S0005 Pasta-annostelija
From Helsinki Hacklabin wiki
Jump to navigation Jump to search
Tieto Teksti
Hacklab ID S0005
Nimitys Pasta-annostelija
Laiteteksti 983A
Tunnusnumero N/A
Hankinta-aika 2022
Erityistietoja
Kommentti
Omistaja Hacklab
Yhteyshenkilö Tilavastaava
Tieto Teksti
Brand Name YDL (YI.DE.LONG) ????
Power Input 220V
Power Consumption N/A
Internal Voltage 12V DC / 24V DC
Input Air Pressure 10-100 psi
Output Air Pressure 1-80 psi
Dispensing Time 0.01s - 99.99s
Dispensing Time Interval 0.1s - 9.9s
Station Dimensions 235(w) x 63(h) x 225(d) mm
Weight 2.2 kg
1. Power Switch: putdown light on shows "On", light off shows "Off"
2. Dispensing time display: Display setting time
3. Input air pressure pressure governor: First pull out, Reversal is lower pressure, veering is the higher pressure
4. Barometer: display range: 0-100 psi
5. Vacuum control unit: Reversal is Vacuum pumpback high, veering is the Vacuum pumpback low
6. Testing button: During testing, it can replace the foot switch
7. Dispensing time dial code button: Display setting time, adopts add and subtract way 00.01s-99.99s
8. time interval setting dial code button: Display setting time, adopts add and subtract way 0.1s-9.9s
9. Dispensing output interface: Connect to dispensing needle cylinder.
10. Air pressure input interface: Connect to clean high pressure source
11. Dispensing modes: 16 modes
12. The foot controller interface: Connect to foot switch
13. Power input socket
14. Fuse holder
The SET TIME control selects the duration of a single dispensing shot.
The INTERVAL control selects the time delay between shots.
Backside dip-switch mode settings:
  • F1: Hold switch to dispense continuously (not in shots). Release switch to stop.
  • F2: Tap switch to begin dispensing shots. Tap switch again to stop.
  • F3: Hold switch to dispense shots continuously. Release switch to stop.
  • F4: Dispense shots continuously whenever powered on.
  • F5: Tap switch to dispense 1 shot.
  • F6-16: Tap switch to dispense 2-12 shots.
