
Sekalaisia pinnejä @61.8.1 X muut
Juotospinnejä @61.8.1 X muut
Juotoskorvia @61.8.2 X muut
Juotoskorvia @61.8.3 X muut
Kaapelimerkintänumeroita @61.5.1 X muut
Lämpötila-anturi termopari @95.8.1 9 muut
Numerolevyjä @61.5.1 X muut
Kaapeliside @16.2.1 X muut Kaapeliside tarrapinnalla
Kahvoja/Vetimiä @45.2.1 X muut Piirilevyn kahvoja/ulosvetimiä PCB Handles/Vetonaru+nuppi
Kaiutin sekalaisia @01.3.2 X muut Sekalaisia kaiuttimia
Kaiutin @26.4.3 16 muut Pienoiskaiuttimia 8Ohm 0.4W 50x50x4mm
Kaiutin @26.4.3 4 muut Pienoiskaiuttimia 8Ohm 0.4W 40x40x4mm FUJI B3A 6L 01
Kaiutin BL @26.4.3 1 muut Pienoiskaiutin 8Ohm 0.2W d=45mm
Kaiutin L @26.4.3 1 muut Pienoiskaiutin 8Ohm 0.2W d=45mm
Kaiutin sekalaisia @26.4.3 X muut
Kaiutin WBN 16 Ohm 2W @26.5.3 3 muut Pienoiskaiutin 16 Ohm 2W d=50mm
Kello @26.3.1 2 muut
Kohdistustapin hylsyjä @61.7.1 X muut
Kohdistustappeja @61.7.2 X muut
Kosteusanturi @26.1.1 6 muut Hoya Funduino Moisture Sensor
Kutistesukat @16.2.1 X muut
Lamppu Philips 100W 12V @41.4.2 X muut
Lähestymisanturi induktiivinen @26.1.1 3 muut M12x1 IP667 SIEN-M12NB-PS-S-L/150411 150411.pdf
Lämpöliuskoja @26.2.3 X muut
Läpivientejä @38.2.2 X muut
Lokerikkojen nimikylttejä @61.1.3 X muut
Lokerikkojen nimikylttejä @61.2.2 X muut
Lokerikkojen välilevyt tasapäiset kapea 5 rinnakkain V-00 @61.1.2 X muut
Lokerikkojen välilevyt tasapäiset leveä 4 rinnakkain V-01 @61.1.2 X muut
Lokerikkojen välilevyjä isommat @61.2.3 X muut
Lokerikkojen välilevyjä muovia @39.2.1 X muut
Lokerikkojen välilevyjä isommat @39.2.2 X muut
Lämpötila-anturi T6 S21 @26.1.2 10 muut
Lämpötila-anturi E05U @26.1.2 4 muut E05U 08005 053D
Marmorikuulia, hiiren kuulia @61.5.3 X muut
Mikrofoni @41.4.1 7 muut Elektreettimikrofoni
Mikrofoni @41.4.1 37 muut Elektreettimikrofoni liitinjohdolla
Mikrofoni @41.4.1 57 muut Elektreettimikrofoni liitinjohdolla ja muovisuojalla
Mikrofoni @41.4.1 100 muut Elektreettimikrofoni liitinjohdolla
Mikrofoni @41.4.1 22 muut Elektreettimikrofoni kumisuojuksella ja liitinjohdolla
Mikrofoni @41.4.1 26 muut Elektreettimikrofoni pitkällä johdolla
Mikrofoni @41.4.1 69 muut Elektreettimikrofoni johdolla
Mikrofoni @41.4.1 24 muut Elektreettimikrofoni PCB 300Ohm/50Hz-12kHz
Minipci @13.3.3 X muut Mini PCI kortteja (WIFI)
Moduleita @13.3.3 X muut Vahvistimia yms.
Moottori @36.1.2 1 muut MITSUMI R-142020 M25E-4 5V 300mA
Moottori @36.1.2 1 muut FAULHABER MINIMOTOR SA 22/2k 30969:1 1589401
Moottori @36.1.2 4 muut Pienoismoottori d=20mm, akseli 2mm
Moottori @36.1.2 6 muut Pienoismoottori d=24mm, akseli 2mm
Moottori,askelmoottori @36.1.2 3 muut 21-02485 mini stepperi 5V
Moottori,askelmoottori @36.1.2 1 muut 39BYGH405B stepperi 12V
Moottori,servo @36.1.2 3 muut AIRPAX A82313 2582
Muistikortteja SD yms @27.6.5 X muut
Muistikampa DIMM @36.2.1 X muut
Muistikampa SO-DIMM @36.2.2 X muut
Nestepinta-anturi @26.1.2 2 muut
Nestepinta-tunnistin @26.1.2 3 muut
NFC, RFI ja muut @14.12.3 X muut
Credit card memory @14.12.3 18 muut EEPROM 256kx8 47-0002-01 REVA GTech
iButton Programmer @14.12.2 1 muut
Particle Photon IOT WIFI-board @14.12.2 1 muut
Näppäimistöjä @61.3.1 X muut
Paine- ja kiihdytysantureita @26.2.2 X muut SATS ry:n antureita
VTI29688A2 @26.2.2 1 muut SCC1300-D02 Gyro sensor board
Paineantureita @13.6.3 X muut
Paineantureita @13.5.3 X muut
Painekytkimiä @13.6.3 X muut
Painoantureita @29.7.2 X muut
Peukalopyöriä @28.5.1 X muut Thumbwheels
Pienoiskaiuttimet @01.3.2 X muut
Pienvirtajohtoja Molex 8-pin @34.7.1 19 muut
Pienvirtajohtoja Molex 4-pin/4-johdin @34.7.2 7 muut
Pienvirtajohtoja Molex 4-pin/2-johdin @34.7.2 7 muut
Pienvirtajohtoja 4-pin/4-johdin PCB @34.7.2 9 muut
Piezo @29.5.4 X muut
Potikan nuppeja @28.5.1 X muut
Potikan nuppeja @28.5.2 X muut
Ruuvi Tag @13.6.1 2 muut Kaksi Ruuvi - piirikorttia
RXZ01.1 @13.6.1 1 muut Bus terminator 52.3 Ohm for LonWorks bus Datasheet
Sekalaisia @61.2.2 X muut
Sekalaisia antureita @13.6.2 X muut
RC-servo arms / RC-servokammat @01.4.1 X muut
RC-servo arms / RC-servokammat @01.5.1 X muut
RC-servo arms / RC-servokammat @01.5.2 X muut
SG90 RC-servo @01.6.1 10 muut
RC-servo erikokoja @01.6.2 x muut
Silikonijohtoa @35.6.2 X muut
RTY360LVEAX @26.2.3 1 muut Hall-anturi Catalog Datasheet
RTY360HVEAX @26.2.3 1 muut Hall-anturi Catalog Datasheet
SR13D-A1 HALL anturi @26.2.3 4 muut SR13-15.pdf
SS41F HALL anturi @26.2.3 9 muut SS41F.pdf
OH44E HALL anturi @26.2.3 10 muut OH44E.pdf
OH44E HALL anturi @26.2.3 10 muut SS49E.pdf
KMZ10C @26.2.3 4 muut Hall anturi
TL170C @26.2.3 1 muut Hall anturi
Tassu, jalka @35.4.3 X muut Kotelon pohjan jalkoja/tassuja
Tulppia @38.3.2 X muut
USB-uppopumppu @13.3.1 1 muut USB-1020 3.5-9V 1-3W IP68
Pienoispumppuja @13.3.1 2 muut
Skootti-akkujen osia @11.8.1 X muut
Valmiit johdot @35.6.3 X muut
Venymäliuska-antureita @13.5.3 4 muut
Vedonpoistaja @38.2.1 X muut
Vedonpoistajia tms. @38.2.1 X muut Vedonpoistajan johdonsuoja
Vedonpoistaja KZ441 @25.12.2 X muut KZ0441 Cable tie mounts polyamide cutout4.4mm W7.3mm L23mm
Vedonpoistaja KZ442 @25.12.2 X muut KZ0442 Cable tie mounts polyamide cutout4.4mm W7.5mm L24mm
Näytöt
Näyttö 128x160 @63.1.1 20 näytöt WF18FTLAADNN0 WF18FTLAADNN0.pdf
Näyttö 128x64 @63.1.2 13 näytöt WEO12864LWAP3N00F00 WEO12864LWAP3N00F00.pdf
Näyttö 320x240 Laatikko C01.2 2 näytöt KTG32024002-FFDWH6N-CN3A STN 320x240 pixel KTG32024002.png
Näyttö 256x64 @63.1.3 5 näytöt WEO025664DLPP3N00000 WEO025664D.pdf
Näyttö 256x64 @63.1.3 1 näytöt EVB Board For WEO025664DLPP3N00000
Näyttö 128x64 @63.2.1 6 näytöt W012864C2-TFH W012864C2.pdf
Näyttö 1024x600 TFT Laatikko C01.5 2 näytöt WF70A7TIFHLHG0 WF70A7TIFHLHGV.pdf
Näyttö 1024x600 LVDS Laatikko C01.5 5 näytöt YTC700TLBC-07100C YTC700TLBC.pdf
Näyttö 800x480 LVDS Laatikko C01.6 7 näytöt YTC700RLBF-16-100C TFT
Näyttö 800x480 Laatikko C01.7 3 näytöt YTC700RLBK-01-100N YTC700RLBF-01-100C.pdf
Näyttö 240x128 Laatikko C01.7 3 näytöt WG240128B-TMI-TZ WG240128B-TMI-TZ.pdf
Näyttö 1.54" 128×64 @63.2.2 6 näytöt WEO012864YLAP3N00000 WEO012864YLAP3N00000.pdf
Näyttö 5.0" 800x480 Laatikko C01.8 8 näytöt WF50FSYAGDNT0 WF50FSYAGDNN0.pdf
TODO: tarkista - kaksi paikkaa Näyttö 5.0" 720x1280 Laatikko C01.8 8 näytöt WF50DSYA3MNG10
Näyttö Laatikko C01.3 5 näytöt W70B7TIJGDNT0
Näyttö 640x480 TTF Laatikko C01.3 7 näytöt DTFS057A3NHLX-D00
Näyttö 7.0" 800x480 Laatikko C01.3 4 näytöt LVDS CF070HLDLWH-002 CF070HLDLWH-002.pdf
Näyttö 128x36 @63.1.2 10 näytöt VGM128036A5W11 VGM128036-1.png VGM128036-2.png
Näyttö 800x480 TFT Laatikko C01.2 2 näytöt WF70A2TIFGDHGV WF70A2TIFGDHGV.pdf
Näyttö 1.54" 128×64 @63.1.2 4 näytöt WEO012864YWAP3N00000 WEO012864YLAP3N00000.pdf
Näyttö 1.71" 128×32 @63.2.3 10 näytöt WEO012832GWAP3N00F00 WEO012832GWAP3N00000.pdf
Näyttö 1.71" 128×32 @63.2.3 15 näytöt WEO012832GWAP3N00000 WEO012832GWAP3N00000.pdf
Näyttö 128x64 Laatikko C01.3 5 näytöt WG12864A-TGH-V#N WG12864A-TGH-V#N.pdf
Näyttö 20x4 char. @63.3.1 5 näytöt WH2004D-YYH-ET# WH2004D.pdf
Näyttö 720×1280 Laatikko C01.3 2 näytöt WF50DSYA3MNN0# WF50DSYA3MNN0.pdf
Näyttö 5.0" 720x1280 TFT Laatikko C01.9 7 näytöt WF50DSYA3MNG10 WF50DSYA3MNG10.pdf
Näyttö Laatikko C01.9 5 näytöt WJ70D5SIAGDNCA
Näyttö 2.8" 240x320 @63.2.3 12 näytöt YTS280DLAY-01-100N YTS280DLAY-01-100N.pdf
Näyttö 64x32 @63.3.1 15 näytöt Visionox VGM064032A2W01
Näyttö 1.54" 128x64 @63.3.1 17 näytöt Visionox VGM128064B1W01 VGM128064B1W01.pdf
Näyttö 3.5" 320x240 TFT ???? 100 näytöt WJ35TTLACDNC2A iso laatikko
Näyttö 416x240 Laatikko C01.10 8 näytöt YMS416240-037AAAMFGN YMS416240-037AAAMFGN.png
Näyttö 0.71" 84x84 @63.3.2 5 näytöt VGM084084A0F01 VGM084084A0F01.pdf
Näyttö .96" 96x96 @63.3.2 5 näytöt VGM096096A8F01 VGM096096A8F01.pdf
Näyttö 1.3" 160x160 @63.3.2 5 näytöt VGM160160A3W01 VGM160160A3W01.pdf
Näyttö 3.97" 480x800 TFT @63.3.3 5 näytöt WF40CTYAQMNN0 WF40CTYAQMNN0.pdf
Näyttö 5.0" 720x1280 @63.4.1 9 näytöt YTS500XLAI-01-100C YTS500XLAF-01-100C.pdf
Näyttö 128x36 @63.3.2 14 näytöt WGM128036A5W11
Näyttö 240x240 Pyöreä @63.4.3 5 näytöt TFT240240-8-E
Näyttö 1.5" 200x200 @63.3.2 1 näytöt HINKE0154A45 JIANGXI XI e-paper HINKE0154A45.png
Näyttö 10.1" 1280x800 WXGA Laatikko B23 2 näytöt FG1001F1DSSWNGL1 HCM17334W-1010 SCF1001146GGU13 FG1001F1DSSWNGL1.pdf
JH-17X/1.97.1HV @63.4.2 6 muut LCD näyttömoduli
JH-17X/1.98.11.1HQ @63.4.2 2 muut LCD näyttömoduli
LXD 43D5R03J @63.4.2 3 muut LCD näyttömoduli 12/84 172C
METS0B1L01 @63.4.2 2 muut LCD näyttömoduli
TJDM12232A @63.4.2 1 moduli LCD moduli Datasheet
Akkuliitin 5€ @17.5.1 1 rakennussarja Akkuliitin skoottiakkuun MOBILE PAY 5€
Genuino 101 5€ @17.5.2 7 moduli 20250623x7 Intel Genuino/Arduino 101 MOBILE PAY 5€ GenuinoProductsBrief.pdf
USB - RS232 TTL muunnin 3€ @17.4.3 7 moduli 20250530x7 Kiinalainen FTDI-klooni Mini-USB MOBILE PAY 3€ USBTTL.png
ESP8266 3€ @17.5.3 1 moduli 20250530x1 ESP8266MOD MOBILE PAY 3€
ESP32 dev board 5€ @17.5.3 2 moduli 20250530x2 ESP32 Development Board Micro-USB MOBILE PAY 5€
Arduino 32U4 USB-C 6€ @17.5.3 0 moduli 20250530x0 Arduino Mega 32U4 USB-C liittimellä MOBILE PAY 6€
Arduino 32U4 micro 6€ @17.5.3 1 moduli 20250530x1 Arduino Mega 32U4 Micro-USB liittimellä MOBILE PAY 6€
Arduino UNO USB-B 5€ @28.1.1 5 moduli 20250530x5 Arduino UNO USB-B liittimellä MOBILE PAY 5€
Arduino UNO USB-B 5€ @28.1.2 7 moduli 20250623x7 Arduino UNO USB-B liittimellä MOBILE PAY 5€
Arduino Mini 5€ @28.1.1 5 moduli 20250530x5 Arduino UNO Micro-USB liittimellä MOBILE PAY 5€
Raspberry PICO 5€ @28.1.1 3 moduli 20250530x3 Raspberry PICO USB-C MOBILE PAY 5€
Raspberry PICO Tiny 5€ @28.1.1 2 moduli 20250530x2 Raspberry PICO Tiny USB-C MOBILE PAY 5€
3.2V 10Ah LI-PO Akku 8€ Noutolaatikko 4 Akku Flatpak akku MOBILEPAY 8€
24V 15AH Polkupyörän akku 40€ Varasto 1.hylly 2 Akkupaketti Polkupyörän tms. akku MOBILE PAY 40€
Opto-komponentit
1A27LC @29.8.1 1 opto Optohaarukka
1A57HR @29.8.1 4 opto Optohaarukka
3A07 @29.8.2 6 opto Optohaarukka SHARP 3A07
3AV2C @29.8.1 1 opto Optohaarukka
42-6 @29.8.1 2 opto Optohaarukka
C6455 @29.8.1 1 opto Optohaarukka C6455-60032 K123
CNY36 TFK452 @29.8.4 15 opto Optohaarukka
EE011111_1_1 @29.8.3 opto Optohaarukka 6 x KTIR
EE-SPY412 @29.8.4 4 opto Optohaarukka
EE-SX450-P1 @29.8.4 12 opto Optohaarukka
H0A096 @29.8.5 2 opto H0A096-P51 H0A0963-P51 Optohaarukka
IR-LED @29.8.5 1 opto Optohaarukka
HPK 9L P1144-05 @29.8.5 1 opto Optohaarukka
H13B1 @29.8.5 10 opto Optohaarukka
Sekalaisia Optohaarukoita @29.8.5 6 opto Optohaarukka
OPB970N11 @29.9.1 1 opto Optohaarukka
OPB990L11 @29.9.1 2 opto Optohaarukka
OPB804 @29.9.1 25 opto Optohaarukka Datasheet
H21A1 @29.9.2 90 opto Optohaarukka Datasheet
TCYS5201 3507 @29.9.3 36 opto TCYS 5201 3507 VISHAY Optohaarukka TCYS5201.pdf
OPB625 @29.9.4 30 opto Optohaarukka
H21L0B moduli @29.9.4 4 opto Optohaarukka H21L.pdf
PM-L44 @29.9.5 9 opto Optohaarukka
4N25 4N26 4N27 @29.10.1 3 opto 8-Pin DIP
4N35 @29.10.1 50 opto 6-Pin DIP 300mil
4N37 @29.10.1 1 opto 6-Pin DIP 300mil Phototransistor Couplers Datasheet
6N136 @29.10.1 4 opto 8-Pin DIP 300mil 6N136.pdf
6N137 @29.10.1 6 opto 8-Pin DIP 300mil
6N139 @29.10.2 8 opto 8-Pin DIP 300mil
BPW34F @29.10.4 650 opto Photodiodi BPW34F.pdf
BPW40 @29.10.2 4 opto Phototransistor Datasheet
BPW41 @29.10.2 20 opto PIN Photodiode Datasheet
BP103B @29.10.2 10 opto NPN Phototransistor
L14G3 @29.10.2 10 opto NPN Phototransistor [https://nx2063.your-storageshare.de/s/9yHWMjGGr6ZoqtT L14G3.pdf
CNY17-2 @29.10.3 43 opto CNY17.pdf
CNY17-3 @29.10.3 50 opto CNY17.pdf
CNY65B @29.10.3 20 opto Optocoupler, Phototransistor Output, Very High Isolation Voltage Datasheet
FPT100 @29.10.4 2 opto 3-pin NPN General-purpose silicon planar phototransistor Datasheet
GI2601 @29.10.3 11 opto GI 2601
H11L1 @29.10.4 28 opto 6-Pin DIP 300mil Logic output optoisolator Datasheet
HBCS-1100 @29.10.4 6 opto TO-5 High resolution optical reflective sensor Datasheet
HP2200 @29.10.5 40 opto 8-Pin DIP 300mil Datasheet
HP2531 @29.10.5 3 opto 8-Pin DIP 300mil
HP2630 @29.10.5 4 opto 8-Pin DIP 300mil
HP2631 @29.10.5 24 opto 8-Pin DIP 300mil HP2631
HP2731 @29.10.5 80 opto 8-Pin DIP 300mil 2731 HP2731 HCPL2731 Dual-channel darlington photocoupler Datasheet
HP4503 @29.10.5 20 opto 8-Pin DIP 300mil HP4503 HCPL4503 HP4503.pdf
IL-100 @29.10.3 10 opto 8-Pin DIP 300mil High speed optoisolator Datasheet
ILD74 @29.11.1 2 opto 8-Pin DIP 300mil Dual channel optocoupler
ILQ-74 @29.11.1 54 opto 16-Pin DIP 300mil Quad channel optocoupler Datasheet
IRM-2036 @29.11.1 120 opto 3-pin Datasheet
IRM-2036 @29.11.2 250 opto 3-pin Datasheet
IRM-2036F14(QN) @29.11.3 500 opto 3-pin Infrared Remote-control Receiver Module Datasheet
LDR 596-141 @29.11.4 7 opto
LDR NORP @29.11.4 4 opto SILONEX
LDR NSL @29.11.4 4 opto ORP 12
LDR @29.11.4 27 opto
LDR @29.11.4 3 opto
LDR @29.11.4 50 opto LDR A
LDR @29.11.5 70 opto
LTV827 @29.11.5 39 opto 8-Pin DIP 300mil Dual opto isolator Datasheet
MCA230 @29.11.5 2 opto 6-Pin DIP Photodarlington optocoupler Datasheet
MCA255 @29.11.5 1 opto 6-Pin DIP 300mil
MCT2 @29.12.1 1 opto 6-Pin DIP 300mil
MCT271 @29.12.1 2 opto 6-Pin DIP 300mil
MCT275 @29.12.1 56 opto 6-Pin DIP 300mil
MOC3021 @29.12.1 50 opto 6-Pin DIP 300mil QTC MOC 3021 Phototriac driver optocoupler Datasheet
MOC3023 @29.12.1 15 opto 6-Pin DIP 300mil QTC MOC 3023 Phototriac driver optocoupler Datasheet
MOC3041 @29.12.1 1 opto 6-Pin DIP 300mil
MOC3063 @29.12.2 10 opto 6-Pin DIP 300mil
MOC8101 @29.12.2 2 opto 6-Pin DIP 300mil Phototransistor optocoupler
ON3171 @29.12.2 3 opto 4-Pin DIP Photo-transistor Optoisolator Datasheet
PC111 @29.12.2 1 opto 6-Pin DIP 300mil Datasheet
PC702V @29.12.2 4 opto 6-Pin DIP 300mil Datasheet
PC817 @29.12.2 1 opto 4-Pin DIP 300mil Opto isolator Datasheet
PC817-4 @29.12.3 19 opto 4-Pin DIP 300mil Opto isolator Datasheet
PS2021 @29.12.3 1 opto 6-Pin DIP 300mil Opto isolator
PVU414 @29.12.3 60 mikropiiri Datasheet
SFH300 @29.12.3 10 opto NPN Phototransistor
SL23821 @29.12.3 1 opto 8-Pin DIP F 7541
TIL111 @29.12.4 1 opto
TI112 @29.12.4 1 opto
TIL113 @29.12.4 6 opto 6-Pin DIP 300mil Optocoupler with photodarlington output Datasheet
TI115 @29.12.4 2 opto
TI127 @29.12.4 49 opto
TIL81 @29.12.4 2 opto
TLP534 @29.12.5 1 opto Phototransistor Optoisolator Recommended Replacement: TLP734 Datasheet
TLP547G @29.12.5 1 opto Thyristor Optoisolator Recommended Replacement: TLP747G Datasheet
TLP621 @29.12.5 120 opto 4-Pin DIP Phototransistor Optoisolator T 2E: TLP621 Datasheet
T-T532Z @29.8.3 10 opto Avago Technologies 1115 T-T523Z Valokuitulähetin Kuva
VOH1016A @92.12.1 2 opto
XCA110 @29.12.5 3 opto Datasheet
Valokenno mini @29.12.5 18 opto
Aurinkokenno 4x4 in @39.3.1 80 opto SÄRKYVÄT HELPOSTI, KÄSITTELE VAROVASTI
Aurinkokenno 1.5x1.5 in @39.3.1 14 opto
ZMP31 @29.12.5 47 opto 2-Pin Phototransistor 780nm Datasheet
Rakennussarjat ja modulit
03962A @13.5.1 25 moduli Micro USB to Li-ion battery charger board
2G Moduli @13.4.1 3 moduli VAYU REV D 2019 Moduli SIM800 2G moduli
3G Moduli @13.4.1 1 moduli SIM5215E
4056 @13.5.1 8 moduli USB-C to Li-ion battery charger board
433MHz @26.7.2 X moduli 433MHz moduleita ja antenneja
7-Segment näyttömoduli @13.5.2 X moduli 4x7-Segment led ja 4-painiketta 76621I.pdf
76621I CF-to-IDE moduli @26.3.2 1 moduli Inline 76621I CF 2xCF to 2.25in IDE
CF-IDE44 Adapter @26.3.2 1 moduli CF-IDE44/2.0mm Adapter, V.B1
AC1005 @13.4.2 2 moduli 5A AC Virtamuuntaja AC1005.pdf
AC1015 @13.4.2 1 moduli 15A AC Virtamuuntaja AC1015.pdf
AC1050 @13.4.2 9 moduli 50A AC Virtamuuntaja AC1050.pdf
ACX-1050 @13.4.2 12 moduli 50A AC Virtamuuntaja ACX-1050.pdf
ATS-1255R Ethernet PoE moduli @26.4.1 9 moduli
Ag5300 1 Ethernet PoE moduli @26.4.1 1 moduli Silvertel PoE Moduli Datasheet
FT232RLBB @26.4.1 2 moduli FT232RL USB to Serial DIL Breakout
LX-LC535 @13.5.1 4 moduli USB-C to Li-ion battery charger board
Breadboard power supply @13.5.1 1 moduli 3.3V 5V Breadboard poweri
CNC-SHIELD @13.5.2 1 moduli Ver 3.00 info.protoneer.com/1
HaoYunLai-Audio vahvistin @13.5.2 1 moduli P/N Y148 Ver.002 Date 20110707
GY-521 Gyroscope @13.5.1 1 moduli 3-Axis Acceleration Gyroscope 6DOF Module Web-page Print of Web-page
DS1307 RTC moduleita @13.6.1 8 moduli
RPI E1P-V1.0.2 @28.1.2 16 moduli RPI 2/B+/3B-GPIO Expansion Board E1P-V1.0.2
RPI Kamera @26.4.2 1 moduli Raspberry Pi Camera Rev 1.3 ERASE
PowerBoost 1000C @26.4.2 5 moduli USB Power and backup battery board for RPI
REG71055 Charge Pump @26.5.1 3 moduli 3V to 5V Charge pump Datasheet
BOB-08745 Level Converter @26.5.1 1 moduli Sparkfun 3.3V 5V Level Converter Datasheet Schema
Logic Level Translator @26.5.1 1 moduli 3.3V to 5V Converter Datasheet
Euclid Probe PCB @26.4.2 16 moduli Euclid Probe PCB piirilevy
D/C 4217 Pressure sensor @26.5.2 12 moduli First Sensor ID ZA009102 D/C 4217
LDES025B Pressure sensor @26.5.2 15 moduli LDE digital low differential pressure sensor
SAA1099koekytkentä @13.4.3 1 moduli
PIR module @26.3.1 5 moduli KC778N ohjaimella KC788B.pdf
STK463 @13.4.2 1 moduli Stereo Amplifier module
SmartLED Shield @26.3.2 1 moduli Led Shield for Teensy 4
Rephone Seeed @26.3.3 6 moduli XADOW GSM+BLE
RLP434 @26.3.3 2 moduli Ultra Small Receiver 315, 418, 433.92MHz
EG25GGB-256-SGNS @26.6.1 20 moduli Quectel IoT/M2M-optimized LTE Cat 4 Module EG25GGB.pdf
BG95M3LA @26.6.1 17 moduli Quectel BG95M3LA-MINIPCIe LTE Cat M1/ Cat NB2/ EGPRS Module BG95M3LA.pdf
EM160RGLAU-M21-SGADA @26.6.1 2 moduli Quectel LTE-A Cat 16 M.2 Module EM160RGL.pdf
EM120RGLAU-M21-SGADA @26.1.3 2 moduli Quectel LTE-A Cat 12 M.2 Module EM120RGLAU.pdf
FC20-Q73 @26.1.3 20 moduli Quectel Wi-Fi & BT Module LCC Package FC20-Q73.pdf
OLED dev-board @26.1.3 1 moduli SL10256400B000B0100
CO8725-B5SA-E @26.1.3 13 moduli 8725F-A1-E 5M Camera Module
RM500Q-GL @63.7.1 20 moduli Quectel RM500Q-GL IoT/eMBB-Optimized 5G Sub-6 GHz M.2 Module RM500Q-GL.pdf
RM500Q-AE @63.7.1 6 moduli Quectel RM500Q-AE IoT/eMBB-Optimized 5G Sub-6 GHz M.2 Module RM500Q-AE.pdf
RM510Q-GL @26.2.1 2 moduli Quectel RM510Q-GL 5G Sub-6 GHz & mmWave M.2 Module RM510Q_GL.pdf
WT32-S1 @26.2.1 1 moduli Wi-Fi Module WT32-S1.pdf
EC21-EUX-GA @26.5.3 25 moduli Quectel EC21EUXGA-MINIPCIE EC21.pdf
EC25-EUX-GA @26.2.1 6 moduli Quectel EC25EUXGA-128-SGNS
EP06ELA-512-SGA @26.2.1 1 moduli EP06ELA-512-SGA LTE-A Cat.6 module with MiniPCIe
EC25EFA @26.2.1 2 moduli EC25EFA-512-STD RF Module/Cat 4 LTE/MiniPCIe
EM06-ELA @26.2.1 23 moduli EM06ELA-512-SGAS LTE Cat 6 module M.2 EM06E-LA.pdf
BG77LATEA-64-SGNS @26.2.2 6 muut LCD näyttömoduli BG77_LPWA.pdf
TELEDYNE4021 @13.4.2 1 moduli
TLP434A @26.3.3 2 moduli Ultra Small Transmitter 315, 418, 433.92MHz
XYX-3*3W-C @26.3.3 6 moduli Ledi driver/vakiovirta
DC12 to 5V+3.3V Linear @26.4.1 2 moduli Power Module 12V to 5V and 3.3V Datasheet
DSN2596 @26.4.1 1 moduli 3.2-3V to 1.25-30V Buck converter
LED Driver @26.4.1 4 moduli LED Driver?
