Lotan automaattiajo
Kohteesta Helsinki Hacklabin wiki
Loikkaa: valikkoon, hakuun
Lotta automatic operation
In automatic mode, Lotta executes a G code program either from the internal program memory (the only option at the time of writing) or directly from line to line as a serial transfer. The following instructions assume that you are running from memory. The general principle is that the selected program is started from where the cursor is when the [CYCLE START] command is issued. So make sure the cursor is at the beginning when you start! Also remember that the program interprets the block (line) one by one in advance and the line is executed in the optimization order decided by the machine. If there are conflicting G-code words on the line then the last one on the line remains valid.
Automaattiajon valmistelu
Preparing to run automatically
Before a program can be run on the machine, it must be prepared accordingly. At least the following things should be fine:
  1. The tools required in the program have been loaded into the magazine and their offsets have been programmed in the tool offset table
  2. The position of the workpiece on the table is programmed in the desired work coordinate system and is referenced in the program.
Ohjelman kirjoitus käsin
G-koodi voidaan syöttää sisään suoraan paneelilta ja lyhyillä ohjelmilla se on täysin realistinen vaihtoehto.
Handwriting a program
The G code can be entered directly from the panel and with short programs it is a completely realistic option.
  4. Näytön alaoikealla pitäisi nyt vilkkua 'LSK' eli ”line skip” sen merkiksi että sarjalinja on auki lukua varten. Kun lähde alkaa lähettämään, näyttö muttuu tilaan 'INPUT' joka lopulta poistuu jos kaikki meni OK.
  5. Paina [RESET] tai vasemmanpuoleisinta pehmonäppäintä (jossa ei ole otsikkoa) jolloin luettu ohjelma tulee näyttöön.
Reading a program from a serial line to memory
Slightly longer programs should be read in from the series line to avoid unbridled and time-consuming tapping. To start a serial number:
  3. Press the [C.A.P.] soft key and then [READ], then [INPUT]
  4. The bottom right of the display should now flash 'LSK' or 'line skip' to indicate that the serial line is open for reading. When the source starts transmitting, the display changes to 'INPUT' which eventually disappears if everything went OK.
  5. Press [RESET] or the leftmost soft key (without title) to display the read program.
Ohjelman aloituskoodi
Lotan muisti on paristovarmennettu, joten aiemmat modaaliset G-koodit ovat edelleen voimassa edellisen ohjelman jäljiltä. Useimmat eivät muutu, mutta siltä varalta, että ovat kuitenkin muuttuneet, on suositeltavaa aloittaa ohjelmat asettamalla muutamat perusjutut tunnetuun alkutilaan. Suositeltava aloitussekvenssi on:
G90 G80 G40 G17 G21
MUISTA ASETTAA TYÖKOORDINAATISTO VOIMAAN ennen kuin ohjelmoit liikkeitä sen perusteella. Eli jokin koodeista G54 ... G59 sen mukaan mitä olet päättänyt käyttää.
Recommended programming practices
Program start code
Lota's memory is battery-backed, so previous modal G-codes are still valid after the previous program. Most don’t change, but just in case they have changed, it’s a good idea to start the programs by putting a few basic things in a known initial state. The recommended start sequence is:
G90 G80 G40 G17 G21
BE SURE TO ACTIVATE THE WORK COORDINATE BEFORE programming movements based on it. That is, one of the codes 'G54 ... G59' depending on what you have decided to use.
G28 G91 Z0.
G90
Tool change
The tool can only be changed when the spindle is in the home position, because then the magazine is in line with the holder on the spindle. The drive to the home position takes place with command G28, which takes as an argument the waypoint through which the drive takes place. When the waypoint is usually irrelevant, the following sequence can be used:
G28 G91 Z0.
G90
In this case, the spindle is driven home while switching to relative coordinates and setting the Z-direction as the midpoint of 0.0 (i.e., where it already is). Mentioning the Z-axis in a sentence starts a home drive. Immediately after that, the absolute coordinates are restored. NOTE: If there is a particularly high workpiece on the table so that there is a risk of the workpiece colliding with tools while the magazine is rotating, it may also be necessary to drive the X and Y axes home.
Ohjelman syöttäminen sarjalinjaan
Osoitteessa 192.168.110.161 on verkkosivu, jonne G-koodin voi ladata. Kun lotan konsolissa vilkkuu 'LSK', kopioi koodi teksikenttään ja paina SEND nappulaa. Ohjelman koosta riippuen sen lähettämiseen voi mennä hetki.
Koneen käyttäjätunnus lotta ja salasana lotta.
Entering a program on a serial bus
There is a web page at 192.168.110.161 where you can download the G code. When 'LSK' flashes on Lota's console, copy the code into the text field and press the SEND button. Depending on the size of the program, it may take a while to broadcast.
Machine username lotta and password lotta.
Lotta Ohjeet:
Edellinen
Ylös
Seuraava
