Kohteesta Helsinki Hacklabin wiki
Start of operation checklist
- Check log entries for when the water level was last checked, if it was not already done today, check level and add water if needed. Take care not to let any contaminants in when checking or adding. If water can be seen, it's ok. Mark in log accordingly.
- Make sure the bed is empty and the honeycomb is not installed (when the machine resets it will raise the bed, if the honeycomb is on this will lead it to crash into the cutting-head).
- Use keys to turn on power
- Turn on blower (switch)
Adjusting the bed
- Never set the measuring piece between the cutting-head and the bed while rising the bed.
- Once you have added your material on the bed, raise the bed so, that it is a bit too close to the cutting-head.
- Place the measuring piece on the material next to the cutting-head and lean it carefully against the cutting-head
- Lower the bed slowly until the measuring piece slides under the cutting-head.
- Make sure lid is closed
- Risk of fire
- Settings may need tuning
End of operation checklist
- Raise bed to top
- Turn off blower (switch)
- Turn off machine (keys)