USB - UART @26.4.1 1 moduli USB-to-UART moduli
D24V6F3 @26.4.2 1 moduli Pololu 3.3V, 600mA Step-Down Converter
BMP180BARO @26.4.2 0 moduli sparkfun.com
GAMMA M0 @26.4.2 1 moduli Adafruit MC-board Datasheet
MicroSD Card @26.6.2 1 moduli Micro SD Card breakout board
MOD-WiFi-ESP8266-DEV Board @26.4.2 1 moduli www.olimex.com
MR003-005.1 @26.4.2 1 moduli microbot.it
IGD507AN @26.5.1 7 moduli
ISO215N @26.5.1 2 moduli
HW-95 @26.6.2 1 moduli L298N STEPPER MOTOR DRIVER MODULE Home Page
ROB-12779 @26.6.2 5 moduli Easy Driver Stepper Motor Driver HW-135 Home Page
ROB-12859 @26.6.2 3 moduli Big Easy Driver Stepper Motor Driver Home Page
Relemoduleita @26.6.2 3 moduli
SBT0811 @26.6.2 2 moduli ULN2003 Stepper Motor Driver board Home Page
XY-L-1610 @26.6.2 1 moduli Tasavirtamoottorin säätö 9-50V 10A (kiinalaisia arvoja)
YS-U20S 5V @26.5.3 1 moduli 100V-240VAC/5V3A DC YS-U20S_AC100~264V_to_DC5V_3A.pdf
100V-280VAC/12VDC PSU @26.5.3 1 moduli 100V-280VAC/12VDC
PWM-säädin @26.6.2 1 moduli HW-070 12V 10A PWM controller
WT588DM01 @26.6.3 1 moduli Voice Module Sound Board
IPA-05 @26.6.3 1 moduli D-Class 30W Mono Amplifier 22-36V 4 Ohm
HX711 @26.6.3 1 moduli HX711 ADC module
RAM BOARD 10571-500 @13.4.1 2 moduli PCB RAM ASSEMBLY
WT41-A Bluetooth @13.4.3 13 moduli Bluegiga WT41-A bluetooth moduli
YWRobot modRL04 4-Relay board @26.7.1 0 moduli
Panelimittareita @65.3.1 4 moduli
DC/DC muuntimia @65.3.1 2 moduli
Säätimiä @65.3.2 2 moduli
Releet
D47-S 5VDC @03.1.3 8 rele Finder 36.11.9.005.4011 5VDC 10A/250VAC 10A/30VDC
E10-S 5VDC @03.1.3 5 rele Finder 36.11.9.005.4011 5VDC 10A/250VAC 10A/30VDC
FRS1B-S 5VDC @03.1.3 5 rele 1A/125VAC
G2R-1A 12VDC @04.4.2 3 rele OMRON 10A/250VAC 10A/30VDC
G5V-1 5VDC @03.1.3 11 rele OMRON
G7L-2A-T 24VDC @02.5.1 3 rele OMRON 25A/277VAC DPST
ITT ??? @03.1.3 4 rele ITT 48518 98551
RT424F12 12V @03.1.3 1 rele SCHRACK 8A/250VAC
VB 6TCN-E 6V @03.1.3 1 rele TAKAMISAWA
HF115F 5VDC @03.1.4 5 rele 8A/250VAC
HF118F 24VDC @02.5.1 29 rele 10A/250VAC 180A/30VDC HF118F 024-1ZS1T HF118F.pdf
HF32FA 5VDC??? @03.1.4 10 rele 005-HSL2(610) 5A/250VAC 5A/30VDC
HF32FA 5VDC??? @03.1.4 10 rele 005-ZS2(610) 3A/250VAC 3A/30VDC
HF46F 5VDC??? @03.1.4 5 rele 5-HS1(610) 5A/250VAC 5A/30VDC
HJR-4102-L-05V @03.1.4 15 rele 3A/120VAC 3A/30VDC
DSP1-DC12V Rele 12V @03.1.4 10 rele 5A/250VAC 5A/30VDC DSP1.pdf
JV5S-KT 5VDC??? @03.2.1 15 rele TAKAMISAWA 5A/250AC 5A/30VDC
M4-5H @03.2.1 5 rele
RY5W-K 5VDC??? @03.2.1 5 rele TAKAMISAWA
VE 5H5-K 5V @03.2.1 10 rele TAKAMISAWA 5A/250VAC 150VDC VE.pdf
ST1-DC5V 5VDC @03.2.1 2 rele 8A/350VAC 8A/30VDC 2000VA 150W ST1.pdf
191TE1A1-12G @03.1.2 94 rele Reed Relay Datasheet
191TE1C1-12G @03.1.2 16 rele Reed Relay Datasheet
24A02C09A @04.1.4 5 rele ITT
65423 60C NC @04.1.1 2 rele
DECO 12V 96190187 @03.3.3 5 rele
DECO 12V 96190189 @03.3.3 4 rele
TTI Rele 12V @04.3.4 4 rele TRP-12VDC-C-C8 avorele
OEG Rele 12V @04.3.4 3 rele PCD12D1MH
Schrack Rele 12V @04.3.4 2 rele RT424F12
DIP Rele 12V @04.3.4 140 rele SIGMA 191TE1A1-12G
DIP Rele 5V @04.3.3 X rele
Elec-Trol RA38815009 @04.1.2 3 rele Reed relay
Elec-Trol RA31171241 @03.1.1 147 rele Reed relay
EZ240D18 SSR @03.3.3 7 rele Solid State Relay 18A/240V 3-15V DC
FTK3L AB012W 12V DC @03.4.3 41 rele 12V DC 250VAC/25A FTR-K3L.pdf
FRM1-2C2 DC 9V @04.3.2 2 rele
FRS1H DC 9V 1A/125VAC @04.3.1 17 rele
HELLA 4RA 003 510-08 DC 12V 30A @04.3.1 1 rele
G4 IDC5 @02.1.1 24 rele OPTO 22 G4 IDC5 10-32VDC in, 5V logic out
G4 IDC5 @02.1.2 24 rele OPTO 22 G4 IDC5 10-32VDC in, 5V logic out
G4 ODC5 @02.2.1 24 rele OPTO 22 G4 ODC5 5V logic in 60V/3A out
G4 ODC5 @02.2.2 24 rele OPTO 22 G4 ODC5 5V logic in 60V/3A out
G4 ODC5 sulake @02.3.1 6 rele OPTO 22 G4 ODC5 sulake
G6EU-134P @03.3.1 19 rele G6EU-134P-US 12VDC 2A/30VDC 0.4A/125VAC
HFE10-2 12H/T-L2 12V @04.3.3 4 rele Miniature 12V 50A/277VAC Latching Relay
ITT Rele 12V @04.3.2 X rele
ITT Rele 24V @04.3.2 X rele ITT Swiss A2420
K3 AB005W 5V @03.3.2 49 rele F&T KE AB005W 20A/250V SPST rele
KU1TF 12V @04.3.2 4 rele KAM LING KU1TF 5A 110VAC 24VDC
Lämpörele KSD301 0C @03.2.2 2 rele lämpökytkin KSD301 250V/10A 0 Degree NC
Lämpörele KSD301 0C @03.2.2 2 rele lämpökytkin KSD301 250V/10A 0 Degree NO
Lämpörele KSD301 5C @03.2.2 2 rele lämpökytkin KSD301 250V/10A 5 Degree NO
Lämpörele KSD301 10C @03.2.2 2 rele lämpökytkin KSD301 250V/10A 10 Degree NO
Lämpörele KSD301 15C @03.2.2 2 rele lämpökytkin KSD301 250V/10A 15 Degree NO
Lämpörele KSD301 20C @03.2.2 2 rele lämpökytkin KSD301 250V/10A 20 Degree NO
Lämpörele KSD301 25C @03.2.3 4 rele lämpökytkin KSD301 250V/10A 25 Degree NC
Lämpörele KSD301 30C @03.2.3 2 rele lämpökytkin KSD301 250V/10A 30 Degree NC
Lämpörele KSD301 30C @03.2.3 2 rele lämpökytkin KSD301 250V/10A 30 Degree NO
Lämpörele KSD301 35C @03.2.3 2 rele lämpökytkin KSD301 250V/10A 35 Degree NO
Lämpörele KSD301 40C @03.2.3 2 rele lämpökytkin KSD301 250V/10A 40 Degree NO
Lämpörele KSD301 45C @03.2.3 2 rele lämpökytkin KSD301 250V/10A 45 Degree NO
Lämpörele KSD301 50C @03.2.4 2 rele lämpökytkin KSD301 250V/10A 50 Degree NO
Lämpörele KSD301 55C @03.2.4 2 rele lämpökytkin KSD301 250V/10A 55 Degree NO
Lämpörele KSD301 65C @03.2.4 2 rele lämpökytkin KSD301 250V/10A 60 Degree NO
Lämpörele KSD9700T 40C @03.2.4 3 rele lämpökytkin KSD9700T. 250V/5A 40 Degree NO
Lämpörele KSD9700 40C @03.2.4 4 rele lämpökytkin KSD9700. 250V/5A 40 Degree NC
Lämpörele TZD-99 99C @03.4.1 14 rele lämpökytkin 99C Datasheet
Lämpörele ASAHI US-603U @03.4.1 1 rele lämpökytkin 100C
Lämpörele TH-100 100C @03.4.1 79 rele lämpökytkin 100C
Lämpörele 128C @03.4.1 8 rele lämpökytkin 128C 250V 10A
Lämpörele 193-398 @03.4.1 4 rele lämpökytkin 98 Degree opening temperature
Lämpörele 413-181 @03.4.1 4 rele lämpökytkin 184 Degree opening temperature
Lämpörele KSD1 @03.4.2 1 rele lämpökytkin KSD1 90
Lämpörele KSD1 @03.4.2 2 rele lämpökytkin KSD1 160
Lämpörele Klixon @03.4.2 1 rele lämpökytkin T20601L80-200 L265-8 P9T
Lämpörele Klixon @03.4.2 20 rele lämpökytkin T-2D704154-16L140-3,5 D4T
Lämpörele L110C @03.4.2 3 rele lämpökytkin R100-19 L110C 8B Elwood Sensors
Lämpörele L240 21-125 @03.4.2 12 rele lämpökytkin Elwood Sensors
M1B - 12H @03.1.1 31 rele 12V 0.55W 220V Rele Datasheet
LRE 2P2T 12V @03.3.1 3 rele 24VDC 2A
MI-SH-105L @03.3.1 34 rele
MSR 200B SSR @02.3.1 1 rele
MSS2-1A24 @03.1.2 25 rele Reed rele 24V Datasheet
OJ-SS-112LMH2 @02.3.2 75 rele 12V 8A/250V SPST OJE.pdf
OPTO-22 SSR 240D25-40 @02.4.1 2 rele 3-32VDC Control
OPTO-22 SSR OAC5A @02.4.1 4 rele 5VDC Logic Control 24-280VAC
S228-1 SSR @02.4.1 1 rele 3.5-8.0V Control 8A/240VAC
RP 100 240 2 SSR @02.4.1 2 rele Electromatic 3-32V Control 2A/240VAC
DP2110 @02.4.1 2 rele 380VAC SSR DP1210.PDF
PCN-124D3MHZ @03.1.2 9 rele 24V SPST-NO 3A 250VAC 30VDC
PRME 15005 DIP Rele @04.3.3 58 rele PRME 15005 C.P. CLARE INT. N.V.
RAV1401 @04.4.2 19 rele RAV4101 8.2VDC S33 ERICSSON
Reed rele @04.1.1 25 rele Single pole reed relay
Reed rele / magneetti 59145-010 @02.6.1 5 rele magneettikytkin/tunnistin Datasheet
Reed rele / magneettitunnistin @02.4.2 50 rele Ovikytkin/tunnistin
Reed rele / magneetti @02.5.2 50 rele Ovimagneetti/tunnistin
Reed rele/Ovikytkin johdolla @02.6.1 1 rele Ovikytkin johdolla
Reed rele/Ovikytkin johdolla @02.6.2 1 rele Ovikytkin johdolla
RELE @04.2.1 X rele
Rele CLARE @04.4.1 X rele
RELEITÄ @04.2.2 X rele
RFT Reed Rele 1.5V/40mA @04.3.3 3 rele RFT Reedrelay 3 x ein - 242 47740 8030 R8003
SA1025 SSR @02.3.1 1 rele 10A/240VAC 3-32VDC Control
SDS S2L-5V @04.1.2 1 rele Rele piirilevyllä
Siemens SSR ELR V23103-S2232-B302 @02.3.1 2 rele
Celduc SSR @02.3.1 2 rele 10A/380V 3-30V DC Control
Siemens V23016-C0006-A101 @04.1.2 9 rele Piirilevyrele ja tuki
Siemens V23027-B0006-A101 @04.1.2 2 rele Piirilevyrele
Siemens V23026-A1002-B201 @04.1.3 40 rele 12V Piirilevyrele
SCHRACK RP 420012 @04.1.3 1 rele 12V Rele 8A/250VAC
TAKAMISAWA NA12W-K @04.1.3 26 rele 12V Piirilevyrele Datasheet
C93402-MT Alcatel @04.1.3 16 rele 12V Piirilevyrele Datasheet
Phoenix Contact 29 61 422 @65.3.3 1 rele 220VAC 16A/250VAC DPDT Piirilevyrele
JQX-115F @65.3.3 2 rele 24V 12A/250VAC SPDT Piirilevyrele
Panasonic ALFG2PF12 @65.3.3 2 rele 12V 31A/250VAC Piirilevyrele
PCFN-112H2MG @65.3.3 6 rele 12V 22A/277VAC Tyco Electronics Piirilevyrele
RY210012 @04.1.3 5 rele 12V Piirilevyrele
RT314012 @65.3.3 2 rele 12VDC 16A/250VAC DPST Schrack Piirilevyrele
RT314110 @02.3.2 40 rele 110VDC Piirilevyrele
RT314730 @04.1.4 15 rele 230VAC Piirilevyrele
RT33L012 @65.3.3 2 rele 12VDC 16A/250VAC DPST Schrack Piirilevyrele
RZ03-1C4-0012 @65.3.3 2 rele 12VDC 16A/250VAC DPDT Schrack Piirilevyrele
Solenoidi @04.4.3 X rele FH7-5034, muita
Solenoidi @04.5.1 X rele Lineaari- kierto- solenoideja
Sähkömagneetti @04.2.2 1 rele KUHNKE HT-D25-F 24VDC
W65RPCX-3 @04.4.3 3 rele 24V DC Piirilevyrele 250V/10A
R7394-I @04.3.1 16 rele ELEC-TROL R7394-I reed rele
T9GV1L14-12 @04.4.3 3 rele 12VDC 30A 250V
T92P7D22-12 @04.4.2 1 rele 12VDC DPDT 30A/277VAC 20A/28VDC
V23040-A0001-B201 V23040-A0002-B201 @04.3.1 6 rele Siemens 5V reed rele 12V rele
V23040-A0002-B201 @04.3.1 1 rele Siemens 12V reed rele
Retrokomponentit
AA112 @22.1.1 3 diodi
2AA119 @22.1.1 4 diodi
AA119 @22.1.1 13 diodi
AA134 @22.1.1 1 diodi
AA135 @22.1.1 2 diodi
AAZ15 @22.1.2 150 diodi
A979 @22.1.2 3 transistori
AC03B 03L @22.1.2 2 transistori
ACY24 @22.1.2 5 transistori
AD149 @22.1.3 5 transistori
AD161/AD162 @22.1.3 1 transistori Matched pair?
AD162 @22.1.3 6 transistori
ADZ11 @22.1.3 1 transistori
ASY27 @22.1.4 46 transistori
ASY75 @22.1.4 3 transistori
ASY80 @22.1.4 3 transistori
ASZ16 @22.1.4 2 transistori
AY102 @22.1.4 3 transistori
AC122 @22.2.1 6 transistori
AC124 @22.2.1 1 transistori
AC126 @22.2.1 2 transistori
AC127 @22.2.1 1 transistori
AC128 @22.2.1 3 transistori
AC131 @22.2.2 2 transistori
AC141B @22.2.2 1 transistori
AC151 @22.2.2 9 transistori
AC153K @22.2.2 1 transistori
AC154 @22.2.3 2 transistori
AC171 @22.2.3 1 transistori
AC175 @22.2.3 1 transistori
AC187 @22.2.3 22 transistori
AC187-K @22.2.3 1 transistori
AC188 @22.2.3 3 transistori
AD136 @22.2.4 29 transistori
AD161 @22.2.4 2 transistori
AF106 @22.3.1 6 transistori
AF114 @22.3.1 2 transistori
AF115 @22.3.1 2 transistori
AF118 @22.3.1 14 transistori
AF121 @22.3.2 1 transistori
AF125 @22.3.2 1 transistori
AF126 @22.3.2 19 transistori
AF127 @22.3.2 1 transistori
AF137 @22.3.3 1 transistori
AF180 @22.3.3 1 transistori
AF185 @22.3.3 2 transistori
AF239 @22.3.3 14 transistori
GP297-1 @22.3.3 2 transistori PNP germanium alloy transistor Datasheet
OA5 @22.3.4 3 diodi
OA7 @22.3.4 8 diodi
OA10 @22.3.4 10 diodi 100mA/30V Mullard Germanium signal diode
OA70 @22.3.4 5 diodi
OA72 @22.3.4 4 diodi
OA73 @22.3.4 6 diodi
OA81 @22.4.1 2 diodi
OA85 @22.4.1 1 diodi
OA95 @22.4.1 80 diodi DO-7 500mA/115V Low threshold Germanium diode Datasheet
OA1172 @22.4.1 6 diodi
OAZ201 @22.4.1 9 transistori
OAZ202 @22.4.1 1 transistori
OC25 @22.4.2 1 transistori
OC26 @22.4.2 1 transistori
OC45 @22.4.2 1 transistori
OC60 @22.4.2 2 transistori
OC70 @22.4.3 1 transistori
OC71 @22.4.3 4 transistori
OC73 @22.4.3 1 transistori
OC74 @22.4.3 1 transistori
OC75 @22.4.4 1 transistori
OC75N @22.4.4 2 transistori
OC79 @22.4.4 1 transistori
OC170 @22.4.4 1 transistori
OY241 @22.4.4 1 diodi
SP198 @22.4.4 2 diodi
4JA10MX210 @22.4.4 2 diodi
SK 0.5/12 @22.4.4 1 diodi
026 @22.5.1 6 transistori
033 @22.5.1 8 transistori
034 @22.5.1 2 transistori
063 @22.5.1 3 transistori
071 @22.5.2 5 transistori
083 @22.5.2 9 transistori
086 @22.5.2 10 transistori
3334 @22.5.2 2 transistori
102 6320 @22.5.3 2 transistori Motorola
102E 6324 @22.5.3 1 transistori TI
1016 6328 @22.5.3 5 transistori TI
2SA30 @22.5.3 2 transistori
2SB112 @22.5.3 1 transistori NEC
2SB163 @22.5.3 2 transistori NEC
2SD789 @22.5.3 1 transistori NEC
2G382 @22.5.3 1 transistori
TD101 @22.5.4 100 transistori
C1702A @22.6.1 71 muisti C1702A
C2708 @22.6.1 6 muisti C2708
C2716 @22.6.1 2 muisti C2716
C2716 @22.6.1 1 muisti C2716-6
C8185 @22.6.2 2 muisti C8185
MC14581CL @22.6.2 4 muisti 4-Bit Arithmetic Logic Unit Datasheet
Sekal. diodi @22.6.2 X diodi Värikoodattuja diodeita
MK4128N-15 @22.6.3 35 muisti 16-Pin DIP 2-chip stacked 128k x 1 DRAM stacked package Datasheet
LF13509D @22.6.3 6 mikropiiri 8-Channel Analog Multiplexer LF1350D-9D.pdf
AH0014CD @22.6.3 1 mikropiiri
AH0152CD @22.6.3 73 mikropiiri
sormiruuveja @22.6.4 7 vastus
5.6 k vastus @22.6.4 150 vastus
6A?U putki @22.6.4 1 putki radioputki
Raytheon 280 313 @22.6.4 1 putki radioputki
2N1175 @22.7.1 7 transistori Datasheet
2N1302 @22.7.1 4 transistori
2N1303 @22.7.1 2 transistori
2N1305 @22.7.1 2 transistori
2N1893 @22.7.1 2 transistori
2N458A @22.7.1 4 transistori
BA101 @22.7.2 1 diodi
BA111 @22.7.2 2 diodi
BA114 @22.7.2 3 diodi
BCY10 ? @22.7.2 2 diodi
C2259 @22.7.2 6 transistori
C73 @22.7.2 1 transistori SONY
C76 @22.7.2 2 transistori SONY
EP1A @22.7.3 0 diodi
GE @22.7.3 0 diodi GE ???
RT33/3 @22.7.3 6 transistori
TI2033A @22.7.3 1 diodi
TI3027 @22.7.3 2 diodi
ITT 5870 S @22.7.4 0 putki Nixie putki Datasheet
Kondensaattoreita @22.8.1 X kondensaattorit
Kondensaattoreita @22.8.2 X kondensaattorit
Nuppeja @22.8.3 X muut
Kytkimiä @22.8.4 X muut Putkiaikaisia kytkimiä
Kiteitä @22.9.1 X muut
Eristeitä @22.9.2 X muut
Kiinnitysosia @22.9.2 X muut Puolijohteiden kiinnitysmuttereita
Sekalaista @22.9.3 X muut
Putkikantoja @22.9.4 X muut
Kondensaattoreita @22.10.1 X kondensaattorit
Kondensaattoreita @22.10.2 X kondensaattorit
Kondensaattoreita @22.10.3 X kondensaattorit
Kondensaattoreita @22.10.4 X kondensaattorit
Sulakerasioita @22.11.1 X muut
Liittimiä @22.11.2 X muut
Vastuksia @22.11.3 X kondensaattorit
Vastuksia @22.11.4 X kondensaattorit
Putkia @22.12.1 X muut
Putkia @22.12.2 X muut
Releitä @22.12.3 X rele
Rimoja @22.12.4 X muut
Sekalaista @34.1.1 X muut Laskureita,kiertokytk,läpivienti yms.
