Optinen kaiverrin
Helsinki Hacklabin wiki
Loikkaa: valikkoon, hakuun
Sisällysluettelo
History
Status: Donated to Hacklab Jyväskylä in 03/2018
General Information
  • multicast address: laserweb.local
  • IPv4: 192.168.110.176 (not guaranteed to be the same)
  • LaserWeb is listening on port 8000
  • LaserWeb: try connecting with /dev/tty/ACM0 + 115200
Control panel buttons
Control panel
BEAM
  • must be enabled before engraving or cutting
  • dry run the process using 0 position
Manual test, safety switch
  • test the beam manually (for material tests etc.)
0-10 dial
  • set maximum reference power of the beam
Steps to engrave/cut an SVG:
Preparig the Machine
  1. Make sure the power is turned on both in the extension cords and in the machine itself
  2. Install the workpiece and close the lid
  3. Turn the laser on (green button, check that the red led turns on)
  4. Turn on the lights (flip the small metallic switch)
  5. Check that the laser power is set at an appropriate level
Engraving the SVG
  1. Browse to http://192.168.110.165:8000 or http://laserweb.local:8000
  2. Click the Open button and select an SVG image or drag-and-drop it
  3. Configure the feedrate, number of passes and depth of each pass
  4. Click the Generate G-Code button
  5. Click the Process button to load the G-Code
  6. Click the run gcode (Play) button to run the G-Code
  7. After the machine is idle, click the home laser button to return the laser home
Engraving pre made gcode
Upload gcode as it was any other source file (such as svg, graphics, etc.). Open gcode file in CAM, then "generate gcode" - it just replicates the code as it is!
The machine operates with these codes:
  • S0.0 Turn beam off (use 0% of beam power)
  • S1.0 Turn beam on (100%)
Installing the Workpiece
  • If possible, use the clamps. The laser focus seems to be good at the depth of the clamp.
  • The maximum height of an object that fits the clamp is roughly 80mm.
  • If engraving larger pieces, make sure that they stay still and don't move. Some duct tape or a few drops of superglue should hold them still.
6mm acrylic
Feedrate Laser Current Passes Cut depth observations
20mm 5mA 10 Barely a scratch, might work for engravings
20mm 10mA 5 About the same as 5mW x 10
20mm 15mA 5 Roughly half a millimeter
20mm 20mA 5 Roughly half a millimeter
20mm 20mA 30 Around 2-3mm, acrylic started to melt
40mm 20mA 30 Around 2-3mm, clean cut
4mm acrylic
Stamp rubber
Using full power burns the material black (might not happen during the first pass), which prevents beam engraving the material. Don't use maximum power, reduce if any charring appears. Make multiple passes. Use about 40% power in the dial, see if any charring happens. You can probably lift the power a bit, if the work path does not contain large continuous areas to be removed. Observe.
Debugging
Further reading and training
Laserweb support community: https://plus.google.com/communities/115879488566665599508