Automaattisulakkeita @34.1.2 11 sulakkeet
Sekalaisia liittimiä @34.2.1 X liittimet mm. antenniliittimiä
Trimmeri 250R @34.3.1 12 vastus RUWIDO
Trimmeri 500R @34.3.1 19 vastus RUWIDO
Trimmeri 1k @34.3.1 53 vastus RUWIDO
Trimmeri 5k @34.3.2 6 vastus RUWIDO
Trimmeri 10k @34.3.2 35 vastus RUWIDO
Trimmeri 2M @34.3.2 1 vastus
Trimmeri koteloita @34.3.2 X vastus RUWIDO
Sulakkeet
Lasiputkisulake 5x20mm T 50mA @33.1.1 20 sulake
Lasiputkisulake 5x20mm F 100mA @33.1.1 20 sulake
Lasiputkisulake 5x20mm T 100mA @33.1.1 20 sulake
Lasiputkisulake 5x20mm F 125mA @33.1.1 20 sulake
Lasiputkisulake 5x20mm T 125mA @33.1.1 20 sulake
Lasiputkisulake 5x20mm F 160mA @33.1.2 20 sulake
Lasiputkisulake 5x20mm T 160mA @33.1.2 20 sulake
Lasiputkisulake 5x20mm F 200mA @33.1.2 20 sulake
Lasiputkisulake 5x20mm T 200mA @33.1.2 20 sulake
Lasiputkisulake 5x20mm F 250mA @33.1.2 20 sulake
Lasiputkisulake 5x20mm T 250mA @33.1.2 20 sulake
Lasiputkisulake 5x20mm F 315mA @33.1.3 20 sulake
Lasiputkisulake 5x20mm T 315mA @33.1.3 20 sulake
Lasiputkisulake 5x20mm F 400mA @33.1.3 20 sulake
Lasiputkisulake 5x20mm T 400mA @33.1.3 20 sulake
Lasiputkisulake 5x20mm F 500mA @33.1.3 20 sulake
Lasiputkisulake 5x20mm T 500mA @33.1.3 20 sulake
Lasiputkisulake 5x20mm F 630mA @33.1.4 20 sulake
Lasiputkisulake 5x20mm T 630mA @33.1.4 20 sulake
Lasiputkisulake 5x20mm F 700mA @33.1.4 20 sulake
Lasiputkisulake 5x20mm T 700mA @33.1.4 20 sulake
Lasiputkisulake 5x20mm F 800mA @33.2.1 20 sulake
Lasiputkisulake 5x20mm M 800mA @33.2.1 20 sulake
Lasiputkisulake 5x20mm T 800mA @33.2.1 40 sulake
Lasiputkisulake 5x20mm F 1A @33.2.1 17 sulake
Lasiputkisulake 5x20mm T 1A @33.2.1 20 sulake
Lasiputkisulake 5x20mm F 1.25A @33.2.2 20 sulake
Lasiputkisulake 5x20mm T 1.25A @33.2.2 17 sulake
Lasiputkisulake 5x20mm F 1.4A @33.2.2 20 sulake
Lasiputkisulake 5x20mm T 1.4A @33.2.2 20 sulake
Lasiputkisulake 5x20mm F 1.6A @33.2.3 17 sulake
Lasiputkisulake 5x20mm M 1.6A @33.2.3 20 sulake
Lasiputkisulake 5x20mm T 1.6A @33.2.3 20 sulake
Lasiputkisulake 5x20mm F 1.8A @33.2.3 20 sulake
Lasiputkisulake 5x20mm T 1.8A @33.2.3 20 sulake
Lasiputkisulake 5x20mm F 2A @33.2.4 20 sulake
Lasiputkisulake 5x20mm M 2A @33.2.4 20 sulake
Lasiputkisulake 5x20mm T 2A @33.2.4 20 sulake
Lasiputkisulake 5x20mm F 2.5A @33.2.4 20 sulake
Lasiputkisulake 5x20mm M 2.5A @33.2.4 20 sulake
Lasiputkisulake 5x20mm T 2.5A @33.2.4 20 sulake
Lasiputkisulake 5x20mm F 3.15A @33.3.1 20 sulake
Lasiputkisulake 5x20mm M 3.15A @33.3.1 20 sulake
Lasiputkisulake 5x20mm T 3.15A @33.3.1 20 sulake
Lasiputkisulake 5x20mm F 4A @33.3.1 20 sulake
Lasiputkisulake 5x20mm M 4A @33.3.1 20 sulake
Lasiputkisulake 5x20mm T 4A @33.3.1 20 sulake
Lasiputkisulake 5x20mm F 5A @33.3.2 20 sulake
Lasiputkisulake 5x20mm M 5A @33.3.2 20 sulake
Lasiputkisulake 5x20mm T 5A @33.3.2 20 sulake
Lasiputkisulake 5x20mm F 6.3A @33.3.2 10 sulake
Lasiputkisulake 5x20mm M 6.3A @33.3.2 20 sulake
Lasiputkisulake 5x20mm T 6.3A @33.3.2 20 sulake
Lasiputkisulake 5x20mm F 8A @33.3.3 20 sulake
Lasiputkisulake 5x20mm M 8A @33.3.3 20 sulake
Lasiputkisulake 5x20mm T 8A @33.3.3 20 sulake
Lasiputkisulake 5x20mm F 10A @33.3.3 20 sulake
Lasiputkisulake 5x20mm T 10A @33.3.3 20 sulake
Lasiputkisulake 5x20mm F 16A @33.3.4 20 sulake
Lasiputkisulake 5x20mm M 16A @33.3.4 20 sulake
Lasiputkisulake 5x20mm T 16A @33.3.4 20 sulake
Lasiputkisulake 5x20mm F 5A @33.4.1 100 sulake
Lasiputkisulake 5x20mm F 10A @33.4.1 100 sulake
Lasiputkisulake 5x20mm F 15A @33.4.2 100 sulake
Lasiputkisulake 5x20mm F 20A @33.4.2 100 sulake
Lasiputkisulake 5x20mm 32mA @33.9.3 7 sulake
Lasiputkisulake 5x20mm F 100mA @33.8.1 100 sulake
Lasiputkisulake 5x20mm T 100mA @33.9.1 20 sulake
Lasiputkisulake 5x20mm F 125mA @33.9.2 50 sulake
Lasiputkisulake 5x20mm F 200mA @33.9.1 40 sulake
Lasiputkisulake 5x20mm T 200mA @33.9.1 80 sulake
Lasiputkisulake 5x20mm T 200mA @33.9.3 130 sulake
Lasiputkisulake 5x20mm F 250mA @33.10.1 120 sulake
Lasiputkisulake 5x20mm F 315mA @33.8.1 100 sulake
Lasiputkisulake 5x20mm T 315mA @33.9.1 21 sulake
Lasiputkisulake 5x20/25mm 400mA @33.9.3 10 sulake
Lasiputkisulake 4x20mm F 400mA @33.10.1 110 sulake
Lasiputkisulake 5x20mm T 400mA @33.8.3 7 sulake
Lasiputkisulake 5x20mm F 500mA @33.9.3 10 sulake
Lasiputkisulake 5x20mm T 500mA @33.8.3 8 sulake
Lasiputkisulake 5x20mm F 630mA @33.9.4 2 sulake
Lasiputkisulake 5x20mm T 630mA @33.8.3 14 sulake
Lasiputkisulake 5x20mm T 700mA @33.9.1 58 sulake
Lasiputkisulake 5x20mm F 800mA @33.10.1 120 sulake
Lasiputkisulake 5x20mm T 800mA @33.9.4 30 sulake
Lasiputkisulake 5x20mm F 1A @33.10.2 130 sulake
Lasiputkisulake 5x20mm T 1A @33.9.2 34 sulake
Lasiputkisulake 5x20mm F 1.25A @33.9.2 17 sulake
Lasiputkisulake 5x20mm T 1.25A @33.8.2 3 sulake
Lasiputkisulake 5x20mm F 1.4A @33.9.4 40 sulake
Lasiputkisulake 5x20mm F 1.6A @33.4.3 390 sulake
Lasiputkisulake 5x20mm F 1.6A @33.4.4 390 sulake
Lasiputkisulake 5x20mm F 1.6A @33.5.1 260 sulake
Lasiputkisulake 5x20mm T 1.6A @33.8.2 17 sulake
Lasiputkisulake 5x20mm F 1.6A @33.10.2 120 sulake
Lasiputkisulake 5x20mm F 2A @33.10.2 100 sulake
Lasiputkisulake 5x20mm T 2A @33.8.3 16 sulake
Lasiputkisulake 5x20mm F 2.5A @33.8.1 120 sulake
Lasiputkisulake 5x20mm M 2.5A @33.9.4 10 sulake
Lasiputkisulake 5x20mm T 2.5A @33.9.4 7 sulake
Lasiputkisulake 5x20mm F 3A @33.8.2 11 sulake
Lasiputkisulake 5x20mm F 3.15A @33.9.2 90 sulake
Lasiputkisulake 5x20mm T 3.15A @33.8.2 12 sulake
Lasiputkisulake 5x20mm T 4A @33.8.3 6 sulake
Lasiputkisulake 5x20mm F 5A @33.9.4 13 sulake
Lasiputkisulake 5x20mm F 6.3A @33.8.2 12 sulake
Lasiputkisulake 5x20mm T 6.3A @33.8.3 24 sulake
Lasiputkisulake 6.3x32mm T 250mA @33.7.2 2 sulake
Lasiputkisulake 6.3x32mm F 500mA @33.7.2 6 sulake
Lasiputkisulake 6.3x32mm F 0.1A @33.7.1 8 sulake
Lasiputkisulake 6.3x32mm F 0.375A @33.7.1 20 sulake
Lasiputkisulake 6.3x32mm T 0.5A @33.7.1 5 sulake
Lasiputkisulake 6.3x32mm T 0.8A @33.7.3 7 sulake
Lasiputkisulake 6.3x32mm F 1A @33.7.2 8 sulake
Lasiputkisulake 6.3x32mm T 1A @33.7.2 4 sulake
Lasiputkisulake 6.3x32mm F 2.5A @33.7.1 8 sulake
Lasiputkisulake 6.3x32mm F/? 3.15A @33.7.2 7 sulake
Lasiputkisulake 6.3x32mm F 5A @33.7.2 2 sulake
Lasiputkisulake 6.3x32mm T 6.3A @33.7.1 4 sulake
Lasiputkisulake 6.3x32mm 8A @33.7.4 4 sulake
Lasiputkisulake 6.3x32mm F 9A @33.7.1 18 sulake
Lasiputkisulake 6.3x32mm 1.5A @33.7.3 2 sulake
Lasiputkisulake 6.3x32mm 10A/32V @33.7.3 4 sulake
Lasiputkisulake 6x30mm 1A @33.7.3 5 sulake
Lasiputkisulake 6x30mm T 2A @33.7.3 3 sulake
Lasiputkisulake 6x30mm T 10A @33.7.3 8 sulake
Sulakkeet sekalaiset 5x20mm @33.8.2 X sulake
Sulakkeet sekalaiset 6.3x32mm @33.7.4 X sulake
Erikoissulakkeet @33.7.4 X sulake BUSSMAN etc.
PCB sulake F 0.5A @33.5.2 10 sulake
PCB sulake F 1A @33.5.2 10 sulake
PCB sulake F 2A @33.5.2 10 sulake
PCB sulake F 3A @33.5.2 10 sulake
PCB sulake F 3.15A @33.5.2 10 sulake
PCB sulake F 4A @33.5.2 10 sulake
PCB sulake F 5A @33.5.2 10 sulake
PCB sulake F 6.3A @33.5.2 10 sulake
PCB sulake F 8A @33.5.2 10 sulake
PCB sulake F 10A @33.5.2 10 sulake
PCB sulake T 2.5A @33.5.3 8 sulake
PCB sulake T 4A @33.5.3 10 sulake
PCB sulake MF-R020 @33.5.3 10 sulake Sulake Multifuse
PCB sulake 0.125A @33.5.3 300 sulake
PCB sulake T100mA 250VAC @33.5.4 15 sulake
PCB sulake 1.6A @33.5.4 2 sulake palautuva
PCB sulake 2.5A @33.5.4 2 sulake palautuva
PCB sulake T3.15A @33.5.4 5 sulake
Sulakepidin 5x20mm PCB @33.6.1 60 sulake
Sulakepidin 5x20mm PCB @33.6.2 15 sulake
Sulakepidin 5x20mm PCB @33.6.2 19 sulake
Sulakepidin 5x20mm juotettava @33.6.2 34 sulake
Sulakepidin 5x20mm PCB @33.6.3 37 sulake
Sulakepidin 5x20mm PCB kannella @33.6.3 30 sulake
Sulakepidin 5x20mm PCB @33.6.4 20 sulake
Sulakepidin 6.3x30mm PCB @33.6.4 10 sulake
Sulakepidin @33.10.4 X sulake
Sulakepidin @33.11.1 X sulake
Sulakepesät johtoon @33.11.2 10 sulake
Automaattisulake @33.10.3 X sulake
Sulakepesät @33.12.1 X sulake
Sulakepesät PCB @33.12.2 X sulake
Tehopuolijohteet
25C2608 @11.1.1 2 transistori TO-3 17A/200V NPN Silicon Power Transistor 2SC2608.PDF
2N1022 @11.7.1 2 transistori TO-3 5A?/55V germanium power transistors Reference Table
2N3055 @11.1.1 44 transistori TO-3 15A/60V NPN Silicon Power Transistor Datasheet
2N3055H @11.1.2 100 transistori TO-3 15A/60V NPN Silicon Power Transistor Datasheet
2N3714 @11.1.3 2 transistori
2N3772 @11.1.3 8 transistori
2N4399 @11.7.3 4 transistori TO-3
2N4904 @11.7.3 1 transistori TO-3
2N4905 @11.7.3 1 transistori TO-3
2N4906 @11.7.3 1 transistori TO-3
2N4914 @11.7.3 1 transistori TO-3
2N5302 @11.7.3 4 transistori TO-3
2N5881 @11.1.3 1 transistori
2N5883 @11.1.3 20 transistori
2N6051 @11.2.1 10 transistori
2N6055 @11.2.1 1 transistori
2N6058 @11.2.1 14 transistori
2N6546 @11.2.2 4 transistori Power NPN
2SD15 @11.2.2 1 transistori TO-3 40V/5A Silicon Power Transistor 2SD15.pdf
2SD299 @11.2.2 1 transistori TO-3 5A/700V Silicon Power Transistor 2SD299.pdf
APT10053LNR @11.3.1 24 transistori TO264 20A/1000V 0.53Ohm Enh. N-Channel MOSFET Datasheet
APT10M25SVR @11.7.2 57 transistori D3PAK 75A/100V 0.025Ohm Enh. N-Channel MOSFET Datasheet
APT20M40BVR @11.7.2 160 transistori TO247 59A/200V 0.04Ohm Enh. N-Channel MOSFET Datasheet
BD181 @11.3.1 14 transistori TO-3 15A/45V NPN Silicon Power Transistor Datasheet
BDW52B @11.4.3 1 transistori TO-3 15A/80V PNP Silicon Power Transistor BDW52.pdf
BDX64A @11.3.1 4 transistori TO-3 12A/80V PNP Silicon Power Darlingtons Datasheet
BDX65A @11.3.1 2 transistori TO-3 12A/80V NPN Silicon Darlington Transistor Datasheet
BDX66B @11.3.2 4 transistori TO-3 16A/100V PNP Silicon Darlington Transistor Datasheet
BDX67B @11.3.2 2 transistori TO-3 16A/100V NPN Silicon Darlington Transistor Datasheet
BDX87B @11.3.2 7 transistori TO-3 12A/80V NPN Silicon Darlington Transistor Datasheet
BDY56 @11.3.3 1 transistori TO-3 15A/120V NPN Silicon Power Transistor BDY56.pdf
BDY90 @11.3.3 1 transistori TO-3 10A/100V High Current NPN Silicon Transistor Datasheet
BU104 @11.3.3 3 transistori TO-3 7A/150V Silicon NPN Power Transistor Datasheet
BU126LUX @11.3.3 2 transistori TO-3 3A/300V Silicon NPN Power Transistors Datasheet
BU208 @11.4.1 3 transistori TO-3 5A/700V NPN Horizontal Deflection Transistor Datasheet
BU208A @11.4.1 14 transistori TO-3 5A/700V NPN Horizontal Deflection Transisto Datasheet
BU526 @11.4.1 1 transistori TO-3 8A/400V Silicon NPN Power Transistors Datasheet
BU526A @11.4.2 1 transistori TO-3 8A/460V Silicon NPN Power Transistors Datasheet
BU626A @11.4.2 3 transistori TO-3 10A/400V NPN Power Switching Transistor Datasheet
BUS13 @11.4.2 3 transistori TO-3 15A/400V Silicon NPN Power Transistors Datasheet
BUW25 @11.4.3 1 transistori TO-3 10A/400V isc Silicon NPN Power Transistor Datasheet
BUX10 @11.4.3 15 transistori TO-3 25A/125V HIGH POWER NPN SILICON TRANSISTOR Datasheet
BUX41 @11.4.3 4 transistori TO-3 15A/200V Switchmode NPN Silicon Power Transistor Datasheet
BUX48 @11.5.1 1 transistori TO-3 15A/400V NPN Silicon Power Transistor Datasheet
IRF253 @11.5.1 1 transistori TO-3 25A 150V 0.12 Ohm N-Channel Power MOSFET Datasheet
IRF451 @11.5.1 2 transistori TO-3 13A 450V 0.4 Ohm N-Channel Power MOSFET Datasheet
IXTK21N100 @11.6.1 100 transistori TO-264AA 21A/1000V 0.55Ohm Enh. N-Channel MOSFET Datasheet
MJ2901 @11.5.1 1 transistori Case 11 15A/40V PNP Power Transistor Datasheet
MJ2955 @11.5.2 9 transistori TO-3 15A/60V PNP Power Transistor Datasheet
MJ3001 @11.5.2 1 transistori TO-3 5A/80C SILICON POWER DARLINGTON TRANSISTORS Datasheet
MJ4033 @11.5.2 5 transistori TO-3 16A/60V NPN Darlington Power Transistor Datasheet
MJ411 @11.5.3 1 transistori TO-3 5A/300V NPN Power Transistor Datasheet
MJ413 @11.5.3 4 transistori TO-3 10A/400V High-Voltage NPN Transistor Datasheet
MJ4502 @11.5.3 3 transistori TO-3 30A/100V PNP Power Transistor Datasheet
MJ802 @11.6.1 20 transistori TO-3 30A/100V NPN Power Transistor Datasheet
MTV32N20E @11.6.2 60 transistori D3PAK 32A/200V 0.075Ohm Enh. N-Channel MOSFET Datasheet
QM50CY-H @11.6.1 1 transistori Custom Mitsubishi Power Darlington 50A/600V Datasheet
QM50CY-H @11.6.2 2 transistori Custom Mitsubishi Power Darlington 50A/600V Datasheet
QM50CY-H @11.6.3 2 transistori Custom Mitsubishi Power Darlington 50A/600V Datasheet
Transistorit
15/80H @23.1.1 2 transistori
16802 @23.1.1 3 transistori
17023 @23.1.1 2 transistori
2601L @23.1.1 4 transistori TI 2601L
311-2 @23.1.1 1 transistori
5022-240 @23.1.1 4 transistori
2N1132 @23.1.2 5 transistori TO-39 PNP 40V 600mA low power
2N1308 @23.1.2 3 transistori TO-5 NPN Ge 25V 300mA
2N1309 @23.1.2 90 transistori TO-5 PNP Ge 30V 300mA
2N1596 @23.1.2 4 transistori TO-39 Thyristor 100V 1.6A
2N1613 @23.1.3 32 transistori TO-39 NPN 75V 500mA
2N1671A @23.1.3 1 transistori TO-5 Unijunction 30V 50mA
2N1711 @23.1.3 85 transistori TO-39 NPN 50V 500mA
2N1893 @23.1.3 10 transistori TO-39 NPN 80V 500mA
2N2102 @23.1.3 2 transistori TO-39 NPN 65V 1A Datasheet
2N2189 @23.1.4 200 transistori TO-58 PNP Ge 40V 30mA
2N2193 @23.1.4 1 transistori TO-39 NPN 50V 1A 800mW
2N2218 @23.2.1 4 transistori TO-39
2N2219 @23.2.1 44 transistori TO-39 NPN 30V 800mA 800mW Datasheet
2N2219A @23.2.1 200 transistori TO-39 NPN 40V 800mA 800mW
2N2222 @23.2.2 23 transistori TO-18 NPN 30V 800mA 500mW
2N2222A @23.2.2 18 transistori TO-18 NPN 40V 800mA 500mW
2N2222AH @23.2.2 50 transistori
2N2369 @23.2.2 21 transistori TO-18 NPN 40V 200mA 360mW Hfe:>20
2N2369A @23.2.2 75 transistori TO-18 NPN 40V 200mA 360mW Hfe:40-120
2N2484 @23.2.3 17 transistori TO-18 NPN 60V 50mA 360mW Hfe:150-900
2N2646 @23.2.3 31 transistori TO-18 PN Unijunction 30V 50mA
2N2904A @23.2.3 3 transistori TO-39 PNP 60V 600mA 800mW Hfe:40-120
2N2905 @23.2.3 100 transistori TO-39 PNP 40V 600mA 800mW Hfe:100-300
2N2905A @23.2.4 80 transistori TO-39 PNP 60V 600mA 800mW Hfe:100-300
2N2906A @23.2.4 16 transistori TO-18 PNP 60V 600mA 400mW Hfe:40-120
2N2907 @23.2.4 8 transistori TO-18 PNP 40V 600mA 400mW Hfe:100-300
2N2907A @23.2.4 48 transistori TO-18 PNP 60V 600mA 400mW Hfe:100-300
2N2924 @23.2.4 10 transistori TO-92 NPN 25V 100mA 360mW Hfe:150-300
2N3019 @23.3.1 5 transistori TO-39 NPN 80V 1A 800mW Hfe:80-400
2N3053 @23.3.1 17 transistori TO-39 NPN 40V 700mA 5W Hfe:25-250
2N3054 @23.3.1 6 transistori TO-66 NPN 55V 4A 25W Hfe:5-180
2N3375 @23.3.1 1 transistori TO-60 NPN 40V
2N3391A @23.3.1 2 transistori TO-92 NPN 25V 500mA 625mW Hfe:250-500
2N3417 @23.3.1 26 transistori TO-92 NPN 50V 500mA 625mW Hfe:180-540
2N3439 @23.3.2 8 transistori TO-39 NPN 350V 1A 10W Hfe:30-160
2N3570 @25.5.4 18 transistori TO-39 50mA/15V NPN Silicon HF Transistor
2N3702 @23.3.2 62 transistori TO-92 PNP 25V 200mA 360mW Hfe:60-300
2N3703 @23.3.2 6 transistori TO-92 PNP 30V 500mA 625mW Hfe:30-150
2N3704 @23.3.2 13 transistori TO-92 NPN 30V 800mA 625mW Hfe:100-300
2N3705 @23.3.2 21 transistori TO-92 NPN 30V 800mA 625mW Hfe:50-150
2N3707 @23.3.2 4 transistori TO-92 NPN 30V 200mA 625mW Hfe:100-550 low noise
2N3708 @23.3.3 78 transistori TO-92 NPN 30V 200mA 625mW Hfe:45-800 low noise
2N3741 @23.3.3 1 transistori TO-66 PNP 80V 4A 25W Hfe:10-200
2N3767 @23.3.3 2 transistori TO-66 NPN 80V 4A 25W Hfe:10-160
2N3819 @23.3.3 15 transistori TO-92 J-FET N-ch 25V IDSS:2-20mA
2N3823 @23.3.3 1 transistori TO-92 J-FET N-ch 30V IDSS:4mA
2N3866 @23.3.3 11 transistori TO-39 NPN RF 30V 400mA 5W Hfe:10-200
2N3904 @23.3.4 600 transistori TO-92 NPN 40V 200mA 625mW Hfe:30-300
2N3904B @23.3.4 5 transistori
2N3906 @23.4.1 240 transistori TO-92 PNP 40V 200mA 625mW Hfe:30-300
2N3906B @23.4.1 5 transistori
2N3906H @23.4.1 100 transistori
2N3916 @23.4.1 3 transistori
2N4033 @23.4.2 1 transistori TO-39 PNP 80V 1A 800mW Hfe:30-300
2N4036 @23.4.2 5 transistori TO-39 PNP 65V 1A 5W Hfe:20-200
2N4037 @23.4.2 2 transistori TO-39 PNP 40V 1A 5W Hfe:15-250
2N4058 @23.4.2 5 transistori TO-92 PNP 30V 200mA 625mW Hfe:100-550
2N4092/E174 @23.4.2 8 transistori TO-18 J-FET N-ch 40V IDSS:15mA Rds(on):<50R
E112 @23.4.2 7 transistori
2N4101 @23.4.3 1 transistori
2N4221 @23.4.3 4 transistori TO-72 J-FET N-ch 15V IDSS:6mA Rds(on):<50R
2N4250 @23.4.3 11 transistori TO-106 PNP 40V 200mW
2N4393 @23.4.3 12 transistori TO-18 J-FET N-ch 40V IDSS:5-30mA Rds(on):<100R
2N4401 @23.4.3 13 transistori TO-92 NPN 40V 600mA 625mW Hfe:20-300
2N4403 @23.4.3 16 transistori TO-92 PNP 40V 600mA 625mW Hfe:20-300
2N4441 @23.4.4 11 transistori TO-127 8A/75V Silicon Controlled Rectifier SCR 2N4441-2N4444.pdf
2N4442 @23.4.4 1 transistori TO-127 8A/300V Silicon Controlled Rectifier SCR 2N4441-2N4444.pdf
2N4443 @23.4.4 1 transistori TO-127 8A/500V Silicon Controlled Rectifier SCR 2N4441-2N4444.pdf
2N4444 @23.4.4 10 transistori TO-127 8A/700V Silicon Controlled Rectifier SCR 2N4441-2N4444.pdf
2N4856 @23.5.1 1 transistori TO-92
2N4870 @23.5.1 24 transistori TO-92 UJT unijuntion transistor
2N4871 @23.5.1 42 transistori TO-92 UJT unijuntion transistor Motorola 2N487I?
2N4916 @23.5.1 23 transistori TO-106 PNP 30V 100mA 200mW
2N4992 @23.5.1 1 transistori TO-92 Silicon Bilateral Switch (SBS) Datasheet
2N5061 @23.5.2 2 transistori TO-92 SCR 60V
2N5064 @23.5.2 82 transistori TO-92 SCR 200V
2N5087 @23.5.2 230 transistori TO-92 PNP 50V 50mA 625mW Hfe:250-800
2N5109 @23.5.2 2 transistori TO-93 NPN RF 20V 400mA 1W Hfe:5-210
2N5190 @23.5.3 6 transistori TO-225 NPN 40V 4A 40W Hfe:25-100
2N5191 @23.5.3 1 transistori TO-225 NPN 60V 4A 40W Hfe:25-100
2N5192 @23.5.3 5 transistori TO-225 NPN 80V 4A 40W Hfe:25-100
2N5193 @23.5.3 19 transistori TO-126 NPN 40V 4A 40W Hfe:25-100
2N5209 @23.5.4 3 transistori TO-92 NPN 50V 50mA 1W Hfe:100-300
2N5210 @23.5.4 7 transistori TO-92 NPN 50V 50mA 1W Hfe:200-600
2N5322 @23.5.4 70 transistori TO-39 PNP 75V 2A 10W Hfe:10-175
2N5401 @23.5.4 26 transistori TO-92 PNP 150V 300mA 630mW Hfe:50-240
2N5416 @23.5.4 2 transistori TO-39 PNP 300V 1A 1W Hfe:30-120
2N5457 @23.6.1 2 transistori TO-92 J-FET N-ch 25V IDSS:1-5mA
2N5461 @23.6.1 2 transistori TO-92 J-FET N-ch 40V IDSS:2-9mA
2N5462 @23.6.1 9 transistori TO-92 J-FET N-ch 40V IDSS:4-16mA
2N5551 @23.6.1 23 transistori TO-92 NPN 160V 600mA 625mW Hfe:30-250
2N5551B @23.6.1 5 transistori
2N5682 @23.6.1 1 transistori TO-39 NPN 120V 1A 1W Hfe:40-150
2N6028 @23.6.2 800 transistori TO-92 PUT PUJT Programmable Unijunction Transistor 2N6028.pdf
2N6073A @23.6.3 25 transistori TO-225 Triac 400V 4A
2N6080 @23.6.3 8 transistori NPN RF 36V 1A 2N6080.pdf
2N6081 @23.6.3 4 transistori NPN RF 36V 2.5A 2N6080.pdf
2N6084 @23.6.3 3 transistori NPN RF 36V 6A 2N6080.pdf
2N6155 @23.6.3 2 transistori TO-127 Triac 400V 10A
2N6164 @23.6.3 1 transistori TO-48-ISO Triac 400V 30A
2N6237 @23.6.4 1 transistori
2N6516 @23.6.4 1 transistori TO-92 NPN 300V 500mA 625mW Hfe:30-270
2N6553 @23.6.4 5 transistori TO-202 NPN 100V 1A 2W Hfe:30-300
2N6556 @23.6.4 4 transistori TO-202 PNP 100V 1A 2W Hfe:30-300
2N6660 @23.6.4 7 transistori TO-39 MOSFET N-ch 60V 1A 5W Vgs(th):0.8-2.4V
2N7000 @23.7.1 40 transistori TO-92 MOSFET N-ch 60V 200mA 350mW Vgs(th):0.8-3V Rds(on):<5R
2N7000L @23.7.1 20 transistori
2N706A @23.7.1 10 transistori TO-18 NPN 15V 50mA 1W Hfe:20-60
2N708 @23.7.1 100 transistori TO-18 NPN 15V 200mA 360mW Hfe:15-120
2N918 @23.7.1 29 transistori TO-72 NPN RF 15V 50mA 200mW Hfe:>20
2N956 @23.7.1 1 transistori TO-18 NPN 50V 500mA 500mW Hfe:>100
2S302 @23.7.2 1 transistori
2SA1015 @23.7.2 16 transistori TO-92 PNP 50V 200mA 400mW Hfe:70-400
2SA1170 @23.7.2 3 transistori MT-200 PNP Power Transistor 17A/200V Datasheet
2SA1371 @23.7.3 8 transistori TO-92 NPN 300V 100mA 1W Hfe:40-320
2SA1568 @23.7.3 27 transistori TO-220 PNP 12A/60V Hfe:50min
2SA1837 @23.7.3 1 transistori TO-220 PNP 230V 1A 20W Hfe:100-320
2SA562 @23.7.3 2 transistori TO-92 PNP 30V 500mA 500mW Hfe:70-240
2SA733 @23.7.3 9 transistori TO-92 PNP 50V 500mA 625mW Hfe:90-600
2SB822R @23.7.3 1 transistori
2SC1815 @23.7.4 29 transistori TO-92 NPN 50V 150mA Datasheet
2SC1959 @23.7.4 2 transistori TO-92 PNP 30V 500mA 500mW Hfe:70-400
2SC2389 @23.7.4 10 transistori TO-92 NPN 120V 50mA 300mW Hfe:180-820
2SC2774 @23.7.4 3 transistori MT-200 NPN 200V 17A 200W Hfe:50-140
2SC2901 @23.7.4 1 transistori
2SC3113 @23.8.1 1 transistori
2SC33725 @23.8.1 2 transistori
2SC3402 @23.8.1 1 transistori
2SC3468 @23.8.1 5 transistori TO-92 NPN 300V 100mA 1W Hfe:>40
2SC3656 @23.8.2 1 transistori
2SC3790 @23.8.2 1 transistori
2SC38-C @23.8.2 6 transistori
2SC3800 @23.8.2 1 transistori
2SC3973B @23.8.3 6 transistori TO-220F NPN 500V 7A 45W Hfe:>15
2SC438 @23.8.3 2 transistori 9014 C 438
2SC945 @23.8.3 4 transistori TO-92 NPN 50V 100mA 250mW Hfe:90-600
2SD1196 @23.8.3 1 transistori
2SD1276A @23.8.3 1 transistori
2SD965 @23.8.3 1 transistori Mitsubishi
2ST501T @23.8.3 8 transistori TO-220 4A/500V NPN Darlington Transistor 2ST501T.pdf
3N201 @23.8.4 4 transistori
40823 @23.8.4 5 transistori RCA N-Mosfet
71T2 @23.8.4 2 transistori CB-44 Silicon NPN 2A/60V Datasheet
A42B @23.8.4 5 transistori
A92B @23.8.4 5 transistori
B601 @23.9.1 1 transistori
B703 @23.9.1 1 transistori
B795L @23.9.1 1 transistori
BB204G @23.9.1 10 transistori TO-92 VHF variable capacitance double diode 30V
BC107B @23.9.1 24 transistori TO-18 NPN 45V 200mA 600mW Hfe:200-450
BC108 @23.9.2 6 transistori TO-18 NPN 25V 200mA 600mW Hfe:>40
BC108B @23.9.2 160 transistori TO-18 NPN 25V 200mA 600mW Hfe:200-450
BC109 @23.9.2 11 transistori TO-18 NPN 25V 200mA 600mW Hfe:>40
BC109B @23.9.2 85 transistori TO-18 NPN 25V 200mA 600mW Hfe:200-450
BC109C @23.9.3 150 transistori TO-18 NPN 25V 200mA 600mW Hfe:420-800
BC119 @23.9.3 30 transistori TO-39 NPN 30V 1A 5W Hfe:40-120
BC148 @23.9.3 4 transistori SOT-25 NPN 20V 100mA 300mW Hfe:90-170
BC148B @23.9.3 15 transistori SOT-25 NPN 20V 100mA 300mW Hfe:150-270
BC148C @23.9.3 2 transistori SOT-25 NPN 20V 100mA 300mW Hfe:270-500
BC157A @23.9.4 2 transistori
BC158 @23.9.4 1 transistori
BC158B @23.9.4 4 transistori TO-18 PNP 25V 100mA 300mW Hfe:>180
BC159 @23.9.4 15 transistori TO-18 PNP 20V 100mA 300mW Hfe:>120
BC161-6 @23.9.4 78 transistori TO-39 PNP 60V 1A 4W Hfe:>40
BC161-16 @23.10.1 40 transistori TO-39 PNP 60V 1A 4W Hfe:100-250
BC171A @23.10.1 1 transistori
BC171B @23.10.1 1 transistori
BC177A @23.10.1 12 transistori TO-18 PNP 45V 100mA 300mW Hfe:125-250
BC178 @23.10.1 6 transistori TO-18 PNP 25V 100mA 300mW Hfe:>60
BC178A @23.10.1 1 transistori
BC182 @23.10.2 60 transistori TO-92 NPN 50V 100mA 300mW Hfe:80-500
BC183 @23.10.2 80 transistori TO-92 NPN 30V 100mA 300mW Hfe:>40
BC183A @23.10.2 1 transistori
BC183B @23.10.2 1 transistori
BC192 @23.10.2 1 transistori
BC212B @23.10.3 5 transistori
BC237 @23.10.3 200 transistori TO-92 NPN 45V 100mA 350mW Hfe:120-800
BC237B @23.10.3 100 transistori TO-92 NPN 45V 100mA 350mW Hfe:200-460
BC238 @23.10.3 1 transistori TO-92 NPN 25V 100mA 350mW Hfe:120-800
BC238B @23.10.4 32 transistori TO-92 NPN 25V 100mA 350mW Hfe:180-460
BC238C @23.10.4 1 transistori TO-92 NPN 25V 100mA 350mW Hfe:380-800
BC303-5 @23.10.4 1 transistori
BC307 @23.10.4 1 transistori
BC307A @23.10.4 8 transistori TO-92 PNP 45V 100mA 350mW Hfe:120-220
BC307B @23.10.4 58 transistori TO-92 PNP 45V 100mA 350mW Hfe:180-460
BC308BT @23.11.1 13 transistori TO-92 PNP 25V 100mA 350mW Hfe:180-460
BC308C @23.11.1 1 transistori TO-92 PNP 25V 100mA 350mW Hfe:380-800
BC317 @23.11.1 24 transistori TO-92 NPN 45V 150mA 350mW Hfe:>40
BC327 @23.11.1 25 transistori TO-92 PNP 45V 800mA 625mW Hfe:60-600
BC327-25 @23.11.1 1 transistori
BC337 @23.11.2 250 transistori TO-92 NPN 45V 800mA 625mW Hfe:60-600
BC337A @23.11.2 19 transistori TO-92 NPN 60V 800mA 625mW Hfe:60-600
BC337B @23.11.2 40 transistori
BC337-25 @23.11.2 99 transistori TO-92 NPN 45V 800mA 625mW Hfe:160-400
BC337-40 @23.11.2 48 transistori TO-92 NPN 45V 800mA 625mW Hfe:250-630
BC338N @23.11.3 1 transistori
BC414 @23.11.3 1 transistori
BC416B @23.11.3 300 transistori TO-92 PNP 45V 100mA 500mW Hfe:220-475
BC416C @23.11.3 160 transistori TO-92 PNP 45V 100mA 500mW Hfe:420-800
BC450A @23.11.4 11 transistori TO-92 PNP 100V 300mA 625mW Hfe:120-220
BC487 @23.11.4 5 transistori TO-92 NPN 60V 500mA 625mW Hfe:60-400
BC487A @23.11.4 250 transistori TO-92 NPN 60V 500mA 625mW Hfe:100-250
BC487C @23.11.4 120 transistori
BC516 @23.11.4 14 transistori TO-92 PNP Darlington 30V 1A 625mW Hfe:>30000
BC517 @23.12.1 230 transistori TO-92 NPN Darlington 30V 1A 625mW Hfe:>30000
BC531 @23.12.1 2 transistori FBC531
BC533 @23.12.1 20 transistori TO-92 NPN 160V 100mA 625mW Hfe:>80
BC538-16 @23.12.1 12 transistori
BC546 @23.12.1 46 transistori TO-92 NPN 65V 100mA 625mW Hfe:>80
BC546A @23.12.2 180 transistori TO-92 NPN 65V 100mA 625mW Hfe:110-220
BC547 @23.12.2 30 transistori TO-92 NPN 45V 100mA 625mW Hfe:>80
BC547A @23.12.2 800 transistori TO-92 NPN 45V 100mA 625mW Hfe:110-220
BC547B @23.12.3 900 transistori TO-92 NPN 45V 100mA 625mW Hfe:200-450
BC547B @23.12.4 400 transistori TO-92 NPN 45V 100mA 625mW Hfe:200-450
BC547C @23.12.4 300 transistori TO-92 NPN 45V 100mA 625mW Hfe:420-800
BC548 @24.1.1 4 transistori TO-92 NPN 30V 100mA 625mW Hfe:>80
BC548A @24.1.1 7 transistori TO-92 NPN 30V 100mA 625mW Hfe:110-220
BC548B @24.1.1 200 transistori TO-92 NPN 30V 100mA 625mW Hfe:200-450
BC548C @24.1.1 160 transistori TO-92 NPN 30V 100mA 625mW Hfe:420-800
BC549B @24.1.2 125 transistori TO-92 NPN 30V 100mA 625mW Hfe:200-450 low noise
BC549C @24.1.2 14 transistori TO-92 NPN 30V 100mA 625mW Hfe:420-800 low noise
BC550B @24.1.2 20 transistori TO-92 NPN 45V 100mA 625mW Hfe:200-450 low noise
BC557A @24.1.2 10 transistori TO-92 PNP 45V 100mA 625mW Hfe:110-220
BC557C @24.1.2 7 transistori TO-92 PNP 45V 100mA 625mW Hfe:420-800
BC557B @24.1.3 800 transistori TO-92 PNP 45V 100mA 625mW Hfe:200-450
BC557B @24.1.4 600 transistori TO-92 PNP 45V 100mA 625mW Hfe:200-450
BC558 @24.1.4 1 transistori
BC558A @24.1.4 13 transistori TO-92 PNP 30V 100mA 625mW Hfe:110-220
BC558B @24.2.1 800 transistori TO-92 PNP 30V 100mA 625mW Hfe:200-450
BC558C @24.2.1 5 transistori TO-92 PNP 30V 100mA 625mW Hfe:420-800
BC560B @24.2.1 1 transistori
BC637 @24.2.2 30 transistori TO-92 NPN 60V 1A 625mW Hfe:40-160
BC638 @24.2.2 24 transistori TO-92 PNP 60V 1A 625mW Hfe:40-160
BC639 @24.2.2 32 transistori TO-92 NPN 80V 1A 625mW Hfe:40-160
BC639 @24.2.2 100 transistori TO-92 NPN 80V 1A 625mW Hfe:40-160
BC640 @24.2.2 31 transistori TO-92 PNP 80V 1A 625mW Hfe:40-160
BCY59 @24.2.2 12 transistori TO-18 NPN 45V 200mA 1W Hfe:
BD106 @24.2.3 5 transistori
BD131 @24.2.3 2 transistori
BD132 @24.2.3 16 transistori TO-126 PNP 45V 3A 15W Hfe:>40
BD135 @24.2.3 15 transistori TO-126 NPN 45V 1.5A 12W Hfe:40-250
BD136 @24.2.3 9 transistori TO-126 PNP 45V 1.5A 12W Hfe:40-250
BD137 @24.2.3 4 transistori TO-126 NPN 60V 1.5A 12W Hfe:40-250
BD138 @25.5.3 5 transistori
BD139 @24.2.4 220 transistori TO-126 NPN 80V 1.5A 12W Hfe:40-250
BD140 @24.2.4 33 transistori TO-126 PNP 80V 1.5A 12W Hfe:40-250
BD140-16 @24.2.4 100 transistori TO-126 PNP 80V 1.5A 12W Hfe:100-250
BD165 @24.2.4 1 transistori
BD177 @24.3.1 7 transistori TO-126 NPN 60V 3A 30W Hfe:40-250
BD230 @24.3.1 250 transistori TO-126 NPN 60V 1.5A 12W Hfe:40-250
BD231 @24.3.2 50 transistori TO-126 PNP 80V 1.5A 12W Hfe:40-250
BD240 @25.5.3 4 transistori BD240A BD240B
BD241 @25.5.3 4 transistori
BD242B @24.3.2 50 transistori TO-220C PNP 80V 3A 40W Hfe:>25 Datasheet
BD243A @25.5.3 16 transistori
BD244 @25.5.3 6 transistori BD244A BD244B
BD249C @24.3.2 4 transistori TO-218 NPN 100V 25A 125W Hfe:>10
BD262 @25.5.3 4 transistori
BD278A @24.3.2 1 transistori TO-220 NPN 45V 10A 125W Hfe: Data from web-bcs.com
BD440 @24.3.4 1 transistori
BD529 @24.3.3 6 transistori TO-152 NPN 100V 2A 10W Hfe:>30
BD607 @24.3.3 1 transistori
BD675A @24.3.3 7 transistori TO-126 NPN Darlington 45V 4A 40W Hfe:>750
BD677 @24.3.3 2 transistori
BD677A @24.3.3 40 transistori TO-126 NPN Darlington 60V 4A 40W Hfe:>750
BD679 @24.3.4 200 transistori TO-126 NPN Darlington 80V 4A 40W Hfe:>750
BD679A @24.3.4 9 transistori TO-126 NPN Darlington 80V 4A 40W Hfe:>750
BD680 @24.4.1 9 transistori TO-126 PNP Darlington 80V 4A 40W Hfe:>750
BD681 @24.4.1 8 transistori TO-126 NPN Darlington 100V 4A 40W Hfe:>750
BD682 @24.4.1 2 transistori
BD697A @24.4.1 4 transistori TO-127 NPN Darlington 60V 8A 70W Hfe:>750
BD698 @24.4.1 1 transistori
BD897A @24.4.2 3 transistori
BD911 @24.4.2 2 transistori TO-220 15A/100V NPN
BDV65A @24.4.2 4 transistori SOT-93 NPN Darlington 80V 12A 125W Hfe:>1000
BDW83C @24.4.2 1 transistori
BDX34B @24.4.2 1 transistori
BF167 @24.4.3 8 transistori TO-72 NPN RF 30V 25mA 130mW Hfe:>30
BF173 @24.4.3 1 transistori
BF199 @24.4.3 20 transistori TO-92 NPN RF 25V 50mA 350mW Hfe:>38
BF200 @24.4.3 1 transistori
BF245 @24.4.3 14 transistori TO-92
BF245A @24.4.4 10 transistori
BF245B @24.4.4 20 transistori
BF245C @24.4.4 80 transistori
BF256 @24.4.4 4 transistori
BF256B @24.4.4 15 transistori
BF256C @24.4.4 14 transistori
BF258 @24.5.1 12 transistori
BF292A @24.5.1 52 transistori TO-39 NPN 15V 100mA 800mW Hfe:>30
BF324 @24.5.1 5 transistori TO-92 PNP RF 30V 25mA 300mW Hfe:>25
BF336 @24.5.1 4 transistori
BF337 @24.5.1 5 transistori
BF414 @24.5.2 6 transistori
BF423 @24.5.2 9 transistori
BF457 @24.5.2 1 transistori
BF458 @24.5.2 9 transistori
BF459 @24.5.2 7 transistori
BF494 @24.5.2 1 transistori F494
BF494B @24.5.3 100 transistori
BF495L @24.5.3 2 transistori
BF959 @24.5.3 1 transistori
BF981 @24.5.3 12 transistori
BFP26 @24.5.3 34 transistori TO-92 200mA 300V PNP Silicon Transistor
BFR40 @24.5.3 1 transistori
BFR80 @24.5.4 9 transistori
BFR91A @25.5.4 1 transistori
BFW11 @24.5.4 15 transistori
BFW30 @24.5.4 5 transistori
BFW92 @24.5.4 7 transistori
BFX89 @24.5.4 2 transistori
BFY51 @24.5.4 2 transistori
BFY52 @24.6.1 2 transistori
BFY56 @24.6.1 41 transistori
BFY56A @24.6.1 20 transistori
BFY90 @24.6.1 30 transistori TO-72 NPN RF 15V 25mA 300mW Hfe:>25
BI099 @24.6.1 2 transistori NEC B1099?
BR101 BRY39 @24.6.1 6 transistori
BS170 @24.6.2 400 transistori TO-92 MOSFET N-ch 60V 500mA 830mW Vgs(th):0.8-3V
BS250 @24.6.2 6 transistori BS250 S250 P-Channel D-MOS 250mA/45V 10Ohm -Vgs=1.0V Datasheet
BSN254A @24.6.2 9 transistori
BSS73 @24.6.2 4 transistori
BSS76 @24.6.2 40 transistori
BSS92 @24.6.3 1300 transistori TO-92 150mA 240V 10Ohm P-Channel Enh. MOSFET Datasheet
BSV10-10 @24.6.4 1 transistori
BSW16/16 @24.6.4 1 transistori
BSW66A @24.6.4 5 transistori TO-39 1A/100V NPN Transistor BSW67.pdf
BSW67A @24.6.4 1 transistori TO-39 1A/120V NPN Transistor BSW67.pdf
BSW68 @24.6.4 6 transistori TO-39 1A/150V NPN Transistor BSW67.pdf
BSX21 @24.6.4 3 transistori
BSX24CP @24.7.1 1 transistori
BSX29 @24.7.1 1 transistori
BSX40 @24.7.1 1 transistori
BSX47-10 @24.7.1 1 transistori TO-39 1A/60V NPN Transistor BSX45.pdf
BSX47-6 @24.7.1 1 transistori to-39 1A/60V NPN Transistor BSX45.pdf
BSY53 @24.7.1 1 transistori
BSY86 @24.7.2 5 transistori
BTA06-600BW @24.7.2 11 transistori
BU506 @24.7.2 5 transistori TO-220C NPN 700V 5A 100W Hfe:
BU508 @24.7.2 2 transistori
BU603 @24.7.2 6 transistori TO-220C NPN 550V 5A 100W Hfe:>3
BUH50 @24.7.2 1 transistori
BUK453-100B @24.7.3 9 transistori
BUK456-1000B @24.7.3 50 transistori MOSFET N-ch 800V
BUK456-100B @24.7.3 1 transistori
BUK463 @24.7.3 2 transistori
BUS48AP @24.7.4 5 transistori NPN 700V
BUV48CFI @24.7.4 13 transistori NPN 700V
BUW12A @24.7.4 39 transistori NPN 450V
BUZ72A @24.7.4 2 transistori Datasheet
C105N @24.8.1 1 transistori TO-220C
C106N @24.8.1 12 transistori TO-220C
C1507 @24.8.1 15 transistori TO-220C 0.2A/300V NPN Power Transistor Datasheet
C2312 @24.8.1 2 transistori NPN RF 12V
C33840 @24.8.1 1 transistori
C3692 @24.8.1 2 transistori
C547A @24.8.2 23 transistori TO-92
C637 @24.8.2 70 transistori TO-92
C879 @24.2.2 1 transistori
CSC1815GR @24.8.2 15 transistori TO-92
D43C10 @24.8.2 3 transistori TO-202AB 3A/80V PNP power transistor Datasheet
D43C7 @24.8.2 2 transistori TO-202AB 3A/60V PNP Power Transistor Datasheet
D44C7 @24.8.2 8 transistori TO-220C 4A/45V NPN Power Transistor Datasheet
D44H8 @24.8.3 27 transistori TO-220C 10A/60V NPN Power Transistor Datasheet
FDA38N30 @25.4.2 4 transistori TO-3PN 38A/300V 85mOhm N-Channel Enh. MOSFET FDA38N30.pdf
FDP6670AL @24.8.3 48 transistori TO-220 80A 30V 0.0065Ohm Vds=3-4V N-Channel Enh. MOSFET Datasheet
FDP6670AL @24.8.3 42 transistori TO-220 80A 30V 0.0065Ohm Vds=3-4V N-Channel Enh. MOSFET Datasheet
FDP6690S @24.8.3 3 transistori TO-220 21A 30V 0.0155Ohm N-Channel Enh. MOSFET Datasheet
FQP30N06L @24.8.3 2 transistori TO-220 32A 60V 0.035Ohm N-Channel Enh. MOSFET Datasheet
FQPF2N60C @24.8.3 10 transistori TO-220 2A 600V 4.7Ohm N-Channel Enh. MOSFET Datasheet
H30R1602 @24.8.4 8 transistori 30A 1600V Reverse Conducting (RC-)IGBT with monolithic body diode Datasheet
IRF1010E @24.8.4 8 transistori TO-220AB 59A 60V 12.0 mOhm N-Channel Power MOSFET IRF1010E.pdf
IRF3205 @24.8.4 16 transistori TO-220AB 80A 55V 8.0 mOhm N-Channel Power MOSFET Datasheet
IRF510 @24.8.4 5 transistori
IRF511 @24.8.4 11 transistori TO220AB 5.6A 80V 0.54Ohm N-Channel Enh. Power MOSFET Datasheet
IRF520N @24.8.4 2 transistori TO-220AB 9.7A 100V 0.20 Ohm N-Channel Enh. Power MOSFET Datasheet
IRF530N @24.9.1 300 transistori TO-220AB 17A 100V 0.11 Ohm N-Channel Enh. Power MOSFET Datasheet
IRF640 @24.9.2 300 transistori TO-220AB 18A 200V 0.18 Ohm N-Channel Enh. Power MOSFET Datasheet
IRF540 @24.9.3 10 transistori TO-220AB 23A 100V 0.077Ohm N-Channel Enh. Power MOSFET Datasheet
IRF540N @24.9.3 13 transistori TO-220AB 33A 100V 0.044Ohm N-Channel Enh. Power MOSFET Datasheet
IRF632 @24.9.3 2 transistori TO-220AB 8A 200V N-Channel Enh. Power MOSFET Datasheet
IRF730 @24.9.3 0 transistori TO-220 5.5A 400V 1.0 Ohm N-Channel Enh. Power MOSFET Datasheet
IRF820 @24.9.3 1 transistori TO-220AB
IRF823 @24.9.3 6 transistori TO-220 2.2A 450V 4.0 Ohm N-Channel Enh. Power MOSFET Datasheet
IRF830 @24.9.4 1 transistori TO-220AB
IRF840 @24.9.4 9 transistori TO-220AB 8A/500V N-Channel MOSFET Datasheet
IRF9531 @24.9.4 1 transistori TO-220AB 12A 60V P-Channel Power MOSFET Datasheet
IRF9540N @24.9.4 40 transistori TO220AB 19A 100V 0.2Ohm P-Channel Power MOSFET Datasheet
IRF9610 @24.9.4 8 transistori TO220 1.8A 200V P-Channel Power MOSFET Datasheet
IRF9Z24N @24.9.4 21 transistori TO-220AB 12A 55V P-Channel Power MOSFET Datasheet
IRF9Z34N @24.9.3 99 transistori TO-220AB
IRFD120 @24.10.1 100 transistori HEXDIP 1.3A 100V 0.30Ohm N-Channel Enh. Power MOSFET Datasheet
IRFD1Z3 @24.10.1 495 transistori HEXDIP 0.4A 60V N-Channel Power MOSFET Datasheet
IRFD9020 @24.10.1 9 transistori HEXDIP 1.6A 60V P-Channel Power MOSFET Datasheet
IRFI820G @24.10.2 11 transistori TO-220 FULLPAK 2.1A/500V 3Ohm N-Channel Power MOSFET Datasheet
IRFP264 @24.10.2 4 transistori TO247AC 38A 250V 0.075Ohm N-Channel Enh. Power MOSFET Datasheet
IRFPC50A @24.10.2 1 transistori TO247AC 11A 600V 0.58Ohm N-Channel Enh. Power MOSFET Datasheet
IRFPE50 @24.10.2 2 transistori TO247AC 7.8A 800V 1.2Ohm N-Channel Enh. Power MOSFET Datasheet
IRFU020 @24.10.2 4 transistori IPAK 15A 50V N-Channel Power MOSFET Rds=4.4Ohm Datasheet
IRFU9024 @24.10.2 88 transistori TO-251AA 8.8A 60V P-Channel Power MOSFET Datasheet
IRFUC20 @24.11.1 49 transistori TO-251AA 2A 600V P-Channel Power MOSFET IRFUC20.pdf
IRFZ34N @24.10.3 3 transistori TO-220 26A 55A 0.040Ohm N-Channel Enh. Power MOSFET DAtasheet
IRFZ42 @24.10.3 6 transistori TO-220 35A 50V N-Channel enh. power MOSFET 35mOhm Datasheet
IRG4BC10KD @24.10.3 11 transistori 5A/600V Insulated gate bipolar transistor (IGBT) with ultrafast soft-recovery diode Datasheet
IRG4PF50W @25.4.2 1 transistori TO-247AC 28A/900V Insulated gate bipolar transistor (IGBT) IRG4PF50W.pdf
IRGPC40S @24.10.3 1 transistori TO-247AC 31A 600V N-Channel IGBT Transistor Datasheet
IRL3705N @24.10.4 2 transistori TO-220AB 89A 55V 0.010Ohm N-Channel Enh. Power MOSGET Datasheet
IRLB8743 @24.10.4 9 transistori TO-220C 150A 30V 3.2mOhm N-Channel Enh. Power MOSFET Datasheet
IRLS530N @24.10.4 19 transistori TO-220AB
IRLZ24N @24.10.4 1 transistori TO-220AB 18A 55V 0.060Ohm N-Channel Enh. Power MOSFET Datasheet
IRLZ34N @24.10.4 3 transistori TO-220AB
IRLZ44N @24.10.4 3 transistori TO-220AB 47A 55V N-Channel Power MOSFET Datasheet
J177 @24.11.1 10 transistori
J200 @24.11.1 1 transistori N-Channel JFET
J201 @24.11.1 3 transistori N-Channel JFET
KSY10 @24.11.1 1 transistori
MC7705CG @24.11.2 2 transistori
MCR264 @24.11.2 1 transistori
MD6002 @24.11.2 3 transistori 654-07 500mA/30V Dual NPN Transistor Datasheet
MFE121 @24.11.2 7 transistori
MRF604 @25.5.4 3 transistori
MJE1090 @25.4.1 120 transistori TO-225AB 5A/60V PNP Darlington Transistor MJE1101.pdf
MJE1100 @25.4.1 90 transistori TO-225AB 5A/60V NPN Darlington Transistor MJE1101.pdf
MJE1101 @24.11.2 1 transistori TO-225AB 5A/60V NPN Power Transistor MJE1101.pdf
MJE13005 @24.11.2 3 transistori TO-220 MJE13004.pdf
MJE13006 @24.11.3 10 transistori TO-220 8A/300V NPN Power Transistor MJE13006-MJE13007.pdf
MJE13007 @24.11.3 1 transistori TO-220 8A/400V NPN Power Transistor MJE13006-MJE13007.pdf
MJE2955T @24.11.3 1 transistori TO-220 10A/60V PNP Power Transistor MJE2955T.pdf
MJE2955 @24.11.3 24 transistori TO-225AB 10A/60V PNP Power Transistor Datasheet
MJE340 @24.11.3 10 transistori TO-225 0.5A/300V NPN Power Transistor Datasheet
MJE541 @24.11.3 1 transistori TO-225
MJF16010A @24.11.4 36 transistori TO-218 15A/500V NPN Power Transistor
MJH16006A @24.11.4 4 transistori
MPF112 @24.11.4 5 transistori TO-92 25mA/25V N-Channel JFET Datasheet
MPF121 @24.11.4 1 transistori
MPQ3467 @24.12.1 1 transistori
MPQ3725 @24.12.1 1 transistori
MPS6532 @24.12.1 50 transistori TO-92 NPN 30V 600mA 625mW Hfe:>30
MPS6533 @24.12.1 4 transistori
MPS6562 @24.12.1 20 transistori TO-92 PNP 25V 1A 625mW Hfe:>30-200
MPS6565 @24.12.1 40 transistori TO-92 NPN 45V 200mA 310mW Hfe:>30-200
MPSA06 @24.12.2 3 transistori
MPSA13 @24.12.2 8 transistori
MPSA14 @24.12.2 10 transistori TO-92 NPN Darlington 30V 500mA 625mW Hfe:>10000
MPSA17 @24.12.2 4 transistori
MPSA18 @24.12.3 1 transistori
MPSA20 @24.12.3 2 transistori
MPSA42 @24.12.3 3 transistori
MPSA55 @24.12.3 12 transistori TO-92 PNP 60V 500mA 625mW Hfe:>100
MPSA56 @24.12.4 2 transistori
MPSA65 @24.12.4 25 transistori TO-92 PNP Darlington 30V 1.2A 625mW Hfe:>20000
MPSA70 @24.12.4 2 transistori
MPSA92 @24.12.4 1 transistori
MPSL01 @25.1.1 2 transistori
MPSL51 @25.1.1 2 transistori
MPSU02 MPSU05 @25.1.1 2 transistori CASE 152-02 2A/60V NPN Silicon Amplifier Transistor Datasheet
MPSU06 @25.1.1 5 transistori CASE 152-02 2A/80V NPN Silicon Amplifier Transistor Datasheet
MPSU45 @25.1.1 1 transistori
MPSU56 @25.1.1 2 transistori
MRF314 @25.3.3 2 transistori
MTP2P45 @25.1.2 6 transistori
MTS102 @25.1.2 16 transistori Lämpötila-anturi vastaa 2N2222? MTS102.pdf
NDP6060 @25.1.2 25 transistori TO-220 48A/60V 25mOhm N-Channel Enh. MOSFET Datasheet
NGBT25N120FL @25.1.2 2 transistori IGBT 25N120FL NFC09G NGBT25N120FL.pdf
P3NA60 @25.1.2 1 transistori TO-220 2.9A/600V 3.3Ohm N-Channel Enh. MOSFET
PN2222A-118 @25.1.2 7 transistori
R3145 8409 @25.1.3 8 transistori TO-3P Texas Instruments R3145 8409 B409? PNP
RFP12N10 @25.1.3 6 transistori TO-220AB N-Channel Power MOSFET 12A/100V 0.2 Ohm Datasheet
RFP12P08 @25.1.3 1 transistori TO-220AB
RFP40N10 @25.1.3 27 transistori TO-220AB N-Channel Power MOSFET 40A/100V 40mOhm Datasheet
S170 @25.1.3 30 transistori
S4006L @25.4.2 1 transistori SCR
S8550D @25.1.3 5 transistori Toshiba 2-3K1B Microwave power GaAs FET Datasheet
S9012H @25.1.4 5 transistori TO-92 PNP Transistor 500mA/25V Datasheet
S9013H @25.1.4 6 transistori TO-92 NPN Transistor 500mA/25V Datasheet
S9014C @25.1.4 5 transistori TO-92 NPN Transistor 100mA/45V Datasheet
S9015C @25.1.4 3 transistori TO-92 PNP Transistor 100mA/45V Datasheet
S9018H @25.1.4 5 transistori TO-92 NPN Transistor 50mA/25V Datasheet
SFT715 @25.1.4 1 transistori
SGSIF4444 @25.2.1 1 transistori
SGSP311 @25.2.1 5 transistori P311 48540
SPF2039 @25.2.1 12 transistori
SR60 @25.2.1 18 transistori
SS8050D @25.2.1 3 transistori TO-92 NPN epitaxial silicon transistor 1.5A/25V Datasheet
ST2222 @25.2.1 23 transistori
ST70A @25.2.2 2 transistori
STC5649 @25.4.2 13 transistori TO-5 1A/60V PNP Datasheet
STD1NB80 @25.2.2 33 transistori IPAK 1A/800V 20Ohm N-Channel MOSFET Datasheet
STD2HNK60Z-1 @25.4.2 9 transistori IPAK 2A/600V 3.5Ohm N-Channel MOSFET STD2HNK60Z-1.pdf
STD5NM50-1 @25.2.2 62 transistori IPAK 7.5A/500V 0.7Ohm N-Channel MOSFET Datasheet
STF3NK90ZFP @25.2.2 10 transistori TO-220FP 3A/900V N-Channel MOSFET
STF3NK100Z @25.2.2 25 transistori TO-220FP 2.5A/1000V 6Ohm N-Channel MOSFET Datasheet
STF8NK100Z @25.2.2 2 transistori TO-220FP 6.5A/1000V N-Channel MOSFET
STP16NF06FP @25.2.3 22 transistori TO-220FP 20A/60V 40mOhm N-Channel MOSFET Datasheet
STP16NF06LFP @25.2.3 37 transistori TO-220FP 20A/60V 40mOhm N-Channel MOSFET
STP30NE06 @25.2.3 49 transistori TO-220FP 20A/60V 40mOhm N-Channel MOSFET
STP36NE06FP @25.2.3 12 transistori TO-220FP 20A/60V 40mOhm N-Channel MOSFET Datasheet
STP55NF06LFP @25.2.3 48 transistori TO-220FP 50A/60V 18mOhm N-Channel MOSFET Datasheet
SUB75P05-08 @25.2.4 11 transistori Datasheet
T9003V @25.2.4 1 transistori TI T9003V
T9004V @25.2.4 2 transistori TI T9004V
TIP115 @25.2.4 5 transistori
TIP120 @25.2.4 80 transistori TO-220AB Silicon NPN Darlington Power Transistors 5A/60V Datasheet
TIP122 TIP121 @25.3.1 4 transistori TO-220AB Silicon NPN Darlington Power Transistors 5A/100V Datasheet
TIP125 @25.3.1 14 transistori TO-220AB PNP Darlington 5A/60V Datasheet
TIP126 @25.3.1 2 transistori TO-220AB PNP Darlington 5A/80V Datasheet
TIP147 @25.3.1 3 transistori PNP Darlington 10A/100V Datasheet
TIP29 @25.3.1 2 transistori TO-220 TIP29A TIP29B NPN Transistor 1A/40V Datasheet
TIP2955 @25.3.1 11 transistori TO-247 PNP power transistor 15A/60V Datasheet
TIP3055 @25.3.2 7 transistori TO-247 NPN power transistor 15A/60V Datasheet
TIP32A @25.3.2 2 transistori TO-220 PNP epitaxial silicon transistor 3A/40V Datasheet
TIP33C @25.3.2 1 transistori TO-218 NPN power transistor 10A/40V Datasheet
TIP31 @25.3.4 3 transistori TO-220
TIP31B @25.3.4 2 transistori TO-220
TIP32 @25.3.4 3 transistori TO-220
TIP34 @25.3.2 5 transistori TO-218 TIP34C TIP34A PNP power transistor 10A/40V Datasheet
TIP41A @25.3.2 2 transistori TO-220AB NPN power transistor 6A/60V Datasheet
TIP41C @25.3.2 11 transistori TO-220AB NPN power transistor 6A/100V Datasheet
TIP42 @25.3.3 5 transistori TO-220AB TIP42B TIP42A PNP Transistor 6A/80V Datasheet
TIP42C @25.3.3 5 transistori TO-220AB PNP Transistor 6A/100V Datasheet
TIP62A @25.3.3 15 transistori TO-220 PNP Transistor 2A/60V
TIS43 @25.3.3 3 transistori TO-5 1.5A 30V PN-Unijunction transistor Datasheet
TIS88 @25.3.3 1 transistori TO-92 N-FET transistor 50mA/30V Datasheet
VP1008M @25.3.4 5 transistori TO237 P-Channel Enh. MOSFET 310mA/100V 4.5V 5Ohm Datasheet
WE28501 @25.3.4 25 transistori TO92-4P Datasheet not available
ZVN3306A @25.3.4 2 transistori TO92-3 270mA/60V 5 Ohm N-Channel MOSFET
10.0R @70.1.1 X vastus
10.2R @70.1.1 X vastus
10.5R @70.1.2 X vastus
10.7R @70.1.2 X vastus
11.0R @70.1.3 X vastus
11.3R @70.1.3 X vastus
11.5R @70.1.4 X vastus
11.8R @70.1.4 X vastus
12.1R @70.2.1 X vastus
12.4R @70.2.1 X vastus
12.7R @70.2.2 X vastus
13.0R @70.2.2 X vastus
13.3R @70.2.3 X vastus
13.7R @70.2.3 X vastus
14.0R @70.2.4 X vastus
14.3R @70.2.4 X vastus
14.7R @70.3.1 X vastus
15.0R @70.3.1 X vastus
15.4R @70.3.2 X vastus
15.8R @70.3.2 X vastus
16.2R @70.3.3 X vastus
16.5R @70.3.3 X vastus
16.9R @70.3.4 X vastus
17.4R @70.3.4 X vastus
17.8R @70.4.1 X vastus
18.2R @70.4.1 X vastus
18.7R @70.4.2 X vastus
19.1R @70.4.2 X vastus
19.6R @70.4.3 X vastus
20.0R @70.4.3 X vastus
20.5R @70.4.4 X vastus
21.0R @70.4.4 X vastus
21.5R @70.5.1 X vastus
22.1R @70.5.1 X vastus
22.6R @70.5.2 X vastus
23.2R @70.5.2 X vastus
23.7R @70.5.3 X vastus
24.3R @70.5.3 X vastus
24.9R @70.5.4 X vastus
25.5R @70.5.4 X vastus
26.1R @70.6.1 X vastus
26.7R @70.6.1 X vastus
27.4R @70.6.2 X vastus
28.0R @70.6.2 X vastus
28.7R @70.6.3 X vastus
29.4R @70.6.3 X vastus
30.1R @70.6.4 X vastus
30.9R @70.6.4 X vastus
31.6R @70.7.1 X vastus
32.4R @70.7.1 X vastus
33.2R @70.7.2 X vastus
34.0R @70.7.2 X vastus
34.8R @70.7.3 X vastus
35.7R @70.7.3 X vastus
36.5R @70.7.4 X vastus
37.4R @70.7.4 X vastus
38.3R @70.8.1 X vastus
39.2R @70.8.1 X vastus
40.2R @70.8.2 X vastus
41.2R @70.8.2 X vastus
42.2R @70.8.3 X vastus
43.2R @70.8.3 X vastus
44.2R @70.8.4 X vastus
45.3R @70.8.4 X vastus
46.4R @70.9.1 X vastus
47.5R @70.9.1 X vastus
48.7R @70.9.2 X vastus
49.9R @70.9.2 X vastus
51.1R @70.9.3 X vastus
52.3R @70.9.3 X vastus
53.6R @70.9.4 X vastus
54.9R @70.9.4 X vastus
56.2R @70.10.1 X vastus
57.6R @70.10.1 X vastus
59.0R @70.10.2 X vastus
60.4R @70.10.2 X vastus
61.9R @70.10.3 X vastus
63.4R @70.10.3 X vastus
64.9R @70.10.4 X vastus
66.5R @70.10.4 X vastus
68.1R @70.11.1 X vastus
69.8R @70.11.1 X vastus
71.5R @70.11.2 X vastus
73.2R @70.11.2 X vastus
75.0R @70.11.3 X vastus
76.8R @70.11.3 X vastus
78.7R @70.11.4 X vastus
80.6R @70.11.4 X vastus
82.5R @70.12.1 X vastus
84.5R @70.12.1 X vastus
86.6R @70.12.2 X vastus
88.7R @70.12.2 X vastus
90.9R @70.12.3 X vastus
93.1R @70.12.3 X vastus
95.3R @70.12.4 X vastus
97.6R @70.12.4 X vastus
100R @71.1.1 X vastus
102R @71.1.1 X vastus
105R @71.1.2 X vastus
107R @71.1.2 X vastus
110R @71.1.3 X vastus
113R @71.1.3 X vastus
115R @71.1.4 X vastus
118R @71.1.4 X vastus
121R @71.2.1 X vastus
124R @71.2.1 X vastus
127R @71.2.2 X vastus
130R @71.2.2 X vastus
133R @71.2.3 X vastus
137R @71.2.3 X vastus
140R @71.2.4 X vastus
143R @71.2.4 X vastus
147R @71.3.1 X vastus
150R @71.3.1 X vastus
154R @71.3.2 X vastus
158R @71.3.2 X vastus
162R @71.3.3 X vastus
165R @71.3.3 X vastus
169R @71.3.4 X vastus
174R @71.3.4 X vastus
178R @71.4.1 X vastus
182R @71.4.1 X vastus
187R @71.4.2 X vastus
191R @71.4.2 X vastus
196R @71.4.3 X vastus
200R @71.4.3 X vastus
205R @71.4.4 X vastus
210R @71.4.4 X vastus
215R @71.5.1 X vastus
221R @71.5.1 X vastus
226R @71.5.2 X vastus
232R @71.5.2 X vastus
237R @71.5.3 X vastus
243R @71.5.3 X vastus
249R @71.5.4 X vastus
255R @71.5.4 X vastus
261R @71.6.1 X vastus
267R @71.6.1 X vastus
274R @71.6.2 X vastus
280R @71.6.2 X vastus
287R @71.6.3 X vastus
294R @71.6.3 X vastus
301R @71.6.4 X vastus
309R @71.6.4 X vastus
316R @71.7.1 X vastus
324R @71.7.1 X vastus
332R @71.7.2 X vastus
340R @71.7.2 X vastus
348R @71.7.3 X vastus
357R @71.7.3 X vastus
365R @71.7.4 X vastus
374R @71.7.4 X vastus
383R @71.8.1 X vastus
392R @71.8.1 X vastus
402R @71.8.2 X vastus
412R @71.8.2 X vastus
422R @71.8.3 X vastus
432R @71.8.3 X vastus
442R @71.8.4 X vastus
453R @71.8.4 X vastus
464R @71.9.1 X vastus
475R @71.9.1 X vastus
487R @71.9.2 X vastus
499R @71.9.2 X vastus
511R @71.9.3 X vastus
523R @71.9.3 X vastus
536R @71.9.4 X vastus
549R @71.9.4 X vastus
562R @71.10.1 X vastus
576R @71.10.1 X vastus
590R @71.10.2 X vastus
604R @71.10.2 X vastus
619R @71.10.3 X vastus
634R @71.10.3 X vastus
649R @71.10.4 X vastus
665R @71.10.4 X vastus
681R @71.11.1 X vastus
698R @71.11.1 X vastus
715R @71.11.2 X vastus
732R @71.11.2 X vastus
750R @71.11.3 X vastus
768R @71.11.3 X vastus
787R @71.11.4 X vastus
806R @71.11.4 X vastus
825R @71.12.1 X vastus
845R @71.12.1 X vastus
866R @71.12.2 X vastus
887R @71.12.2 X vastus
909R @71.12.3 X vastus
931R @71.12.3 X vastus
953R @71.12.4 X vastus
976R @71.12.4 X vastus
1.00k @72.1.1 X vastus
1.02k @72.1.1 X vastus
1.05k @72.1.2 X vastus
1.07k @72.1.2 X vastus
1.10k @72.1.3 X vastus
1.13k @72.1.3 X vastus
1.15k @72.1.4 X vastus
1.18k @72.1.4 X vastus
1.21k @72.2.1 X vastus
1.24k @72.2.1 X vastus
1.27k @72.2.2 X vastus
1.30k @72.2.2 X vastus
1.33k @72.2.3 X vastus
1.37k @72.2.3 X vastus
1.40k @72.2.4 X vastus
1.43k @72.2.4 X vastus
1.47k @72.3.1 X vastus
1.50k @72.3.1 X vastus
1.54k @72.3.2 X vastus
1.58k @72.3.2 X vastus
1.62k @72.3.3 X vastus
1.65k @72.3.3 X vastus
1.69k @72.3.4 X vastus
1.74k @72.3.4 X vastus
1.78k @72.4.1 X vastus
1.82k @72.4.1 X vastus
1.87k @72.4.2 X vastus
1.91k @72.4.2 X vastus
1.96k @72.4.3 X vastus
2.00k @72.4.3 X vastus
2.05k @72.4.4 X vastus
2.10k @72.4.4 X vastus
2.15k @72.5.1 X vastus
2.21k @72.5.1 X vastus
2.26k @72.5.2 X vastus
2.32k @72.5.2 X vastus
2.37k @72.5.3 X vastus
2.43k @72.5.3 X vastus
2.49k @72.5.4 X vastus
2.55k @72.5.4 X vastus
2.61k @72.6.1 X vastus
2.67k @72.6.1 X vastus
2.74k @72.6.2 X vastus
2.80k @72.6.2 X vastus
2.87k @72.6.3 X vastus
2.94k @72.6.3 X vastus
3.01k @72.6.4 X vastus
3.09k @72.6.4 X vastus
3.16k @72.7.1 X vastus
3.24k @72.7.1 X vastus
3.32k @72.7.2 X vastus
3.40k @72.7.2 X vastus
3.48k @72.7.3 X vastus
3.57k @72.7.3 X vastus
3.65k @72.7.4 X vastus
3.74k @72.7.4 X vastus
3.83k @72.8.1 X vastus
3.92k @72.8.1 X vastus
4.02k @72.8.2 X vastus
4.12k @72.8.2 X vastus
4.22k @72.8.3 X vastus
4.32k @72.8.3 X vastus
4.42k @72.8.4 X vastus
4.53k @72.8.4 X vastus
4.64k @72.9.1 X vastus
4.75k @72.9.1 X vastus
4.87k @72.9.2 X vastus
4.99k @72.9.2 X vastus
5.11k @72.9.3 X vastus
5.23k @72.9.3 X vastus
5.36k @72.9.4 X vastus
5.49k @72.9.4 X vastus
5.62k @72.10.1 X vastus
5.76k @72.10.1 X vastus
5.90k @72.10.2 X vastus
6.04k @72.10.2 X vastus
6.19k @72.10.3 X vastus
6.34k @72.10.3 X vastus
6.49k @72.10.4 X vastus
6.65k @72.10.4 X vastus
6.81k @72.11.1 X vastus
6.98k @72.11.1 X vastus
7.15k @72.11.2 X vastus
7.32k @72.11.2 X vastus
7.50k @72.11.3 X vastus
7.68k @72.11.3 X vastus
7.87k @72.11.4 X vastus
8.06k @72.11.4 X vastus
8.25k @72.12.1 X vastus
8.45k @72.12.1 X vastus
8.66k @72.12.2 X vastus
8.87k @72.12.2 X vastus
9.09k @72.12.3 X vastus
9.31k @72.12.3 X vastus
9.53k @72.12.4 X vastus
9.76k @72.12.4 X vastus
10.0k @74.1.1 X vastus
10.2k @74.1.1 X vastus
10.5k @74.1.2 X vastus
10.7k @74.1.2 X vastus
11.0k @74.1.3 X vastus
11.3k @74.1.3 X vastus
11.5k @74.1.4 X vastus
11.8k @74.1.4 X vastus
12.1k @74.2.1 X vastus
12.4k @74.2.1 X vastus
12.7k @74.2.2 X vastus
13.0k @74.2.2 X vastus
13.3k @74.2.3 X vastus
13.7k @74.2.3 X vastus
14.0k @74.2.4 X vastus
14.3k @74.2.4 X vastus
14.7k @74.3.1 X vastus
15.0k @74.3.1 X vastus
15.4k @74.3.2 X vastus
15.8k @74.3.2 X vastus
16.2k @74.3.3 X vastus
16.5k @74.3.3 X vastus
16.9k @74.3.4 X vastus
17.4k @74.3.4 X vastus
17.8k @74.4.1 X vastus
18.2k @74.4.1 X vastus
18.7k @74.4.2 X vastus
19.1k @74.4.2 X vastus
19.6k @74.4.3 X vastus
20.0k @74.4.3 X vastus
20.5k @74.4.4 X vastus
21.0k @74.4.4 X vastus
21.5k @74.5.1 X vastus
22.1k @74.5.1 X vastus
22.6k @74.5.2 X vastus
23.2k @74.5.2 X vastus
23.7k @74.5.3 X vastus
24.3k @74.5.3 X vastus
24.9k @74.5.4 X vastus
25.5k @74.5.4 X vastus
26.1k @74.6.1 X vastus
26.7k @74.6.1 X vastus
27.4k @74.6.2 X vastus
28.0k @74.6.2 X vastus
28.7k @74.6.3 X vastus
29.4k @74.6.3 X vastus
30.1k @74.6.4 X vastus
30.9k @74.6.4 X vastus
31.6k @74.7.1 X vastus
32.4k @74.7.1 X vastus
33.2k @74.7.2 X vastus
34.0k @74.7.2 X vastus
34.8k @74.7.3 X vastus
35.7k @74.7.3 X vastus
36.5k @74.7.4 X vastus
37.4k @74.7.4 X vastus
38.3k @74.8.1 X vastus
39.2k @74.8.1 X vastus
40.2k @74.8.2 X vastus
41.2k @74.8.2 X vastus
42.2k @74.8.3 X vastus
43.2k @74.8.3 X vastus
44.2k @74.8.4 X vastus
45.3k @74.8.4 X vastus
46.4k @74.9.1 X vastus
47.5k @74.9.1 X vastus
48.7k @74.9.2 X vastus
49.9k @74.9.2 X vastus
51.1k @74.9.3 X vastus
52.3k @74.9.3 X vastus
53.6k @74.9.4 X vastus
54.9k @74.9.4 X vastus
56.2k @74.10.1 X vastus
57.6k @74.10.1 X vastus
59.0k @74.10.2 X vastus
60.4k @74.10.2 X vastus
61.9k @74.10.3 X vastus
63.4k @74.10.3 X vastus
64.9k @74.10.4 X vastus
66.5k @74.10.4 X vastus
68.1k @74.11.1 X vastus
69.8k @74.11.1 X vastus
71.5k @74.11.2 X vastus
73.2k @74.11.2 X vastus
75.0k @74.11.3 X vastus
76.8k @74.11.3 X vastus
78.7k @74.11.4 X vastus
80.6k @74.11.4 X vastus
82.5k @74.12.1 X vastus
84.5k @74.12.1 X vastus
86.6k @74.12.2 X vastus
88.7k @74.12.2 X vastus
90.9k @74.12.3 X vastus
93.1k @74.12.3 X vastus
95.3k @74.12.4 X vastus
97.6k @74.12.4 X vastus
100k @75.1.1 X vastus
102k @75.1.1 X vastus
105k @75.1.2 X vastus
107k @75.1.2 X vastus
110k @75.1.3 X vastus
113k @75.1.3 X vastus
115k @75.1.4 X vastus
118k @75.1.4 X vastus
121k @75.2.1 X vastus
124k @75.2.1 X vastus
127k @75.2.2 X vastus
130k @75.2.2 X vastus
133k @75.2.3 X vastus
137k @75.2.3 X vastus
140k @75.2.4 X vastus
143k @75.2.4 X vastus
147k @75.3.1 X vastus
150k @75.3.1 X vastus
154k @75.3.2 X vastus
158k @75.3.2 X vastus
162k @75.3.3 X vastus
165k @75.3.3 X vastus
169k @75.3.4 X vastus
174k @75.3.4 X vastus
178k @75.4.1 X vastus
182k @75.4.1 X vastus
187k @75.4.2 X vastus
191k @75.4.2 X vastus
196k @75.4.3 X vastus
200k @75.4.3 X vastus
205k @75.4.4 X vastus
210k @75.4.4 X vastus
215k @75.5.1 X vastus
221k @75.5.1 X vastus
226k @75.5.2 X vastus
232k @75.5.2 X vastus
237k @75.5.3 X vastus
243k @75.5.3 X vastus
249k @75.5.4 X vastus
255k @75.5.4 X vastus
261k @75.6.1 X vastus
267k @75.6.1 X vastus
274k @75.6.2 X vastus
280k @75.6.2 X vastus
287k @75.6.3 X vastus
294k @75.6.3 X vastus
301k @75.6.4 X vastus
309k @75.6.4 X vastus
316k @75.7.1 X vastus
324k @75.7.1 X vastus
332k @75.7.2 X vastus
340k @75.7.2 X vastus
348k @75.7.3 X vastus
357k @75.7.3 X vastus
365k @75.7.4 X vastus
374k @75.7.4 X vastus
383k @75.8.1 X vastus
392k @75.8.1 X vastus
402k @75.8.2 X vastus
412k @75.8.2 X vastus
422k @75.8.3 X vastus
432k @75.8.3 X vastus
442k @75.8.4 X vastus
453k @75.8.4 X vastus
464k @75.9.1 X vastus
475k @75.9.1 X vastus
487k @75.9.2 X vastus
499k @75.9.2 X vastus
511k @75.9.3 X vastus
523k @75.9.3 X vastus
536k @75.9.4 X vastus
549k @75.9.4 X vastus
562k @75.10.1 X vastus
576k @75.10.1 X vastus
590k @75.10.2 X vastus
604k @75.10.2 X vastus
619k @75.10.3 X vastus
634k @75.10.3 X vastus
649k @75.10.4 X vastus
665k @75.10.4 X vastus
681k @75.11.1 X vastus
698k @75.11.1 X vastus
715k @75.11.2 X vastus
732k @75.11.2 X vastus
750k @75.11.3 X vastus
768k @75.11.3 X vastus
787k @75.11.4 X vastus
806k @75.11.4 X vastus
825k @75.12.1 X vastus
845k @75.12.1 X vastus
866k @75.12.2 X vastus
887k @75.12.2 X vastus
909k @75.12.3 X vastus
931k @75.12.3 X vastus
953k @75.12.4 X vastus
976k @75.12.4 X vastus
1.00R @81.10.1 X vastus
1.50R @81.10.1 X vastus
1.80R @81.10.2 X vastus
1.82R @81.10.2 X vastus
2.00R @81.10.3 X vastus
2.05R @81.10.3 X vastus
2.20R @81.10.4 X vastus
2.21R @81.10.4 X vastus
2.49R @81.11.1 X vastus
3.31R @81.11.1 X vastus
3.32R @81.11.2 X vastus
3.92R @81.11.2 X vastus
4.02R @81.11.3 X vastus
4.70R @81.11.3 X vastus
4.75R @81.11.4 X vastus
5.11R @81.11.4 X vastus
5.60R @81.12.1 X vastus
5.62R @81.12.1 X vastus
6.19R @81.12.2 X vastus
7.50R @81.12.2 X vastus
8.20R @81.12.3 X vastus
8.25R @81.12.3 X vastus
9.09R @81.12.4 X vastus
12.0R @76.1.1 X vastus
16.0R @76.1.1 X vastus
18.0R @76.1.2 X vastus
22.0R @76.1.2 X vastus
24.0R @76.1.3 X vastus
27.0R @76.1.3 X vastus
30.0R @76.1.4 X vastus
33.0R @76.1.4 X vastus
39.0R @76.2.1 X vastus
47.0R @76.2.1 X vastus
51.0R @76.2.2 X vastus
51.7R @76.2.2 X vastus
56.0R @76.2.3 X vastus
62.0R @76.2.3 X vastus
68.0R @76.2.4 X vastus
82.0R @76.2.4 X vastus
91.0R @76.3.1 X vastus
120R @76.3.1 X vastus
180R @76.3.2 X vastus
200R @76.3.2 X vastus
220R @76.3.3 X vastus
270R @76.3.3 X vastus
300R @76.3.4 X vastus
330R @76.3.4 X vastus
360R @76.4.1 X vastus
390R @76.4.1 X vastus
430R @76.4.2 X vastus
470R @76.4.2 X vastus
510R @76.4.3 X vastus
560R @76.4.3 X vastus
620R @76.4.4 X vastus
680R @76.4.4 X vastus
820R @76.5.1 X vastus
910R @76.5.1 X vastus
1.20k @76.5.2 X vastus
1.50k @76.5.2 X vastus
1.60k @76.5.3 X vastus
1.80k @76.5.3 X vastus
2.20k @76.5.4 X vastus
2.40k @76.5.4 X vastus
2.70k @76.6.1 X vastus
3.00k @76.6.1 X vastus
3.30k @76.6.2 X vastus
3.60k @76.6.2 X vastus
3.90k @76.6.3 X vastus
4.13k @76.6.3 X vastus
4.30k @76.6.4 X vastus
4.70k @76.6.4 X vastus
5.10k @76.7.1 X vastus
5.60k @76.7.1 X vastus
6.20k @76.7.2 X vastus
6.80k @76.7.2 X vastus
8.20k @76.7.3 X vastus
9.10k @76.7.3 X vastus
12.0k @76.7.4 X vastus
12.5k @76.7.4 X vastus
16.0k @76.8.1 X vastus
18.0k @76.8.1 X vastus
22.0k @76.8.2 X vastus
24.0k @76.8.2 X vastus
27.0k @76.8.3 X vastus
30.0k @76.8.3 X vastus
33.0k @76.8.4 X vastus
36.0k @76.8.4 X vastus
39.0k @76.9.1 X vastus
43.0k @76.9.1 X vastus
47.0k @76.9.2 X vastus
51.0k @76.9.2 X vastus
56.0k @76.9.3 X vastus
62.0k @76.9.3 X vastus
68.0k @76.9.4 X vastus
82.0k @76.9.4 X vastus
91.0k @76.10.1 X vastus
160k @76.10.1 X vastus
180k @76.10.2 X vastus
220k @76.10.2 X vastus
240k @76.10.3 X vastus
270k @76.10.3 X vastus
300k @76.10.4 X vastus
330k @76.10.4 X vastus
360k @76.11.1 X vastus
390k @76.11.1 X vastus
470k @76.11.2 X vastus
510k @76.11.2 X vastus
560k @76.11.3 X vastus
680k @76.11.3 X vastus
820k @76.11.3 X vastus
910k @76.11.4 X vastus
1.00M @76.11.4 X vastus
1.00M 1% @76.12.1 X vastus
1.00M 2% @76.12.1 X vastus
1.50M @76.12.2 X vastus
2.20M @76.12.2 X vastus
2.70M @76.12.3 X vastus
3.30M @76.12.3 X vastus
4.70M @76.12.4 X vastus
10M @76.12.4 X vastus
0R @78.1.1 64 vastus
0.22R 5% 1/4W @78.1.1 18 vastus
0.47R 5% 1/4W @78.1.1 X vastus
1.0R 5% 1/8W @78.1.2 38 vastus
1.0R 5% 1/4W @78.1.2 9 vastus
1.1R 5% 1/4W @78.1.2 5 vastus
1.3R 5% 1/4W @78.1.2 5 vastus
1.6R 5% 1/4W @78.1.2 5 vastus
2.0R 5% 1/4W @78.1.2 5 vastus
2.4R 5% 1/4W @78.1.2 5 vastus
3.0R 5% 1/4W @78.1.2 5 vastus
3.6R 5% 1/4W @78.1.2 5 vastus
3.9R 5% 1/4W @78.1.2 9 vastus
4.3R 5% 1/4W @78.1.2 5 vastus
5.1R 5% 1/4W @78.1.2 5 vastus
1.0R @78.1.3 X vastus
1.1R @78.1.3 X vastus
1.2R @78.1.4 X vastus
1.3R @78.1.4 X vastus
1.5R @78.2.1 X vastus
1.6R @78.2.1 X vastus
2.0R @78.2.2 X vastus
3.0R @78.2.2 X vastus
3.3R @78.2.3 X vastus
3.6R @78.2.4 X vastus
3.9R @78.2.4 X vastus
4.3R @78.3.1 X vastus
4.7R @78.3.1 X vastus
5.1R @78.3.2 X vastus
5.6R @78.3.2 X vastus
6.2R @78.3.3 X vastus
6.8R @78.3.3 X vastus
7.5R @78.3.4 X vastus
8.2R @78.3.4 X vastus
9.1R @78.4.1 X vastus
10R @78.4.2 X vastus
11R @78.4.2 X vastus
12R @78.4.3 X vastus
13R @78.4.3 X vastus
15R @78.4.4 X vastus
16R @78.5.1 X vastus
18R @78.5.2 X vastus
20R @78.5.3 X vastus
22R @78.5.4 X vastus
24R @78.6.1 X vastus
27R @78.6.2 X vastus
30R @78.6.3 X vastus
33R @78.6.4 X vastus
36R @78.7.1 X vastus
39R @78.7.2 X vastus
43R @78.7.3 X vastus
47R @78.7.4 X vastus
51R @78.8.1 X vastus
56R @78.8.2 X vastus
62R @78.8.3 X vastus
68R @78.8.4 X vastus
82R @78.9.1 X vastus
91R @78.9.2 X vastus
100R @78.9.3 X vastus
110R @78.9.4 X vastus
120R @78.10.1 X vastus
150R @78.10.2 X vastus
160R @78.10.3 X vastus
180R @78.10.4 X vastus
200R @78.11.1 X vastus
220R @78.11.2 X vastus
240R @78.11.3 X vastus
270R @78.11.4 X vastus
300R @78.12.1 X vastus
330R @78.12.2 X vastus
360R @78.12.3 X vastus
390R @78.12.3 X vastus
430R @78.12.4 X vastus
470R @79.1.1 X vastus
510R @79.1.2 X vastus
560R @79.1.3 X vastus
620R @79.1.4 X vastus
680R @79.2.1 X vastus
750R @79.2.2 X vastus
820R @79.2.3 X vastus
910R @79.2.4 X vastus
1k @79.2.4 X vastus
1.1k @79.3.1 X vastus
1.2k @79.3.2 X vastus
1.3k @79.3.3 X vastus
1.5k @79.3.4 X vastus
1.6k @79.4.1 X vastus
1.8k @79.4.2 X vastus
2k @79.4.3 X vastus
2.2k @79.4.4 X vastus
2.4k @79.5.1 X vastus
2.7k @79.5.2 X vastus
3.0k @79.5.3 X vastus
3.3k @79.5.4 X vastus
3.6k @79.6.1 X vastus
3.9k @79.6.1 X vastus
4.7k @79.6.2 X vastus
5.1k @79.6.3 X vastus
5.6k @79.6.3 X vastus
6.2k @79.6.4 X vastus
6.8k @79.6.4 X vastus
7.5k @79.7.1 X vastus
8.2k @79.7.1 X vastus
9.1k @79.7.2 X vastus
10k @79.7.3 X vastus
12k @79.7.4 X vastus
15k @79.8.1 X vastus
18k @79.8.2 X vastus
22k @79.8.3 X vastus
27k @79.8.4 X vastus
33k @79.9.1 X vastus
36k @79.9.2 X vastus
39k @79.9.3 X vastus
43k @79.9.4 X vastus
47k @79.10.1 X vastus
51k @79.10.2 X vastus
56k @79.10.3 X vastus
62k @79.10.4 X vastus
68k @79.11.1 X vastus
75k @79.11.2 X vastus
82k @79.11.3 X vastus
91k @79.11.4 X vastus
100k @79.11.4 X vastus
110k @79.12.1 X vastus
120k @79.12.2 X vastus
130k @79.12.3 X vastus
150k @79.12.4 X vastus
160k @80.1.1 X vastus
180k @80.1.2 X vastus
180k @80.1.3 X vastus
200k @80.1.4 X vastus
220k @80.2.1 X vastus
240k @80.2.2 X vastus
270k @80.2.3 X vastus
270k @80.2.4 X vastus
300k @80.3.1 X vastus
330k @80.3.2 X vastus
360k @80.3.3 X vastus
390k @80.3.4 X vastus
390k @80.4.1 X vastus
470k @80.4.2 X vastus
470k @80.4.3 X vastus
510k @80.4.4 X vastus
560k @80.5.1 X vastus
620k @80.5.2 X vastus
680k @80.5.3 X vastus
750k @80.5.4 X vastus
820k @80.6.1 X vastus
910k @80.6.2 X vastus
1.0M @80.6.3 X vastus
1.2M @80.6.4 X vastus
1.5M @80.7.1 X vastus
1.8M @80.7.2 X vastus
2.2M @80.7.3 300 vastus
2.4M @80.7.4 X vastus
2.7M @80.8.1 X vastus
3.3M @80.8.2 X vastus
3.9M @80.8.3 X vastus
4.7M @80.8.4 X vastus
5.6M @80.9.1 100 vastus
6.8M @80.9.2 100 vastus
8.2M @80.9.3 80 vastus
10M @80.9.4 X vastus
Vastukset 0.5W - 3W
0.1R @77.1.1 35 vastus
0.1R @77.1.1 10 vastus
0.47R @77.1.1 2 vastus
1.0R @77.1.2 300 vastus
2.2R @77.1.2 10 vastus
3.3R @77.1.3 5 vastus
3.9R @77.1.3 10 vastus
4.7R @77.1.3 60 vastus
5.1R @77.1.3 3 vastus
8.2R @77.1.3 5 vastus
10R @77.1.4 X vastus
12R @77.2.1 X vastus
15R @77.2.2 X vastus
18R @77.2.3 X vastus
22R @77.2.4 X vastus
27R @77.3.1 X vastus
33R @77.3.2 X vastus
33R @77.3.3 X vastus
39R @77.3.4 X vastus
47R @77.4.1 X vastus
51R @77.4.1 17 vastus
56R @77.4.2 X vastus
68R @77.4.3 X vastus
82R @77.4.4 X vastus
100R @77.5.1 X vastus
120R @77.5.2 X vastus
150R @77.5.3 X vastus
180R @77.5.4 X vastus
220R @77.6.1 X vastus
270R @77.6.2 X vastus
330R @77.6.3 X vastus
390R @77.6.4 X vastus
430R @77.7.1 X vastus
470R @77.7.2 X vastus
560R @77.7.3 X vastus
680R @77.7.4 X vastus
TODO: REORDER: 750R @81.9.4 X vastus
820R @77.8.1 X vastus
1.0k @77.8.2 X vastus
1.2k @77.8.3 X vastus
1.2k @77.8.4 X vastus
1.5k @77.9.1 X vastus
1.8k @77.9.2 X vastus
1.8k @77.9.3 X vastus
2.2k @77.9.4 X vastus
2.7k @77.10.1 X vastus
3.3k @77.10.2 X vastus
3.8k @77.10.3 X vastus
4.7k @77.10.4 X vastus
5.6k @77.11.1 X vastus
6.8k @77.11.2 X vastus
8.2k @77.11.3 X vastus
10k @77.11.4 X vastus
10k @77.12.1 X vastus
12k @77.12.2 X vastus
15k @77.12.3 X vastus
18k @77.12.4 X vastus
22k @81.1.1 X vastus
26k @81.1.4 X vastus
27k @81.1.2 X vastus
33k @81.1.3 X vastus
35k @81.1.4 X vastus
39k @81.2.1 X vastus
47k @81.2.2 X vastus
56k @81.2.3 X vastus
68k @81.2.4 X vastus
82k @81.3.1 X vastus
100k @81.3.2 X vastus
120k @81.3.3 X vastus
150k @81.3.4 X vastus
180k @81.4.1 X vastus
220k @81.4.2 X vastus
270k @81.4.3 X vastus
330k @81.4.4 X vastus
390k @81.5.1 X vastus
470k @81.5.2 X vastus
560k @81.5.3 X vastus
680k @81.5.4 X vastus
820k @81.6.1 X vastus
1M @81.6.2 X vastus
1.2M @81.6.3 X vastus
1.5M @81.6.4 X vastus
1.8M @81.7.1 X vastus
2.2M @81.7.2 X vastus
2.7M @81.7.3 X vastus
3.3M @81.7.4 X vastus
3.9M @81.8.1 X vastus
4.7M @81.8.2 X vastus
5.1M @81.8.3 X vastus
5.6M @81.8.3 X vastus
6.8M @81.9.3 X vastus
8.2M @81.8.4 X vastus
10M @81.9.1 X vastus
20M @81.9.2 X vastus
22M @81.9.2 X vastus
68M @81.9.3 3 vastus
1.50R 0.6W 1% @73.12.1 X vastus Metallikalvovastus 0.6W
1.80R 0.6W 1% @73.12.1 X vastus Metallikalvovastus 0.6W
2.20R 0.6W 1% @73.12.1 X vastus Metallikalvovastus 0.6W
2.70R 0.6W 1% @73.12.1 X vastus Metallikalvovastus 0.6W
3.90R 0.6W 1% @73.12.1 X vastus Metallikalvovastus 0.6W
4.70R 0.6W 1% @73.12.1 X vastus Metallikalvovastus 0.6W
18.0R 0.6W 1% @73.12.2 X vastus Metallikalvovastus 0.6W
27.0R 0.6W 1% @73.12.2 X vastus Metallikalvovastus 0.6W
39.0R 0.6W 1% @73.12.2 X vastus Metallikalvovastus 0.6W
56.0R 0.6W 1% @73.12.2 X vastus Metallikalvovastus 0.6W
82.0R 0.6W 1% @73.12.2 X vastus Metallikalvovastus 0.6W
220R 0.6W 1% @73.12.2 X vastus Metallikalvovastus 0.6W
27.0k 0.6W 1% @73.12.3 X vastus Metallikalvovastus 0.6W
220k 0.6W 1% @73.12.3 X vastus Metallikalvovastus 0.6W
430k 0.6W 1% @73.12.3 X vastus Metallikalvovastus 0.6W
470k 0.6W 1% @73.12.3 X vastus Metallikalvovastus 0.6W
820k 0.6W 1% @73.12.4 X vastus Metallikalvovastus 0.6W
1.00M 0.6W 1% @73.12.4 X vastus Metallikalvovastus 0.6W
Vastus: NTC PTC
NTC 4R7 @80.10.1 3 vastus
NTC 15R @80.10.1 1 vastus A15R
NTC 47R @80.10.1 1 vastus
NTC 50R @80.10.1 90 vastus
NTC 50R @80.10.1 6 vastus
NTC 130R @80.10.2 X vastus
NTC 150R @80.10.2 X vastus
NTC 150R @80.10.3 X vastus
NTC 470R @80.10.4 1 vastus
NTC 510R @80.10.4 8 vastus
NTC 1.0k @80.10.4 3 vastus Lasiputki
NTC 1.3k @80.10.4 14 vastus
NTC 2.2k @80.10.4 1 vastus
NTC 1.0k @80.11.1 X vastus
NTC 4.7k @80.11.2 X vastus
NTC 100k @80.11.2 X vastus
NTC 10k @80.11.3 X vastus
NTC 100k @80.11.3 5 vastus
NTC Sekalaiset @80.11.3 X vastus
PT1021 @80.11.3 2 vastus TP1021 PT100
PTC @80.11.3 8 vastus
PTC @80.11.3 10 vastus HEL-700-U-1-A 1000Ohm Platinum temp. resistor HEL-700-U-1-A.pdf
PTC 250R @80.11.3 200 vastus B59008C90A40 Datasheet
NTC Anturi ruuvi+johto @80.11.4 9 vastus B12E 11805 061D Mutterikiinnitys ja johto
NTC Anturi ruuvi+johto @80.11.4 4 vastus 0651A 73102 Mutterikiinnitys ja johto
Vastus: Potentiometrit
Potentiometri 10R lanka @66.1.1 1 vastus
Potentiometri 50R lanka @66.1.1 10 vastus
Potentiometri 220R lin. @66.1.2 15 vastus Radiohm 220Ohm A
Potentiometri 250R lin. @66.1.2 30 vastus 250 Ohm lin. 2.69 RUWIDO
Potentiometri 470R lin. @66.1.3 28 vastus 470RA X1
Potentiometri 1k0 lin @66.2.1 26 vastus 1K0LIN A0
Potentiometri 2k2 lin. @66.2.1 8 vastus Radiohm 2K2A
Potentiometri 2k2 lin. @66.2.1 7 vastus 2K2047M
Potentiometri 2k2 lin. 3W @66.2.1 7 vastus 2K2 5% 3W-40C
Potentiometri 4k7 lin. @66.2.2 13 vastus RADIOHM 4K7A
Potentiometri 5k lin. @66.2.2 9 vastus P160KNP8L B5k
Potentiometri 4k7 log. @66.2.2 21 vastus RADIOHM 4K7B
Potentiometri 4k7 log. @66.2.3 27 vastus RADIOHM 4K7B
Potentiometri 4k7 log. stereo @66.2.3 12 vastus 90031 A3
Potentiometri 10k lin. @35.7.3 X vastus
Potentiometri 10k lin. @66.3.1 42 vastus Vishay Sfcrnice PC32A Series P13T Axel M Value 10k LOI A Tolerance 20%
Potentiometri 10k lin. @66.3.1 60 vastus M10KB
Potentiometri 10k lin. @66.3.1 14 vastus
Potentiometri 10k lin. @66.3.2 6 vastus CITEC LIN A 10K
Potentiometri 10k log. kytkimellä @66.3.2 11 vastus A10K
Potentiometri 50k stereo @66.3.2 7 vastus ALPS 503A
Potentiometri 50k stereo @66.3.2 11 vastus C50K
Potentiometri 10k sekal. @66.3.2 3 vastus
Potentiometri 47k lin. @66.3.3 17 vastus 47K 413 PIHER
Potentiometri 47k lin. @66.3.3 4 vastus 47K LIN
Potentiometri 47k lin. stereo @66.3.3 14 vastus 47K LINC1
Potentiometri 47k log. @66.4.1 21 vastus A47K
Potentiometri 47k log. @66.4.1 6 vastus Ratiohm 47KB
Potentiometri 100k lin. @66.4.2 23 vastus 100K lin
Potentiometri 100k lin. @66.4.2 25 vastus Vishay Sfcrnice PC32A Series P13T Axel M Value 100k LOI A Tolerance 20%
Potentiometri 100k lin. @66.4.2 11 vastus Ratiohm 100KA
Potentiometri 100k lin. @66.8.3 13 vastus 100K LIN B6 - 4mm lovettu akseli - PCB kiinnitys
Potentiometri 100k lin. stereo @66.4.3 5 vastus 100K LIN
Potentiometri 100k lin. @66.4.3 24 vastus RFT 100K1
Potentiometri 100k log. @66.5.1 22 vastus 100KLOG
Potentiometri 100k log. @66.5.1 20 vastus 100K LOG
Potentiometri 100k log. @66.5.2 22 vastus RFT 100K2
Potentiometri 220k lin. @66.5.3 30 vastus 220KA TN
Potentiometri 470k lin. @66.6.1 7 vastus Ratiohm 470kA
Potentiometri 470k lin. @66.6.1 7 vastus RFT 470K1
Potentiometri 470k lin. @66.6.2 9 vastus 470K LIN B0
Potentiometri 470k lin. @66.6.2 10 vastus 470K317M
Potentiometri 470k log. @66.6.3 23 vastus 470K LOG
Potentiometri 1M lin. @66.7.1 5 vastus 1M0 LIN B0
Potentiometri 1M lin. @66.7.1 67 vastus B1M
Potentiometri 2M2 lin. @66.7.2 4 vastus 2M2 A
Potentiometri 2M2 lin. @66.7.2 30 vastus Radiohm 2M2A
Potentiometri 2M2 log. @66.7.3 25 vastus A 2.2M
Potentiometri 2M2 log. @66.7.3 5 vastus 2.2M A
Potentiometri 4M7 lin. @66.8.1 30 vastus 4M7 LIN
Potentiometri 10M lin. @66.8.2 21 vastus 10M1
Potikoita @28.2.1 X vastus
Potikoita @28.3.2 X vastus
Potikoita @28.4.1 X vastus
Potikoita @28.4.2 X vastus
Potentiometri 22kSpec liuku @35.8.1 18 vastus
Potentiometri 44kLin liuku @35.8.2 18 vastus
Potentiometri 100kSpec liuku @35.8.3 21 vastus
Potentiometri BI PS100 B1M 8k liuku @36.3.1 2 vastus BI PS100 B1M 8k Liukupotentiometri
Potentiometri PGF3210/D liuku @36.3.1 17 vastus 10k Liukupotentiometri
Potentiometri PGF8110/D liuku @36.3.2 8 vastus 8.3k Liukupotentiometri kytkimellä
Potentiometri M441 SLQ 10k liuku @36.3.2 1 vastus 10k Liukupotentiometri
Vastus: Trimmerit
47R Trimmeri @67.1.1 2 vastus
50R Trimmeri @67.1.1 5 vastus
100R Trimmeri @67.1.1 X vastus
100R Trimmeri @67.1.2 X vastus
200R Trimmeri @67.1.3 X vastus
220R Trimmeri @67.1.4 X vastus
250R Trimmeri @67.1.5 X vastus
470R Trimmeri @67.2.1 X vastus
500R Trimmeri @67.2.2 X vastus
1k0 Trimmeri @67.2.3 X vastus
1k0 Trimmeri @67.2.4 X vastus
1k0 Trimmeri @67.2.5 X vastus
2k0 Trimmeri @67.3.1 X vastus
2k2 Trimmeri @67.3.2 X vastus
2k2 Trimmeri @67.3.3 X vastus
2k2 Trimmeri @67.3.4 X vastus
2k2 Trimmeri @67.3.5 X vastus
2k2 Trimmeri @67.4.1 X vastus
2k5 Trimmeri @67.4.2 X vastus
4k7 Trimmeri @67.4.3 X vastus
4k7 Trimmeri @67.4.4 X vastus
4k7 Trimmeri @67.4.5 X vastus
4k7 Trimmeri @67.5.1 X vastus
4k7 Trimmeri @67.5.2 X vastus
4k7 Trimmeri @67.5.3 X vastus
5k Trimmeri @67.5.4 X vastus
10k Trimmeri @67.5.5 X vastus
10k Trimmeri @67.6.1 X vastus
10k Trimmeri @67.6.2 X vastus
10k Trimmeri @67.6.3 X vastus
10k Trimmeri @67.6.4 X vastus 25 turns 10k trimmer Bourns 3296Z 001 103 Bourns-3296.pdf
20k Trimmeri @67.6.5 X vastus
22k Trimmeri @67.7.1 X vastus
22k Trimmeri @67.7.2 X vastus
25k Trimmeri @67.7.3 X vastus
47k Trimmeri @67.7.4 X vastus
47k Trimmeri @67.7.5 X vastus
47k Trimmeri @67.8.1 X vastus
50k Trimmeri @67.8.2 X vastus
50k Trimmeri @67.8.3 X vastus
100k Trimmeri @67.8.4 X vastus
100k Trimmeri @67.8.5 X vastus
100k Trimmeri @67.9.1 X vastus
200k Trimmeri @67.9.2 X vastus
220k Trimmeri @67.9.3 X vastus
220k Trimmeri @67.9.4 X vastus
250k Trimmeri @67.9.5 X vastus
470k Trimmeri @67.10.1 X vastus
500k Trimmeri @67.10.2 X vastus
1M Trimmeri @67.10.3 X vastus
1M Trimmeri @67.10.4 X vastus
1M Trimmeri @67.10.5 X vastus
2M Trimmeri @67.11.1 3 vastus
2M2 Trimmeri @67.11.1 2 vastus
4M7 Trimmeri @67.11.2 X vastus
4M7 Trimmeri @67.11.3 X vastus
4M7 Trimmeri @67.11.4 X vastus
4M7 Trimmeri @67.11.5 X vastus
5M Trimmeri @67.12.1 X vastus
4R7 Tehotrimmeri @67.12.3 X vastus Tehotrimmeri
4R7 Tehotrimmeri @67.12.4 X vastus Tehotrimmeri
10R Tehotrimmeri @67.12.4 X vastus Tehotrimmeri
22R Tehotrimmeri @67.12.4 X vastus Tehotrimmeri
30R Tehotrimmeri @67.12.5 X vastus Tehotrimmeri
100R Tehotrimmeri @67.12.5 X vastus Tehotrimmeri
120R Tehotrimmeri @67.12.5 X vastus Tehotrimmeri
1k Tehotrimmeri @67.12.5 X vastus Tehotrimmeri
2k5 Tehotrimmeri @67.12.5 X vastus Tehotrimmeri
Trimmerin nuppeja @67.12.5 18 vastus Vääninnuppi Trimmer knobs
Vastus: Verkot
Vastusverkko 4 x 33R @68.7.1 300 vastus 8-Pin SIP 8-2-330 8x-2-330
Vastusverkko 4 x 100R @68.7.1 200 vastus 8-Pin SIP 8-2-101 8x-2-101
Vastusverkko 3 x 150R @68.7.1 11 vastus 6-Pin SIP Bourns 4306R-101-151
Vastusverkko 4 x 150R @68.7.2 70 vastus 8-Pin SIP 8-2-151 D151G
Vastusverkko 4 x 270R @68.7.2 40 vastus 8-Pin SIP 8-2-271
Vastusverkko 4 x 330R @68.7.2 100 vastus 8-Pin SIP O8-2-331 KL8A331J D331G
Vastusverkko 4 x 470R @68.7.2 200 vastus 8-Pin SIP KL8A471J D471G
Vastusverkko 4 x 820R @68.7.2 40 vastus 8-Pin SIP 08-2-821
Vastusverkko 4 x 1k0 @68.7.3 80 vastus 8-Pin SIP RMA4-102J D102G
Vastusverkko 4 x 1k5 @68.7.3 100 vastus 8-Pin SIP 8-2-152 D152G
Vastusverkko 4 x 2k2 @68.7.3 200 vastus 8-Pin SIP 8R-2-222 4306R-102-222
Vastusverkko 3 x 3k3 @68.7.3 29 vastus 6-Pin SIP Bourns 4306R-102-332
Vastusverkko 4 x 3k3 @68.7.4 200 vastus 8-Pin SIP D332M 8x-2-332
Vastusverkko 4 x 3k3 @68.7.4 300 vastus 8-Pin SIP DALE 3-332G
Vastusverkko 4 x 4k7 @68.7.4 170 vastus 8-Pin SIP 8x-2-472 08-2-472 4S4.7k J
Vastusverkko 4 x 6k8 @68.8.1 200 vastus 8-Pin SIP 8x-2-682 D682G
Vastusverkko 4 x 10k @68.8.1 200 vastus 8-Pin SIP 8x-2-103 8-2-103
Vastusverkko 6 x 10k @68.8.2 50 vastus /-Pin SIP 7A103G ROYAL
Vastusverkko 4 x 22k @68.8.2 200 vastus 8-Pin SIP 8R-2-223 D223M
Vastusverkko 4 x 33k @68.8.2 200 vastus 8-Pin SIP 8x-2-333 D333M
Vastusverkko 4 x 47k @68.8.2 80 vastus 8-Pin SIP 8x-2-47 8-2-473
Vastusverkko 4 x 220k @68.8.3 150 vastus 8-Pin SIP 8x-2-224
Vastusverkko 4 x 470k @68.8.3 100 vastus 8-Pin SIP SY474G 8-2-474
Vastusverkko 4 x 680k @68.8.3 50 vastus 8-Pin SIP D684M
Vastusverkko 5 x 680R @68.8.4 30 vastus 10-Pin SIP 10x-2-681
Vastusverkko 5 x 2k2 @68.8.4 500+ vastus 6-Pin SIP 6x-1-222LF
Vastusverkko 5 x 3k3 @68.9.1 400 vastus 6-Pin SIP L61S332
Vastusverkko 5 x 22k @68.9.1 500 vastus 6-Pin SIP L61C223
Vastusverkko 3 x 47k @68.9.2 300 vastus 6-Pin SIP L63S473
Vastusverkko 5 x 47k @68.9.2 300 vastus 6-Pin SIP L61S473
Vastusverkko 7 x 150R @68.9.3 21 vastus 8-Pin SIP 8R-1-151 S8410
Vastusverkko 7 x 220R @68.9.3 200 vastus 8-Pin SIP KL8S221J SCC875R220
Vastusverkko 7 x 330R @68.9.3 200 vastus 8-Pin SIP 8-1-331 8x-1-331 KL8S331J
Vastusverkko 7 x 680R @68.9.3 200 vastus 8-Pin SIP 8R-1-681 ITT-VR7-680 A681G
Vastusverkko 7 x 1k5 @68.9.4 30 vastus 8-Pin SIP 4308R-101-152
Vastusverkko 7 x 2k2 @68.9.4 200 vastus 8-Pin SIP KL8S222J
Vastusverkko 7 x 10k @68.9.4 50 vastus 8-Pin SIP KL8S103J
Vastusverkko 7 x 33k @68.9.4 200 vastus 8-Pin SIP 8R-1-333 A333M
Vastusverkko 7 x 100k @68.8.3 50 vastus 8-Pin SIP KL8S104JW
Vastusverkko 8 x 150R @68.10.1 200 vastus 9-Pin SIP 9x-1-151
Vastusverkko 8 x 220R @68.10.1 70 vastus 9-Pin SIP KL9S221J A221J
Vastusverkko 8 x 330R @68.10.1 100 vastus 9-Pin SIP 9x-1-331 KL9S331J
Vastusverkko 8 x 470R @68.10.1 100 vastus 9-Pin SIP KL9S471J A471J
Vastusverkko 8 x 680R @68.10.1 60 vastus 9-Pin SIP 9x-1-681 ITT-VR8-680
Vastusverkko 8 x 1k0 @68.10.2 100 vastus 9-Pin SIP 9x-1-102
Vastusverkko 8 x 3k3 @68.10.2 200 vastus 9-Pin SIP 9x-1-332
Vastusverkko 8 x 4k7 @68.10.2 100 vastus 9-Pin SIP STC-VRB-8-4k7 L09-1-R4k7
Vastusverkko 8 x 5k6 @68.10.3 200 vastus 9-Pin SIP 9x-1-562
Vastusverkko 8 x 6k8 @68.10.3 200 vastus 9-Pin SIP 6k8 J
Vastusverkko 8 x 10k @68.10.3 30 vastus 9-Pin SIP 9x-1-103 KL9S103J L09-1-R10k
Vastusverkko 8 x 220k @68.10.3 20 vastus 9-Pin SIP 9x-1-224
Vastusverkko 9 x 150R @68.11.1 100 vastus 10-Pin SIP 10x-1-151 10-1-151
Vastusverkko 9 x 220R @68.11.1 80 vastus 10-Pin SIP 10x-1-221 A221G
Vastusverkko 9 x 470R @68.11.1 80 vastus 10-Pin SIP RKL10S471J A471G
Vastusverkko 9 x 1k0 @68.11.1 50 vastus 10-Pin SIP RKL10S102J 10-1-102
Vastusverkko 9 x 1k2 @68.11.1 28 vastus 10-Pin SIP RKL10S102J 10-1-102
Vastusverkko 9 x 2k7 @68.11.2 45 vastus 10-Pin SIP 10x-1-272
Vastusverkko 9 x 3k3 @68.11.2 200 vastus 10-Pin SIP 10x-1-332 L10-1-R3.3k
Vastusverkko 9 x 4k7 @68.11.2 50 vastus 10-Pin SIP 10x-1-472 10-1-472 A472G 9x472JCM06
Vastusverkko 9 x 5k6 @68.11.2 150 vastus 10-Pin SIP 10R-1-562 10x-1-562
Vastusverkko 9 x 10k @68.11.3 90 vastus 10-Pin SIP RKL10S103J 10-1-103 256CK103x2PD A103G 9x103JCM02
Vastusverkko 9 x 33k @68.11.3 22 vastus 10-Pin SIP 10x-1-333
Vastusverkko 9 x 100k @68.11.3 2 vastus 10-Pin SIP 10x-1-104
Vastusverkko 11 x 6k8 @68.9.2 81 vastus 12-Pin SIP 6.8k J
Vastusverkko 13 x 6k8 @68.9.2 68 vastus 14-Pin SIP 6.8k J
Vastusverkko 5 x 100k @68.11.3 9 vastus 10-Pin SIP 10x-2-104
Vastusverkko 5 x 680k @68.11.3 11 vastus 10-Pin SIP 10x-2-684
Vastusverkko 9 x 330k @68.11.3 40 vastus 10-Pin SIP 10x-1-334
Vastusverkko 8 x 470R @68.11.4 100 vastus 16-Pin DIP 898-3-R470 16-1-471 916C471X2SR
Vastusverkko 8 x 680R @68.11.4 154 vastus 16-Pin DIP 16-1-681
Vastusverkko 8 x 820R @68.11.4 49 vastus 16-Pin DIP 16-1-821
Vastusverkko 8 x 2k2 @68.12.1 39 vastus 16-Pin DIP 16-1-222
Vastusverkko 8 x 2k2 @68.12.1 3 vastus 16-Pin DIP 898-3-R2.2k
Vastusverkko 8 x 3k3 @68.12.1 50 vastus 16-Pin DIP 16-1-332 916C332X2SR
Vastusverkko 8 x 4k7 @68.12.1 17 vastus 16-Pin DIP 916C472X2SR 4116R-001-472 RA08-4.7KN
Vastusverkko 15 x 4k7 13 x 4k7 @68.12.1 35+2 vastus 16-Pin DIP 916C472X2PE
Vastusverkko 8 x 10k @68.12.1 9 vastus 16-Pin DIP 4116R-001-103 16-1-103
Vastusverkko 13 x 10k @68.12.2 100 vastus 14-Pin DIP 899-1-R10k
Vastusverkko 15 x 10k @68.12.2 150 vastus 16-Pin DIP 898-1-R10k 4116R-2-103
Vastusverkko 15 x 10k @68.12.2 50 vastus 16-Pin DIP 916C103X2SR
Vastusverkko 15 x 22k @68.12.3 41 vastus 16-Pin DIP 916C223X2PE
Vastusverkko 8 x 22k @68.12.3 42 vastus 16-Pin DIP 32x 916C223X2SR 10x 716-3-R22k
Vastusverkko 13 x 22k @68.12.3 94 vastus 14-Pin DIP 899-1-R22k
Vastusverkko 8 x 33k @68.12.3 78 vastus 16-Pin DIP DALE MDP1603-333G 16-Pin DIP 8 x 333 Ohm +-2% resistor Datasheet
Vastusverkko 8 x 100k @68.12.4 19 vastus 16-Pin DIP 16-1-104
Vastusverkko 8 x 100k @68.12.4 18 vastus 16-Pin DIP 898-3-R100k
Vastusverkko 8 x 220k @68.12.4 26 vastus 16-Pin DIP 16-1-224 316B224
Vastusverkko 1 x 1M @68.12.4 15 vastus 2-Pin SIP HVF7 1M 10% CGS
Vastusverkko 13 x 220R @68.12.4 2 vastus 16-Pin DIP
Vastusverkko 8 x 220R @68.12.4 4 vastus 16-Pin DIP
Vastusverkko 8 x 330R @68.12.4 4 vastus 16-Pin DIP
Vastusverkko 8 x 470R @68.12.4 6 vastus 16-Pin DIP
Vastusverkko 13 x 470R @68.12.4 5 vastus 16-Pin DIP
Vastusverkko 8 x 1k @68.12.4 9 vastus 16-Pin DIP
Vastusverkko 13 x 1k @68.12.4 2 vastus 16-Pin DIP
Vastusverkkoja sekalaiset @68.10.4 X vastus
Vastus: Massavastukset
10R 0.5W 5% @68.1.1 14 vastus
12R 0.25W 5% @68.6.2 12 vastus
18R 0.25W 5% @68.6.3 4 vastus
39R 0.25W 5% @68.6.2 10 vastus
47R 0.25W 5% @68.6.1 44 vastus
68R 0.5W 5% 10% @68.6.1 2+6 vastus
100R 0.5W 10% @68.1.1 13 vastus
270R 0.5W 5% @68.1.2 6 vastus
470R 0.5W 5% @68.1.3 300 vastus
680R 0.25W 5% @68.6.1 25 vastus
820R 0.25W 10% @68.6.3 8 vastus
1k8 0.25W 5% @68.1.2 80 vastus
1k8 0.5W 5% @68.1.4 200 vastus
2k2 0.25W 5% @68.6.4 3 vastus
18k 0.25W 5% @68.1.2 24 vastus
22k 0.25W 5% @68.6.4 1 vastus
33k 0.25W 5% @68.6.4 80 vastus
47k 0.25W 5% @68.1.4 100 vastus
150k 0.5W @68.2.1 2 vastus
680k 0.5W 5% @68.2.1 34 vastus
1M0 0.25W 0.5W 5% @68.2.1 75+22 vastus
2M2 0.25W 5% @68.5.1 X vastus
1.5M 1.6M 2.4M 2.7M @68.5.3 4 vastus
8M2 0.5W 10% @68.5.2 300 vastus
12M 0.25W 5% @68.5.3 10 vastus
15M 0.25W 5% @68.5.3 1 vastus
18M 0.25W 5% @68.5.3 4 vastus
22M 0.25W 5% @68.5.3 3 vastus
27M 0.25W 5% @68.5.3 7 vastus
33M 0.25W 5% @68.5.3 7 vastus
39M 0.25W 5% @68.5.3 5 vastus
47M 0.25W 5% @68.5.3 4 vastus
51M 0.25W 5% @68.5.3 1 vastus
56M 0.25W 5% @68.5.3 4 vastus
68M 0.25W 5% @68.5.3 5 vastus
82M 0.25W 5% @68.5.3 5 vastus
100M 0.25W 5% @68.5.3 4 vastus
2R2 2W @68.2.2 10 vastus
3R3 2W @68.2.2 4 vastus
5R6 2W 10% @68.2.3 10 vastus
6R8 2W 10% @68.2.3 10 vastus
8R2 2W 10% @68.2.4 11 vastus
12R 2W 5% @68.2.4 9 vastus
33R 2W 5% @68.3.1 9 vastus
75R 2W 10% @68.3.1 16 vastus
120R 2W 5% @68.3.1 10 vastus
220R 2W 5% @68.3.2 8 vastus
330R 3W 10% @68.3.3 36 vastus
470R 2W 5% @68.3.4 10 vastus
680R 2W 5% @68.3.4 1 vastus
1k0 2W 10% @68.4.1 16 vastus
1k5 2W 5% @68.4.1 10 vastus
2k0 2W 5% @68.4.2 16 vastus
2k0 3W 5% @68.4.2 12 vastus
10k 2W 5% @68.4.3 29 vastus
10k 3W 5% @68.4.3 8 vastus
12k 3W 10% @68.4.3 2 vastus
18k 3W 10% @68.4.3 2 vastus
51k 2W 5% @68.4.4 6 vastus
51k 3W 5% @68.4.4 10 vastus
820k 3W 10% @68.3.2 45 vastus
2M2 3W 10% @68.4.4 10 vastus
Sekalaisia @68.5.4 45 vastus
Vastus: Tehovastukset
0.01R @69.1.1 2 vastus DALE LVR-3 0.01Ohm 1% 3W
0.015R @69.1.1 1 vastus DALE LVR-3 0.015Ohm 1% 3W
0.02R 1% @69.1.1 1 vastus DALE RH-50 .02 Ohm 1% K8537
0.1R shuntti @69.1.1 2 vastus
0.10R 10% 3W @69.1.2 90 vastus 0.10R 10% 3W
0.10R 10% 4W @69.1.2 9 vastus Vitrohm 206, 4W R10 10%
0.10R 5% 25W @69.1.2 1 vastus CSG HSA25 R10 5% 77/47
0.22R 5% 4W @69.1.3 2 vastus Dale CW-2B-13
0.22R 3W @69.1.3 10 vastus 0.22 Ohm -3W
0.22R 4W 10% @69.1.3 50 vastus Vitrohm 206 4W R22 10%
0.22R 25W 5% @69.1.3 2 vastus CSG HSA25 R22 5% 77/46
0.22R 4W 10% @34.8.1 100 vastus Vitrohm 206. 4W R22 10%
0.27R 2W 10% @69.1.4 42 vastus Vitrohm 202 2W R27 10%
0.30R 25W 1% @69.1.4 1 vastus Vitrohm 202 2W R27 10%
0.33R 3W 10% @69.2.1 120 vastus VTM 204 3W R33 10%
0.33R 3W 10% @69.2.2 95 vastus Vitrohm 204 R33 10% 3W
0.33R 3W 10% @34.8.2 200 vastus VTM 204 3W R33 10%
0.33R 4W 10% @69.2.2 14 vastus RGBE4 0.33R K NOBLE 19, DOC 810A R33 10% 4W
0.33R 4W 10% @69.2.3 19 vastus 206-0 4W R33 10%
0.33R 4W 10% @69.2.4 57 vastus 206-8 R33 10% I
0.39R ?W @69.3.1 3 vastus
0.47R 3W @69.3.2 26 vastus
0.47R 5% 5W @69.3.2 27 vastus 206-3 R47 5% D
0.47R 4W @69.3.3 31 vastus 206-8 R47 10% L
0.47R 5W @69.3.3 17 vastus 208-815 R47 10%
0.47R 5W @69.3.4 1 vastus AX 5W 0R47 5%
0.47R 5W @69.3.4 34 vastus 208-8 R47 10%
0.47R 25W 5% @69.3.4 1 vastus CSG HSA25 R47 5% 78/04
0.50R 5W 1% @69.4.1 16 vastus DALE RH-5 5W .5 Ohm 1% RE60GR500
0.56R 10W 10% @69.4.1 1 vastus Vitrohm216 11W R56 10%
0.68R 4W 10% @34.9.1 100 vastus Vitrohm 206-0 4W R68 10%
0.68R 4W 10% @69.4.2 60 vastus Vitrohm 206-0 4W R68 10%
0.68R 5W @69.4.3 41 vastus 0.68E 37
1.0R 1W 10% @69.4.4 22 vastus VTM.200 1W 1R0 10%
1.0R 3W 5% @69.4.4 9 vastus 1R0 5% 3W
1.0R 5W 5% @69.5.1 30 vastus AX 5W 1R 5%
1.0R 10% 5W @69.5.2 20 vastus 5W 10% 208-815 1R0 10% C
1.0R 5% 5W @69.5.2 5 vastus LV5 1R0J C4X
1.0R 5% 10W @69.5.2 2 vastus 1R-J 10W-K-8
1.0R 5% @69.5.2 3 vastus
1.0R 25W 5% @69.5.2 2 vastus CSG HSA25 1R0 5% 77/47, WH25 1R0 5%
1.0R 20W 5% @69.5.2 2 vastus ROYAL922 W 20W 1 Ohm J
1.0R 12W 5% @69.5.3 33 vastus DALE HLA-12-02Z 1Ohm 5% 12WY8448 Säädettävä
1.5R 5% @69.5.4 1 vastus RYK 17/0224 1R5 J B2
1.5R 5% 7W @69.5.4 1 vastus RCD 1.5R 5% 7W
1.8R 10% 5W @69.5.4 10 vastus 1R8-5W-KM-8
2.2R 5W @69.6.1 72 vastus 208-8 2R2 10%
2.2R 5W @69.6.2 32 vastus R208-8 2R2 10%
2.2R 7W 5% @69.6.2 9 vastus 2R2 5% 7W
2.2R 5% 10W @69.6.2 1 vastus
2.2R 1% 10W @69.6.3 26 vastus DALE RH-10 10W 2.2R 1%
2.2R 5% 25W @69.6.3 2 vastus CGS HSA25 2R2 5% 78/04
2.2R 5% 100W @95.9.2 2 vastus CGS HSC100 2R2 J 0342
3.0R 5% 5W @69.6.4 10 vastus
3.3R 7W 5% @69.6.4 10 vastus 3R3 5% 7W
3.3R 7W 5% @69.6.4 6 vastus SECI RSMM7 CU 3R3 J 8639
3.9R @69.7.1 10 vastus 254-0 3R9 5%
3.9R 5W @69.7.1 34 vastus 5W 3.9Ohm J, AX 5W 3R9 5%, 5W 3.9Ohm JW
4.0R 50W @95.9.2 3 vastus CGS HSA50 4R0 5%
4.7R 25W 5% @95.9.2 4 vastus CGS HSA25 4R7 5%
4.7R 5W @69.7.2 40 vastus 4R7-K 5W-K-8
4.7R 5% 5W @69.7.3 56 vastus 5W 4.7Ohm J, 5W 4.7Ohm JW
5.0R 10W 5% @69.7.4 15 vastus 10W5OhmJ
5.0R 30W 1% @69.7.4 1 vastus DALE RH-50 30W 5R 1%
5.6R 5W 5% @69.7.4 4 vastus 5R6-5W-KM-8
5.6R 7W 5% @69.7.4 2 vastus
6.8R 5% 5W @69.6.3 10 vastus 5W 6.8Ohm J
6.8R 7W 5% @69.7.4 2 vastus
6.8R 5% 5W @69.8.1 63 vastus 5W 6.8Ohm J, 208-8 6R8 10%, 6.8Ohm 5% 5W
8.2R 5% 5W @69.8.2 9 vastus AX 5W 8R2 5%
8.2R 7W 5% @69.8.2 20 vastus
8.2R 5W @69.8.3 60 vastus 208-8 8R2 10%
8.2R 5W @69.8.4 39 vastus AX 5W 8R2 5%, 5W 8R2 J
10R 5W @69.9.1 59 vastus AX 5W 10R 5%, 208-8 K 10R 10%
10R 5W @69.9.2 39 vastus AX 5W 10R 5%
10R 9W @69.9.3 27 vastus 214-8 10R 10%
10R 20W @69.9.4 4 vastus ROYAL 442 W 20W 10Ohm J
10R 25W @69.9.4 1 vastus CGS HSA25 10R J
10R 50W @69.9.4 1 vastus CGS HSA50 10R 5%
15R 5% 10% 5W @69.10.1 13 vastus 15R-5W-KM-8, 15R-J 5W-KM-8, Vitrohm 208-0 15R 5%, 5 15Ohm 10% Z
18R 5% 5W @69.10.2 11 vastus 18R-J 5W-KM-8, Vitrohm 208 5W 18R 5%
18R 5% 5W @69.10.2 28 vastus 5 18R 10% E
18R ?W @69.10.3 X vastus
22R 7W 5% @69.10.4 15 vastus
22R 10W @69.10.4 2 vastus
22R 5% 10W @69.11.1 17 vastus ARCOL HS10 22R J
22R 50W @69.11.1 2 vastus
27R 2W 5% @69.11.2 30 vastus
27R 5W @69.11.3 50 vastus 27R-J 5W-KM-8, 208-0 5W 27R 5%
27R ?W @69.11.4 44 vastus
27R 4W @69.12.1 1 vastus 206-815 27R 5% M
27R 5W @69.12.1 4 vastus 27R-J 5W-KM-8
27R ?W @69.12.1 21 vastus
30R 3% 10W @69.12.2 3 vastus DALERH-10 10W 30Ohm 3#
33R 4W 5% @69.12.3 140 vastus DALE CW2B-13 33Ohm 5%
33R ?W @69.12.4 84 vastus
33R 5% 5W @73.1.1 29 vastus 33R-J 5W-KM-8, 125-0/5 33R 5% Vitrohm 208 5W 33R 5%
33R 25W 5% @73.1.1 3 vastus CGS HSA25 33R 5%
39R 11W @73.1.2 13 vastus 11W 33Ohj J
47R 4W 5% @73.1.3 14 vastus DALE CW2B-13 47Ohm 5%
47R 50W 5% @73.1.3 4 vastus CGS HSA50 47R 5%
47R 20W @73.1.3 5 vastus ROYAL 20W 47Ohm J
47R 30W @73.1.3 50 vastus TO-220 47.0R 1% 30W @25C Power Film Resistors into a heatsink Datasheet
56R 5% 5W @73.1.4 1 vastus 206-815 56R 5%
68R 5% 10W @73.1.4 21 vastus 10W68OhmJ
68R 5% 10W @73.1.4 7 vastus WH5 68R 5%
68R 25W 5% @73.1.4 5 vastus CGS HSA25 68R 5%
82R 4W 5% @73.2.1 2 vastus 206-815 82R 5% t
82R 5W 5% @73.2.1 50 vastus 82R 5% 5.5W
100R ?W 5% @73.2.1 1 vastus 100R 5%
100R ?5W @34.9.2 17 vastus VITROHM GL 100 Ohm
100R 4W 5% @73.2.1 8 vastus Vitrohm 4W 206-0 100R 5%
100R 5W 5% @73.2.1 5 vastus 100R-J 5W-KM-8
100R 50W @73.2.1 1 vastus WH50 100R 5%
100R 12W 5% @73.2.2 53 vastus DALE HL-12-02Z 100Ohm 5% 12W
120R 4W 5% @73.2.3 15 vastus 206-815 120R 5% n
120R 4W 5% @73.2.3 24 vastus DALE CW2B-13 120Ohm 5%
120R 5W 5% @73.2.3 9 vastus 120E A 4D 5.5W
120R 10W 5% @73.2.3 2 vastus 120E5% 10W
150R 1W 5% @73.2.4 72 vastus
150R 5W 5% @73.3.1 8 vastus 150R-5W-KM-8
150R 10W 5% @73.3.1 8 vastus WH5 150R 5%
150R 25W 3% @73.3.1 1 vastus 25W 150R +-3%
220R 2W 5% @73.3.2 86 vastus 220R 5%
220R 4W 5% @73.3.3 34 vastus DALE CW2B-13
220R 5% 5W @73.3.3 20 vastus 220Ohm B&J KNA 615 5%
220R 5% 5W @73.3.4 11 vastus 220R-J 5W-KM-8
220R 5% 4W @73.3.4 3 vastus 206 4W 220R 5%
220R 5% 10W @73.3.4 1 vastus 220E 5% 10W
270R 5% ?W @73.4.1 160 vastus 220RJ 5%
330R 25W @73.4.1 6 vastus CGS HSA25 330R 5%
330R 5W @73.4.2 42 vastus 208-0 330R 5% 330R-J 5W-KM-8
390R 5W 5% @73.4.3 29 vastus 390E 5% 5.5W44
390R 10W @73.4.3 2 vastus 390E 5% 10W
470R 10W @73.4.3 1 vastus AX5W 470R 5%
560R 5W @73.4.4 40 vastus 208-8 560R 5%
680R 5W 5% @73.5.1 10 vastus ROYAL6D3 P 5W 680Ohm J
680R 5W 5% @73.5.1 19 vastus 680R B 5.5W 5% 04D,25D
820R 2W 5% @73.5.2 49 vastus
820R 4W 5% @73.5.2 36 vastus DALE CW2B-13
820R 4W 5% @73.5.3 13 vastus Vitrohm 206 4W 820R 5%
820R 5W 5% @73.5.3 54 vastus 820R-J 5W-KM-8
1.0k 1W 5% @73.5.4 97 vastus
1.0k 2W 5% @73.5.4 100 vastus
1.0k 5W 1% @73.6.1 50 vastus WH5 1K0 1%
1.0k 4W 5% @73.6.2 18 vastus DALE CW2B-13
1.0k 5W 5% @73.6.2 9 vastus Vitrohm 208-0 X 1K0 5W 5%
1.0k 5W 5% @73.6.2 14 vastus 5W1KOhmJ, 1K-5W-KM-8
1.0k ?W @73.6.3 16 vastus
1.0k 25W @73.6.3 4 vastus
1k2 1W 5% @73.6.4 178 vastus
1k2 2W 5% @73.7.1 98 vastus
1k2 4W 5% @73.7.1 6 vastus DALE CW2B-13
1K5 4W 5% @73.7.2 6 vastus Vitrohm 206 4W 1K5 5%
1k5 ?W @73.7.2 1 vastus Säädettävä
1k8 ?W @73.7.2 10 vastus 02038 CZ 1800 Ohm
1.8k 10W 5% @73.7.3 25 vastus 8K2-J 10W-K-8
2.2k 5W 5% @73.7.3 9 vastus ROYAL6N1 P 5W 2K2 J
2.7k 1W 5% @73.7.4 31 vastus
2.7k ?W 5% @73.7.4 5 vastus
3.0k ?W @73.8.1 2 vastus Säädettävä
3.3k 5W @73.8.1 1 vastus 3.3k 5.5W 5%
4k7 5W @73.8.1 35 vastus 4k7 5.5W 5%
5k6 2W 5% @73.8.2 159 vastus
5k6 4W 5% @73.8.3 36 vastus DALE CW2B-13 5.6k 5%
5k6 5% 10W @73.8.3 2 vastus
5k6 4W 5% @73.8.4 10 vastus 206-0 4W 5k6 5%
5k6 20W? @73.8.4 7 vastus
6k8 5W 5% @73.9.1 15 vastus 6k8-J 5W-KM-8
6k8 4W 5% @73.9.1 3 vastus 206 4W 6k8 5%
6k8 5% 10W @73.9.1 2 vastus
7k2 5W? 0.5% @73.9.2 25 vastus
7k5 9W @73.9.2 9 vastus
8k2 5% 10W @73.9.3 2 vastus
10k 5% 20W @73.9.3 1 vastus MPR-20.pdf
15k 5% 5W @73.9.3 30 vastus
22k 5W 10% @73.9.4 20 vastus
27k 10W 5% @73.10.1 1 vastus 27K 5% 10W
33k 10W 5% @73.10.2 2 vastus 33K 5% 10W
47k5 0.5W 1% @73.10.3 100 vastus DALE 47.5k 1% T9 8119
270k 0.5W 0.5% @73.10.4 8 vastus
9M ?W @73.10.4 21 vastus DALE HMF 1/4 9M 1%
Sekalaisia @73.11.1 7 vastus
   2 x 10R 1W 5%
   2 x 22R 1W 5%
   2 x 47R 1W 2%
   1 x 75R 1W 5%
Sekalaisia @73.11.1 18 vastus
   1 x 47R 2W 5%
   3 x 100R 2W 2%
   1 x 270R 2W 5%
   1 x 560R 2W 5%
   1 x 680R 2W 5%
   1 x 1.5k 2W 5%
   2 x 2.7k 2W 5%
   2 x 4.7k 2W 5%
   2 x 5.6k 2W 5%
   1 x 8.2k 2W 5%
   1 x 15k 2W 5%
   1 x 150k 2W 5%
   1 x 220k 2W 5%
Sekalaiset 5W @73.11.2 53 vastus
   2 x 4.7R 5W
   2 x 22R 5W
   1 x 33R 5W
   4 x 39R 5W 10%
   1 x 56R 5W 10%
   1 x 68R 5W 10%
   3 x 82R 5W
   2 x 120R 5W
   3 x 150R 5W
   1 x 270R 5W
   6 x 680R 5W
   1 x 1.0k 5W 5%
   2 x 1.2k 5W
   1 x 1.5k 5W
   2 x 1.8k 5W
   2 x 2.7k 5W
   1 x 3.0k 5W
   4 x 3.3k 5W
   2 x 3.9k 5W 5%
   2 x 4.7k 5W
   4 x 5.6k 5W
   3 x 6.8k 5W
   2 x 8.2k 5W
   1 x 15k 5W
Sekalaiset @73.11.3 X vastus
Sekalaiset @73.11.4 X vastus
2.0M @95.8.2 26 vastus Dale RN70D 2004F
820R 5% 15W @96.1.1 40 vastus 220 15W 820R 5%
3k9 5% 15W @96.1.2 30 vastus 220 15W 3k9 5%
1k5 5% 30W @96.2.1 20 vastus 224 30W 1k5 5%
1k5 5% 23W @96.2.2 18 vastus 224 30W 1k5 5%
1k8 5% 30W @96.3.1 19 vastus 224 30W 1k8 5%
1k8 5% 30W @96.3.2 7 vastus 224 30W 1k8 5%
470R 5% 30W @96.3.2 2 vastus 224 30W 470R 5%
470R 5% 30W @96.3.2 2 vastus 224-5 30W 470R 5%
2k2 5% 15W @96.4.1 2 vastus 220 15W 2k2 5%
2k2 5% 15W @96.4.1 6 vastus 220-5 15W 2k2 5%
2k2 5% 30W @96.4.1 13 vastus 224 30W 2k2 5%
3k9 5% 23W @96.4.2 27 vastus 224 23W 3k9 5%
470R 5% 15W @96.5.1 41 vastus 220_5 15W 470R 5%
390R 10% 10W @96.5.2 34 vastus 390R-10W-K-8
1k8 10% 10W @96.5.2 18 vastus 1k8-10W-K-8
820R 5% 17W @96.6.1 8 vastus 218 17W 820R 5%
6k8 5% 5W @96.6.1 4 vastus 6k8-J 5W-KM-8
8k2 5% 10W @96.6.1 6 vastus 8k2-J 10W-K-8
6k8 5% 10W @96.6.1 6 vastus 8k2-J 10W-K-8
820R 10% 10W @96.6.2 32 vastus 820R-10W-K-8
1k8 5% 10W @96.7.1 64 vastus 1k8-J 10W-K-8
560R 5% 30W @96.7.2 14 vastus 224 30W 560R 5%
4k7 5% 23W @96.8.1 26 vastus 222-5 23W 4k7 5%
4k7 5% 30W @96.8.1 1 vastus 224-5 30W 4k7 5%
150R 5% 30W @96.8.2 20 vastus 224 30W 150R 5%
47R 5% 30W @96.9.1 20 vastus 224-5 30W 47R 5%
47k 5% 23W @96.9.2 22 vastus 222-5 23W 47k 5%
33R 5% 23W @96.10.1 7 vastus 222-5 23W 47k 5%
220R 5% 15W @96.10.2 40 vastus 220 15W 220R 5%
220R 5% 15W @96.11.1 33 vastus 220--5 15W 220R 5%
2k7 5% 15W @96.11.2 6 vastus 220 15W 2k7 5%
3k3 5% 23W @96.11.2 11 vastus 222-5 23W 3k3 5%
100R 5% 15W @96.12.1 4 vastus 220-5 15W 100R 5%
100R 5% 30W @96.12.1 1 vastus 224 30W 100R 5%
220R 5% 15W @96.12.1 3 vastus 220 15W 220R 5%
330R 5% 15W @96.12.1 1 vastus 220 15W 330R 5%
330R 10% 23W @96.12.1 3 vastus 222 23W 330R 10%
1k0 5% 30W @96.12.2 2 vastus 224 30W 1k0 5%
12k 5% 15W @96.12.2 4 vastus 220-5 15W 12k 5%
12k 5% 30W @96.12.2 2 vastus 224-5 30W 12k 5%
Tarvikkeet ja työkalut
0.8mm ja 1.0mm poranteriä @13.8.2 X tarvikkeet käsiporan teriä
0.6-1.5mm PCB Drill Bit Set, Carbide @13.8.2 2 tarvikkeet 8-2-330 8x-2-330 Piirilevykaiverruksen porat
0.9 mm PCB Drill Bit, Carbide @13.8.2 10 10.2.2023 tarvikkeet Piirilevykaiverruksen porat
3.175mm Shank PCB outer Bit End Mill 2mm, Carbide @13.8.3 4 tarvikkeet 8-2-330 8x-2-330 Piirilevykaiverruksen terät
3.175mm Shank V Carving Bit 60deg, tip 0.1mm, Carbide @13.8.3 4 tarvikkeet 8-2-330 8x-2-330 Piirilevykaiverruksen terät
Kondensaattorin tyhjennystyökalu @13.8.1 1 tarvikkeet
5.5 mm liitintulkit @13.8.1 2 tarvikkeet 2.5mm -> 2.1mm (sin.) ja 2.1mm -> 2.5mm (kelt.)
Lämpölevyä @12.12.1 X tarvikkeet Thermal Pads
Lämpöteippiä @12.12.1 X tarvikkeet Thermal tape
Lämpöliimaa @12.12.1 X tarvikkeet Thermal glue
Lämpötahnaa @12.12.1 X tarvikkeet Thermal paste
Silikonilevyä @12.12.1 X tarvikkeet Silicone sheets
Kolvin osia @36.1.1 X tarvikkeet
Imukolvin osia @13.8.1 X tarvikkeet Suodattimia, lasiputki, tiivisteitä
Tyhjät
Tyhjä @01.4.2 X Tyhjä 3/8
Tyhjä @03.4.3 X Tyhjä 3/8
Tyhjä @11.7.3 X Tyhjä 3/8
Tyhjä @11.8.2 X Tyhjä 3/8
Tyhjä @11.8.3 X Tyhjä 3/8
Tyhjä @12.10.1 X Tyhjä 4/12
Tyhjä @12.10.2 X Tyhjä 4/12
Tyhjä @12.10.3 X Tyhjä 4/12
Tyhjä @12.10.4 X Tyhjä 4/12
Tyhjä @12.11.1 X Tyhjä 2/12
Tyhjä @12.11.2 X Tyhjä 2/12
Tyhjä @18.9.4 X Tyhjä 4/12
Tyhjä @18.12.3 X Tyhjä 4/12
Tyhjä @18.12.4 X Tyhjä 4/12
Tyhjä @22.4.2 X Tyhjä 2/12
Tyhjä @22.5.1 X Tyhjä 2/12
Tyhjä @22.5.2 X Tyhjä 2/12
Tyhjä @22.6.1 X Tyhjä 2/12
Tyhjä @22.6.2 X Tyhjä 2/12
Tyhjä @22.7.1 X Tyhjä 2/12
Tyhjä @22.7.2 X Tyhjä 2/12
Tyhjä @22.8.1 X Tyhjä 2/12
Tyhjä @22.8.2 X Tyhjä 2/12
Tyhjä @22.9.1 X Tyhjä 2/12
Tyhjä @22.9.2 X Tyhjä 2/12
Tyhjä @22.10.1 X Tyhjä 2/12
Tyhjä @22.10.2 X Tyhjä 2/12
Tyhjä @22.11.1 X Tyhjä 2/12
Tyhjä @22.11.2 X Tyhjä 2/12
Tyhjä @22.12.1 X Tyhjä 2/12
Tyhjä @22.12.2 X Tyhjä 2/12
Tyhjä @25.4.3 X Tyhjä 4/12
Tyhjä @25.4.4 X Tyhjä 4/12
Tyhjä @25.5.1 X Tyhjä 4/12
Tyhjä @25.5.2 X Tyhjä 4/12
Tyhjä @25.5.3 X Tyhjä 4/12
Tyhjä @25.5.4 X Tyhjä 4/12
Tyhjä @25.6.1 X Tyhjä 4/12
Tyhjä @25.6.2 X Tyhjä 4/12
Tyhjä @25.6.3 X Tyhjä 4/12
Tyhjä @25.6.4 X Tyhjä 4/12
Tyhjä @25.7.1 X Tyhjä 4/12
Tyhjä @25.7.2 X Tyhjä 4/12
Tyhjä @25.7.3 X Tyhjä 4/12
Tyhjä @25.7.4 X Tyhjä 4/12
Tyhjä @25.8.1 X Tyhjä 2/12
Tyhjä @25.8.2 X Tyhjä 2/12
Tyhjä @25.12.3 X Tyhjä 4/12
Tyhjä @27.10.4 X Tyhjä 5/12
Tyhjä @27.11.1 X Tyhjä 5/12
Tyhjä @27.12.5 X Tyhjä 5/12
Tyhjä @29.5.1 X Tyhjä 5/12
Tyhjä @31.9.2 X Tyhjä 4/12
Tyhjä @31.9.3 X Tyhjä 4/12
Tyhjä @31.12.4 X Tyhjä 4/12
Tyhjä @33.8.4 X Tyhjä 4/12
Tyhjä @34.1.1 X Tyhjä 4/12
Tyhjä @34.1.2 X Tyhjä 4/12
Tyhjä @34.1.3 X Tyhjä 4/12
Tyhjä @34.1.4 X Tyhjä 4/12
Tyhjä @34.2.1 X Tyhjä 4/12
Tyhjä @34.2.2 X Tyhjä 4/12
Tyhjä @34.2.3 X Tyhjä 4/12
Tyhjä @34.2.4 X Tyhjä 4/12
Tyhjä @34.3.1 X Tyhjä 4/12
Tyhjä @34.3.2 X Tyhjä 4/12
Tyhjä @34.3.3 X Tyhjä 4/12
Tyhjä @34.3.4 X Tyhjä 4/12
Tyhjä @34.4.2 X Tyhjä 4/12
Tyhjä @34.10.1 X Tyhjä 4/12
Tyhjä @34.10.2 X Tyhjä 4/12
Tyhjä @34.10.3 X Tyhjä 4/12
Tyhjä @34.10.4 X Tyhjä 4/12
Tyhjä @34.11.1 X Tyhjä 4/12
Tyhjä @34.11.2 X Tyhjä 4/12
Tyhjä @34.11.3 X Tyhjä 4/12
Tyhjä @34.11.4 X Tyhjä 4/12
Tyhjä @34.12.1 X Tyhjä 4/12
Tyhjä @34.12.2 X Tyhjä 4/12
Tyhjä @34.12.3 X Tyhjä 4/12
Tyhjä @34.12.4 X Tyhjä 4/12
Tyhjä @35.7.1 X Tyhjä 2/6
Tyhjä @35.7.2 X Tyhjä 2/6
Tyhjä @37.8.2 X Tyhjä 3/8
Tyhjä @37.8.3 X Tyhjä 3/8
Tyhjä @41.5.1 X Tyhjä 2/6
Tyhjä @57.11.4 X Tyhjä 4/12
Tyhjä @58.8.4 X Tyhjä 4/12
Tyhjä @58.9.2 X Tyhjä 4/12
Tyhjä @58.9.3 X Tyhjä 4/12
Tyhjä @58.9.4 X Tyhjä 4/12
Tyhjä @62.11.2 X Tyhjä 2/12
Tyhjä @62.12.1 X Tyhjä 2/12
Tyhjä @62.12.2 X Tyhjä 2/12
Tyhjä @63.1.1 X Tyhjä 5/12
Tyhjä @63.1.2 X Tyhjä 5/12
Tyhjä @63.1.3 X Tyhjä 5/12
Tyhjä @63.1.4 X Tyhjä 5/12
Tyhjä @63.1.5 X Tyhjä 5/12
Tyhjä @63.2.1 X Tyhjä 5/12
Tyhjä @63.2.2 X Tyhjä 5/12
Tyhjä @63.2.3 X Tyhjä 5/12
Tyhjä @63.2.4 X Tyhjä 5/12
Tyhjä @63.2.5 X Tyhjä 5/12
Tyhjä @63.3.1 X Tyhjä 5/12
Tyhjä @63.3.2 X Tyhjä 5/12
Tyhjä @63.3.3 X Tyhjä 5/12
Tyhjä @63.3.4 X Tyhjä 5/12
Tyhjä @63.3.5 X Tyhjä 5/12
Tyhjä @63.4.1 X Tyhjä 5/12
Tyhjä @63.4.2 X Tyhjä 5/12
Tyhjä @63.4.3 X Tyhjä 5/12
Tyhjä @63.4.4 X Tyhjä 5/12
Tyhjä @63.4.5 X Tyhjä 5/12
Tyhjä @63.5.1 X Tyhjä 5/12
Tyhjä @63.5.2 X Tyhjä 5/12
Tyhjä @63.5.3 X Tyhjä 5/12
Tyhjä @63.5.4 X Tyhjä 5/12
Tyhjä @63.5.5 X Tyhjä 5/12
Tyhjä @63.6.1 X Tyhjä 5/12
Tyhjä @63.6.2 X Tyhjä 5/12
Tyhjä @63.6.3 X Tyhjä 5/12
Tyhjä @63.6.4 X Tyhjä 5/12
Tyhjä @63.6.5 X Tyhjä 5/12
Tyhjä @63.7.1 X Tyhjä 5/12
Tyhjä @63.7.2 X Tyhjä 5/12
Tyhjä @63.7.3 X Tyhjä 5/12
Tyhjä @63.7.4 X Tyhjä 5/12
Tyhjä @63.7.5 X Tyhjä 5/12
Tyhjä @63.8.1 X Tyhjä 5/12
Tyhjä @63.8.2 X Tyhjä 5/12
Tyhjä @63.8.3 X Tyhjä 5/12
Tyhjä @63.8.4 X Tyhjä 5/12
Tyhjä @63.8.5 X Tyhjä 5/12
Tyhjä @63.9.1 X Tyhjä 5/12
Tyhjä @63.9.2 X Tyhjä 5/12
Tyhjä @63.9.3 X Tyhjä 5/12
Tyhjä @63.9.4 X Tyhjä 5/12
Tyhjä @63.9.5 X Tyhjä 5/12
Tyhjä @63.10.1 X Tyhjä 5/12
Tyhjä @63.10.2 X Tyhjä 5/12
Tyhjä @63.10.3 X Tyhjä 5/12
Tyhjä @63.10.4 X Tyhjä 5/12
Tyhjä @63.10.5 X Tyhjä 5/12
Tyhjä @63.11.1 X Tyhjä 5/12
Tyhjä @63.11.2 X Tyhjä 5/12
Tyhjä @63.11.3 X Tyhjä 5/12
Tyhjä @63.11.4 X Tyhjä 5/12
Tyhjä @63.11.5 X Tyhjä 5/12
Tyhjä @63.12.1 X Tyhjä 5/12
Tyhjä @63.12.2 X Tyhjä 5/12
Tyhjä @63.12.3 X Tyhjä 5/12
Tyhjä @63.12.4 X Tyhjä 5/12
Tyhjä @63.12.5 X Tyhjä 5/12
Tyhjä @64.7.2 X Tyhjä 3/8
Tyhjä @80.12.1 X Tyhjä 4/12
Tyhjä @80.12.2 X Tyhjä 4/12
Tyhjä @80.12.3 X Tyhjä 4/12
Tyhjä @80.12.4 X Tyhjä 4/12
Tyhjä @89.12.1 X Tyhjä 5/12
Tyhjä @89.12.2 X Tyhjä 5/12
Tyhjä @89.12.3 X Tyhjä 5/12
Tyhjä @89.12.4 X Tyhjä 5/12
Tyhjä @89.12.5 X Tyhjä 5/12
Tyhjä @91.9.1 X Tyhjä 5/12
Tyhjä @91.9.2 X Tyhjä 5/12
Tyhjä @91.9.3 X Tyhjä 5/12
Tyhjä @91.9.4 X Tyhjä 5/12
Tyhjä @91.12.5 X Tyhjä 5/12
Paikantamattomat ja työnalla
Väärä paikka: S25FL128SAIFR0 @27.12.4 6 muisti SMD SO16 16M x 8 3.0V SPI FLASH Memory Datasheet
Väärä paikka: BS62LV1027PCP70 @27.9.4 X muisti PDIP-32 Very Low Power CMOS SRAM 128K X 8 bit Datasheet
Väärä paikka: 9326M @27.3.3 1 mikropiiri
Väärä paikka: AM27256 @53.3.2 X muisti 28-Pin DIP One-time programmable ROM Datasheet
Piirilevy busbar @17.8.2 X liittimet
Laatikossa: Jakosuodinsarja Smartstore 14 34
Laatikossa: Vilkku?sarja Smartstore 14 98
Laatikossa: Vahvistinsarja TDA7056B Smartstore 14 7
TODO LIST:
END OF TODO LIST
